path: root/sound/soc/pxa/raumfeld.c
2011-05-24ASoC: fix raumfeld platformDaniel Mack
Commit f0fba2ad (ASoC: multi-component - ASoC Multi-Component Support) broke support for Raumfeld platforms as it didn't take into account the different hardware features on individual devices. In particular, Raumfeld speakers have no S/PDIF output, so the members of the snd_soc_card struct must be set dynamically. Signed-off-by: Daniel Mack <zonque@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-02-02ASoC: PXA: formattingSven Neumann
Signed-off-by: Sven Neumann <s.neumann@raumfeld.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-27ASoC: Use card rather than soc-audio device to card PM functionsMark Brown
The platform device for the card is tied closely to the soc-audio implementation which we're currently trying to remove in favour of allowing cards to have their own devices. Begin removing it by replacing it with the card in the suspend and resume callbacks we give to cards, also taking the opportunity to remove the legacy suspend types which are currently hard coded anyway. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-01-15ASoC: support more sample rates on raumfeld devicesDaniel Mack
Add support for sample rates other than 44100Khz on raumfeld audio devices. At startup time, call snd_soc_dai_set_sysclk() with 0 as 'freq' argument so it offers all the sample rates. Later, the function is called again to give proper constraints. Use the external audio clock generator to provide double data rate clocks as the PXA's internal baud generator does anything but what's described in the datasheets. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-30ASoC: pxa/raumfeld: adopt new snd_soc_dai_set_pll() APIDaniel Mack
ALSA's for-2.6.33 branch has a new source argument to snd_soc_dai_set_pll(). Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-27ALSA: ARM: add Raumfeld audio supportDaniel Mack
