A recent conversion has introduced references to &pdev->dev, which does
not actually exist in all the contexts it's used in.
Replace this with card->dev where necessary, in order to let
the driver build again.
Cc: stable@kernel.org
Remove unused variable 'dai' to eliminate below warning.
CC sound/soc/pxa/pxa2xx-pcm.o
sound/soc/pxa/pxa2xx-pcm.c: In function 'pxa2xx_soc_pcm_new':
sound/soc/pxa/pxa2xx-pcm.c:91: warning: unused variable 'dai'
Acked-by: Liam Girdwood <lrg@ti.com>
Don't rely on the codec's channels_min information to decide wheter or
not allocate a substream's DMA buffer. Rather check if the substream
itself was allocated previously.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI.
Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains
card, pcm and DAI along with other members too that are useful too.
Signed-off-by: Liam Girdwood <lrg@ti.com>
Commit f0fba2ad (ASoC: multi-component - ASoC Multi-Component Support)
broke support for Raumfeld platforms as it didn't take into account the
different hardware features on individual devices.
In particular, Raumfeld speakers have no S/PDIF output, so the members
of the snd_soc_card struct must be set dynamically.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
AK4641 connected via I2S and I2C, jack detection via GPIO.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
This patch firstly restructurizes the code a bit by getting rid of continuous
checking for machine type in spitz_mic_bias().
Then the patch properly requests the MIC GPIO in the spitz_init() and frees it
in spitz_exit().
pxa2xx_pcm_hw_free frees dma channel and sets prtd->dma_ch to -1,
but does not set prtd->params to NULL, so if pxa2xx_pcm_hw_params will
be called immediately, it leaves prtd->dma_ch initialized with -1,
and it results in oops in __pxa2xx_pcm_prepare. This bug is triggered
via SDL.
This patch adds check for prtd->dma_ch to __pxa2xx_pcm_prepare and
cleans prtd->params, so now it works properly.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Fix the initialization of .codec_dai_name in zylonite_dai initializer,
do not mix it with the initialization of .codec_name which is set
already a few lines above.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Got typoed in the multi-component changes.
MONO was renamed to MONO1.
Correct names for pxa AC97 DAI are pxa2xx-ac97 and pxa2xx-ac97-aux. Fix
that for all PXA platforms.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Sven Neumann <s.neumann@raumfeld.com>
In order to support cards instantiated without using soc-audio remove
the use of the platform device in the card probe() and remove() ops.
The platform device for the card is tied closely to the soc-audio
implementation which we're currently trying to remove in favour of
allowing cards to have their own devices. Begin removing it by
replacing it with the card in the suspend and resume callbacks we
give to cards, also taking the opportunity to remove the legacy
suspend types which are currently hard coded anyway.
ASoC DAI link descriptions for Corgi, Poodle and Spitz platforms
contained incorrect names for cpu_dai and codec, which effectievly disabled sound
on theese platforms. Fix that errors.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into for-2.6.38
WM8750 address is 0x1b, not 0x1a. Without this fix ALSA detects no sound
cards on Zipit
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Fix jack detection on Zipit Z2, otherwise it
disables headphones output when jack is connected
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits)
ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection
ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO
ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO
ALSA: oxygen: fix Xonar DG input
ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low
ALSA: hda - Fix missing EAPD for Acer 4930G
ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs.
ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser
ALSA: hda - Don't refer ELD when unplugged
ASoC: tpa6130a2: Fix compiler warning
ASoC: tlv320dac33: Add DAPM selection for LOM invert
ASoC: DMIC codec: Adding a generic DMIC codec
ALSA: snd-usb-us122l: Fix missing NULL checks
ALSA: snd-usb-us122l: Fix MIDI output
ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync()
ASoC: Fix section mismatch in wm8995.c
ALSA: oxygen: add S/PDIF source selection for Claro cards
ALSA: oxygen: fix CD/MIDI for X-Meridian (2G)
ASoC: fix migor audio build
ALSA: include delay.h for msleep in Xonar DG support
* 'spi' of git://git.linutronix.de/users/bigeasy/soda into spi/next
spi/pxa2xx: register driver properly
spi/pxa2xx: add support for shared IRQ handler
spi/pxa2xx: Use define for SSSR_TFL_MASK instead of plain numbers
arm/pxa2xx: reorgazine SSP and SPI header files
spi/pxa2xx: Add CE4100 support
spi/pxa2xx: Consider CE4100's FIFO depth
spi/pxa2xx: Add chipselect support for Sodaville
spi/pxa2xx: Modify RX-Tresh instead of busy-loop for the remaining RX bytes.
spi/pxa2xx: pass of_node to spi device and set a parent device
The PXA-SPI driver relies on some files / defines which are arm specific
and are within the ARM tree. The CE4100 SoC which is x86 has also the
SPI core.
This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to
include/linux where the CE4100 can access them.
This move got verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Fix following warning observed when SND_PXA2XX_SOC is set and SND_ARM isn't:
warning: (SND_PXA2XX_AC97 && SOUND && !M68K && SND && SND_ARM && ARCH_PXA ||
SND_PXA2XX_SOC && SOUND && !M68K && SND && SND_SOC && ARCH_PXA) selects
SND_PXA2XX_LIB which has unmet direct dependencies (SOUND && !M68K && SND &&
SND_ARM)
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
When doing anything with the system, especially DAPM, we need to hold the
CODEC mutex.
The "priv" allocated in pxa_ssp_probe() should be kfreed in pxa_ssp_remove().
Signed-off-by: Ian Lartey <ian@opensource.wolfsonmicro.com>
Fix reference to moved header file, which was unused anyway.
This change fixes below build error:
CC sound/soc/pxa/pxa2xx-ac97.o
sound/soc/pxa/pxa2xx-ac97.c:27:24: error: pxa2xx-pcm.h: No such file or directory
make[3]: *** [sound/soc/pxa/pxa2xx-ac97.o] Error 1
make[2]: *** [sound/soc/pxa] Error 2
make[1]: *** [sound/soc] Error 2
make: *** [sound] Error 2
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
In e740_init(), we call gpio_request() for
GPIO_E740_MIC_ON, GPIO_E740_AMP_ON and GPIO_E740_WM9705_nAVDD2.
We should free the these gpio accordingly in e740_exit().
88PM860x codec is used in Marvell saarb development board. 88PM860x codec
is used as master mode for SSP communication. Only I2S format is supported.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Instead of unconditionally enabling the crystal oscillator on the WM8731
only enable it when explicitly selected via set_sysclk(), allowing machine
drivers to specify that they drive a clock into MCLK alone. This avoids
any conflicts between the oscillator and the external MCLK source and saves
power for systems which do not need the oscillator.
This should also deliver a small power saving on systems using the crystal
since the oscillator will only be enabled when the ADC or DAC is active.
Dead pxa2xx-pcm.h includes and a missing ,
SCFR bit is required to be always set if pxa ssp is in slave mode. This bit
indicates clock input to SSPSCLK is only active during data transfers.
Since pxa2xx-pcm.h is removed from sound/soc/pxa, we need to update the
path in related files.
Tested-by: Ian Lartey <ian@opensource.wolfsonmicro.com>
anyway.
Removed #include of pxa2xx-pcm.h
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits)
ALSA: hda: Storage class should be before const qualifier
ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies
ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT
ASoC: sdp4430 - add sdp4430 pcm ops to DAI.
ASoC: TWL6040: Enable earphone path in codec
ASoC: SDP4430: Add support for Earphone speaker
ASoC: SDP4430: Add sdp4430 machine driver
ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF
ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function
ALSA: sound/pci/asihpi: Use kzalloc
ALSA: hdmi - dont fail on extra nodes
ALSA: intelhdmi - add id for the CougarPoint chipset
ALSA: intelhdmi - user friendly codec name
ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS
ALSA: asihpi: incorrect range check
ALSA: asihpi: testing the wrong variable
ALSA: es1688: add pedantic range checks
ARM: McBSP: Add support for omap4 in McBSP driver
ARM: McBSP: Fix request for irq in OMAP4
OMAP: McBSP: Add 32-bit mode support
sound/soc/codecs/ad1938.c
In order to prevent code ambiguous, add namespace on functions in ssp driver.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
