It has now become necessary to use a DAPM mutex instead of the codec
mutex to lock the DAPM operations. This is due to the recent multi
component support and forth coming Dynamic PCM updates.
Currently we lock DAPM operations with the codec mutex of the calling
RTD context. However, DAPM operations can span the whole card context
and all components.
This patch updates the DAPM operations that use the codec mutex to
now use the DAPM mutex PCM subclass for all DAPM ops.
We also add a mutex subclass for DAPM init and PCM operations.
Signed-off-by: Liam Girdwood <lrg@ti.com>
(cherry picked from commit a73fb2df01866b772a48fab93401fe3edbe0b38d)
Updated call sequences
Bug 1039523
Change-Id: If079bbe5032971251d6b5426c752cbcc6ad6bcf5
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/128937
We have dapm_context instead of codec parameter.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
In preparation for ASoC Dynamic PCM (AKA DSP) support.
Provide convenience methods to retrieve the soc_card or snd_card from a
DAPM context.
Makes life a little easier if you want to add subsequences to an existing
driver as you can use -1 to put things at the start of sequences.
Allow platform driver widgets to perform any IO required for DAPM.
Previously we were using the DAPM context rather than a widget as the
argument for update_bits() so we didn't need to care that our list walk
of widgets left us one beyond the end of the list. Now we're using them
for the register update we need to make sure we're pointing at an actual
widget not the list_head.
Fix originally suggested by Liam on IM.
Acked-by: Liam Girdwood <lrg@ti.com>
This time with soc_widget_update_bits reflecting recent soc_update_bits changes.
Currently widget IO is tightly coupled to the CODEC drivers. Future platform DSP
devices have mixer components that can alter power usage and hence require full
DAPM support.
This provides a generic widget IO operation wrapper in preparation for
future patches that implement platform driver DAPM.
Normally DAPM will power up any connected audio path. This is not ideal
for sidetone paths as with sidetone paths the audio path is not wanted in
itself, it is only desired if the two paths it provides a sidetone between
are both active. If the sidetone path causes a power up then it can be
hard to minimise pops as we first power up either the sidetone or the main
output path and then power the other, with the second power up potentially
introducing a DC offset.
Address this by introducing the concept of a weak path. If a path is marked
as weak then DAPM will ignore that path when walking the graph, though all
the relevant controls are still available to the application layer to allow
these paths to be configured.
Currently it is possible that snd_soc_new_{mixer,mux,pga} is called with a
DAPM context not matching the widgets context. This can lead to a wrong
prefix_len calculation, which will result in undefined behaviour. To avoid
this always use the DAPM context from the widget itself.
Cc: stable@kernel.org
This allows the card driver to use the bias level variable more easily in
multi component systems.
The card callback will get called for each DAPM context in the card so it
can be useful for it to know which device is currently undergoing a
transition.
No functional changes but much less indentation.
It's redundant now thanks to the use of the generic trace infrastructure.
More with the legibility.
If the only widgets active within a CODEC are supplies and micbiases we
are not passing audio, we are probably just doing microphone detection.
This will not generally require either fully accurate reference voltages
or much power so
If this turns out to be unsuitable for some systems we can provide a
facility to override this decision.
Rather than a simple flag to say if we want the DAPM context to be at full
power specify the target bias state. This should have no current effect
but is a bit more direct and so makes it easier to change our decisions
about the which bias state to go into in future.
Commit af46800 ("ASoC: Implement mux control sharing") introduced
function dapm_is_shared_kcontrol.
When this function returns true, the naming of DAPM controls is derived
from the kcontrol_new. Otherwise, the name comes from the widget (and
possibly a widget's naming prefix).
A bug in the implementation of dapm_is_shared_kcontrol made it return 1
in all cases. Hence, that commit caused a change in control naming for
all controls instead of just shared controls.
Specifically, a control is always considered shared because it is always
compared against itself. Solve this by never comparing against the widget
containing the control being created.
Equally, controls should never be shared between DAPM contexts; when the
same codec is instantiated multiple times, the same kcontrol_new will be
used. However, the control should no be shared between the multiple
instances.
I tested that with the Tegra WM8903 driver:
* Shared is now mostly 0 as expected, and sometimes 1.
* The expected controls are still generated after this change.
However, I don't have any systems that have a widget/control naming
prefix, so I can't test that aspect.
Thanks for Jarkko Nikula for pointing out how to fix this.
Reported-by: Liam Girdwood <lrg@ti.com>
Tested-by: Jarkko Nikula <jhnikula@gmail.com>
Commit 52ba67b ("ASoC: Force all DAPM contexts into the same bias state")
powers up all the DAPM contexts in a card if any DAPM context becomes
active. Unfortunately power down newer happens if per-card DAPM context
doesn't have any widgets.
Reason for this is that power state of per-card DAPM context without
widgets is never cleared and thus all the DAPM contexts remain permanently
active. Test for widgetless calling DAPM context in dapm_power_widgets()
doesn't work for per-card DAPM context since power change is never
originating from widgetless per-card DAPM context.
Fix this by pre-clearing power state flag of non-codec DAPM context at the
beginning of power sequence.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Control sharing is enabled when two widgets include pointers to the
same kcontrol_new in their definition. Specifically:
static const struct snd_kcontrol_new adcinput_mux =
SOC_DAPM_ENUM("ADC Input", adcinput_enum);
static const struct snd_soc_dapm_widget wm8903_dapm_widgets[] = {
SND_SOC_DAPM_MUX("Left ADC Input", SND_SOC_NOPM, 0, 0, &adcinput_mux),
SND_SOC_DAPM_MUX("Right ADC Input", SND_SOC_NOPM, 0, 0, &adcinput_mux),
This is useful when a single register bit or field affects multiple
muxes at once. The common case is to have separate control bits or
fields for each mux (channel). An alternative way of looking at this
is that the mux is a stereo (or even n-channel) mux, rather than
independant mono muxes.
Without this change, a separate kcontrol will be created for each
DAPM_MUX. This has the following disadvantages:
* Confuses the user/programmer with redundant controls that don't
map to separate hardware.
* When one of the controls is changed, ASoC fails to update the DAPM
logic for paths solely affected by the other controls impacted by
the same register bits. This causes some paths not to be correctly
powered up or down. Prior to this change, to work around this, the
user or programmer had to manually toggle all duplicate controls away
from the intended setting, and then back to it.
Control sharing implies that the control is named based on the
kcontrol_new itself, not any of the widgets that are affected by it.
Control sharing is implemented by: When creating kcontrols, if a
kcontrol does not yet exist for a particular kcontrol_new, then a new
kcontrol is created with a list of widgets containing just a single
entry. This is the normal case. However, if a kcontrol does already
exists for the given kcontrol_new, the current widget is simply added
to that kcontrol's list of affected widgets.
A future change will allow multiple widgets to be affected by the same
control. For example, a single register bit that controls separate muxes
in both the L and R audio paths.
This change updates the code that handles relevant controls to be able
to iterate over a list of affected widgets. Note that only the put
functions need significant modification to implement the iteration; the
get functions do not need to iterate, nor unify the results, since all
affected widgets reference the same kcontrol.
When creating the list of widgets, always create a 1-sized list, since
the control sharing is not implemented in this change.
Future changes will need reference to the kcontrol created for a given
kcontrol_new. Store the created kcontrol values now.
A future change will modify struct snd_soc_dapm_widget to store the
actual kcontrol pointers for each kcontrol_new in a field named
kcontrols. Rename the existing kcontrols field to enable this.
Remove the DAPM debugfs entries before freeing the context's widgets, otherwise a
use after free situation might occur.
Currently debugfs entries for a DAPM widgets are only added in
snd_soc_dapm_debugfs_init. If a widget is added later (for example in the
dai_link's probe callback) it will not show up in debugfs.
This patch moves the creation of the widget debugfs entry to
snd_soc_dapm_new_widgets where it will be added after the widget has been
properly instantiated.
As a side-effect this will also reduce the number of times the DAPM widget list
is iterated during a card's instantiation.
Since it is possible that snd_soc_dapm_new_widgets is invoked form the codecs or
cards probe callbacks, the creation of the debugfs dapm directory has to be
moved before these are called.
Move the creation of the DAPM debugfs directory to snd_soc_dapm_debugfs_init
instead of having the same duplicated code in both codec and card DAPM setup.
This patch adds a helper function for searching DAPM widgets by name.
This allows to streamline functions which operate on widgets by name.
It also allows to get rid of copy'n'pasted code which was added to fallback to
widgets from other contexts if the widget was not found in the current context.
Signed-off-by: Lu Guanqun <guanqun.lu@intel.com>
Not all widgets on a card are within the codec's DAPM context. Fix
snd_soc_dapm_get_pin_status to search all contexts when looking for a
widget.
This change is required when modifying tegra_wm8903 to use
snd_soc_card.widgets rather than calling snd_soc_dapm_new_controls; the
former adds the widgets to the card's DAPM context, whereas tegra_wm8903
uses the codec's DAPM context when calling snd_soc_dapm_new_controls.
By code inspection, I suspect this also applies to Samsung Speyside.
The DAPM pin operations currently require that the specific DAPM context
that the pin being operated in is contained in be specified. With multi
component and especially with the addition of a per-card DAPM context
this isn't ideal as it means that things like disabling unused pins on
CODECs require looking up the CODEC DAPM context.
Fix this by falling back to matching a widget in any context if there isn't
a match in the current context. The code isn't ideal currently but will do
the job.
Currently we allow all DAPM contexts to determine their own bias level.
While this should in general work in most situations and will deliver the
lowest possible power it causes problems for our integration with the
card bias level as we're calling the card bias level functions for each
DAPM context even though they're card wide but don't say which CODEC
we're calling them for. Mitigate against this by forcing everything to
be in the same state.
Since we recently explicitly set the register for registerless widgets
to no register there is no longer any need to special case power updates
for them, we can allow them to be handled with the register compression
code as other widgets are.
As this is the only remaining user of dapm_generic_apply_power() and
dapm_update_bits() also remove those functions.
Noticed-by: Lu Guanqun <guanqun.lu@intel.com>
This is also in the old sysfs diagnostics but it's nice to have everything
in one place.
sound/soc/codecs/wm8978.c
sound/soc/soc-dapm.c
We're not only prefixing all controls, we're also prefixing the widget
names in the runtime data. This causes us to add the prefix twice - once
when using the widget name to generate the control name and once when
adding the control.
Really we shouldn't be prefixing the widget names at all, the matching
code should be handing this as we always know which DAPM context a
widget came from and always display the widget name in terms of a DAPM
context. However, we're quite close to the merge window and that's
relatively invasive.
Reported-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
Now we've got multi-component we need to make sure that the DAPM context
(and hence register I/O context) we use to apply the pending updates at
the end of a DAPM sequence is the one we were processing rather than the
one that was used to initate the state change.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Currently will ignore prefixes when creating DAPM controls. Since currently
all control creation goes through snd_soc_cnew() we can fix this by factoring
the prefixing into that function.
A CODEC pointer is optional (and is checked for in most contexts within
DAPM) - add checks to the few places where it was missed.
Rather than indirecting through the CODEC we can look the card up directly
from the card pointer in the DAPM context.
Sometimes the name of the control switch of a dapm route contains
spaces which makes it impossible to distinguish it from the source widget.
Add quotes around the names of the widgets to makes these parsable.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
As bias level changes can be quite time consuming and the bias changes
for multiple devices aren't strongly tied to each other (if anything it
can be advantageous to bring different devices up together) we can improve
the state transition time for multi-component systems by running the bias
level changes for all the devices in parallel. This is very simple to
achieve using the kernel async functionality so use that to schedule the
work.
This should have no practical effect for the overwhelming majority of
systems which have a single DAPM context - we'll bounce into another
thread to do the bias level change but otherwise everything will happen
in exactly the same order as it did before.
We can get the card from the DAPM context so don't bother passing it as
an argument.
The only thing that should ever be calling this is soc-core and that is
built as part of the same module so doesn't need the export.
If a widget has been force enabled then not only do we need to keep the
widget itself enabled, we also need to keep any supplies the widget
requires enabled. The user could force all the individual widgets on but
this requires too much knowledge of device internals.
ASoC generally uses the register defaults for everything, but in some
cases the hardware will default to enabling some of the DAPM widgets
(clocks for example). Ensure that DAPM knows about the actual widget
state at initialisation by reading the enable bits after instantiating
the widgets so they don't get left enabled needlessly.
snd_soc_dapm_put_volsw() has variables for both the unshifted and
shifted mask for updates commit 97404f (ASoC: Do DAPM control updates in
the middle of DAPM sequences) got confused between the two of these.
Since there's no need to keep a copy of the unshifted mask fix this and
simplify the code by using only one mask variable.
[Completely rewrote the changelog to describe the issue -- broonie.]
Allows drivers to distinguish which subsequence is being notified when
they get called back.
