Signed-off-by: Joseph Pentland <jp@opensource.wolfsonmicro.com>
Acked-by: Liam Girdwood <lrg@ti.com>
We get called once per DAPM context but only need to run once. When DAPM
was serialized this was a series of noops but now it can run in parallel
we need to take proper care.
Add linux/types.h to fix this compilation error:
In file included from arch/arm/mach-s3c2410/include/mach/gpio-fns.h:27:0,
from arch/arm/mach-s3c2410/include/mach/gpio.h:27,
from /home/anarsoul/work/pda-linux/linux-next/arch/arm/include/asm/gpio.h:5,
from include/linux/gpio.h:18,
from sound/soc/samsung/rx1950_uda1380.c:20:
arch/arm/plat-samsung/include/plat/gpio-cfg.h:29:34: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘s3c_gpio_pull_t’
arch/arm/plat-samsung/include/plat/gpio-cfg.h:30:34: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘s5p_gpio_drvstr_t’
arch/arm/plat-samsung/include/plat/gpio-cfg.h:57:2: error: expected specifier-qualifier-list before ‘s3c_gpio_pull_t’
arch/arm/plat-samsung/include/plat/gpio-cfg.h:148:47: error: expected declaration specifiers or ‘...’ before ‘s3c_gpio_pull_t’
arch/arm/plat-samsung/include/plat/gpio-cfg.h:156:24: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘s3c_gpio_getpull’
arch/arm/plat-samsung/include/plat/gpio-cfg.h:175:24: error: expected declaration specifiers or ‘...’ before ‘s3c_gpio_pull_t’
arch/arm/plat-samsung/include/plat/gpio-cfg.h: In function ‘s3c_gpio_cfgrange_nopull’:
arch/arm/plat-samsung/include/plat/gpio-cfg.h:180:47: error: ‘s3c_gpio_pull_t’ undeclared (first use in this function)
arch/arm/plat-samsung/include/plat/gpio-cfg.h:180:47: note: each undeclared identifier is reported only once for each function it appears in
arch/arm/plat-samsung/include/plat/gpio-cfg.h:180:47: error: expected ‘)’ before numeric constant
arch/arm/plat-samsung/include/plat/gpio-cfg.h:180:47: error: too many arguments to function ‘s3c_gpio_cfgall_range’
arch/arm/plat-samsung/include/plat/gpio-cfg.h:174:12: note: declared here
arch/arm/plat-samsung/include/plat/gpio-cfg.h: At top level:
arch/arm/plat-samsung/include/plat/gpio-cfg.h:199:26: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘s5p_gpio_get_drvstr’
arch/arm/plat-samsung/include/plat/gpio-cfg.h:210:50: error: expected declaration specifiers or ‘...’ before ‘s5p_gpio_drvstr_t’
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Acked-by: Jassi Brar <jassisinghbrar@gmail.com>
I2S in Exynos4 and S5PC110(S5PV210) has a internal dma.
It can be used low power audio mode and 2nd channel transfer.
This patch can support idma.
[Reapplied after dependencies propagated through in 3.1-rc1. --broonie]
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com>
The I2C address is misformatted and would never match.
Cc: stable@kernel.org
For marketing reasons the part will be called WM8996. In order to avoid
user confusion rename the driver to reflect this.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
This reverts commit d7c3e9525ac8e898f1156a1f3a7c5038f6560186 as it does
not currently build due to missing dependencies in the Samsung tree.
Previously, I2S driver only can support system dma.
In this patch, i2s driver can support internal dma too.
IDMA h/w configuration is initialized on idma.c
Using 256fs or 512fs will result in distortion of 24-bit
audio samples. This is because the lrclk generated is not
proper. Using 384 fs generates proper output.
Signed-off-by: Giridhar Maruthy <giridhar.maruthy@linaro.org>
This patch add idma related register definitions to support idma.
Acked-by: Jassi Brar <jaswinder.singh@linaro.org>
I2S registers can be used for control idma.
Previously, register is defined in i2s.c.
For sharing the registers, It is moved to i2s-regs.h
This patch add WM8994 PCM machine driver to support PCM audio
on SMDKV310, SMDKC210 boards.
Playback and Capture supports 8kHz sampling rates.
and It is tested on SMDKV310, SMDKC210.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
If DMA active status should be checked, I2SCON register should be referenced.
In this patch, Fix the incorrect referencing of I2SCON register.
Reported-by : Lakkyung Jung <lakkyung.jung@samsung.com>
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI.
Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains
card, pcm and DAI along with other members too that are useful too.
Signed-off-by: Liam Girdwood <lrg@ti.com>
Now that the CODEC driver supports it defer configuration of the system
clock until bias management which is a much more idiomatic place to do
system power control and makes things a lot more happy when we're using
both interfaces.
The card callback will get called for each DAPM context in the card so it
can be useful for it to know which device is currently undergoing a
transition.
Revision 2 of the Speyside platform supplies a 32kHz clock on MCLK2 rather
than MCLK1.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable
arch/arm/Kconfig
arch/arm/mach-exynos4/mach-nuri.c
According to removing ARCH_S5P6442, we don't need to support
sound for S5P6442.
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Immediately after sending the last fix I realised that the CODEC DAI names
also don't correspond to the WM8994 driver. Update the DAI names to match.
This was typoed at some point in the multi-component merge, though the
driver was added along with that.
Fix trivial conflict caused by silly spelling fix patch.
sound/soc/codecs/wm8994.c
Allow audio paths through the Speyside system to be kept active while the
system is suspended (for example, when on a voice call) by marking all the
external widgets and the DAI link to the WM1250-EV1 baseband module as
ignoring suspend.
Demonstrate the connection of a baseband to the system. We add a DAI for
the link to the baseband. This will become visible to the application
layer - audio should be started from the application layer using an
application such as this:
http://opensource.wolfsonmicro.com/~gg/bluetooth-pcm/bluetooth_pcm.c
which starts up audio as for CPU based playback and record up to the point
where data is streamed.
Due to non-availability of baseband simulation hardware we reuse the
configuration for the CPU link with the CODEC acting as clock master,
allowing signals to be observed with a scope. A more standard system
would have separate configuration for the baseband with its own ops
structure and operations. Normally the baseband would be clock master
as the baseband audio will be synchronised to the external telephony
network.
Pin switches enable direct control of the DAPM state from userspace,
enabling simple enabling and disabling of the path. This is especially
useful for outputs such as the speaker which are composed of several
physical devices as it allows them to be controlled as a group.
Speyside makes use of support the WM8915 has for detecting the polarity
of the microphone and ground connections on headsets, using a GPIO to
control the polarity of the ground connection and switching between the
two microphone bias supplies available on the device in order to do so.
As a result of this the detection support is more involved than for most
other CODECs, using a callback to configure the current polarity of the
jack and translate this into the board-specific connections required for
the current scenario.
On Android some additional work is required to hook this up to the
application layer as the Android HeadsetObserver monitors a custom
drivers/switch API rather than the standard Linux APIs. This can be
done by either updating HeadsetObserver or modifying the ALSA core to
report via drivers/switch as well.
Speyside includes a WM9081 configured as an external speaker driver taking
an analogue input from HPOUT2 on the WM8915 on the system. Add support for
this to the driver, using a prefix of "Sub" for the WM9081 controls to
ensure we avoid collisions with controls on the WM8915.
Dynamically enable and disable the FLL on the WM8915, configuring the
system clock to 256fs for 48kHz when the device is active but reverting
to using the input 32.768kHz clock directly at other times to support
features such as jack detection with minimal power consumption.
Provide widgets for the basic widgets connected directly to the WM8915
on Speyside - the headphones, speaker, digital and analogue microphones.
For the outputs this is just documentation, for the inputs this ensures
that the relevant microphone biases are enabled when they are in use.
This is minimal code required to get audio out of the Speyside audio
subsystem on the Wolfson Cragganmore 6410 reference platform. It sets
up the link between the CPU and AIF1 of the WM8915 on the system,
enabling audio playback via the headphone and speaker outputs of the
device (which require no further configuration except runtime). It
allows verification of basic functionality of the system.
This patch add WM8580 PCM machine driver to support PCM audio
on SMDKC110, SMDKV210, SMDK6450, SMDK6440 boards.
and It is tested on SMDKC110, SMDKV210, SMDK6450
Fix the inverted clocks handling for pcm cpu driver.
By using SND_SOC_DAIFMT_NB_NF, Audio noise can be generated on SMDK.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: HDA: Realtek: Avoid unnecessary volume control index on Surround/Side
ASoC: Support !REGULATOR build for sgtl5000
ALSA: hda - VIA: Fix VT1708 can't build up Headphone control issue
ALSA: hda - VIA: Correct stream names for VT1818S
ALSA: hda - VIA: Fix codec type for VT1708BCE at the right timing
ALSA: hda - VIA: Fix invalid A-A path volume adjust issue
ALSA: hda - VIA: Add missing support for VT1718S in A-A path
ALSA: hda - VIA: Fix independent headphone no sound issue
ALSA: hda - VIA: Fix stereo mixer recording no sound issue
ALSA: hda - Set EAPD for Realtek ALC665
ALSA: usb - Remove trailing spaces from USB card name strings
sound: read i_size with i_size_read()
ASoC: Remove bogus check for register validity in debugfs write
ASoC: mini2440: Fix uda134x codec problem.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits)
ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl
ALSA: aloop - Fix possible IRQ lock inversion
ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail()
ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination
ALSA: firewire - msleep needs delay.h
ALSA: firewire-lib, firewire-speakers: handle packet queueing errors
ALSA: firewire-lib: allocate DMA buffer separately
ALSA: firewire-lib: use no-info SYT for packets without SYT sample
ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver
ALSA: hda - Remove an unused variable in patch_realtek.c
ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs
ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs
ALSA: hda - Move default input-src selection to init part
ALSA: hda - Initialize special cases for input src in init phase
ALSA: ctxfi - Clear input settings before initialization
ALSA: ctxfi - Fix SPDIF status retrieval
ALSA: ctxfi - Fix incorrect SPDIF status bit mask
ALSA: ctxfi - Fix microphone boost codes/comments
ALSA: atiixp - Fix wrong time-out checks during ac-link reset
ALSA: intel8x0m: append 'm' to "r_intel8x0"
ASoC audio for mini2440 platform in current kenrel doesn't work.
First problem is samsung_asoc_dma device is missing in initialization.
Next problem is with codec. Codec is initialized but never probed
because no platform_device exist for codec driver. It leads to errors
during codec binding to asoc dai. Next problem was platform data which
was passed from board to asoc main driver but not passed to codec when
called codec_soc_probe().
Following patch should fix issues. But not sure if in correct way.
Please review.
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
