Added TDM mode support in I2S driver.
Added support functions in AHUB to pass audio/client bits.
Added support functions in AHUB to pass audio/client channels.
Fixed the stopping of I2S/TDM by clearing the fifo.
Bug 948478
Change-Id: I246942b3a07ffcfbcfafbc820208190bd3acc5d4
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/98456
Reviewed-by: Scott Peterson <speterson@nvidia.com>
stop the enabling/disabling of i2s capture from i2s dai in
voice call recording usecase because this would be handled
by the voice call management functions and also add parameters
for voice call record usecase in i2s structures.
Bug: 912897
Change-Id: I9df117300121218fe7f258fd8c79092ab3e1f8e1
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/72352
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
If AP is set as slave set audio_sync clock as source of i2s controller
clock and use pll_a_out0 as i2s controller source in AP master mode.
This change is needed to support AP slave mode reliably on Tegra30.
Bug 911332
Change-Id: I91e54d1d297c58ad65baac86831bccfbaadf732c
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/69777
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
add code for handling register save/restore and clocks
disable/enable during suspend/resume
Bug: 862023
Change-Id: I1b709b6bf674c9a2d93c2a21c1f44bbadff64aab
Reviewed-on: http://git-master/r/65478
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Rebase-Id: R2383486dac0892e317dbd25044df59284031b6c4
Bug: 862023
Change-Id: If22a815f3c941e07b4be91c485353087e45b7503
Reviewed-on: http://git-master/r/62894
Rebase-Id: R3cceb258be9da3e8bb45741705aabd65c6065c3c
default playback path is established through the dam
so as to support mixing of system sounds during voice call and also
playing of connection and disconnection tones
Bug: 862023
Change-Id: Ia055e7372f4ca18d038db483c3657ee4bbbfb6ca
Reviewed-on: http://git-master/r/63816
Rebase-Id: R38a4b7b469f5c8cffdc9c53a4a1fb07c13b5a531
with these changes from the machine driver we can configure
the default playback path to go through the dam or bypass
the dam
Bug: 862023
Change-Id: I0c51dd167c6822c4583240ece14211a82734ee2e
Reviewed-on: http://git-master/r/62891
Rebase-Id: R7e756015a8436841c00295145ec45a23ec3ba8f7
Correct DSP-A/B mode logic and bitcnt calculation logic for DSP mode.
Also enable single slot for both I2s and DSP modes.
Bug 872652
Change-Id: I9df935bfddde71b3c3a0df68cef73f530079176c
Reviewed-on: http://git-master/r/62024
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Rebase-Id: R8ef4810768bbc7d3d091cc08054e952763d9087f
Remove redundant ref counting for I2s and AHUB clocks.
For Tegra30 enable AHUB clocks before I2s registers are accessed.
Disable clocks when they are not in use.
Bug 872652
Change-Id: I7ec4e45cecd0391d0b5a2765214d6c03fa5cc339
Reviewed-on: http://git-master/r/55005
Tested-by: Gerrit_Virtual_Submit
Rebase-Id: R886c4a1a472c6b68240f2899a0b0be94c7ac9966
This provides an ASoC DAI interface for Tegra 30's I2S controller.
Rebase-Id: R7ff210416560aa776e2e751ceba765083f4ce6e5
