path: root/sound/soc/spear
2015-09-14ASoC: SPEAr: Make SND_SPEAR_SOC select SND_SOC_GENERIC_DMAENGINE_PCMAxel Lin
devm_snd_dmaengine_pcm_register() is guarded by CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-30ASoC: spear_pcm: Use devm_snd_dmaengine_pcm_register to fix resource leakAxel Lin
All the callers assume devm_spear_pcm_platform_register is a devm_ API, so use devm_snd_dmaengine_pcm_register in devm_spear_pcm_platform_register. Fixes: e1771bcf99b0 ("ASoC: SPEAr: remove custom DMA alloc compat function") Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-25ASoC: SPEAr: Convert to use devm_ioremap_resourceAxel Lin
Use devm_ioremap_resource() instead of open code. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-10-20ASoC: spear: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-09ASoC: Update email id of the authorRajeev Kumar
I moved from ST Microelectronics and so updating email-id to personal one. Signed-off-by: Rajeev Kumar <rajeevkumar.linux@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-10ASoC: spear: spdif_out: Fix mute controlLars-Peter Clausen
For controls registers with snd_soc_add_dai_controls snd_kcontrol_chip() returns a pointer to the DAI, not to the CODEC. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-18ASoC: SPEAr: remove custom DMA alloc compat functionStephen Warren
spear_pcm_request_chan() is almost identical to dmaengine_pcm_compat_request_channel(), with the exception that the latter: a) Assumes that the DAI DMA data is a struct snd_dmaengine_dai_dma_data pointer rather than some custom type. b) dma_data->filter_data rather than dma_data should be passed to snd_dmaengine_pcm_request_channel() as the filter data. Make minor changes to the SPEAr DAI drivers so that those two conditions are met. This allows removal of the custom .compat_request_channel(). Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-18ASoC: SPEAr: get rid of spear-pcm-audio struct deviceStephen Warren
Modify the SPEAr PCM driver so that it's a utility library that can be registered on each DAI, rather than a separate struct device. This is more in line with how many recent DT-converted platforms operate, and avoids the need for yet another struct device. This is also required as a pre-cursor to removing spear_pcm_request_chan(). Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-28ASoC: spear: Use devm_snd_dmaengine_pcm_registerLars-Peter Clausen
Makes the code slightly shorter. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-19ASoC: SPEAr spdif_out: Remove redundant variableSachin Kamat
Return directly and remove the intermediate local variable. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-18ASoC: SPEAr spdif_out: Use devm_snd_soc_register_componentSachin Kamat
devm_snd_soc_register_component makes code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-18ASoC: SPEAr spdif_in: Use devm_snd_soc_register_componentSachin Kamat
2013-08-15ALSA: move dmaengine implementation from ASoC to ALSA coreDaniel Mack
For the PXA DMA rework, we need the generic dmaengine implementation that currently lives in sound/soc for standalone (non-ASoC) AC'97 support. Move it to sound/core, and rename the Kconfig symbol. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-17ASoC: spear: Convert to use devm_ioremap_resourceTushar Behera
Commit 75096579c3ac ("lib: devres: Introduce devm_ioremap_resource()") introduced devm_ioremap_resource() and deprecated the use of devm_request_and_ioremap(). devm_request_mem_region is called in devm_ioremap_resource(). Hence that part can also be removed. Since devm_ioremap_resource prints error message on failure, there is no need to print an explicit warning message. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> CC: alsa-devel@alsa-project.org CC: Liam Girdwood <lgirdwood@gmail.com> CC: Mark Brown <broonie@kernel.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-17ASoC: spear: Normalise module namesMark Brown
2013-06-17ASoC: spear: Remove nonexistant EVM optionsMark Brown
The source wasn't added. Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-14ASoC: SPEAr: Hide component drivers in KconfigMark Brown
The individual component drivers are only useful with a machine driver and should be selected by the machine drivers so shouldn't have help text of their own in order to hide them in interactive configuration. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-14ASoC: SPEAr: Add dependency on dmaengine helpersMark Brown
I'd be very surprised if anyone has used the Kconfig... Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-13ASoC: SPEAr spdif_{in,out}: fix fallout of previous cleanupUwe Kleine-König
The patch that resulted in bfcc74e (ASoC: SPEAr spdif_{in,out}: use devm for clk and a few more cleanups) was broken and applied on a newer tree than it was created for. So bfcc74e introduced unbalanced clk handling, two warnings about unused variables and passed 3 arguments to a function only taking 2. This commit fixes that. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-12ASoC: Add Kconfig and Makefile to support SPEAr audio driverRajeev Kumar
This patch adds Kconfig and Makefile to support SPEAr Audio driver. Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-05-15ASoC: spear: spdif_out: Staticize unexported functionLars-Peter Clausen
The spdif_soc_dai_probe function is only used in spdif_out.c, so make it static. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-15ASoC: spear: spdif_in: Staticize non exported structLars-Peter Clausen
The spdif_in_dai struct is not used outside of spdif_in.c, so make it static. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-12ASoC: SPEAr spdif_{in,out}: use devm for clk and a few more cleanupsUwe Kleine-König
Drop dev_set_drvdata as this is handled in the core and use devm_request_and_ioremap instead of devm_ioremap to properly register the address range used Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-12ASoC: spear: Use generic dmaengine PCMLars-Peter Clausen
Use the generic dmaengine PCM driver instead of a custom implementation. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-12ASoC: spear: Setup dma data in DAI probeLars-Peter Clausen
This allows us to access the DAI DMA data when we create the PCM. We'll use this when converting spear to generic DMA engine PCM driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-18Merge tag 'asoc-v3.10-2' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: More updates for v3.10 The main additional change here is Lars-Peter's DMA work plus the platform conversions which have been tested - getting this in mainline will make life easier for development after the merge window. These factor a large chunk of code out of the drivers for the platforms using dmaengine, greatly simplifying development.
2013-04-17Merge tag 'v3.9-rc7' into asoc-dmaMark Brown
Linux 3.9-rc7
2013-04-17ASoC: dmaengine-pcm: Make requesting the DMA channel at PCM open optionalLars-Peter Clausen
Refactor the dmaengine PCM library to allow the DMA channel to be requested before opening a PCM substream. snd_dmaengine_pcm_open() now expects a DMA channel instead of a filter function and filter parameter as its parameters. snd_dmaengine_pcm_close() is updated to not release the DMA channel. This allows a dmaengine based PCM driver to request its channels before the substream is opened. The patch also introduces two new functions, snd_dmaengine_pcm_open_request_chan() and snd_dmaengine_pcm_close_release_chan(), which have the same signature and behaviour of the old snd_dmaengine_pcm_{open,close}() and internally use the new variants of these functions. All users of snd_dmaengine_pcm_{open,close}() are updated to use snd_dmaengine_pcm_open_request_chan() and snd_dmaengine_pcm_close_release_chan(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Stephen Warren <swarren@nvidia.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-12Merge remote-tracking branch 'asoc/topic/spear' into asoc-nextMark Brown
2013-04-12Merge remote-tracking branch 'asoc/topic/dma' into asoc-nextMark Brown
2013-04-12Merge remote-tracking branch 'asoc/topic/component' into asoc-nextMark Brown
2013-03-26ASoC: switch over to use snd_soc_register_component() on spear spdif inKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-26ASoC: switch over to use snd_soc_register_component() on spear spdif outKuninori Morimoto
2013-03-26ASoC: speaer_pcm: No need to use snd_dmaengine_pcm_set_data()Lars-Peter Clausen
The driver never uses snd_dmaengine_pcm_get_data(), so there is no need to use snd_dmaengine_pcm_set_data(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-26ASoC: spear_pcm: No need to wrap snd_dmaengine_pcm_close()Lars-Peter Clausen
If a PCM driver using the dmaengine PCM helper functions doesn't need to do anything special in its pcm_close callback, snd_dmaengine_pcm_close can be used directly for as the pcm_close callback and there is no need to wrap it in a custom function. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-20ASoC: spear_pcm: Staticize non-exported structsLars-Peter Clausen
2013-03-20ASoC: spear_pcm: Update to new pcm_new() APILars-Peter Clausen
Commit 552d1ef6 ("ASoC: core - Optimise and refactor pcm_new() to pass only rtd") updated the pcm_new() callback to take the rtd as the only parameter. The spear PCM driver (which was merged much later) still uses the old API. This patch updates the driver to the new API. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-12-10ASoC: spear: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-31ASoC: spear: correct the check for NULL dma_buffer pointerPrasad Joshi
The if condition if (!buf && !buf->area) checks if the buf pointer is NULL and then dereferences it again to check if the buffer area is NULL, resulting in possible NULL dereference. Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-07-04ASoC: SPEAr spdif_out: Add spdif out supportVipin Kumar
This patch implements the spdif out driver for ST peripheral. This peripheral implements IEC60958 standard Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-23ASoC: SPEAr spdif_in: Add spdif IN supportVipin Kumar
This patch implements the spdif IN driver for ST peripheral Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-22ASoC: Add support for SPEAr ASoC pcm layer.Rajeev Kumar
This patch add support for the SPEAr ASoC pcm layer in ASoC framework. The pcm layer uses common snd_dmaengine framework. Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
