path: root/sound/soc
2011-06-24Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-06-24ALSA: Remove unneeded version.h includes from sound/Jesper Juhl
In the sound/ directory there are two files (flagged by 'make versioncheck'); sound/pci/asihpi/asihpi.c and sound/soc/codecs/wm8991.c that include linux/version.h although they don't need it. This patch removes the unneeded includes. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-23ASoC: pxa-ssp: Correct check for stream presenceDaniel Mack
Don't rely on the codec's channels_min information to decide wheter or not allocate a substream's DMA buffer. Rather check if the substream itself was allocated previously. Signed-off-by: Daniel Mack <zonque@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-06-23ASoC: imx: add missing module informationsArnaud Patard (Rtp)
- add some modules aliases - add module license to avoid tainted kernel when loading the imx-pcm-audio driver Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-23ASoC: imx: Remove unused Kconfig SND_MXC_SOC_SSI entryArnaud Patard (Rtp)
SND_MXC_SOC_SSI looks to be unused, so kill it. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-13ASoC: Remove unused and about to be broken SND_SOC_CUSTOM I/O busMark Brown
This will be removed in -next so let's drop it from mainline as soon as we can in order to minimise surprises. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-10Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-06-10ASoC: SAMSUNG: Fix the incorrect referencing of I2SCON registerSangbeom Kim
If DMA active status should be checked, I2SCON register should be referenced. In this patch, Fix the incorrect referencing of I2SCON register. Reported-by : Lakkyung Jung <lakkyung.jung@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-06-09ASoC: snd_soc_new_{mixer,mux,pga} make sure to use right DAPM contextLars-Peter Clausen
Currently it is possible that snd_soc_new_{mixer,mux,pga} is called with a DAPM context not matching the widgets context. This can lead to a wrong prefix_len calculation, which will result in undefined behaviour. To avoid this always use the DAPM context from the widget itself. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-06-09ASoC: fsl: fix initialization of DMA buffersTimur Tabi
The DMA (PCM) driver used by some Freescale PowerPC supports separate DAIs for playback and capture, so DMA buffers should be allocated only for the initialized streams. Instead of checking for the number of active channels, which apparently is not reliable, check to see if the actual stream object exists. Also provide a better name for the DMA interrupt. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-09ASoC: WM8804 does not support sample rates below 32kHzMark Brown
Reported-by: Kieran O'Leary <Kieran.O'Leary@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Cc: stable@kernel.org
2011-06-08ASoC: Fix WM8962 headphone volume update for use of advanced cachesMark Brown
2011-06-07ASoC: Blackfin: bf5xx-ad1836: Fix codec device nameLars-Peter Clausen
Fix the codec_name field of the dai_link to match the actual device name of the codec. Otherwise the card won't be instantiated. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-06-06ASoC: AD1836: Fix setting the PCM formatLars-Peter Clausen
2011-06-06ASoC: Check for NULL register bank in snd_soc_get_cache_val()Mark Brown
2011-06-06ASoC: Add missing break in WM8915 FLL source selectionMark Brown
2011-06-06ASoC: Only update SYSCLK_ENA when pausing WM8915 SYSCLKMark Brown
2011-06-06Merge branch 'for-3.0' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into for-3.0
2011-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: usb - turn off de-emphasis in s/pdif for cm6206 ALSA: asihpi: Use angle brackets for system includes ALSA: fm801: add error handling if auto-detect fails ALSA: hda - Check pin support EAPD in ad198x_power_eapd_write ALSA: hda - Fix HP and Front pins of ad1988/ad1989 in ad198x_power_eapd() ALSA: 6fire: Don't leak firmware in error path ASoC: Fix wm_hubs input PGA ZC bits ASoC: Fix dapm_is_shared_kcontrol so everything isn't shared
2011-06-06Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-06-04Revert "ASoC: Update cx20442 for TTY API change"Linus Torvalds
This reverts commit ed0bd2333cffc3d856db9beb829543c1dfc00982. Since we reverted the TTY API change, we should revert the ASoC update to it too. Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-03ASoC: atmel_ssc: Don't try to free ssc if request failedJoachim Eastwood
We should only call ssc_free() when ssc_request() succeeds or bad things will happen. Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-27Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (45 commits) ARM: 6945/1: Add unwinding support for division functions ARM: kill pmd_off() ARM: 6944/1: mm: allow ASID 0 to be allocated to tasks ARM: 6943/1: mm: use TTBR1 instead of reserved context ID ARM: 6942/1: mm: make TTBR1 always point to swapper_pg_dir on ARMv6/7 ARM: 6941/1: cache: ensure MVA is cacheline aligned in flush_kern_dcache_area ARM: add sendmmsg syscall ARM: 6863/1: allow hotplug on msm ARM: 6832/1: mmci: support for ST-Ericsson db8500v2 ARM: 6830/1: mach-ux500: force PrimeCell revisions ARM: 6829/1: amba: make hardcoded periphid override hardware ARM: 6828/1: mach-ux500: delete SSP PrimeCell ID ARM: 6827/1: mach-netx: delete hardcoded periphid ARM: 6940/1: fiq: Briefly document driver responsibilities for suspend/resume ARM: 6938/1: fiq: Refactor {get,set}_fiq_regs() for Thumb-2 ARM: 6914/1: sparsemem: fix highmem detection when using SPARSEMEM ARM: 6913/1: sparsemem: allow pfn_valid to be overridden when using SPARSEMEM at91: drop at572d940hf support at91rm9200: introduce at91rm9200_set_type to specficy cpu package at91: drop boot_params and PLAT_PHYS_OFFSET ...
2011-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits) ASoC: Fix power down for widgetless per-card DAPM context case ASoC: wm1250-ev1: Define "WM1250 Output" with SND_SOC_DAPM_OUTPUT ASoC: Remove duplicate linux/delay.h inclusion. ASoC: sam9g20_wm8731: use the proper SYSCKL value ASoC: wm8731: fix wm8731_check_osc() connected condition ALSA: hda - Reorganize controller quriks with bit flags ALSA: hda - Use snd_printd() in snd_hda_parse_pin_def_config() ALSA: core: remove unused variables. ALSA: HDA: Increase MAX_HDMI_PINS ALSA: PCM - Don't check DMA time-out too shortly MAINTAINERS: add FireWire audio maintainer ALSA: usb-audio: more control quirks for M-Audio FastTrack devices ALSA: usb-audio: add new quirk type QUIRK_AUDIO_STANDARD_MIXER ALSA: usb-audio: export snd_usb_feature_unit_ctl ALSA: usb-audio: rework add_control_to_empty() ALSA: usb-audio: move assignment of chip->ctrl_intf ALSA: hda - Use model=auto for Lenovo G555 ALSA: HDA: Unify HDMI hotplug handling. ALSA: hda - Force AD1988_6STACK_DIG for Asus M3N-HT Deluxe ASoC: core - remove superfluous new line. ...
2011-05-27ASoC: Fix wm_hubs input PGA ZC bitsMark Brown
2011-05-27ASoC: Fix dapm_is_shared_kcontrol so everything isn't sharedStephen Warren
Commit af46800 ("ASoC: Implement mux control sharing") introduced function dapm_is_shared_kcontrol. When this function returns true, the naming of DAPM controls is derived from the kcontrol_new. Otherwise, the name comes from the widget (and possibly a widget's naming prefix). A bug in the implementation of dapm_is_shared_kcontrol made it return 1 in all cases. Hence, that commit caused a change in control naming for all controls instead of just shared controls. Specifically, a control is always considered shared because it is always compared against itself. Solve this by never comparing against the widget containing the control being created. Equally, controls should never be shared between DAPM contexts; when the same codec is instantiated multiple times, the same kcontrol_new will be used. However, the control should no be shared between the multiple instances. I tested that with the Tegra WM8903 driver: * Shared is now mostly 0 as expected, and sometimes 1. * The expected controls are still generated after this change. However, I don't have any systems that have a widget/control naming prefix, so I can't test that aspect. Thanks for Jarkko Nikula for pointing out how to fix this. Reported-by: Liam Girdwood <lrg@ti.com> Tested-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-26Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (57 commits) regulator: Fix 88pm8607.c printk format warning input: Add support for Qualcomm PMIC8XXX power key input: Add Qualcomm pm8xxx keypad controller driver mfd: Add omap-usbhs runtime PM support mfd: Fix ASIC3 SD Host Controller Configuration size mfd: Fix omap_usbhs_alloc_children error handling mfd: Fix omap usbhs crash when rmmoding ehci or ohci mfd: Add ASIC3 LED support leds: Add ASIC3 LED support mfd: Update twl4030-code maintainer e-mail address mfd: Correct the name and bitmask for ab8500-gpadc BTempPullUp mfd: Add manual ab8500-gpadc batt temp activation for AB8500 3.0 mfd: Provide ab8500-core enumerators for chip cuts mfd: Check twl4030-power remove script error condition after i2cwrite mfd: Fix twl6030 irq definitions mfd: Add phoenix lite (twl6025) support to twl6030 mfd: Avoid to use constraint name in 88pm860x regulator driver mfd: Remove checking on max8925 regulator[0] mfd: Remove unused parameter from 88pm860x API mfd: Avoid to allocate 88pm860x static platform data ...
2011-05-26Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (33 commits) OMAP3: PM: Boot message is not an error, and not helpful, remove it OMAP3: cpuidle: change the power domains modes determination logic OMAP3: cpuidle: code rework for improved readability OMAP3: cpuidle: re-organize the C-states data OMAP3: clean-up mach specific cpuidle data structures OMAP3 cpuidle: remove useless SDP specific timings usb: otg: OMAP4430: Powerdown the internal PHY when USB is disabled usb: otg: OMAP4430: Fixing the omap4430_phy_init function usb: musb: am35x: fix compile error when building am35x usb: musb: OMAP4430: Power down the PHY during board init omap: drop board-igep0030.c omap: igep0020: add support for IGEP3 omap: igep0020: minor refactoring omap: igep0020: name refactoring for future merge with IGEP3 omap: Remove support for omap2evm arm: omap2plus: GPIO cleanup omap: musb: introduce default board config omap: move detection of NAND CS to common-board-devices omap: use common initialization for PMIC i2c bus omap: consolidate touch screen initialization among different boards ...
2011-05-26mfd: Use mfd cell platform_data for wm8400 cells platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Use mfd cell platform_data for davinci cells platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Cc: Miguel Aguilar <miguel.aguilar@ridgerun.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Use mfd cell platform_data for twl4030 codec cells platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Use mfd cell platform_data for wl1273 cells platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Cc: Matti Aaltonen <matti.j.aaltonen@nokia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26ASoC: Fix power down for widgetless per-card DAPM context caseJarkko Nikula
Commit 52ba67b ("ASoC: Force all DAPM contexts into the same bias state") powers up all the DAPM contexts in a card if any DAPM context becomes active. Unfortunately power down newer happens if per-card DAPM context doesn't have any widgets. Reason for this is that power state of per-card DAPM context without widgets is never cleared and thus all the DAPM contexts remain permanently active. Test for widgetless calling DAPM context in dapm_power_widgets() doesn't work for per-card DAPM context since power change is never originating from widgetless per-card DAPM context. Fix this by pre-clearing power state flag of non-codec DAPM context at the beginning of power sequence. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-26ASoC: wm1250-ev1: Define "WM1250 Output" with SND_SOC_DAPM_OUTPUTAxel Lin
Codec output pin should be defined with SND_SOC_DAPM_OUTPUT. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-26ASoC: Remove duplicate linux/delay.h inclusion.Jesper Juhl
It's enough to include linux/delay.h just once in sound/soc/codecs/wm8915.c, so remove the duplicate. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-26ASoC: sam9g20_wm8731: use the proper SYSCKL valueNicolas Ferre
at91sam9g20 is providing master clock to wm8731: not using a crystal but an external MCLK. We can avoid conflict and save power using WM8731_SYSCLK_MCLK as we do not need oscillator to be powered. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-26ASoC: wm8731: fix wm8731_check_osc() connected conditionNicolas Ferre
The crystal oscillator is only enabled if the WM8731_SYSCLK_XTAL master clock is specified. Fix the connected() struct snd_soc_dapm_route function to take this into account. Oscillator is not enabled on machine that need it otherwise. Machine drivers have to make sure that they use the proper SYSCLK value. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-25Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/Kconfig arch/arm/mach-exynos4/mach-nuri.c
2011-05-25ASoC: core - remove superfluous new line.Liam Girdwood
Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-24ASoC: core - fix module reference counting for CPU DAIsLiam Girdwood
Currently CODEC and platform drivers have their module reference count incremented soc_probe_dai_link() whilst CPU DAI drivers have their reference count incremented in soc_bind_dai_link(). CPU DAIs should have their reference count incremented in soc_probe_dai_link() just like the CODEC and platform drivers. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-24ASoC: fix raumfeld platformDaniel Mack
Commit f0fba2ad (ASoC: multi-component - ASoC Multi-Component Support) broke support for Raumfeld platforms as it didn't take into account the different hardware features on individual devices. In particular, Raumfeld speakers have no S/PDIF output, so the members of the snd_soc_card struct must be set dynamically. Signed-off-by: Daniel Mack <zonque@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-05-24Merge branch 'for_2.6.40/pm-cleanup' of ↵Tony Lindgren
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-22Merge branch 'topic/asoc' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into for-2.6.40
2011-05-22ASoC: core: Don't set "(null)" as a driver nameJarkko Nikula
Commit 22de71b ("ASoC: core - allow ASoC more flexible machine name") writes "(null)" to driver name string in struct snd_card if card->driver_name is NULL. This causes segmentation faults with some user space ALSA utilities like aplay and arecord. Fix this by using the card->name if no driver name is specified. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-20ASoC: Tegra: Fix compile when debugfs not enabledStephen Warren
The prototype of the inline dummy version of tegra_i2s_debug_add was not consistent with the real version. Reported-by: Rhyland-Klein <rklein@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-20ASoC: spdif-dit: Add missing MODULE_*Stephen Warren
MODULE_ALIAS is required so that the module will auto-load based on a platform_device registration in the board file. While we're at it, add some other MODULE_*. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-20Merge branch 'for-2.6.40' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
2011-05-19ASoC: davinci-mcasp: enable ping-pong SRAM buffersBen Gardiner
The davinci-i2s driver copies the platform data for playback and capture sram sizes which is in turn used by davinci-pcm to allocate ping-pong buffers. Copy also the platform data in davinci-mcasp probe. Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-05-19ASoC: add iPAQ hx4700 machine driverDmitry Artamonow
AK4641 connected via I2S and I2C, jack detection via GPIO. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
