Set I2s FIFO attention level based on sample size and channel count.
Also set playback DMA destination bus width and capture DMA source bus
width based on sample size. These changes are needed to have proper
BT SCO playback and record which uses 16bit-mono format.
Bug 934101
Bug 874428
Bug 927978
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/84817
(cherry picked from commit 3ca2eb665af450d7e8f3bf6f2471e31203052641)
Change-Id: I95c10716eaa990adb8b6ae535ce6acfca122a609
Reviewed-on: http://git-master/r/87192
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Fix headset switch name for kai.
Bug 945640
Change-Id: I61b0a7c58a97bd3f2b976d521a5298a48a27798c
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/87136
Reviewed-by: Simone Willett <swillett@nvidia.com>
Add support for headset detection on kai board.
Bug 937914
Change-Id: Ic69f5ffda45f71c3f566533ef74fd2a94d82894c
Reviewed-on: http://git-master/r/86601
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Add support for headset detection for ALC5639/40
codec for kai board.
Bug 937914
Change-Id: I0bb9e913601c37a1cc8f7094fbdd3885aeec92b3
Reviewed-on: http://git-master/r/86348
Tested-by: Chandler Zhang <chazhang@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
bug 940617
Change-Id: I83f43820761d0227d7a594123d22fe79089e2e15
Signed-off-by: Harry Hong <hhong@nvidia.com>
Reviewed-on: http://git-master/r/86280
Tested-by: Gerrit_Virtual_Submit
Invert the gpio output because GPIO_EXT_MIC_EN is active low.
Bug 937914
Change-Id: Ifeccda092d7834dfdd39e3d1df616bda7bf516bc
Reviewed-on: http://git-master/r/86038
Reviewed-by: Liangchuan Mi <lmi@nvidia.com>
Reviewed-by: Johnny Qiu <joqiu@nvidia.com>
Tested-by: Kerwin Wan <kerwinw@nvidia.com>
Change-Id: Ia6fac687a6b302fa49b6f8a7cfd74abfde5b45f9
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/84544
add support for aic326x on cardhu and also cleanup unused code
of t30 voice call since it has never been tested as aic326x is
not used on any t30 phone platform yet
Change-Id: I32e916f53f6e73031d39bc09afef8ad7f872639b
Reviewed-on: http://git-master/r/84545
Change-Id: I970ab858399113e4ea0d079779a2cb368af90850
Reviewed-on: http://git-master/r/84539
configure ASI2 as master and add missing dapm widgets and routes
Change-Id: If2f9c8361888ec40147cd5537f435c91e50cbcc8
Reviewed-on: http://git-master/r/84538
Change-Id: Ie8ef49b2a76e27e07835fb61bce23ddf69c0b1f9
Reviewed-on: http://git-master/r/84537
If sw dev is registered after the card then there would be a kernel
panic if we try to boot the device with Headset connected because
when the card is registered init of every dai link is called from where
we register the jack with codec driver and doing so will enable headset
interrupts which would try to set switch state for an unregistered switch
device
Change-Id: Ie951f41028a3459e4e13d021c80c3f830bbcc533
Reviewed-on: http://git-master/r/84536
Change-Id: I682ccc9ba44f82b8acf836c1703d5d54419da54b
Reviewed-on: http://git-master/r/84535
change the init values of aic326x registers to keep unrequired
codec elements powered off to save power, these codec elements would
be turned on when required by dapm
Change-Id: Id843fae2ca1f30b77c402da7ac24e89fb04828b6
Reviewed-on: http://git-master/r/84534
Change-Id: I3d2bb9de12f72fe7c860bdfe740a2d55676a8aa3
Reviewed-on: http://git-master/r/84533
add mixer controls for configuring CM modes and use the
non-inverting modes for speaker and receiver mixers
Change-Id: I247ccea17d08dc92ac035d6e8070fb146d26b7f5
Reviewed-on: http://git-master/r/84532
Change-Id: I433c35f2ada14f273f85d67f8cf18612bd1e72ea
Reviewed-on: http://git-master/r/84531
Change-Id: I773a7c6769ca74d1a02e2d0b8236fdc20af3ecb8
Reviewed-on: http://git-master/r/84530
support bt sco playback and recording with bt chip as master
and ap-i2s as slave
Change-Id: I0e1bcd6fa71a234a90c830195a7eb2015f71a3b0
Reviewed-on: http://git-master/r/84529
Change-Id: If40c181227981696961d3c563008261e5324e807
Reviewed-on: http://git-master/r/84528
Change-Id: I39fc88a2647556b261767fa8ec990282ceb65103
Reviewed-on: http://git-master/r/84527
Add support for Headphone detect on Kai.
Bug 928046
Change-Id: Ieffb3aed32e57ca3e43f6a1c8d049ac1b433867f
Reviewed-on: http://git-master/r/83408
The value of reset register of ALC5639 is 0x0008
instead of 0x000c.
bug 931371
Change-Id: I5fbf31411ddab2358d61f998f74a7b1f8c151312
Signed-off-by: Kerwin Wan <kerwinw@nvidia.com>
Reviewed-on: http://git-master/r/83318
- Added suspend/resume support for ALC5640
- Fix for I2S1 interface
Bug 936013
Change-Id: I60b0eb224e9475b722ecb9e2fb8bf0a6dae12767
Reviewed-on: http://git-master/r/83058
Tested-by: Johnny Qiu <joqiu@nvidia.com>
Add support for cdc_en regulator on kai.
Bug 928574
Change-Id: I11590cbd5b7fc91238bde3c7dbe72736117d4457
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/83485
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Changes made to add support of BT Sco for kai.
Bug 936626
Change-Id: If01fe20ed94cc5634b581554b668c744fd822fc3
Reviewed-on: http://git-master/r/83072
added Line In and digital and analog mic to capture path.
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/78752
(cherry picked from commit 832552a5751502eaf1d3d917368c8d889badb353)
Change-Id: I6304aa179a989becbfc3bf6b85e42d28fdbaabf9
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82712
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
The vendor supplied driver has to be fixed to work on older kernels.
Bug 931371
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/78278
(cherry picked from commit ffce206b2d67bb9618a97d08e88c6ae25ba79baa)
Change-Id: Ifd8712758307cd4f31526cc050c62a89187a7c8d
Reviewed-on: http://git-master/r/82733
Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com>
Add files for ALC5639 codec as provided by vendor.
Bug 931371
Reviewed-on: http://git-master/r/78277
(cherry picked from commit b45ab605accb68fd303deec5ed962f213047f9bf)
Change-Id: I6c19e13c3dfec394cef812a5be1bc2ee5d58751b
Reviewed-on: http://git-master/r/82732
Changes made to add support of ALC5639 codec for kai.
Bug 931371
Reviewed-on: http://git-master/r/77953
(cherry picked from commit 481fabd90e34b9a8246d494b0caefa212238c1c2)
Change-Id: I1bcc882cb4b8f7bd257b737295061ea1e9e7e41c
Reviewed-on: http://git-master/r/82731
Add support for ALC5639 codec present in the KAI A01 board.
Bug 931371
Reviewed-on: http://git-master/r/77952
(cherry picked from commit 1747f1003be6413e0e173dee39b25afcbe522528)
Change-Id: I5180d4ed669c4100ca29e6ed508406e69a88fe88
Reviewed-on: http://git-master/r/82730
Bug: 919350
Reviewed-on: http://git-master/r/77989
Change-Id: I9a8d9a1a4d029f1b312405200fcb485de0fc5767
Reviewed-on: http://git-master/r/78704
add support for bt voice call and also make bt as master
and i2s as slave for bt-soc playback and record because for
bt voice call modem is slave and bt is master
Bug: 919350
Reviewed-on: http://git-master/r/77990
Change-Id: I5bbb6cc4b08c5ab1d700ce4d21bbdf9be606e551
Reviewed-on: http://git-master/r/78703
Dma user must call the function tegra_dma_get_transfer_count()
for knowing transferred count without stopping dma.
Change-Id: I5e0060fd8163b285496442268548a90bdd0e294c
Reviewed-on: http://git-master/r/77800
Support I2S slave mode. Disable pll_p_out1 and
pll_a to reduce power when in slave mode.
Slave mode disabled by default.
Reviewed-on: http://git-master/r/76046
Change-Id: I873a11d54f1e037d99c86ff4cec06ee83064902a
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/77765
Bug: 924817
Reviewed-on: http://git-master/r/77238
Change-Id: Ife3bb3439b4b00d042684500d7ffb6bc00100ba6
Reviewed-on: http://git-master/r/77756
Clock function for non-integral of sample
rate clocks does not work correctly and
generates incorrect sample rate.
Reviewed-on: http://git-master/r/75792
Change-Id: I39977c9e2b647d4eabc8d9209c2d05665f708ab0
Reviewed-on: http://git-master/r/77752
In Voice Call when ringtone stream is opened the codec is busy and the
call mode needs to be set before closing the ringtone stream hence we
put the logic in codec driver to enable dai mode change even when codec
is busy
Bug: 919350
Reviewed-on: http://git-master/r/76954
Change-Id: Iaf7176b3a7f72709140e29c2c6071ab4101ec418
Reviewed-on: http://git-master/r/77732
Bug: 919350
Reviewed-on: http://git-master/r/76953
Change-Id: I95611af5e6c12e03cc22fc30c8147e3ef6852615
Reviewed-on: http://git-master/r/77731
Bug: 919350
Reviewed-on: http://git-master/r/76952
Change-Id: Iffc597141a3a5ea528089ce06bf57a4b012eefe8
Reviewed-on: http://git-master/r/77730
This reverts commit 78d27b4b610fbe7d77e3cf43a3b82e15cf879d37.
Bug 916409
Reviewed-on: http://git-master/r/76446
Change-Id: I4288dc4d90b393dd8dbefd7e997b9bfceb49d564
Reviewed-on: http://git-master/r/77305
Reviewed-on: http://git-master/r/75964
Change-Id: Iddc1a4ab042aaab00d7959f957b66fc879c76ccc
Reviewed-on: http://git-master/r/77302
Instead of using tight bitclk use 2x of minimum bitclk requirement
in codec master mode. This change is needed to have clean audio
in codec master mode on Tegra30 based cardhu platform.
Bug 915107
Change-Id: Ia59e1a906415ad8fd1ed324ab4dabef61746b62f
Reviewed-on: http://git-master/r/75706
Reviewed-on: http://git-master/r/76467
commit 37d5993c5cc9bc83762ae1b5bd287438022e8afe upstream.
Record the clock after the divider as that is what all SYSCLK users see.
Without this the other clock configuration in the device comes out at
half rate.
Change-Id: Ifd4d1165bc59b4cb35a3d30e43ebba442c67a68c
Reviewed-on: http://git-master/r/74167
Add the support for handling the wm8903 sound card registration
failure error.
Bug 910788
Change-Id: Ib25f9ca4dd7f5ebd417700421625eb2f3bdc7b5e
Reviewed-on: http://git-master/r/73694
(cherry picked from commit 505788de21a98bbc651a536a56f6594fa589252e)
Reviewed-on: http://git-master/r/73963
Implementation of suspend/resume functionality
is not proper for ALC5640 codec , so remove it
temporarily.
Bug 910788
Change-Id: I243c327602a45a3084befd17a1e722e4d844e502
Reviewed-on: http://git-master/r/73478
(cherry picked from commit 3e24bcc4df716bd1e1f3772300aaa9988319f91a)
Reviewed-on: http://git-master/r/73962
Changes made to add support of ALC5640 codec
for cardhu.
Bug 910788
Change-Id: I134b95a20d1a377eeb534e263fb74c0871e2fd0f
Reviewed-on: http://git-master/r/71459
(cherry picked from commit 844ef13a8281fe307b1adddcdc440b7e191d8926)
Reviewed-on: http://git-master/r/73956
set default bias level to standby
Change-Id: I89f375c88efae48fff43fe57e15659b40602dfac
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Reviewed-on: http://git-master/r/73174
Reviewed-by: Nikesh Oswal <noswal@nvidia.com>
(cherry picked from commit d00767b6573367a6827f35c2339e46f68f75cbaf)
Reviewed-on: http://git-master/r/73952
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
during suspend if bias is set to off then disable the pll_a and
related clock only once this would prevent the kernel warnings
Bug: 920911
Change-Id: Id85cba4548894572dfd17e51c8a55707bfba7105
Reviewed-on: http://git-master/r/72739
