Add Support to detect the HP insertion or removal during
LP0 state.
Bug 969405
Change-Id: Ibedf1769338e16877240ea9cc82fa7469eb7ff9e
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/98745
Reviewed-by: Simone Willett <swillett@nvidia.com>
Instead of always using 2 dma_req count pass max dma_req_count
through a macro. Ensure dma_req_count does not cross
period_count.
Bug 968814
Change-Id: Iddfbd77017992ccb8c90441213e191133dadb347
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/97915
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Change prototype of tegra_asoc_utils_init to pass snd_soc_card handle.
It is needed to move common tegra machine driver codes to
tegra_asoc_utils interface.
Bug 968814
Change-Id: I98490ffdda51cf7d0b89adadb23c31892183bc0e
Reviewed-on: http://git-master/r/97914
Added TDM mode support in I2S driver.
Added support functions in AHUB to pass audio/client bits.
Added support functions in AHUB to pass audio/client channels.
Fixed the stopping of I2S/TDM by clearing the fifo.
Bug 948478
Change-Id: I246942b3a07ffcfbcfafbc820208190bd3acc5d4
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/98456
bug 949219
Change-Id: I52969e8dd1a5ed4dc76ac360ec08b0afb18cd4a5
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92833
The bias control must be done after the default register value
been restored.
Bug 964400
Change-Id: Iefbd96506573d5ea0e1b3123bb34c38e34e75068
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Reviewed-on: http://git-master/r/96658
1. Use rt5639/40 internal clk source during jack insert detection.
2. Add delay to 100ms.
Bug 955019
Reviewed-on: http://git-master/r/93510
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
(cherry picked from commit 4c07fc1b10ac8abbbf167952071e47aa6179a635)
Change-Id: I4021232674f5432392dc013ddc76c3bf08b44ed0
Reviewed-on: http://git-master/r/95874
Tested-by: Manoj Gangwal <mgangwal@nvidia.com>
use common platform data for machine driver
Change-Id: I90e0d2f47aed46da650305d98f6525287adfaf04
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/95101
replace platform specific data with common platform data
Change-Id: Ie34b9b9288bf76a004db0bcdf4fd59845e0c9d71
Reviewed-on: http://git-master/r/95083
check max98095_reset() return value, this function fails if codec
read/write fails.
Change-Id: I4dddd75e0870e4168288396a462133f7287ad72e
Reviewed-on: http://git-master/r/95078
Add support to customize modem parameters for voice call.
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: I947bf1955713c4ae19e5dd829091bd7e51bca08f
Reviewed-on: http://git-master/r/93091
Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
Enable/disable the ext mic depending on the jack notification
for insertion/removal comes.This is done to save the Audio power.
Bug 955019
(cherry picked from commit 7a22037fd4a274637a5bdb18a8c5452fe58aad32)
Change-Id: I1a8b47c4e9c424a914f546b48c86a6fb07d8e42a
Reviewed-on: http://git-master/r/93956
Drive ext mic gpio (active low) to 1 during init. It will
be toggled as needed by ext mic events.
Bug 949026
Signed-off-by: Daniel Solomon <daniels@nvidia.com>
(cherry picked from commit de806c193fde5cd8c5b0285efeeaef4adb7be611)
Change-Id: Idd72830d89ebe080739694d7f2c8f6ad80d5cdf5
Reviewed-on: http://git-master/r/93955
Allow bias off in order to turn off clock extern1 when codec
is not used.
Bug 957635
(cherry picked from commit adc6929ab3170acd6a0b2cee4f65fa20a1c1d30f)
Change-Id: I4f2e91b0cd9bb4516a5722d2df268f08e78f92e2
Reviewed-on: http://git-master/r/93949
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline commit
16052827d98fbc13c31ebad560af4bd53e2b4dd5
Change-Id: I929a49556539621a0546829e88b3caa498c94be2
Reviewed-on: http://git-master/r/94463
To terminate request from dma, use the tegra_dma_cancel() inplace of
tegra_dma_dequeue().
The api tegra_dma_dequeue() is getting to be obsolete.
Change-Id: Id2a888a726086fb1e4ade04ac047442554188bee
Reviewed-on: http://git-master/r/91754
fix i2s for BT Sco.
Bug 936626
Change-Id: Iaf1d1a230fcb37d45d9deaaf1dae780f5870e99f
Reviewed-on: http://git-master/r/92860
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
bug 949219
Change-Id: I8abd1e837a774d15aef25ec8c40b857b8cba0426
Reviewed-on: http://git-master/r/92858
Few boards which uses wm8903 has independent regulators
for spk and mic while others do not have it.
For the boards which do not have independent regulators
we should avoid getting their regulators otherwise we
would get the following error messages:
"tegra-snd-wm8903 tegra-snd-wm8903.0: No speaker regulator found"
"tegra-snd-wm8903 tegra-snd-wm8903.0: No digital mic regulator found"
Bug 956562
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ide1ce141b5d45d56e834dc82a7cf5a7adc6c3e80
Reviewed-on: http://git-master/r/91548
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Removing legacy i2s/spdif driver from tree.
These files are added to support customer projects prior
to moving over to alsa driver for audio.
There is no intention of using them and hence removing it.
Change-Id: I864dbc50e2e76ac16f40542460f63c8c8a0eff71
Reviewed-on: http://git-master/r/91758
use common platform data instead of using codec specific platform
data for different codecs
Change-Id: I88ecb08f3945e0d9c5162ec2b2d3279a4da50099
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/91686
add voice call, bt voice call, voice call with system sound mix,
bt voice call with system sound mix, voice call recording,
bt voice call recording functionalities for ti aic326x on ap30
Change-Id: Ia94c1586c30d0636d8de738ff6cbb716f4f79d16
Reviewed-on: http://git-master/r/90123
check for revision id, it must be 0x40 as per the datasheet,
if its not 0x40 then dont allow the card to register by failing
in the codec probe. This functionality will be required when the
same board support multiple codecs. Also register the irq only
after validating the codec.
Change-Id: I8553b85d534428c7137ec2d03e2f814b898609a6
Reviewed-on: http://git-master/r/90061
If card fails to instantiate then unregister the card
Change-Id: Ibcc0d505a8df48c1f924a3d8688dc23e362d5e8d
Reviewed-on: http://git-master/r/90060
If switch registration is success and later card registration
fails then we must unregister the switch
Change-Id: I140b3fb0890f41fea653100bcff450f10294cd9d
Reviewed-on: http://git-master/r/90058
Change-Id: I1b41c408b65b79f12b20a5efb7c0d2e3245bad6a
Reviewed-on: http://git-master/r/90057
This change resolves the control name (Line Out Switch) conflict between
wm8903 codec driver and tegra machine driver.
Bug 956506
Change-Id: Iab049c7fb2fdde0d481d07d8e1bbdbeea1a831d9
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/91510
Suspend and resume code included for headphone detection. Earlier,
it was causing problem in HP detection when device enters into LP0
state and headphone is plugged in. (Bug 937153)
Change-Id: If625f0e7b857b40b0535f8bc8d1c262650886fa7
Reviewed-on: http://git-master/r/89975
Added machine driver for P1852 board.
The driver supports a plug/play architecture where the
details of the codec_driver/codec_dai will come from the top level
board config file.
Bug 948478
Change-Id: Id34a34b224e02b61475ca17253c1b13893a09e6c
Reviewed-on: http://git-master/r/89474
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Fixing the typos in the member of cardhu_controls.
Bug 946932
Change-Id: I26f2a5a60f40d55846a89aaa76dab00741e018d0
Reviewed-on: http://git-master/r/88824
Reviewed-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: I0b2b50c007d9e7b722b2c4bbc0282c51a8d18b00
Reviewed-on: http://git-master/r/88239
change M/S configuration for bt, with BT as Slave and Modem
as Master
Change-Id: Ifae5ca228f3bcf0f882f47e79448c10bcc33ec4d
Reviewed-on: http://git-master/r/89127
Tested-by: Nikesh Oswal <noswal@nvidia.com>
update the TIAIC326x driver for voice call
Change-Id: I1443b462b5b7e049fe4cbf39215aea6eeb955500
Reviewed-on: http://git-master/r/88012
change M/S configurations as modem has been made master
on whistler
Change-Id: Iae0cf3f85c43116b13ceb1ff5dfa4a9b121a5d62
Reviewed-on: http://git-master/r/88014
i2s bitclk for dsp mode was kept 4 times the minimum requirement
for bcm4330 bt chip on whistler we require only 2 times the minimum
requirement because modem is also configured similarly and for bt call
both the bit clocks should match
Change-Id: I6a84b22c9fbd66b4e60832933b508fe8cf21f387
Reviewed-on: http://git-master/r/88013
Fix for pop noise 'cut' from internal speaker while booting
on kai board.
Bug 929049
Change-Id: I9c3fe7e05d869709f50036042e70abc91722885e
Reviewed-on: http://git-master/r/87685
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Set I2s FIFO attention level based on sample size and channel count.
Also set playback DMA destination bus width and capture DMA source bus
width based on sample size. These changes are needed to have proper
BT SCO playback and record which uses 16bit-mono format.
Bug 934101
Bug 874428
Bug 927978
Reviewed-on: http://git-master/r/84817
(cherry picked from commit 3ca2eb665af450d7e8f3bf6f2471e31203052641)
Change-Id: I95c10716eaa990adb8b6ae535ce6acfca122a609
Reviewed-on: http://git-master/r/87192
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Fix headset switch name for kai.
Bug 945640
Change-Id: I61b0a7c58a97bd3f2b976d521a5298a48a27798c
Reviewed-on: http://git-master/r/87136
Add support for headset detection on kai board.
Bug 937914
Change-Id: Ic69f5ffda45f71c3f566533ef74fd2a94d82894c
Reviewed-on: http://git-master/r/86601
Add support for headset detection for ALC5639/40
codec for kai board.
Bug 937914
Change-Id: I0bb9e913601c37a1cc8f7094fbdd3885aeec92b3
Reviewed-on: http://git-master/r/86348
Tested-by: Chandler Zhang <chazhang@nvidia.com>
bug 940617
Change-Id: I83f43820761d0227d7a594123d22fe79089e2e15
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/86280
Tested-by: Gerrit_Virtual_Submit
Invert the gpio output because GPIO_EXT_MIC_EN is active low.
Bug 937914
Change-Id: Ifeccda092d7834dfdd39e3d1df616bda7bf516bc
Reviewed-on: http://git-master/r/86038
Reviewed-by: Liangchuan Mi <lmi@nvidia.com>
Reviewed-by: Johnny Qiu <joqiu@nvidia.com>
Tested-by: Kerwin Wan <kerwinw@nvidia.com>
Change-Id: Ia6fac687a6b302fa49b6f8a7cfd74abfde5b45f9
Reviewed-on: http://git-master/r/84544
add support for aic326x on cardhu and also cleanup unused code
of t30 voice call since it has never been tested as aic326x is
not used on any t30 phone platform yet
Change-Id: I32e916f53f6e73031d39bc09afef8ad7f872639b
Reviewed-on: http://git-master/r/84545
Change-Id: I970ab858399113e4ea0d079779a2cb368af90850
Reviewed-on: http://git-master/r/84539
configure ASI2 as master and add missing dapm widgets and routes
Change-Id: If2f9c8361888ec40147cd5537f435c91e50cbcc8
Reviewed-on: http://git-master/r/84538
Change-Id: Ie8ef49b2a76e27e07835fb61bce23ddf69c0b1f9
Reviewed-on: http://git-master/r/84537
If sw dev is registered after the card then there would be a kernel
panic if we try to boot the device with Headset connected because
when the card is registered init of every dai link is called from where
we register the jack with codec driver and doing so will enable headset
interrupts which would try to set switch state for an unregistered switch
device
Change-Id: Ie951f41028a3459e4e13d021c80c3f830bbcc533
Reviewed-on: http://git-master/r/84536
Change-Id: I682ccc9ba44f82b8acf836c1703d5d54419da54b
Reviewed-on: http://git-master/r/84535
change the init values of aic326x registers to keep unrequired
codec elements powered off to save power, these codec elements would
be turned on when required by dapm
Change-Id: Id843fae2ca1f30b77c402da7ac24e89fb04828b6
Reviewed-on: http://git-master/r/84534
