Bug 964287
1) Add support for resetting the codec while entering in lp0
state to save codec power in lpo for KAI.
2) Fix for cache sync.
3) Add index sync functionality.
Change-Id: I04039eb55944bfe7f06e6a1405ac3c810c5688a1
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/104480
GVS: Gerrit_Virtual_Submit
Tested-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Add alsa controls to specify which alsa device is used by AVP to render
audio. Also add support for disabling DMA interrupt when AVP renders
audio. Also add couple of alsa controls to query DMA channel ID and
DMA buffer physical address.
Bug 968814
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Change-Id: If593329db72bf00d97f7433f5c54e13500281253
Reviewed-on: http://git-master/r/97916
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Bug 949219
Change-Id: Ic8976b008772220299369369427a80dd370df596
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/104419
Bug 949219
Change-Id: If7b4dd928cc5a808fd1a674bcc5f31c9a396a043
Reviewed-on: http://git-master/r/103772
Reviewed-by: Simone Willett <swillett@nvidia.com>
The extern1 codec clock was not getting switched off whenever
codec goes below BIAS_OFF level. Moreover, there were two
instances of extern1 clock whenever codec was on. Reason behind
this was that, those codecs for which probe function was called
and were not present on board, turned on their extern1 clock, but
clean up routine (for switch device register failure) was not able
to turn off the clock. With this change, a conditional check is
put to turn off the clock.
(Bug 984678)
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: I585ecf73c0cabca856592dcd84e67588dfe13beb
Reviewed-on: http://git-master/r/104073
Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Pass TDM mode variables for CPU dai.
Codec Id is not passed properly, hence use dual instances
of the dai_link operations.
Bug 948478
Change-Id: I13188d5001b8f9c2f2f67ee7a9d3bec89311037d
Signed-off-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-on: http://git-master/r/103793
Reviewed-by: Nitin Pai <npai@nvidia.com>
Added TDM mode support in I2S driver.
Added support functions in AHUB to pass audio/client bits.
Added support functions in AHUB to pass audio/client channels.
Fixed the stopping of I2S/TDM by clearing the fifo.
Bug 948478
Signed-off-by: Nitin Pai <npai@nvidia.com>
Change-Id: I560f4ab5b71e4833931934275272a094241241fe
Reviewed-on: http://git-master/r/103840
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
disable the compilation of minidsp specific code,
we are disabling the minidsp in codec because the driver is
not stable and different customers are using different process flows
for mini dsp
Change-Id: I08f8f485f1a379773f2f1f7ae2fd1b3a89c45d07
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/101232
Allow setting bias level to turn off clock extern1 when codec
is idle for enterprise board. (Maxim 98088 codec)
Bug 984678
Change-Id: Ib01be71362ab0c5525f570693b41db73777875e6
Reviewed-on: http://git-master/r/102240
Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com>
Associated with I2S there is a playback ref count, when
we open the I2S for plyabck it is incremented and during
voice call we check if its not zero then enable the tX.
This logic fails if the start-trigger is not called for the prior
playback stream. Hence we unconditionally enable the tx,
which is harmless
Bug: 981806
Change-Id: I66aafda596e2b2b03745e93f3e851dedc3b8ef5d
Reviewed-on: http://git-master/r/101996
Allow setting bias level to turn off clock extern1 on enterprise
when codec is idle. Added a dummy widget to make the
target_bias_level to BIAS_OFF as per required by the new ALSA
kernel.
Bug 984678
Change-Id: I29de405c26286eee0a49e655f1d4236f6093ce8a
Reviewed-on: http://git-master/r/100287
is idle for Enterprise (Maxim 98088 codec).
Bug 984678
Change-Id: I09538dafe6c6f01547ff989de3c23933c9745db0
Reviewed-on: http://git-master/r/100286
Bug 949219
Change-Id: I9c2a0aa22432c586a7e72273ad935d42332e873f
Reviewed-on: http://git-master/r/95087
This reverts commit dfa00e184b5fe0d4d48fa62a15fc956de9b6b65c.
This is causing a regresssion.
Bug: 977319
Change-Id: I4fe6daf88b2988978f089194f2931691eeb0eb09
Reviewed-on: http://git-master/r/101687
Reviewed-by: Vijaya Bhaskar <vbhaskar@nvidia.com>
This reverts commit 774fa71fc9834fbdcb297048d9e9a4bc7b944b48
Change-Id: Ib187dff51d3b2fd2b2ac0c98a53abe07c99148aa
Reviewed-on: http://git-master/r/101359
bug 949219
Change-Id: I4409eaff4042967133cc948452ca8e52d15b2d18
Reviewed-on: http://git-master/r/92279
If there is no dma information exit from trigger, this is required
for the dummy voice call playback and capture streams
Change-Id: I5276e7ebb72c17268a9785204fea9f395b2e5d3a
Reviewed-on: http://git-master/r/101235
Use non-inverting type alsa control for headphones as same have
been used for spk and recv
Change-Id: I39d2613071063782dff8151b07ef46ca8e16db5c
Reviewed-on: http://git-master/r/101234
disable the flags for turning off the mini dsp support
Change-Id: Ieb0b18fc3cc1143cbd0a315c85688d2f1ae4efe1
Reviewed-on: http://git-master/r/101233
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Change-Id: I0931f4ef7a5464dd32d8c703288a137fc77857ce
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/100090
Allow setting bias level to turn off clock extern1 on KAI when
codec is idle. Added a dummy widgets to make the target_bias_level
to BIAS_OFF as per required by the new ALSA kernel.
Bug 964287
Change-Id: I628744040866a9879eedc41ed4ee25af38ed86fb
Reviewed-on: http://git-master/r/99667
Tested-by: Hunk Lin <hulin@nvidia.com>
is idle.
Bug 964287
Change-Id: I48056b86a9fdaea70202bee9326debaaddf69c0c
Reviewed-on: http://git-master/r/99665
is idle.
Bug 964287
Reviewed on: http://git-master/r/#change,93950
Change-Id: Icc11e8bfb359b432f0bfd9ba214877259188de2b
Reviewed-on: http://git-master/r/99659
condition to check bit-format is always false
because TEGRA20_I2S_CTRL_BIT_FORMAT_I2S is zero.
Bug 947429
Change-Id: Ieb92f0732b092100dc1bf323ad60aff4439d5b3d
Signed-off-by: Jubeom Kim <jubeomk@nvidia.com>
Reviewed-on: http://git-master/r/99341
Modified existing pcm driver to take dma mode/ hw structure.
Exported the functions needed for other pcm mode driver.
Added new TDM mode hw param structure.
Added pass SINGLE/DOUBLE buffered dma mode params.
Bug 948478
Change-Id: I58309d52748f813b3303a8d6a052fbb6cc7ca87a
Reviewed-on: http://git-master/r/99146
Add Support to detect the HP insertion or removal during
LP0 state.
Bug 969405
Change-Id: Ibedf1769338e16877240ea9cc82fa7469eb7ff9e
Reviewed-on: http://git-master/r/98745
Instead of always using 2 dma_req count pass max dma_req_count
through a macro. Ensure dma_req_count does not cross
period_count.
Bug 968814
Change-Id: Iddfbd77017992ccb8c90441213e191133dadb347
Reviewed-on: http://git-master/r/97915
Change prototype of tegra_asoc_utils_init to pass snd_soc_card handle.
It is needed to move common tegra machine driver codes to
tegra_asoc_utils interface.
Bug 968814
Change-Id: I98490ffdda51cf7d0b89adadb23c31892183bc0e
Reviewed-on: http://git-master/r/97914
Bug 948478
Change-Id: I246942b3a07ffcfbcfafbc820208190bd3acc5d4
Reviewed-on: http://git-master/r/98456
bug 949219
Change-Id: I52969e8dd1a5ed4dc76ac360ec08b0afb18cd4a5
Reviewed-on: http://git-master/r/92833
The bias control must be done after the default register value
been restored.
Bug 964400
Change-Id: Iefbd96506573d5ea0e1b3123bb34c38e34e75068
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Reviewed-on: http://git-master/r/96658
1. Use rt5639/40 internal clk source during jack insert detection.
2. Add delay to 100ms.
Bug 955019
Reviewed-on: http://git-master/r/93510
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
(cherry picked from commit 4c07fc1b10ac8abbbf167952071e47aa6179a635)
Change-Id: I4021232674f5432392dc013ddc76c3bf08b44ed0
Reviewed-on: http://git-master/r/95874
Tested-by: Manoj Gangwal <mgangwal@nvidia.com>
use common platform data for machine driver
Change-Id: I90e0d2f47aed46da650305d98f6525287adfaf04
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/95101
replace platform specific data with common platform data
Change-Id: Ie34b9b9288bf76a004db0bcdf4fd59845e0c9d71
Reviewed-on: http://git-master/r/95083
check max98095_reset() return value, this function fails if codec
read/write fails.
Change-Id: I4dddd75e0870e4168288396a462133f7287ad72e
Reviewed-on: http://git-master/r/95078
Add support to customize modem parameters for voice call.
Change-Id: I947bf1955713c4ae19e5dd829091bd7e51bca08f
Reviewed-on: http://git-master/r/93091
Enable/disable the ext mic depending on the jack notification
for insertion/removal comes.This is done to save the Audio power.
Bug 955019
(cherry picked from commit 7a22037fd4a274637a5bdb18a8c5452fe58aad32)
Change-Id: I1a8b47c4e9c424a914f546b48c86a6fb07d8e42a
Reviewed-on: http://git-master/r/93956
Drive ext mic gpio (active low) to 1 during init. It will
be toggled as needed by ext mic events.
Bug 949026
Signed-off-by: Daniel Solomon <daniels@nvidia.com>
(cherry picked from commit de806c193fde5cd8c5b0285efeeaef4adb7be611)
Change-Id: Idd72830d89ebe080739694d7f2c8f6ad80d5cdf5
Reviewed-on: http://git-master/r/93955
Allow bias off in order to turn off clock extern1 when codec
is not used.
Bug 957635
(cherry picked from commit adc6929ab3170acd6a0b2cee4f65fa20a1c1d30f)
Change-Id: I4f2e91b0cd9bb4516a5722d2df268f08e78f92e2
Reviewed-on: http://git-master/r/93949
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline commit
16052827d98fbc13c31ebad560af4bd53e2b4dd5
Change-Id: I929a49556539621a0546829e88b3caa498c94be2
Reviewed-on: http://git-master/r/94463
To terminate request from dma, use the tegra_dma_cancel() inplace of
tegra_dma_dequeue().
The api tegra_dma_dequeue() is getting to be obsolete.
Change-Id: Id2a888a726086fb1e4ade04ac047442554188bee
Reviewed-on: http://git-master/r/91754
fix i2s for BT Sco.
Bug 936626
Change-Id: Iaf1d1a230fcb37d45d9deaaf1dae780f5870e99f
Reviewed-on: http://git-master/r/92860
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
bug 949219
Change-Id: I8abd1e837a774d15aef25ec8c40b857b8cba0426
Reviewed-on: http://git-master/r/92858
Few boards which uses wm8903 has independent regulators
for spk and mic while others do not have it.
For the boards which do not have independent regulators
we should avoid getting their regulators otherwise we
would get the following error messages:
"tegra-snd-wm8903 tegra-snd-wm8903.0: No speaker regulator found"
"tegra-snd-wm8903 tegra-snd-wm8903.0: No digital mic regulator found"
Bug 956562
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ide1ce141b5d45d56e834dc82a7cf5a7adc6c3e80
Reviewed-on: http://git-master/r/91548
Removing legacy i2s/spdif driver from tree.
These files are added to support customer projects prior
to moving over to alsa driver for audio.
There is no intention of using them and hence removing it.
Change-Id: I864dbc50e2e76ac16f40542460f63c8c8a0eff71
Reviewed-on: http://git-master/r/91758
use common platform data instead of using codec specific platform
data for different codecs
Change-Id: I88ecb08f3945e0d9c5162ec2b2d3279a4da50099
Reviewed-on: http://git-master/r/91686
add voice call, bt voice call, voice call with system sound mix,
bt voice call with system sound mix, voice call recording,
bt voice call recording functionalities for ti aic326x on ap30
Change-Id: Ia94c1586c30d0636d8de738ff6cbb716f4f79d16
Reviewed-on: http://git-master/r/90123
check for revision id, it must be 0x40 as per the datasheet,
if its not 0x40 then dont allow the card to register by failing
in the codec probe. This functionality will be required when the
same board support multiple codecs. Also register the irq only
after validating the codec.
Change-Id: I8553b85d534428c7137ec2d03e2f814b898609a6
Reviewed-on: http://git-master/r/90061
If card fails to instantiate then unregister the card
Change-Id: Ibcc0d505a8df48c1f924a3d8688dc23e362d5e8d
Reviewed-on: http://git-master/r/90060
If switch registration is success and later card registration
fails then we must unregister the switch
Change-Id: I140b3fb0890f41fea653100bcff450f10294cd9d
Reviewed-on: http://git-master/r/90058
