Change-Id: I0931f4ef7a5464dd32d8c703288a137fc77857ce
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/100090
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline commit
16052827d98fbc13c31ebad560af4bd53e2b4dd5
Change-Id: I929a49556539621a0546829e88b3caa498c94be2
Reviewed-on: http://git-master/r/94463
it shouldn't contain space letters and
special letters like parentheses.
aplay will be "Segmentation fault" without this patch
special thanks to Takashi.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Liam Girdwood <lrg@ti.com>
aplay will be "Segmentation fault" without this patch.
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI.
Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains
card, pcm and DAI along with other members too that are useful too.
Signed-off-by: Liam Girdwood <lrg@ti.com>
This patch is preparation of cleanup suspend/resume patch.
Current FSI driver was using saved_xxx variable for suspend/resume.
OTOH, the start and stop of power/clock are controlled by
fsi_hw_startup/fsi_hw_shutdown in current FSI driver.
The all necessary registers value are set by fsi_hw_startup.
So, if fsi_hw_shutdown is called when "suspend" is generated,
and fsi_hw_startup is called at "resume",
the saved_xxx are not needed.
FSIA/B ports is enabled by default when power-on,
and current FSI is supporting RuntimePM.
In addition, current fsi_module_init/kill doesn't care
simultaneous playback/recorde.
This mean FSI port control is not needed.
This patch remove fsi_module_init/kill
fsi_stream_push/pop might be called in same time.
This patch protect it.
pm_runtime_get/put_sync were used to access FSI register in fsi_dai_set_fmt
which is called when ALSA probe.
But this register value will disappear after pm_runtime_put_sync
if platform is supporting RuntimePM.
To solve this issue, this patch adds new variable for format,
and remove pm_runtime_get/put_sync from fsi_dai_set_fmt.
Some variables on this driver were a unclear naming,
and were different unit (byte, frame, sample).
And some functions had wrong name
(ex. it returned "sample width" but name was "fsi_get_frame_width").
This patch tidy-up this issue, and the minimum unit become "sample".
Special thanks to Takashi YOSHII.
Using fsi_irq_enable/disable in fsi_port_start/stop is very natural.
Current FSI driver is using set_rate call back function which is for
master mode.
By this patch, it is used from fsi_set_master_clk.
It is possible to create buff_len and period_len
from substream->runtime.
This patch is preparation of tidyup unclear variable naming patch.
The FIFO of each port were always working though it was not used
This patch add module/port clock control function for fixing it.
This patch is also caring suspend/resume.
Reviewed-by: Simon Horman <simon@horms.net>
Current FSI driver sets important settings when probing.
And it are not set again as long as driver is not bind again.
This mean FSI driver will lost it from register
if suspend/resume are happen.
This patch save important settings for suspend/resume.
If FSI port is clock master, it use set_rate function
which is callback from platform,
and it is not necessary to call it if FSI port is clock slave.
Current FSI driver called this callback if platform provide it.
This patch modify it.
This patch enables FSI driver autoloading on sh-mobile systems.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Reviewed-by: Simon Horman <horms@verge.net.au
free_irq and pm_runtime_disable should be called before
snd_soc_unregister_xxx
Current format selection of FSI-codecs depended on platform information for FSI,
and chip default settings for codecs. It is not understandable/formal method.
This patch modify FSI and FSI-codecs to use snd_soc_dai_set_fmt.
But FSI can use I2S/PCM and SPDIF format today.
It can be selected to I2S/PCM by snd_soc_dai_set_fmt, but can not select SPDIF.
So, this patch change FSI platform information to have DAI/SPDIF mode.
If platform selects DAI mode (default),
FSI-codecs can select I2S/PCM by snd_soc_dai_set_fmt,
and if it is SPDIF mode, FSI become SPDIF format.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Current FSI driver assumed master->info is not NULL.
This patch allow NULL in master->info
This patch add platform_device_id which can control
PortA/PortB for FSI2-HDMI from platform data.
This patch add snd_soc_dai_ops :: set_fmt to FSI driver and
select master/slave clock mode by snd_soc_dai_set_fmt on
fsi-xxx.c instead of platform infomation code.
This patch remove fsi_is_master function which is no longer needed.
This patch support LEFT_J / I2S only for now
Commit 6d803ba736abb5e122dede70a4720e4843dd6df4 "ARM: 6483/1: arm & sh:
factorised duplicated clkdev.c" broke compilation of migor audio. Use the
correct header to fix the problem.
FSI-AK4642 and FSI-DA7210 are depend on I2C, not I2C_SH_MOBILE
Current FSI driver had printed under/over run error
if status register have its error bit.
But runtime print cause the next error
because print out is slow.
This patch add error counter and print error when sound stop
sound/soc/codecs/wm8350.c
sound/soc/codecs/wm8753.c
sound/soc/sh/fsi.c
sound/soc/soc-core.c
Current FSI driver was checking register range on fsi_master_xxx function.
This runtime check was added to avoid an illegal access
from wrong/mistake implementation.
But it is useless check under the correct implementation.
This patch escape runtime check by using macro technique.
If there is wrong implementation, it will be compile error.
Current FSI driver was checking register range on fsi_reg_xxx function.
There was a strange part where fsi->xxx had been used
for fsi_master_xxx function instead of master->xxx in current FSI.
Current FSI-Ak4642 device had niche settings which were
FSI2-A-AK4643 and FSI-A-AK4642.
FSI/FSI2, PortA/PortB, AK4642/AK4643 from platform data.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (30 commits)
ALSA: hda - Use ALC_INIT_DEFAULT for really default initialization
ASoC: Fix resource reclaim for osk5912
ASoC: tlv320aic3x - fix variable may be used uninitialized warning
ASoC: davinci-vcif - fix a memory leak
ASoC: phycore-ac97: fix resource leak
ASoC: imx-ssi: fix resource leak
ASoC: simone: fix resource leak in simone_init error path
ASoC: sam9g20_wm8731: fix resource leak in at91sam9g20ek_init error path
ASoC: snd-soc-afeb9260: remove unneeded platform_device_del in error path
ASoC: pcm030-audio-fabric: fix resource leak in pcm030_fabric_init error path
ASoC: efika-audio-fabric: fix resource leak in efika_fabric_init error path
ASoC: Call snd_soc_unregister_dais instead of snd_soc_unregister_dai in sh4_soc_dai_remove
ASoC: fix SND_PXA2XX_LIB Kconfig warning
ALSA: hda - Fix ALC660-VD/ALC861-VD capture/playback mixers
ALSA: HDA: Add an extra DAC for Realtek ALC887-VD
ASoC: nuc900-ac97: fix a memory leak
ASoC: Return proper error for omap3pandora_soc_init
ASoC: wm8961 - clear WM8961_MCLKDIV bit for freq <= 16500000
ASoC: wm8961 - clear WM8961_DACSLOPE bit for normal mode
ALSA: hda - Fix Acer 7730G support
sh4_soc_dai_remove
We call snd_soc_register_dais() in sh4_soc_dai_probe(),
thus we should call snd_soc_unregister_dais() in sh4_soc_dai_remove().
Otherwise, we got "too many arguments to function 'snd_soc_unregister_dai'"
error message.
Current AP4 FSI didn't use set_rate for ak4642,
and used dummy rate when init.
And FSI driver was modified to always call set_rate.
The user which are using FSI set_rate is only AP4 now.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
