path: root/sound/soc/soc-jack.c
2011-09-05ASoC: Fix reporting of partial jack updatesMark Brown
We need to report the entire jack state to the core jack code, not just the bits that were being updated by the caller, otherwise the status reported by other detection methods will be omitted from the state seen by userspace. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Cc: stable@kernel.org
2011-08-15ASoC: soc-jack: Fix checking return value of request_any_context_irqAxel Lin
request_any_context_irq() returns a negative value on failure. On success, it returns either IRQC_IS_HARDIRQ or IRQC_IS_NESTED. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.orG
2011-04-18ASoC: Merge branch 'for-2.6.39' into for-2.6.40Mark Brown
Fix trivial conflict caused by silly spelling fix patch. Conflicts: sound/soc/codecs/wm8994.c
2011-04-03ASoC: Name jack GPIOs based on jack not codecStephen Warren
snd_soc_jack_gpio has a name field. Use that name when registering the IRQ, since this is far more informative than the codec driver name. This shows up in /proc/interrupts. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-03-30sound: Fixup the last user of the old irq functionsThomas Gleixner
I had seen that before, but now that I removed set_irq_wake it broke. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-24ASoC: Pass the jack to jack notifiersMark Brown
We're currently not passing anything and this will make the card and so on more discoverable. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-18ASoC: Allow GPIO jack detection to be configured as a wake sourceMark Brown
Some systems wish to use jacks as wake sources. Provide a wake flag in the GPIO configuration which causes the driver to enable the IRQ as a wake source. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-11ASoC: Allow use sleeping gpio in soc-jackJarkko Nikula
It is safe to use sleeping gpio in snd_soc_jack_gpio_detect as it is not called from interrupt context. This avoids WARN_ON from __gpio_get_value if sleeping gpio is registered for jack. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-02-09ASoC: add support for multiple jack typesVinod Koul
This patch adds soc-jack support for adding voltage zones and for detecting jack type Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Harsha Priya <priya.harsha@intel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-06ASoC: Add trace events for jack detectionMark Brown
As jack detection can trigger DAPM and the latency in debouncing can create confusing windows in operation provide some trace events which will hopefully help in diagnostics. The soc-jack core traces all reports that it gets and the resulting notifications to upper layers. An event for jack IRQs is also provided for instrumentation of debounce, and used in the GPIO jack code. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-15ASoC: Prevent system suspend while debouncing wakeup capable GPIO jacksMark Brown
If the device associated with a GPIO jack is wakeup capable then disable suspend while we're debouncing the jack so that we skip suspends that race with the jack. Note that currently the GPIO based jack has a CODEC associated with it which we're using right now. These jacks should be reparented against the card itself and this code adjusted. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-03ASoC: Convert soc-jack code to use request_any_context_irq()Mark Brown
Allow the standard soc-jack GPIO based jack handling to handle the use of GPIOs which may sleep (such as those on GPIO expanders) by converting the code to use request_any_context_irq(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-07ASoC: Use delayed work for debounce of GPIO based jacksMark Brown
Rather than block the workqueue by sleeping to do the debounce use delayed work to implement the debounce time. This should also means that we extend the debounce time on each new bounce, potentially allowing shorter debounce times for clean insertions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-04-23ASoC: Allow reporting of NULL jacksMark Brown
Follow the core jack implementation and allow reporting on the status of NULL jacks, avoiding the need to check in detection implementations. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-22ASoC: Add a notifier for jack status changesMark Brown
Some systems provide both mechanical and electrical detection of jack status changes. On such systems power savings can be achieved by only enabling the electrical detection methods when physical insertion has been detected. Begin supporting such systems by providing a notifier for jack status changes which can be used to trigger any reconfiguration. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-11-12ASoC: Add jack_status_check callback function for GPIO jacksJoonyoung Shim
The jack_status_check callback function is the interface to check the status of the jack. Some target provides the method to distinguish what is the jack inserted - headphone jack, microphone jack, tvout jack, etc, so we can implement it using the jack_status_check function. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-10-19ASoC: Move dereference after NULL testJulia Lawall
If the NULL test on jack is needed, then the derefernce should be after the NULL test. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-31ASoC: jack: Fix race in snd_soc_jack_add_gpiosLars-Peter Clausen
The irq can fire as soon as it has been requested, thus all fields accessed from within the irq handler must be initialized prior to requesting the irq. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-24ASoC: Jack handling enhancements as suggested by subsystem maintainerJanusz Krzysztofik
The patch adds a few small enhancements to the ASoC jack handling, as suggested by Mark in his comments to my Amstrad Delta driver, and a few fixes for related bugs found while learning Mark's code and testing results. Enhancements: 1. Update status of an ASoC jack while associating it with new gpios. 2. Really update DAPM pins while associating them with an ASoC jack. 3. Export ASoC jack gpios over gpiolib sysfs for diagnostic purposes. Fixes: 1. Apply mask on jack status report before using it, just for case. 2. While updating jack associated DAPM pins, use full resulting jack status, not the status report passed as an argument. Created and tested on linux-2.6.31-rc3 Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-06ASoC: Staticise workqueue function for GPIO jack detectionMark Brown
2009-03-04ASoC: Add GPIO support for jack reporting interfaceLopez Cruz, Misael
Add GPIO support to jack reporting framework in ASoC using gpiolib calls. The gpio support exports two new functions: snd_soc_jack_add_gpios and snd_soc_jack_free_gpios. Client drivers using gpio feature must pass an array of jack_gpio pins belonging to a specific jack to the snd_soc_jack_add_gpios function. The framework will request the gpios, set the data direction and request irq. The framework will update power status of related jack_pins when an event on the gpio pins comes according to the reporting bits defined for each gpio. All gpio resources allocated when adding jack_gpio pins can be released using snd_soc_jack_free_gpios function. Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-27ASoC: Push the codec runtime storage into the card structureMark Brown
This is a further stage on the road to refactoring away the ASoC platform device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-09ASoC: Add jack reporting interfaceMark Brown
This patch adds a jack reporting interface to ASoC. This wraps the ALSA core jack detection functionality and provides integration with DAPM to automatically update the power state of pins based on the jack state. Since embedded platforms can have multiple detecton methods used for a single jack (eg, separate microphone and headphone detection) the report function allows specification of which bits are being updated on a given report. The expected usage is that machine drivers will create jack objects and then configure jack detection methods to update that jack. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
