Finally, move the 's3c24xx' directory to 'samsung'
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Move prefixes to repesent the nature of Samsung ASoC suitably.
SND_S3C24XX_SOC -> ASOC_SAMSUNG
SND_S3C_SOC_PCM -> SND_SAMSUNG_PCM
SND_S3C_SOC_AC97 -> SND_SAMSUNG_AC97
SND_S5P_SOC_SPDIF -> SND_SAMSUNG_SPDIF
SND_S3C24XX_SOC_I2S -> SND_S3C24XX_I2S
SND_S3C64XX_SOC_SMARTQ -> ASOC_SMARTQ
SND_SOC_SMDK_SPDIF -> ASOC_SAMSUNG_SMDK_SPDIF
SND_SOC_SMDK_WM8580 -> ASOC_SAMSUNG_SMDK_WM8580
SND_SOC_SMDK_WM9713 -> ASOC_SAMSUNG_SMDK_WM9713
SND_SOC_GONI_AQUILA_WM8994 -> ASOC_GONI_AQUILA_WM8994
Enable the ASoC Machine driver to run on SMDKC100 as well.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
We plan to use the same ASoC Machine driver for most of
latest SMDK platforms. So rename the 64XX specific driver
to generic named.
Now that we have better I2S CPU drivers and no need for the old
ones, discard them.
Modify the smdk64xx_wm8580.c to use new i2s controller driver.
Modify the goni_wm8994.c to use new i2s controller driver.
Modify the smartq_wm8987.c to use new i2s controller driver.
The I2S controllers since S3C64XX are incremental revisions, with
a new feature added to the last one. The programming i/f doesn't
conflict between these revisions, so it is possible to have one
common driver that could manage various versions of I2S (v3, 4 & 5)
AQUILA and GONI are essentially the same h/w w.r.t ASoC.
They only differ by the fact that GONI has stereo speaker-out
whereas AQUILA has mono.
The difference can easily be handled in the same MACHINE driver
by making machine-specific runtime changes.
When make mini2440_defconfig compilation end with undefined
references to DMA functions. There was missing selection
for S3C2410_DMA when compile ASoC audio for S3C24xx CPU.
Tested on mini2440 board.
Signed-off-by: Marek Belisko <marek.belisko@gmail.com>
This patch add S/PDIF machine driver to support S/PDIF PCM audio
on SMDKC100, SMDKC110 and SMDKV210 boards.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
This patch adds S/PDIF CPU driver for various Samsung SoCs.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
This patch add sound support for the Goni board based on S5PV210.
The Goni board is based on Samsung SoC(S5PV210) and include
WM8994 codec over I2S to support sound.
The kind of jack is below states :
* SND_JACK_HEADPHONE
* SND_JACK_HEADSET
* SND_JACK_MECHANICAL
: When TV-OUT cable is inserted on Goni board,
the TV-OUT cable isn't connected to television.
* SND_JACK_AVOUT
the TV-OUT cable is connected to television.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch add sound support for the Aquila board based on S5PC110.
The Aquila board is based on Samsung SoC(S5PC110) and include
WM8994 codec over I2S to support sound. This uses the I2Sv4 driver
compatible with I2Sv5 to run sound.
* SND_JACK_HEADSET
: When TV-OUT cable is inserted on Aquila board,
* SND_JACK_AVOUT
ASoC: multi-component: SAMSUNG: Fix wrong field name on Aquila board
This patch modify the wrong field name on Aquila board.
This adds sound support for the SmartQ board.
The hardware consists of a S3C6410 coupled with a WM8987 over I²S. The WM8750
driver is used for driving the WM8987, as they are register compatible.
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
The S5PV210 and S5PC110 has the AC97 controller same as S3C6410.
Simply enable the options to build the drivers for S5PC110 and
S5PV210 also.
The S5PC100 has the AC97 controller same as S3C6410.
S5PC100 also.
Switch the MACHINE driver to use IISv4 CPU dai.
Remove BROKEN dependency now that we have proper CPU driver available.
Also, disable build for SMDK6400, since the S3C6400 doesn't have IISv4
controller.
Add the CPU driver for the IISv4 block found on S3C6410.
For now, the driver is almost a copy of s3c64xx-i2s.c but
it should diverge as more IISv4 specific stuff is added.
Since, we have generic AC97 controller driver and all the machines
have moved to that, there is no need for old s3c2443-ac97.c to exist.
Switch to use s3c-ac97.c AC97 controller driver.
This patch adds the common machine driver for SMDKs that
have a WM9713 codec attched to the AC97 controller.
Add the AC97 controller driver for Samsung SoCs that have one.
New machine driver for WM8580 I2S i/f on SMDK64XX.
By default SoC-Slave is set and WM8580 is configured to use it's
PLLA to generate clocks from a 12MHz crystal attached to WM8580.
[Added dependency on BROKEN since the IISv4 interface hasn't been merged
yet, fixed the PLL API usage and removed the disabling of the PLL in the
hw_free function since that'll break simultaneous playback and record
-- broonie.]
Signed-off-by: Jassi <jassi.brar@samsung.com>
No point in building them for S3C64xx, certainly no sense in running
into build issues there.
Ensure that the core DMA support is available when building for
S3C64xx.
Add support for the tlv320aic3x CODEC on the Simtec Hermes board.
Signed-off-by: Ben Dooks <ben@simtec.co.uk>
Add core support for the range of S3C24XX Simtec boards with TLV320AIC23
CODECs on them. Since there are also boards with similar IIS routing the
AMP and the configuration code is placed in a core file for re-use with
other CODEC bindings.
Joonyoung Shim reports that S3C64xx I2S is working on the NCP boards so
allow it to be selected in Kconfig.
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmciro.com>
This driver supports the audio subsystem on the Openmoko Neo FreeRunner
smartphone, often known by its codename GTA02. The system has a WM8753
connected to a Samsung S3C2442 with an external GPIO controlled speaker
amplifier.
The driver was originally written by Graeme Gregory and has recieved
contributions from Openmoko, myself and members of the Openmoko
community. For much of this time the primary Openmoko kernel maintainer
was Andy Green.
Signed-off-by: Graeme Gregory <graeme@openmoko.com>
Signed-off-by: Andy Green <andy@openmoko.com>
Due to the process and communications issues with the 2.6.30 S3C
platform merges none of the underlying arch/arm code for S3C64xx audio
support made it into mainline, rendering the drivers useless. Disable
them in Kconfig to avoid user confusion - users patching in the required
support can always reenable this too.
Remove a non-existing Kconfig CONFIG_SND_SOC_WM8750_SPI.
We now support the 64xx series as well as the 24xx series - make sure
people using Kconfig know this.
Select the relevant DMA implementation when the
sound driver is selected.
Add the initial code to support the S3C64XX I2S hardware using the
s3c-i2s-v2 core code.
The S3C2412 I2S (IIS) interface is replicated on further Samsung SoC
parts in a broadly compatible way, so split the common code out into
a core called s3c-i2s-v2.[ch] so that the newer SoCs such as the
S3C6410 can make use of it.
As such, all the original s3c2412 functions are currently being left
with their original names, and will be renamed later in the series.
Add support for the Jive's WM8750 codec attached via the S3C2412 IIS.
It has no external dependencies but needs to be selected for L3 based
codecs to work.
Signed-off-by: Christian Pellegrin <chripell@fsfe.org>
Convert menu in sound Kconfig files to menuconfig and if.
S3C2412 SoC IIS support for ALSA/ASoC
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This patch adds ac97 support for ln2440sbc board from LittleChips.
This board is based on s3c2440 SoC + AC97 Realtek ALC650 codec.
Existing s3c2443 implementation is slightly modified because s3c2440
and s3c2443 have different AC97 interrupts.
Signed-off-by: Ivan Kuten <ivan.kuten@promwad.com>
SND_S3C24XX_SOC_NEO1973_WM8753 depends on MACH_GTA01 but the Kconfig
entry which is going to be merged is MACH_NEO1973_GTA01.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
This patch adds Kconfig and build support for the Neo1973, SMDK2443 and
S3C2443 AC97 ALSA audio drivers.
Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
The new ALSA 'SOC' support has bogus Kconfig ... it should
not be presenting anything AT91-related except on AT91,
or anything PXA-related except on PXA. Right now, x86
sees both of those menus, as do all other platforms.
This patch removes needless Kconfig layering, and the
related inappropriate choice presentation.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
