path: root/sound/soc/tegra/tegra_spdif.c
2012-04-06ASoC: tegra: rename Tegra20-specific driver filesStephen Warren
Rename these files so they include a specific hardware version in their filenames. The contents is only touched minimally so that git's rename tracking operates correctly; renaming all symbols in the files results in a diff so large that the rename detection fails. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-01ASoC: tegra: remove open-coded clk reference countingStephen Warren
clk_enable/disable() already reference count the enable calls, so there's no need for the callers to do the same. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-01ASoC: tegra: register 'platform' from DAIs, get rid of pdevStephen Warren
Previously, the ASoC 'platform' (PCM/DMA) object was instantiated via a platform_device. This didn't represent the hardware well, since there was no separate hardware associated with this platform_device; it was a virtual device with sole purpose to call snd_soc_register_platform(). This mechanism required all board files to register this device, and all ASoC machine drivers to create and register this device when booting using device tree. This change removes the platform_device completely. Each Tegra DAI now registers the ASoC 'platform' itself. Machine drivers are adjusted for the new 'platform' name. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-28ASoC: Convert tegra_spdif to use module_platform_driver()Axel Lin
Use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23ASoC: Constify snd_soc_dai_ops structsLars-Peter Clausen
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure") introduced the possibility to have constant DAI ops structures, yet this is barley used in both existing drivers and also new drivers being submitted, although none of them modifies its DAI ops structure. The later is not surprising since existing drivers are often used as templates for new drivers. So this patch just constifies all existing snd_soc_dai_ops structs to eliminate the issue altogether. The patch was generated with the following coccinelle semantic patch: // <smpl> @@ identifier ops; @@ -struct snd_soc_dai_ops ops = +const struct snd_soc_dai_ops ops = { ... }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-02ASoC: Remove unused srate variable in tegra_spdif_hw_paramsAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-02ASoC: tegra: Staticise tegra_i2s_dai and tegra_spdif_daiAxel Lin
2011-07-05ASoC: Tegra: Implement SPDIF CPU DAIStephen Warren
This is a minimal driver for the Tegra SPDIF controller. In hardware, the SPDIF output signal is always routed to any active HDMI display controllers, and may also be routed to external pins on Tegra using the pinmux. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
