path: root/sound/soc
2011-08-08Merge branch 'wm8996-rename' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into fix/asoc
2011-08-08ASoC: Acknowledge WM8996 interrupts before acting on themMark Brown
This closes the small race between a status being read in response to an interrupt and clearing the interrupt, meaning that if the status changes between those periods we might not get a reassertion of the interrupt. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-08ASoC: Rename WM8915 to WM8996Mark Brown
For marketing reasons the part will be called WM8996. In order to avoid user confusion rename the driver to reflect this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: asihpi - Clarify adapter index validity check ALSA: asihpi - Don't leak firmware if mem alloc fails ALSA: rtctimer.c needs module.h ASoC: Fix txx9aclc.c build ALSA: hdspm - Add firmware revision 0xcc for RME MADI ALSA: hdspm - Fix reported external sample rate on RME MADI and MADIface ALSA: hdspm - Provide MADI speed mode selector on RME MADI and MADIface ALSA: sound/core/pcm_compat.c: adjust array index
2011-08-03ASoC: sgtl5000: fix cache handlingWolfram Sang
Cache handling in this driver is broken. The chip has 16-bit registers, yet the register numbers also increase by 2 per register, i.e. there are only even-numbered registers. The cache in this driver, though, simply increments register numbers, so it does need some mapping as seen in sgtl5000_restore_regs(), note the '>> 1': snd_soc_write(codec, SGTL5000_CHIP_LINREG_CTRL, cache[SGTL5000_CHIP_LINREG_CTRL >> 1]); That, of course, won't work with snd_soc_update_bits(). (Thus, we won't even notice the missing register 0x1c in the default regs which shifted all follwing registers to wrong values.) Noticed on the MX28EVK where enabling the regulators simply locked up the chip. Refactor the routines and use a properly sized default_regs array which matches the register layout of the underlying chip, i.e. create a truly flat cache. This also saves some code which should make up for the bigger array a little. When soc-core will somewhen have another cache type which handles a step size, this conversion will also ease the transition. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Dong Aisheng <b29396@freescale.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-08-02Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-07-29ASoC: Disable wm_hubs periodic DC servo updateMark Brown
This does not function correctly in all circumstances so disable the periodic updates unconditionally for stable; a future patch will reenable where appropriate. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-07-29ASoC: Fix txx9aclc.c buildRalf Baechle
552d1ef6b5a98d7b95959d5b139071e3c90cebf1 [ASoC: core - Optimise and refactor pcm_new() to pass only rtd] breaks compilation of txx9aclc.c: CC [M] sound/soc/txx9/txx9aclc.o /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c: In function 'txx9aclc_pcm_new': /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c:318:3: error: 'card' undeclared (first use in this function) /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c:318:3: note: each undeclared identifier is reported only once for each function it appears in make[5]: *** [sound/soc/txx9/txx9aclc.o] Error 1 Fixed by providing a definition for card. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (22 commits) ALSA: hda - Cirrus Logic CS421x support ALSA: Make pcm.h self-contained ALSA: hda - Allow codec-specific set_power_state ops ALSA: hda - Add post_suspend patch ops ALSA: hda - Make CONFIG_SND_HDA_POWER_SAVE depending on CONFIG_PM ALSA: hda - Make sure mute led reflects master mute state ALSA: hda - Fix invalid mute led state on resume of IDT codecs ASoC: Revert "ASoC: SAMSUNG: Add I2S0 internal dma driver" ALSA: hda - Add support of the 4 internal speakers on certain HP laptops ALSA: Make snd_pcm_debug_name usable outside pcm_lib ALSA: hda - Fix DAC filling for multi-connection pins in Realtek parser ASoC: dapm - Add methods to retrieve snd_card and soc_card from dapm context. ASoC: SAMSUNG: Add I2S0 internal dma driver ASoC: SAMSUNG: Modify I2S driver to support idma ASoC: davinci: add missing break statement ASoC: davinci: fix codec start and stop functions ASoC: dapm - add DAPM macro for external enum widgets ASoC: Acknowledge WM8962 interrupts before acting on them ASoC: sgtl5000: guide user when regulator support is needed ASoC: sgtl5000: refactor registering internal ldo ...
2011-07-26Merge branch 'next/devel2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits) OMAP: Add debugfs node to show the summary of all clocks OMAP2+: hwmod: Follow the recommended PRCM module enable sequence OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming OMAP2+: PM: idle clkdms only if already in idle OMAP2+: clockdomain: add clkdm_in_hwsup() OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition() OMAP4: hwmod: Introduce the module control in hwmod control OMAP4: cm: Add two new APIs for modulemode control OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure OMAP4: hwmod data: Add PRM context register offset OMAP4: prm: Remove deprecated functions OMAP4: prm: Replace warm reset API with the offset based version OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros OMAP: hwmod: Wait the idle status to be disabled OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros OMAP2+: hwmod: Init clkdm field at boot time OMAP4: hwmod data: Add clock domain attribute OMAP4: clock data: Add missing divider selection for auxclks ...
2011-07-26Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-25Merge branch 'next/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (35 commits) ARM: msm: platsmp: determine number of CPU cores at boot time ARM: Tegra: Seaboard: Fix I2C bus numbering for ADT7461 ARM: Tegra: Trimslice: Tri-state DAP3 pinmux ARM: orion5x: fixup 5181 MPP mask check ARM: mxs-dma: include <linux/dmaengine.h> ARM: i.MX53: consistently use MX53_UART_PAD_CTRL for uart txd/rxd/rts/cts ARM: i.MX53: UARTn_CTS pin should not change RTS input select ARM: i.MX53: UARTn_TXD pin should not change RXD input select ARM: mx25: Fix typo on CAN1_RX pad setting iomux-mx53: add missing 'IOMUX_CONFIG_SION' for some I2C pad definitions ARM: NUC93X: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: LPC32XXX: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: CNS3XXX: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: i.MX53: Fix IOMUX type o's ARM i.MX dma: Fix burstsize settings mach-mx5: fix the I2C clock parents ARM: mxs/tx28: according to the TX28's datasheet D4-D7 are not used for MMC0 ARM i.MX23/28: platform-mxsfb: Add missing include of linux/dma-mapping.h ARM: mx53: Fix some interrupts marked as reserved. MXC: iomux-v3: correct NO_PAD_CTRL definition ... Fix up trivial conflict in arch/arm/mach-imx/mach-mx31_3ds.c
2011-07-24ASoC: Revert "ASoC: SAMSUNG: Add I2S0 internal dma driver"Mark Brown
This reverts commit d7c3e9525ac8e898f1156a1f3a7c5038f6560186 as it does not currently build due to missing dependencies in the Samsung tree. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-07-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (297 commits) ALSA: asihpi - Replace with snd_ctl_boolean_mono_info() ALSA: asihpi - HPI version 4.08 ALSA: asihpi - Add volume mute controls ALSA: asihpi - Control name updates ALSA: asihpi - Use size_t for sizeof result ALSA: asihpi - Explicitly include mutex.h ALSA: asihpi - Add new node and message defines ALSA: asihpi - Make local function static ALSA: asihpi - Fix minor typos and spelling ALSA: asihpi - Remove unused structures, macros and functions ALSA: asihpi - Remove spurious adapter index check ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macro ALSA: asihpi - DSP code loader API now independent of OS ALSA: asihpi - Remove controlex structs and associated special data transfer code ALSA: asihpi - Increase request and response buffer sizes ALSA: asihpi - Give more meaningful name to hpi request message type ALSA: usb-audio - Add quirk for Roland / BOSS BR-800 ALSA: hda - Remove a superfluous argument of via_auto_init_output() ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecs ALSA: hda - Add documentation for codec-specific mixer controls ...
2011-07-22Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/imx: add device tree probe support spi/imx: copy gpio number passed by platform data into driver private data spi/imx: use soc name in spi device type naming scheme spi/imx: merge type SPI_IMX_VER_0_7 into SPI_IMX_VER_0_4 spi/imx: do not use spi_imx2_3 to name SPI_IMX_VER_2_3 function and macro spi/imx: use mx21 to name SPI_IMX_VER_0_0 function and macro spi/imx: do not make copy of spi_imx_devtype_data spi/dw: Add spi number into spi irq desc spi/tegra: Use engineering names in DT compatible property spi/fsl_spi: fix CPM spi driver mach-s3c2410: remove unused spi-gpio.h file spi: remove obsolete spi-s3c24xx-gpio driver mach-gta2: remove unused spi-gpio.h include mach-qt2410: convert to spi_gpio mach-jive: convert to spi_gpio spi/pxa2xx: Remove unavailable ssp_type from documentation spi/bfin_spi: uninline fat queue funcs spi/bfin_spi: constify pin array spi/bfin_spi: use structs for accessing hardware regs spi/topcliff-pch: Support new device ML7223 IOH ... Fix up trivial conflict in arch/arm/mach-ep93xx/Makefile
2011-07-22Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-07-20ASoC: dapm - Add methods to retrieve snd_card and soc_card from dapm context.Liam Girdwood
In preparation for ASoC Dynamic PCM (AKA DSP) support. Provide convenience methods to retrieve the soc_card or snd_card from a DAPM context. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-20ASoC: SAMSUNG: Add I2S0 internal dma driverSangbeom Kim
I2S in Exynos4 and S5PC110(S5PV210) has a internal dma. It can be used low power audio mode and 2nd channel transfer. This patch can support idma. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-20ASoC: SAMSUNG: Modify I2S driver to support idmaSangbeom Kim
Previously, I2S driver only can support system dma. In this patch, i2s driver can support internal dma too. IDMA h/w configuration is initialized on idma.c Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Acked-by: Liam Girdwood <lrg@ti.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-20ASoC: davinci: add missing break statementRajashekhara, Sudhakar
In davinci_vcif_trigger() function, a break() statement was missing causing the davinci_vcif_stop() function to be called as a fallback after calling davinci_vcif_start(). Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-07-20ASoC: davinci: fix codec start and stop functionsRajashekhara, Sudhakar
According to DM365 voice codec data sheet at [1], before starting recording or playback, ADC/DAC modules should follow a reset and enable cycle. Writing a 1 to the ADC/DAC bit in the register resets the module and clearing the bit to 0 will enable the module. But the driver seems to be doing the reverse of it. [1] http://focus.ti.com/lit/ug/sprufi9b/sprufi9b.pdf Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-07-20ASoC: Acknowledge WM8962 interrupts before acting on themMark Brown
This closes the small race between a status being read in response to an interrupt and clearing the interrupt, meaning that if the status changes between those periods we might not get a reassertion of the interrupt. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-07-19ASoC: sgtl5000: guide user when regulator support is neededWolfram Sang
Print a hint when the user has a setup where CONFIG_REGULATOR is really needed to make the driver work. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Dong Aisheng <b29396@freescale.com> Tested-by: Shawn Guo <shawn.guo@freescale.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-19ASoC: sgtl5000: refactor registering internal ldoWolfram Sang
The code for registering the internal ldo was present twice. Turn it into a function instead. Also, inform the user if LDO is used now. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Dong Aisheng <b29396@freescale.com> Tested-by: Shawn Guo <shawn.guo@freescale.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-19ASoC: core: make comments fit the codeWolfram Sang
In one comment, cpu_dai was mentioned although codec_dai was used in the code. Also, fix the name for the card dai list which has no seperation into card_dai and codec_dai. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-19ASoC: Mark cache as dirty when suspendingMark Brown
Since quite a few drivers are not managing to flag the cache as needing to be resynced after suspend and it's a reasonable thing to do flag the cache as needing sync automatically when suspending. The expectation is that systems will mainly only keep the CODEC powered when doing audio through the CODEC so we won't actually suspend the device anyway; drivers which want to can override this behaviour when they resume. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Cc: stable@kernel.org
2011-07-18Merge branch 'fix/asoc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/asoc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: Correct WM8994 MICBIAS supply widget hookup ASoC: Fix shift in WM8958 accessory detection default implementation ASoC: sh: fsi-hdmi: fixup snd_soc_card name ASoC: sh: fsi-da7210: fixup snd_soc_card name ASoC: sh: fsi-ak4642: fixup snd_soc_card name
2011-07-17Merge branches 'omap/prcm' and 'omap/mfd' of ↵Arnd Bergmann
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc into next/devel-2
2011-07-17Merge branch 'for-3.0' into for-3.1Mark Brown
2011-07-17ASoC: Correct WM8994 MICBIAS supply widget hookupMark Brown
The WM8994 and WM8958 series of devices have two MICBIAS supplies rather than one, the current widget actually manages the microphone detection control register bit (which is managed separately by the relevant API). Fix this, hooking the relevant supplies up to the MICBIAS1 and MICBIAS2 widgets. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-07-17ASoC: Don't use -1 to boostrap subseq so it can be used by driversMark Brown
Makes life a little easier if you want to add subsequences to an existing driver as you can use -1 to put things at the start of sequences. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-17ASoC: Reduce power consumption for idle DAIs in WM8994Mark Brown
If DAIs are idle but their clocks are in use for some reason (eg, as SYSCLK or for accessory detect) then set the clock dividers to the maximum to reduce slightly the power consumption of the unclocked circuits. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-17ASoC: Report an error for unknown adav80x formatsMark Brown
Not only fixes error handling but also some uninitialized variable warnings. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de>
2011-07-17ASoC: Handle failed WM8994 FLL lock waitsMark Brown
Try the completion before we start the FLL so that if an interrupt was delayed long enough for us to miss it we don't wait for the completion it signalled. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-15Merge branch 'fixes-for-arnd' of git://git.pengutronix.de/git/imx/linux-2.6 ↵Arnd Bergmann
into imx/fixes
2011-07-15ASoC: Handle spurious wm_hubs DC servo done interruptsMark Brown
Don't assume the first fire indicates that we're done. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-15ASoC: WM8983: Initial driverDimitris Papastamos
The WM8983 is a low power, high quality stereo CODEC designed for portable multimedia applications. Highly flexible analogue mixing functions enable new application features, combining hi-fi quality audio with voice communication. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-15Merge branch 'for-3.0' into for-3.1Mark Brown
2011-07-15ASoC: Fix shift in WM8958 accessory detection default implementationMark Brown
2011-07-14ASoC: wm8900: fix a memory leak if wm8900_set_fll failsAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-14ASoC: Log WM8994 FIFO errors from the interruptMark Brown
We should spot them anyway on state changes but logging them gives us better time information about when the misconfiguration happened. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-14ASoC: SAMSUNG: 24-bit audio playback on Exynos4210Giridhar Maruthy
Using 256fs or 512fs will result in distortion of 24-bit audio samples. This is because the lrclk generated is not proper. Using 384 fs generates proper output. Signed-off-by: Giridhar Maruthy <giridhar.maruthy@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-14ASoC: Don't warn on low WM8994/58 AIFnCLKsMark Brown
We can have valid but very low clocks in accessory detection modes. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-14ASoC: Use WM8994 FLL lock interruptMark Brown
If we have interrupts then wait for the FLL lock interrupt rather than using dead reckoning when waiting for the FLL to start. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-14ASoC: Hook up DC servo completion IRQ for WM8994 and WM8958Mark Brown
2011-07-14ASoC: Implement DC servo completion IRQ handling for wm_hubs devicesMark Brown
The individual devices should set the flag dcs_done_irq in the hubs shared data structure to indicate that they will flag the interrupt by calling wm_hubs_dcs_done(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-14ASoC: Use late enable handling for direct voice, speaker and headphoneMark Brown
This ensures appropriate clocking for bypass paths to speaker and headphone and direct voice paths on affected revisions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-14ASoC: STA32x: Preserve reserved register bitsJohannes Stezenbach
Chip documentation explicitly requires that the reset values of reserved register bits are left untouched. It is possible there are differences between STA326 and STA328 or future chip revisions in these bits, and clobbering them might cause malfunction. Signed-off-by: Johannes Stezenbach <js@sig21.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-14ASoC: STA32x: Add mixer controls for biquad coefficientsJohannes Stezenbach
The STA32x has a number of preset EQ settings, but also allows full user control of the biquad filter coeffcients (when "Automode EQ" is set to "User"). Each biquad has five signed, 24bit, fixed-point coefficients representing the range -1...1. The five biquad coefficients can be uploaded in one atomic operation into on-chip coefficient RAM. There are also a few prescale, postscale and mixing coefficients, in the same numeric format and range (a negative coefficient inverts phase). These coefficients are made available as SNDRV_CTL_ELEM_TYPE_BYTES mixer controls. Signed-off-by: Johannes Stezenbach <js@sig21.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
