Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
The ctrl_xxx routines are deprecated, switch over to the __raw_xxx
versions.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits)
ALSA: hda - Disable sticky PCM stream assignment for AD codecs
ALSA: usb - Creative USB X-Fi volume knob support
ALSA: ca0106: Use card specific dac id for mute controls.
ALSA: ca0106: Allow different sound cards to use different SPI channel mappings.
ALSA: ca0106: Create a nice spot for mapping channels to dacs.
ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence.
ALSA: ca0106: Pull out dac powering routine into separate function.
ALSA: ca0106 - add Sound Blaster 5.1vx info.
ASoC: tlv320dac33: Use usleep_range for delays
ALSA: usb-audio: add Novation Launchpad support
ALSA: hda - Add workarounds for CT-IBG controllers
ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs
ASoC: tpa6130a2: Error handling for broken chip
ASoC: max98088: Staticise m98088_eq_band
ASoC: soc-core: Fix codec->name memory leak
ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066
ALSA: hda - Add some workarounds for Creative IBG
ALSA: hda - Fix wrong SPDIF NID assignment for CA0110
ALSA: hda - Fix codec rename rules for ALC662-compatible codecs
ALSA: hda - Add alc_init_jacks() call to other codecs
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (110 commits)
sh: i2c-sh7760: Replase from ctrl_* to __raw_*
sh: clkfwk: Shuffle around to match the intc split up.
sh: clkfwk: modify for_each_frequency end condition
sh: fix clk_get() error handling
sh: clkfwk: Fix fault in frequency iterator.
sh: clkfwk: Add a helper for rate rounding by divisor ranges.
sh: clkfwk: Abstract rate rounding helper.
sh: clkfwk: support clock remapping.
sh: pci: Convert to upper/lower_32_bits() helpers.
sh: mach-sdk7786: Add support for the FPGA SRAM.
sh: Provide a generic SRAM pool for tiny memories.
sh: pci: Support secondary FPGA-driven PCIe clocks on SDK7786.
sh: pci: Support slot 4 routing on SDK7786.
sh: Fix up PMB locking.
sh: mach-sdk7786: Add support for fpga gpios.
sh: use pr_fmt for clock framework, too.
sh: remove name and id from struct clk
sh: free-without-alloc fix for sh_mobile_lcdcfb
sh: perf: Set up perf_max_events.
sh: perf: Support SH-X3 hardware counters.
Fix up trivial conflicts (perf_max_events got removed) in arch/sh/kernel/perf_event.c
Current FSI driver had not cared about simultaneous
playback/capture on same port.
This patch add new fsi_stream struct to care it,
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Some FSI register have similar bit array for PortA/B and In/Out.
This patch add new macro and shift for it
It is not so important for now.
But will be used in future.
Platform driver ID table must be zero-element terminated.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Current FSI driver had data push/pop functions.
But the main operation of these 2 were very similar.
This mean it is possible to merge these to 1 function.
Current FSI driver is using
data-length / width / number / offset for variables.
But it was a very confusing name.
This patch rename them to easy to understand,
and add new functions for it.
Standardise on 'wm8978' as the name for the CODEC.
Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
This patch fixes multiple bugs and a typo, occurred during the multi-
component transition.
The sh/siu ASoC driver doesn't compile because of a function defined static in
the source and extern in a header. Remove the unneeded declaration in the
header.
The clkdev API doesn't use .name and .id members of struct clk for clock
lookup. Instead clocks should be added to a lookup list. Without this patch
audio om the Migo-R board fails silently.
Signed-off-by: Dzianis Kahanovich <mahatma@eu.by>
[Modified to move the location of the table]
This patch solve below report from Guennadi.
But I didn't remove #include <sound/sh_fsi.h>.
Because it have FSI_PORT_B define which is used on this file.
> +#include <linux/platform_device.h>
> +#include <sound/sh_fsi.h>
> +#include <video/sh_mobile_hdmi.h>
Now that everything is done with strings - do you still need these
headers?
Reviewed-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Current SND_FSI_xxx menu attributes were bool,
but it should be tristate.
"bool" means, if someone is linking the whole ASoC into the kernel, they
will not be able to build this as a module. Not a big deal, but you're
stealing some freedom from the user.
Acked-by: Laim Girdwood <lrg@slimlogic.co.uk>
This patch modify dai link
- platform_name: sh_fsi/sh_fsi2 are used for FSI driver
- codec_name: ak4642/ak4643 are used for ak4642 driver
This is quick hack. I should modify it more wisely in future
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
arch/sh/include/asm/Kbuild
drivers/Makefile
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Without this patch, an undefined/random sg->dma_length is used and
the sound will be played/captured wrongly.
Signed-off-by: Markus Pietrek <markus.pietrek@emtrion.de>
Current FSI driver id is not only 0
Specified ID is necessary, when some codecs are used with FSI.
This patch add hw_params to snd_soc_dai_ops,
because board specific set_rate is needed
when FSI was used as master mode.
This patch remove fsi_clk_ctrl from fsi_dai_startup,
because clock should be disabled before set_rate.
This patch didn't use dev_err,
because it is difficult to get struct device here.
Many registers which were grouped by category were added in FSI2.
To make easy to switch FSI/FSI2, fsi_core was added instead of fsi_regs.
channel size should be set before setting register value
Clock inversion should be specified by each flags bit.
The config option SND_FSI_AK4642 selects SND_SOC_AK4642 which in turn
enables the compilation of ak4642.c - however this codec uses I2C to
communicate with the HW.
Same applies to DA7210.
Consequently when I2C is not set, the compilation fails [1]
This patch fixes this issues, by adding a depencdency on the related HW-
controller.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits)
ALSA: snd-usb-caiaq: Bump version number to 1.3.21
ALSA: Revert "ALSA: snd-usb-caiaq: Set default input mode of A4DJ"
ALSA: snd-usb-caiaq: Simplify single case to an 'if'
ALSA: snd-usb-caiaq: Restore 'Control vinyl' input mode on A4DJ
ALSA: hda: Use LPIB for a Shuttle device
ALSA: hda: Add support for another Lenovo ThinkPad Edge in conexant codec
ALSA: hda: Use LPIB for Sony VPCS11V9E
ALSA: usb-audio: fix feature unit parser for UAC2
ALSA: asihpi - Minor code cleanup
ALSA: asihpi - Add support for new ASI8800 family
ALSA: asihpi - Fix bug preventing outstream_write preload from happening
ALSA: asihpi - Fix imbalanced lock path in hw_message
ALSA: asihpi - Remove support for old ASI8800 family
ALSA: asihpi - Add hd radio blend functions
ALSA: asihpi - Remove unused io map functions
ALSA: usb-audio: add support for UAC2 pitch control
ALSA: usb-audio: parse UAC2 endpoint descriptors correctly
ALSA: usb-audio: fix return values
ALSA: usb-audio: parse more format descriptors with structs
sound: Add missing spin_unlock
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into fix/asoc
