Add alsa controls to specify which alsa device is used by AVP to render
audio. Also add support for disabling DMA interrupt when AVP renders
audio. Also add couple of alsa controls to query DMA channel ID and
DMA buffer physical address.
Bug 968814
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Change-Id: If593329db72bf00d97f7433f5c54e13500281253
Reviewed-on: http://git-master/r/97916
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Allow setting bias level to turn off clock extern1 when codec
is idle for enterprise board. (Maxim 98088 codec)
Bug 984678
Change-Id: Ib01be71362ab0c5525f570693b41db73777875e6
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Reviewed-on: http://git-master/r/102240
Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Change prototype of tegra_asoc_utils_init to pass snd_soc_card handle.
It is needed to move common tegra machine driver codes to
tegra_asoc_utils interface.
Bug 968814
Change-Id: I98490ffdda51cf7d0b89adadb23c31892183bc0e
Reviewed-on: http://git-master/r/97914
Reviewed-by: Simone Willett <swillett@nvidia.com>
bug 949219
Change-Id: I52969e8dd1a5ed4dc76ac360ec08b0afb18cd4a5
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92833
Add support to customize modem parameters for voice call.
Change-Id: I947bf1955713c4ae19e5dd829091bd7e51bca08f
Reviewed-on: http://git-master/r/93091
Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
use common platform data instead of using codec specific platform
data for different codecs
Change-Id: I88ecb08f3945e0d9c5162ec2b2d3279a4da50099
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/91686
If card fails to instantiate then unregister the card
Change-Id: Ibcc0d505a8df48c1f924a3d8688dc23e362d5e8d
Reviewed-on: http://git-master/r/90060
Change-Id: I0b2b50c007d9e7b722b2c4bbc0282c51a8d18b00
Reviewed-on: http://git-master/r/88239
Support I2S slave mode. Disable pll_p_out1 and
pll_a to reduce power when in slave mode.
Slave mode disabled by default.
Reviewed-on: http://git-master/r/76046
Change-Id: I873a11d54f1e037d99c86ff4cec06ee83064902a
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/77765
Bug: 924817
Reviewed-on: http://git-master/r/77238
Change-Id: Ife3bb3439b4b00d042684500d7ffb6bc00100ba6
Reviewed-on: http://git-master/r/77756
set default bias level to standby
Change-Id: I89f375c88efae48fff43fe57e15659b40602dfac
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Reviewed-on: http://git-master/r/73174
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Nikesh Oswal <noswal@nvidia.com>
(cherry picked from commit d00767b6573367a6827f35c2339e46f68f75cbaf)
Reviewed-on: http://git-master/r/73952
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
during suspend if bias is set to off then disable the pll_a and
related clock only once this would prevent the kernel warnings
Bug: 920911
Change-Id: Id85cba4548894572dfd17e51c8a55707bfba7105
Reviewed-on: http://git-master/r/72739
Bug: 912897
Change-Id: I3bdc879d7eecea78eace7452fd9b157f68aeea48
Reviewed-on: http://git-master/r/72355
during voice call, prevent suspend of codec and audio
modules, whereas for other mode they are allowed to suspend.
Bug: 917672
Change-Id: I1e8ff06fa21084a0187d35258177f22ae112f1ce
Reviewed-on: http://git-master/r/71174
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Bug 912637
Change-Id: I05e2d3dcb903bf9d011f9b108a8f65f25ee1d3b5
Reviewed-on: http://git-master/r/68956
when writing into ahub connection registers for i2s
i2s clocks must be enabled hence calling the
ahub resume from i2s driver
Bug: 908372
Change-Id: Ieb1312f5d98e54882ae0328fffcf7668649dc999
Reviewed-on: http://git-master/r/68412
add code for handling register save/restore and clocks
disable/enable during suspend/resume
Bug: 862023
Change-Id: I7502fb4cd0db8be250e3fd9047d98e6ad5cafec1
Reviewed-on: http://git-master/r/65479
Rebase-Id: Rf83ed876bd330000b8778f832b0fddcfef954bb2
Bug: 862023
Change-Id: I74f6d8e14ca9c48cbbe272384c0821e880e59697
Reviewed-on: http://git-master/r/63259
Rebase-Id: Re4124a65167562191b9058455a20f941887fad54
add alsa control for voice call and add voice call dai link
Bug: 862023
Change-Id: I1fb45e0c987e93e90f631b09d7146852c141816f
Reviewed-on: http://git-master/r/62622
Rebase-Id: Rd6168ccb88d9758be4919d16aa972fbd27e7ee46
default playback path is established through the dam
so as to support mixing of system sounds during voice call and also
playing of connection and disconnection tones
Bug: 862023
Change-Id: Ia055e7372f4ca18d038db483c3657ee4bbbfb6ca
Reviewed-on: http://git-master/r/63816
Rebase-Id: R38a4b7b469f5c8cffdc9c53a4a1fb07c13b5a531
Bug: 862023
Change-Id: If5aaa1add08d1339a93a84c41ad1c98a24b63db5
Reviewed-on: http://git-master/r/62082
Rebase-Id: R7531465a6b899b9da52a2003cd6e07afb53961bf
Use tegra asoc util lock_rate API to lock pll_a, pll_a_out and mclk
settings whenever any DAI-link using these clocks is active. If any
dai-link fails to set clock due to another active dai-link it will
check if the current mclk rate is acceptable for it's purpose before
erroring out.
Also add hw_param ops for SPDIF dai-link.
Bug 872652
Change-Id: I6ef1a3b69745bdf85cb88f5fbccfb05c37e33c5d
Reviewed-on: http://git-master/r/63856
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rdf4d19ce1ff150dd5835c891dfed0cea16150016
Change SPDIF dai-link codec name from spdif-dit to spdif-dit.0 since
spdif-dit platform driver index has been changed from -1 to 0.
Bug 872652
Change-Id: I3a234e237149607346301bf1f19d5a2e7f9e69b6
Reviewed-on: http://git-master/r/61509
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rdd42749aae8eb8f8eb5afbf541ba1f780fca9316
Bug: 890385
Bug: 862023
Change-Id: I154ba0c016c058bd7c3ca04b496c3fce9639ea4f
Reviewed-on: http://git-master/r/59104
Tested-by: Scott Peterson <speterson@nvidia.com>
Rebase-Id: Re63b865dff15841a27d692a078c327fc84b7edfe
Fixed a typo in the names of the mic input.
Change-Id: Ib40672c44e57887389949f93f09b852188c8772a
Change-Id: Ifda29a75ccf2a160849090ceacbfdddd7d26808f
Reviewed-on: http://git-master/r/60005
Rebase-Id: Ra29a910c4737a1667d2640ce8cb9592ade7f1573
Fix invalid printf arguments in error handler.
Change-Id: I4d86ba0b00eb4ab7d04660c5c9cd69082ea7799f
Signed-off-by: Colin Patrick McCabe <cmccabe@nvidia.com>
Reviewed-on: http://git-master/r/59171
Reviewed-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R3786dda027d44f423ac2417c9f560761bd10ef10
Bug: 862023
Change-Id: I0302091654c5394733264712269be4fe0aefa39a
Reviewed-on: http://git-master/r/55466
Rebase-Id: R3c915a05a2f6bc90ff24d9ee6625dcadd92f93e8
Bug 872652
Change-Id: Ia35ba728859bcba1bff1ce73c622203d027bc8f9
Reviewed-on: http://git-master/r/54989
Tested-by: Gerrit_Virtual_Submit
Rebase-Id: Rd23d694c056cefb76669c510b1367128255f3835
Bug 862023
Change-Id: I715ce95e3cece3fc8eeea81ab6b95ad6de3b2a1c
Reviewed-on: http://git-master/r/50907
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Rebase-Id: R736182cd182138901b3f79b6fbfe3adee8ce7105
