path: root/sound/soc/s3c24xx
2010-11-23ASoC: Samsung: Rename from s3c24xx to samsungJassi Brar
Finally, move the 's3c24xx' directory to 'samsung' Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Generalize Kconfig symbolsJassi Brar
Move prefixes to repesent the nature of Samsung ASoC suitably. SND_S3C24XX_SOC -> ASOC_SAMSUNG SND_S3C_SOC_PCM -> SND_SAMSUNG_PCM SND_S3C_SOC_AC97 -> SND_SAMSUNG_AC97 SND_S5P_SOC_SPDIF -> SND_SAMSUNG_SPDIF SND_S3C24XX_SOC_I2S -> SND_S3C24XX_I2S SND_S3C64XX_SOC_SMARTQ -> ASOC_SMARTQ SND_SOC_SMDK_SPDIF -> ASOC_SAMSUNG_SMDK_SPDIF SND_SOC_SMDK_WM8580 -> ASOC_SAMSUNG_SMDK_WM8580 SND_SOC_SMDK_WM9713 -> ASOC_SAMSUNG_SMDK_WM9713 SND_SOC_GONI_AQUILA_WM8994 -> ASOC_GONI_AQUILA_WM8994 Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: SMDK_WM8580: Enable for SMDKC100Jassi Brar
Enable the ASoC Machine driver to run on SMDKC100 as well. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: SMDK64XX: Rename for other platformsJassi Brar
We plan to use the same ASoC Machine driver for most of latest SMDK platforms. So rename the 64XX specific driver to generic named. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: S3C64XX: Remove obsoleted I2S driversJassi Brar
Now that we have better I2S CPU drivers and no need for the old ones, discard them. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: SMDK64XX: Move to use new I2S driverJassi Brar
Modify the smdk64xx_wm8580.c to use new i2s controller driver. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: GONI: Move to use new I2S driverJassi Brar
Modify the goni_wm8994.c to use new i2s controller driver. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: SMARTQ: Move to use new I2S driverJassi Brar
Modify the smartq_wm8987.c to use new i2s controller driver. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Add common I2S driverJassi Brar
The I2S controllers since S3C64XX are incremental revisions, with a new feature added to the last one. The programming i/f doesn't conflict between these revisions, so it is possible to have one common driver that could manage various versions of I2S (v3, 4 & 5) Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Rename s3c64xx I2S deviceJassi Brar
Since the I2S of S3C64XX and newer SoCs are incremental versions of each other with changes managable in a single driver, rename the 's3c64xx-iis' -> 'samsung-i2s' Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Generalize DMA driver namespaceJassi Brar
Remove S3C,s3c from static defines. s3c_dma_ -> dma_ s3c24xx_runtime_ -> runtime_ s3c24xx_audio_ -> audio_ s3c_preallocate_ -> preallocate_ s3c24xx_soc_platform -> samsung_asoc_platform s3c24xx_pcm_driver -> asoc_dma_driver snd_s3c24xx_pcm_ -> samsung_asoc_ Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Rename PCM driverJassi Brar
Rename Samsung PCM Controller driver s3c-pcm.[c/h] -> pcm.[c/h] Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Rename AC97 driverJassi Brar
Rename Samsung AC97 driver s3c-ac97.[c/h] -> ac97.[c/h] Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Rename AC97 platform deviceJassi Brar
Call the AC97 controller devices found in S3C, S5P and newer SoCs as 'samsung-ac97' rather than 's3c-ac97'. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Rename ASoC DMA driverJassi Brar
Rename Samsung ASoC DMA driver s3c-dma.[c/h] -> dma.[c/h] Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Rename DMA deviceJassi Brar
Some Samsung SoCs have a PCM(DSP) controller. So the name s3c24xx-pcm-audio for DMA driver is not very appropraite. This patch moves :- s3c24xx-pcm-audio -> samsung-audio Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-23ASoC: Samsung: Remove redundant AQUILA driverJassi Brar
AQUILA and GONI are essentially the same h/w w.r.t ASoC. They only differ by the fact that GONI has stereo speaker-out whereas AQUILA has mono. The difference can easily be handled in the same MACHINE driver by making machine-specific runtime changes. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-22Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-22ASoC: Fix compile breakage in jz4740.c and smartq_wm8987.cJarkko Nikula
Commit ce6120c require that soc-dapm.h cannot be included before soc.h but these two drivers were not checked. Fix them by including only soc.h as it includes soc-dapm.h. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-22ASoC: s3c24xx: test wrong variableVasiliy Kulikov
After clk_get() mclk is checked three times instead of mout_epll and sclk_spdif checks. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-15Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-15ASoC: RX1950: Fix hw_params functionVasily Khoruzhick
Unfortunatelly, I misunderstood datasheet, and on s3c244x-iis when MPLLin source for master clock is selected, prescaler has no effect. Remove dividor calculation for 44100 rate; remove 88200 rate at all, rx1950 can't do it. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-08Merge branch 'for-2.6.37' into HEADMark Brown
2010-11-08ASoC: s3c24xx: Fix compilation problem for mini2440Marek Belisko
When make mini2440_defconfig compilation end with undefined references to DMA functions. There was missing selection for S3C2410_DMA when compile ASoC audio for S3C24xx CPU. Tested on mini2440 board. Signed-off-by: Marek Belisko <marek.belisko@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-17sound: fixed typosAndrea Gelmini
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-15ASoC: SAMSUNG: Add Machine driver for S/PDIF PCM audioSeungwhan Youn
This patch add S/PDIF machine driver to support S/PDIF PCM audio on SMDKC100, SMDKC110 and SMDKV210 boards. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-15ASoC: SAMSUNG: Add S/PDIF CPU driverSeungwhan Youn
This patch adds S/PDIF CPU driver for various Samsung SoCs. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-24ASoC: Add debug logging for s3c-ac97 resetsMark Brown
Helps tracing errors further up the stack. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-24ASoC: Convert s3c-ac97 to pr_() macrosMark Brown
Could use dev_() but we'd have to remember the struct device somewhere and it wouldn't make the logging clearer. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-24ASoC: Clean up the CODEC device as well as the board for SMDK WM9713Mark Brown
Otherwise we try to re-register the CODEC device if the module is reloaded and sysfs becomes miserable. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-24ASoC: Clarify naming for SMDK WM9713 driverMark Brown
At least some of the systems using this device have multiple audio subsystems so provide some guidance to userspace about which one this is. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-24ASoC: Remove unneeded WM9713 header include from SMDK WM9713 driverMark Brown
2010-09-21ASoC: Prototype s3c64xx_i2s_get_clock()Mark Brown
So machine drivers can see the declaration. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-14ASoC: Samsung: Debug PCM snd_soc_dai_driver registrationJassi Brar
Each of the two PCM controllers need to be registered during probe with appropriate 'name' of the dai driver. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-14ASoC: Set more meaningful name for SMDK64xx WM8580 audioMark Brown
Since the SMDK64xx boards have two audio subsystems using the board name as the card name by itself isn't so user friendly as it might be. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-13sound: Remove pr_<level> uses of KERN_<level>Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-11ASoC: S3C: Fix PCM TXFIFO_DIPSTICK valueSeungwhan Youn
This patch modify FIFO_DIPSTICK value of PCM TX FIFO to be a optimal one. Privious value (0x20) did not support 'Almost_full' of PCM FIFO for the DMA request. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-11ASoC: S3C: Fix PCM RX FIFO settingsSeungwhan Youn
When PCM capture, sound recorded abnormally because of RX FIFO threshold settings are missing. So, This patch modify PCM RX FIFO setting codes same as TX. And for DMA, if PCM RXFIFO_DIPSTICK is not '0', it doesn't effect to DMA request, because DMA refer RX_FIFO_EMPTY flag as the DMA request. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-10ASoC: Samsung: Debug PCM platform device nameJassi Brar
The PCM controller platform devices are registered by the name 'samsung-pcm', so use the same in the CPU driver. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-10ASoC: S3C: AC97: Remove the -dai suffixJassi Brar
Drop the invalid -dai suffix appended to the Samsung AC97 CPU DAI. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-08ASoC: rx1950: Fix clkdiv for 16khz and 48khzVasily Khoruzhick
Usage of 256 as clkdiv gives better rounding error (<1%) for 16khz and 48khz Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-08ASoC: rx1950: remove unnecessary headersVasily Khoruzhick
2010-09-08ASoC: rx1950: check that machine is rx1950 in glue driverVasily Khoruzhick
2010-08-31ASoC: Add HP iPAQ RX1950 supportVasily Khoruzhick
2010-08-15ASoC: Automatically calculate clock ratio for WM8580Mark Brown
Implement set_sysclk() and then rather than assuming 256fs use the supplied value to calculate and configure the clock ratio for the currently used sample rate. As a side effect we also end up implementing clock selection for the ADC path. In order to avoid confusion remove the existing set_clkdiv() based configuration of the clock source for the DAC and update the SMDK64xx driver (which is the only in-tree user of the CODEC). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-15ASoC: Add a bit of resource unwinding in the S3C IISv4 driverMark Brown
There's much more needed but this'll get us started. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-12Merge branch 'topic/multi-component' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into for-2.6.37
