Sometimes more than 1 widget per DAI can be created when the
DAI is embedded with a codec or platform component.
Change-Id: I3208d2be35a7d1afc789c5623e7ae97f9f3667f8
Signed-off-by: Liam Girdwood <lrg@ti.com>
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/361955
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
warn_on message is shown for rt5639 dev when usage count for it goes
negative, so if any case the refcount count goes negative we will see
the warn_on message on particular dev, this change will increment the
usage count when the dev changes from SND_SOC_BIAS_OFF to
SND_SOC_BIAS_STANDBY or during LP0 were the resume will set the bias
to SND_SOC_BIAS_STANDBY, so need to increment refcount based on it.
Bug 1410313
Change-Id: Ie2326cffe406d1a3d61905ecba1437445cd350ad
Signed-off-by: Mohan Kumar <mkumard@nvidia.com>
Reviewed-on: http://git-master/r/336540
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
This is the 3.10.24 stable release
Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
commit ff18620c2157671a8ee21ebb8e6a3520ea209b1f upstream.
... due to a copy & paste error.
Spotted by coverity CID 710923.
Signed-off-by: Mark Brown <broonie@linaro.org>
When we use identical codec for dual codec use case,
we need to use prefix for codec driver, but dapm making double
addition prefix for codec DAI widget in snd_soc_dapm_add_route.
So, this change is for avoiding double addition prefix for codec
DAI widget.
This change is needed by dual codec use case.
Bug 1354235
Bug 1373091
Change-Id: I3e9214ca87ccd14c9729b4accb40ec3cf4f65ed0
Signed-off-by: Songhee Baek <sbaek@nvidia.com>
Reviewed-on: http://git-master/r/289442
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
commit fe581391147cb3d738d961d0f1233d91a9e1113c upstream.
list_first_entry() will always return a valid pointer, even if the list is
empty. So the check whether path is NULL will always be false. So we end up
calling dapm_create_or_share_mixmux_kcontrol() with a path struct that points
right in the middle of the widget struct and by trying to modify the path the
widgets memory will become corrupted. Fix this by using list_emtpy() to check if
the widget doesn't have any paths.
Even though they are virtual widgets DAI widgets still get counted for the
DAPM context power management so we can't just use the active state to
check if they should be powered as they may not be part of a complete path.
Instead split them into input and output widgets and do the same power
checks as we perform on AIFs.
Reported-by: Stephen Warren <swarren@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next
ASoC: Updates for v3.10
A few more bug fixes, the DAPM clock fix is actually a driver specific
one since currently there's only one user of the clock support due to
the problems relying on the clock API.
Update dapm_clock_event to use clk_prepare_enable and
clk_disable_unprepare.
Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org>
When clearing the walked flags there is no need to clear all paths, we
only need to clear the paths we actually walked. This means we can split
dapm_clear_walk() into input and output versions and rather than going
through all DAPM paths we can recurse down the path until we encounter
paths we have not yet walked.
This reduces the number of operations we need to perform and improves
cache locality.
[Pulled out of the vendor tree that the patch was originally generated
for by me, any bugs were introduced in that process -- broonie]
Signed-off-by: Ryo Tsutsui <Ryo.Tsutsui@wolfsonmicro.com>
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
We already clear the walked state in dapm_widget_power_check(), no need
to do it again.
This is the equivalent of commit af46800 "ASoC: Implement mux control
sharing", but applied to mixers instead of muxes.
This allows a single control to affect multiple mixer widgets at once,
which is useful when there is a single set of register bits that affects
multiple mixers in HW, for example both the L and R mixers of a stereo
path.
Without this, you either:
1) End up with multiple controls that affect the same register bits, but
whose DAPM state falls out of sync with HW, since the DAPM state is only
updated for the specific control that is modified, and not for other
paths that are affected by the register bit(s).
2) False paths through DAPM, since you end up merging unconnected stereo
paths together into a single widget which hosts the single control, and
then branching back out again, thus conjoining the enable states of the
two input paths.
Now that the kcontrol creation logic is split out into a separate
function, dapm_create_or_share_mixmux_kcontrol(), also use that to
replace most of the body of dapm_new_mux(). This should produce no
functional change, but simply eliminates some mostly duplicated code.
*path is not yet initialized when we check if the widget is connected.
The compiler also warns about this:
sound/soc/soc-dapm.c: In function 'is_connected_output_ep':
sound/soc/soc-dapm.c:824:18: warning: 'path' may be used uninitialized in this function
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Commit 497098be ("ASoC: dapm: Remove bodges for no-widget CODECs") removed the
last user of the n_widgets field. Currently it is incremented for each widget
added, but the value is never used, so we can remove it.
Currently if a path loops back on itself we correctly skip over it to
avoid going into an infinite loop but this causes us to ignore the need
to power up the path as we don't count the loop for the purposes of
counting inputs and outputs. This means that internal loopbacks within a
device that have powered devices on them won't be powered up.
Fix this by treating any path that is currently in the process of being
recursed as having a single input or output so that it is counted for
the purposes of power decisions.
Help avoid noise from the power up of the capture path propagating through
into the start of the recording (especially noise caused by the ramp of
microphone biases) by keeping the capture muted until after we've finished
powering things up with DAPM in the same manner we do for playback. This
allows us to take advantage of soft mute support in the hardware more
effectively and is more consistent.
The core code using the existing digital mute operation is updated to take
advantage of this. Some additional cases in the soc-pcm code and suspend
will need separate handling but these are less practically relevant than
the main runtime stream start/stop case.
Rather than refactor the digital mute function in every single driver a
new operation is added for drivers taking advantage of this functionality,
the old operation should be phased out over time.
Acked-by Vinod Koul <vinod.koul@intel.com>
Enable bypass when the regulator is idle, not when it is in use. This is
consistent with what the few existing users actually want.
Currently ASoC has a mixture of message prefixes e.g. "ASoC", "asoc"
or none and message types e.g. pr_debug or dev_dbg.
Make sure all ASoC core messages use the same "ASoC" prefix and
convert any component device specific messages to use dev_dbg
instead of pr_debug.
DAPM shutdown incorrectly uses "list" field of codec struct while
iterating over probed components (codec_dev_list). "list" field
refers to codecs registered in the system, "card_list" field is
used for probed components.
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
Cc: stable@vger.kernel.org
Allow regulators managed via DAPM to make use of the bypass support that
has recently been added to the regulator API by setting a flag
SND_SOC_DAPM_REGULATOR_BYPASS. When this flag is set the regulator will
be put into bypass mode before being disabled, allowing the regulator to
fall into bypass mode if it can't be disabled due to other users.
Linux 3.6-rc6 has all our bug fixes.
Conflicts (trivial overlap):
sound/soc/omap/am3517evm.c
For ENUM controls the bitmask is calculated based on the number of items.
Currently this is done each time the control is accessed. And while the
performance impact of this should be negligible we can easily do better. The
roundup_pow_of_two macro performs the same calculation which is currently done
manually, but it is also possible to use this macro with compile time constants
and so it can be used to initialize static data. So we can use it to initialize
the mask field of a ENUM control during its declaration.
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Since bypass paths aren't part of DAPM streams and we may not have any
DAPM streams there may not be anything that triggers a DAPM sync for
them. Mark all input and output widgets as dirty and then sync to do so
at the end of suspend and resume.
Acked-by: Liam Girdwood <lrg@ti.com>
Commit 412312 (ASoC: dapm: Make sure all dapm contexts are updated) means
that any DAPM context being updated will have the bias level automatically
set, including the card. We can't safely do this as the card callbacks are
called for each device context and so the management of the card bias is
more complex. Several multi-component cards rely on this behaviour.
Skip updates during the asynchronous run entirely. We should really do them
in the synchronous section but it's not 100% clear which values to pick as
the different DAPM contexts may have different bias levels.
ensures that we update non-CODEC DAPM contexts but means that if a
CODEC has no set_bias_level() operation it'll not be updated. Fix
that.
Pull first round of SCSI updates from James Bottomley:
"The most important feature of this patch set is the new async
infrastructure that makes sure async_synchronize_full() synchronizes
all domains and allows us to remove all the hacks (like having
scsi_complete_async_scans() in the device base code) and means that
the async infrastructure will "just work" in future.
The rest is assorted driver updates (aacraid, bnx2fc, virto-scsi,
megaraid, bfa, lpfc, qla2xxx, qla4xxx) plus a lot of infrastructure
work in sas and FC.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (97 commits)
[SCSI] Revert "[SCSI] fix async probe regression"
[SCSI] cleanup usages of scsi_complete_async_scans
[SCSI] queue async scan work to an async_schedule domain
[SCSI] async: make async_synchronize_full() flush all work regardless of domain
[SCSI] async: introduce 'async_domain' type
[SCSI] bfa: Fix to set correct return error codes and misc cleanup.
[SCSI] aacraid: Series 7 Async. (performance) mode support
[SCSI] aha152x: Allow use on 64bit systems
[SCSI] virtio-scsi: Add vdrv->scan for post VIRTIO_CONFIG_S_DRIVER_OK LUN scanning
[SCSI] bfa: squelch lockdep complaint with a spin_lock_init
[SCSI] qla2xxx: remove unnecessary reads of PCI_CAP_ID_EXP
[SCSI] qla4xxx: remove unnecessary read of PCI_CAP_ID_EXP
[SCSI] ufs: fix incorrect return value about SUCCESS and FAILED
[SCSI] ufs: reverse the ufshcd_is_device_present logic
[SCSI] ufs: use module_pci_driver
[SCSI] usb-storage: update usb devices for write cache quirk in quirk list.
[SCSI] usb-storage: add support for write cache quirk
[SCSI] set to WCE if usb cache quirk is present.
[SCSI] virtio-scsi: hotplug support for virtio-scsi
[SCSI] virtio-scsi: split scatterlist per target
Ever since the DAPM performance improvements we've been marking all widgets
as not dirty after each DAPM run. Since _PRE and _POST events aren't part
of the DAPM graph this has rendered them non-functional, they will never be
marked dirty again and thus will never be run again.
Fix this by skipping them when marking widgets as not dirty.
This is in preparation for teaching async_synchronize_full() to sync all
pending async work, and not just on the async_running domain. This
conversion is functionally equivalent, just embedding the existing list
in a new async_domain type.
The .registered attribute is used in a later patch to distinguish
between domains that want to be flushed by async_synchronize_full()
versus those that only expect async_synchronize_{full|cookie}_domain to
be used for flushing.
[jejb: add async.h to scsi_priv.h for struct async_domain]
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Tested-by: Eldad Zack <eldad@fogrefinery.com>
Fix following:
sound/soc/soc-dapm.c: In function ‘dapm_clock_event’:
sound/soc/soc-dapm.c:1021:1: warning: control reaches end of non-void function [-Wreturn-type]
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Since we're now relying on DAPM for things like enabling clocks when we
reparent the clocks for widgets we need to either use conditional routes
(which are expensive) or remove routes at runtime. Add a route removal
API to support this use case.
If we add a new route at runtime then we'll need to recheck the connections
to the affected widgets.
Make sure we set the bias level for all DAPM contexts when
changing level.
Codec shutdown performs a DAPM power sequence that might cause conflicts
and/or race conditions if another stream power event is running simultaneously.
Use card's dapm mutex to protect any potential race condition between them.
dapm_set_path_status() sets connect incorrectly in the case max > 1 with invert.
In that case, the raw disconnect value should be max, which corresponds to the
userspace value 0.
This use case currently does not appear upstream, but it could break
SOC_DAPM_SINGLE() or SOC_DAPM_SINGLE_TLV() elsewhere or in the future.
This patch completes commit 3a9abe8.
Cc: Liam Girdwood <lrg@ti.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: <alsa-devel@alsa-project.org>
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Stereo is not yet supported by dapm widgets, so remove stereo code from
snd_soc_dapm_get_volsw(), and warn if stereo controls are detected.
snd_soc_dapm_put_volsw() sets connect incorrectly in the case max > 1 with
invert. In that case, the raw disconnect value should be max, which corresponds
to the userspace value 0.
Linux 3.5-rc4 contains some bug fixes which overlap with new features.
We may as well print as many errors as we can in one go rather than
requiring developers to iterate through all their typos.
We should only add source widgets to the input list.
Make sure we check the correct path for capture.
Adds a supply-widget variant for connection to the clock-framework.
This widget-type corresponds to the variant for regulators.
Signed-off-by: Ola Lilja <ola.o.lilja@stericsson.com>
Linux 3.4-rc7
Conflicts):
drivers/base/regmap/regmap.c (overlap with bug fixes)
sound/soc/blackfin/bf5xx-ssm2602.c (overlap with bug fixes)
