Use HDA HDMI audio now on Colibri T30 as well allowing for up to 7.1
multi-channel playback. Split board sound initialisation between Apalis
and Colibri T30 in order to distinguish better between default SPDIF
being supported out-of-the-box on Apalis vs. this being an optional
feature for the Colibri. Therefore remove SPDIF for the Colibri T30.
While at it add csus clock required for vi_sensor camera master clock
on Apalis T30 and clk_out_2/extern2 for Colibri T30, fix debug UART1
initialisation, get rid of spurious CONFIG_SND_USB enable and further
clean-up both board platform data files.
Fix issue with slow SPDIF clock by just doubling desired rate prior to
doing any further calculations on it.
BTW: A proper fix might involve overall clock doubler configuration.
The AC97 sampling rate is really fixed to 48 kHz at all times.
While at it clean-up dangerous time out handling.
Fix errors when registration fails, correctly unregister the
platform device.
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Prepare Kconfig for Colibri T30 ALSA SoC SGTL5000 board driver to be
usable on Apalis T30 as well.
sgtl5000 microphone gain only has 2 bits of resolution, so maximum value is 3.
From Eric Nelson:
"We also found that for the microphones we have here (commodity PC boom mics) a
default value of 2 for the gain gives the best results."
So change the default microphone gain as well.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
LINE_IN also needs VAG_POWER on or we may hear noise when directly
route LINE_IN to Headphone Mux.
Tested on imx28evk.
Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
Correct SGTL5000_CHIP_CLK_CTRL to SGTL5000_CHIP_REF_CTRL in
sgtl5000_restore_regs(), and add comment to explain the
restore order.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Signed-off-by: Zeng Zhaoming <zengzm.kernel@gmail.com>
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
As manual described, VAG is an internal voltage reference of DAC/ADC,
So enabled it before DAC/ADC up.
One more thing should care about is VAG fully ramped down requires 400ms,
wait it to avoid pop.
Give the correct number of entries to TLV_DB_RANGE_HEAD to prevent
reading more data than actually is in the array.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Ensure all mask bits are clear before setting new value.
Acked-by: Dong Aisheng <b29396@freescale.com>
Acked-by: Liam Girdwood <lrg@ti.com>
We have defined SGTL5000_LINREG_VDDD_MASK in sgtl5000.h,
use it instead of hardcoded (0x1 << 4) - 1 for the mask.
Otherwise calling ldo_regulator_remove() does not unregister regulator
and free memories.
According to the datasheet:
CHIP_MIC_CTRL 0x002A
BITS[9:8] BIAS_RESISTOR
0x0 = Powerd off
0x1 = 2.0 kohm
0x2 = 4.0 kohm
0x3 = 8.0 kohm
To set mic bias resistor, we need to update bits[9:8] of
SGTL5000_CHIP_MIC_CTRL register.
0x0 = Powerd off
0x1 = 2.0 kohm
0x2 = 4.0 kohm
0x3 = 8.0 kohm
Thus SGTL5000_BIAS_R_MASK should be defined as 0x0300 instead of 0x0200.
The module device table for of_device_id should use "of" type.
version.
sound/soc/codecs/sgtl5000.c
- select RT5640 ASoC support in Cardhu machine Kconfig
- enable RT5640 ASoC driver in tegra3_defconfig
- select RT5639 ASoC codec when selecting RT5640, othwise kernel
linking will fail
Bug 1190823
Change-Id: I1046c30667d4ca8276080f1b3174eccd0b25328c
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/168884
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Add configurability support for i2s parameters.
See 907bac80691c7df5b5b57cbf27f91e8bb1dcf434.
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
WAR to check souncard data's avp_id before trying to set
DMA address. An invalid avp_id can cause invlaid rtd, causing
panic in control ioctl calls.
Bug 1046249
Bug 1044761
Bug 1049940
Bug 1050152
Change-Id: Ib536220fdb92f8256c777d6fa14b66e47bc6b7be
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/134426
(cherry picked from commit 007fd7b1ae101c5be2a3d35ad11e7190862c04ca)
Reviewed-on: http://git-master/r/142493
GVS: Gerrit_Virtual_Submit
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Integrate ALSA SoC SGTL5000 codec on Toradex Colibri T30.
Removing tegra_gpio_enable and disable calls as they are supported
through set direction calls in the driver.
Activate microphone bias which is used to enable microphone ground on Colibri T20.
Merge with latest NVIDIA L4T R16.
Only real conflict concerning inverted VBUS gpio support.
Add support for setting of DMA address through alsa control for AVP
rendering. This is required to directly do DMA from IRAM to I2S.
Bug 1024403
Change-Id: I6b79ae6e9a562160a19d238b817e1a8b407ac208
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/127436
(cherry picked from commit f270f46bef98a56f44432e608041adb617c22559)
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Change-Id: I195aae9043f967273283579f44d5367fe73d542f
Reviewed-on: http://git-master/r/129159
Reviewed-by: Scott Peterson <speterson@nvidia.com>
It has now become necessary to use a DAPM mutex instead of the codec
mutex to lock the DAPM operations. This is due to the recent multi
component support and forth coming Dynamic PCM updates.
Currently we lock DAPM operations with the codec mutex of the calling
RTD context. However, DAPM operations can span the whole card context
and all components.
This patch updates the DAPM operations that use the codec mutex to
now use the DAPM mutex PCM subclass for all DAPM ops.
We also add a mutex subclass for DAPM init and PCM operations.
Signed-off-by: Liam Girdwood <lrg@ti.com>
(cherry picked from commit a73fb2df01866b772a48fab93401fe3edbe0b38d)
Updated call sequences
Bug 1039523
Change-Id: If079bbe5032971251d6b5426c752cbcc6ad6bcf5
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/128937
Bug 1034241
Change-Id: I205a74a8f27237470a3cd1266bb925971654459c
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/125280
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bug 1034241
Change-Id: Id0037f18afa58be82cbeeb43e97b606614fb8ba8
Reviewed-on: http://git-master/r/125273
Add support for latest TI codec aic326x driver.
Bug 1034241
Change-Id: I387693ed2de466d1704c6f7ff0a1b15c7cbff32f
Reviewed-on: http://git-master/r/125180
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Add latest TI aic326x driver.
Bug 1034241
Change-Id: I8457538025b2989c4baa5eaefef48bdd5535def9
Reviewed-on: http://git-master/r/125167
change 4b70cc537cadc787b748c7c246d703a240b08985 introduced
a compilation error.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Change-Id: I59e54537d9bb4b30e807478e5b7634db0813a739
Reviewed-on: http://git-master/r/120443
Reviewed-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
98088 codec register value is altered to fix no audio issue after
reset. Previously after reset the register value was getting wiped
out.
Bug 1017782
Change-Id: I060929bfb868c48dc4db9def171a3bdd167a3913
Reviewed-on: http://git-master/r/120319
Tested-by: Sayak Choudhury <sayakc@nvidia.com>
Reviewed-by: Vijay Mali <vmali@nvidia.com>
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
audio_clock_2x parent needs to be set first before
changing the rate, else it will not work.
Bug 1019017
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/116682
(cherry picked from commit fdc4da6d96e7be4aa2accf098de48543e745cf11)
Change-Id: I93aeb1afed8732e8a1b1cff4ab03b9a9f654804f
Reviewed-on: http://git-master/r/118250
Reviewed-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Add master/slave configurability support interface for
all codecs. Currently, complete slave mode functionality
is added only for MAX98088 and WM8903 codec only. By
default, board parameters will set i2s master mode for
all codecs.
asoc: tegra: utils: add support for i2s master/slave mode.
Support for i2s in master or slave mode is made generic by
obtaining information from platform data.
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: Ided0fcefb6cdb124b78aab423bfd8c7dccd4bf6e
Reviewed-on: http://git-master/r/111553
(cherry picked from commit bb1ad7222f9c75424a45976d16de418bc927dc04)
asoc: tegra: wm8903 machine: add support for i2s in slave mode.
Add support for i2s as slave for playback and capture use cases.
Change-Id: I1f6b73a0a1b690ecd311b0ff4107aadbb1f037d8
Reviewed-on: http://git-master/r/111472
(cherry picked from commit 0434f8ba74adefe60597d95d30a455b9b2ece9b8)
asoc: tegra: wm8753 machine: add support for i2s in slave mode.
Change-Id: Ib0596955cd0c6ac5ec57b0f3c6ecc9e4ed41268c
Reviewed-on: http://git-master/r/113208
(cherry picked from commit 0fc6b5e3a98d9f8866f73d7914b0c590334ce862)
asoc: tegra: aic326x machine: add support for i2s in slave mode.
Support for i2s in slave mode is added for playabck and capture
use cases.
Change-Id: I41f6459765f075703ad7f5f8dc9d4628dd853820
Reviewed-on: http://git-master/r/112874
(cherry picked from commit 9a89ede36a1dca6f53250444e819443fb6f28d09)
asoc: tegra: rt5640 machine: add support for i2s in slave mode.
Change-Id: I850ec62149b8a8d244445b70658b632dbce06558
Reviewed-on: http://git-master/r/112878
(cherry picked from commit 1d51561c8edf47d8557a825450a48ee8743a185b)
asoc: tegra: max98088 machine: add support for codec i2s as slave.
Add support for codec i2s as slave during voice Call.
(Bug 998682)
Change-Id: I8fc54d367e9acd5417d270869cb5a9398b3b527f
Reviewed-on: http://git-master/r/110559
(cherry picked from commit 78a490867e131b1cc892094ddd844c2b892cafb6)
asoc: tegra: max98095 machine: add support for i2s in slave mode.
Change-Id: I80944d403be94c55ad2ce31aea921d80ea7c088a
Reviewed-on: http://git-master/r/112875
Reviewed-on: http://git-master/r/118080
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Building an ac97 only configuration failed due to missing SND_SOC_TEGRA20_DAS.
While at it fix build time warning caused by two unused local variables.
Renamed P1852 machine driver to VCM so that can be used
for P1852/P852 and E1853 as well.
Bug 1008391
Reviewed-on: http://git-master/r/113886
(cherry picked from commit 5eb23e30bab716b28146b85438989e58761c7136)
Change-Id: I8d1363a6419c6381b8d23ebd38d625fb482084dc
Reviewed-on: http://git-master/r/116056
Add code for headset detection according to that
state transitions mentioned for JKSNS field in the
max98088 codec datasheet
Bug: 110529
Bug: 1008246
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/112127
(cherry picked from commit 12a2259e0e9cf7da4bf64bad2a97c32cec41477c)
Change-Id: I7d45b210dd02f181e71a08d9b3de7cff109dd88b
Reviewed-on: http://git-master/r/114445
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Change HW disabling dequence and I2S clock parent in slave mode
for voice call use-case
Bug: 1005176
Reviewed-on: http://git-master/r/110529
(cherry picked from commit 4b138cdeb3374575bde9f49d0c644faa91ced68f)
Change-Id: Ia037ed5ef45d38972c3e1e1a78b4b7b7f39d8f72
Reviewed-on: http://git-master/r/114444
Migrate AC97 audio capture aka record functionality.
Several compilation errors popped up when building the 3.1 kernel for
chrome. Warnings included callback structure changing and not being
updated in the max98095 codec driver and unused labels.
With these change I am able to compile in the max98095 codec support
and wm8903 without build errors.
Bug 986933
Change-Id: Ia8b2511f54b031eadcad8c74efa88be9288f25fb
Reviewed-on: http://git-master/r/105464
There is path through which registering a card will fail to probe,
but that error code is not propogated back to the tegra machine
driver. To catch this case in the machine driver's probe routine,
we need to ensure that after registering the card, the card is
instantiated and fail probe if not.
Change-Id: I64ba952685ef193a3b248502943771c518396808
Reviewed-on: http://git-master/r/106837
- For slave mode, clk_audio_2x needs to be
programmed to bitclock value. Setting this frequency
is not possible if the parent clock has different
frequency. Hence change the parent of this clock
to i2s_sync clock first before setting the rate.
- Fixed setting uninitialized variables.
Bug 948478
Change-Id: Ieb4656e6e114d3a9b815f44003a476c4b9892059
Reviewed-on: http://git-master/r/104445
Use the pcm-driver specified from platform/board
specified file.
Bug 991926
Change-Id: I9e4c9a3f76bacb22de817273a2281ac9b8959c43
Reviewed-on: http://git-master/r/105415
Ensure i2s_client_bits and i2s_audio_bits do not get used
uninitialized.
Bug 949219
Change-Id: Ibdd7f2598278639388d2c2afb5843f2471375ea2
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/105426
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Bug 964287
1) Add support for resetting the codec while entering in lp0
state to save codec power in lpo for KAI.
2) Fix for cache sync.
3) Add index sync functionality.
Change-Id: I04039eb55944bfe7f06e6a1405ac3c810c5688a1
Reviewed-on: http://git-master/r/104480
Tested-by: Daniel Solomon <daniels@nvidia.com>
