path: root/sound/soc
2011-08-24ASoC: Correct element count for WM8996 sidetone HPFMark Brown
I can count. Honest. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-24ASoC: Tegra: wm8903 machine driver: Drop Ventana supportStephen Warren
Board file support for Ventana is not yet mainlined, and probably won't ever be given the move to Device-Tree. Consequently, the Ventana entry is being removed from arch/arm/tools/mach-types in the next merge window, since it was registered over a year ago. This will also remove function machine_is_ventana(), which is used by the ASoC Tegra WM8903 machine driver. This will cause compilation failures. Drop Ventana support to resolve this. Hopefully, in the not-too-distant future, tegra_wm8903.c will be able to configure itself from Device-Tree, and hence we'll be able to re-instate Ventana support just by creating a .dts file for the board. Also note that Aebl support is in a similar boat. However, that board isn't scheduled for deprecation for at least another 5 months, and perhaps we will have completely removed non-Device-Tree support from tegra_wm8903.c by then and/or adjusted mach-types policy. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-24ASoC: Add Springbank I/O card to Speyside KconfigJoseph Pentland
Signed-off-by: Joseph Pentland <jp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-22sound/soc/fsl/mpc8610_hpcd.c: add missing of_node_putJulia Lawall
The first change is to add an of_node_put, since codec_np has previously been allocated. The rest of the patch reorganizes the error handling code so the only code executed is that which is needed. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier x; expression E1!=0,E2,E3,E4; statement S; iterator I; @@ ( if (...) { ... when != of_node_put(x) when != x = E3 when != E3 = x * return ...; } ... when != x = E2 when != I(...,x,...) S if (...) { ... when != x = E4 of_node_put(x); ... return ...; } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-22sound/soc/fsl/p1022_ds.c: add missing of_node_putJulia Lawall
dma_channel_np has been accessed at this point, so decrease its reference count before leaving the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier x; expression E1!=0,E2,E3,E4; statement S; iterator I; @@ ( if (...) { ... when != of_node_put(x) when != x = E3 when != E3 = x * return ...; } ... when != x = E2 when != I(...,x,...) S if (...) { ... when != x = E4 of_node_put(x); ... return ...; } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-22sound/soc/ep93xx/ep93xx-i2s.c: add missing kfreeJulia Lawall
Introduce a new label that includes kfree and jump to that one. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier x; expression E1!=0,E2,E3,E4; statement S; iterator I; @@ ( if (...) { ... when != kfree(x) when != x = E3 when != E3 = x * return ...; } ... when != x = E2 when != I(...,x,...) S if (...) { ... when != x = E4 kfree(x); ... return ...; } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Alexander Sverdlin <subaparts@yandex.ru> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-22sound/soc/kirkwood/kirkwood-i2s.c: add missing kfreeJulia Lawall
Adjust the goto to jump to the error handling code that includes kfree. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier x; expression E1!=0,E2,E3,E4; statement S; iterator I; @@ ( if (...) { ... when != kfree(x) when != x = E3 when != E3 = x * return ...; } ... when != x = E2 when != I(...,x,...) S if (...) { ... when != x = E4 kfree(x); ... return ...; } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-22ASoC: soc-core: use GFP_KERNEL flag for kmalloc in snd_soc_cnewAxel Lin
GFP_ATOMIC is not needed here, use GFP_KERNEL instead. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-22sound/soc/fsl/fsl_dma.c: add missing of_node_putTimur Tabi
of_parse_phandle increments the reference count of np, so this should be decremented before trying the next possibility. Since we don't actually use np, we can decrement the reference count immediately. Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-22ASoC: Clear completions from late WM8996 FLL lock IRQsMark Brown
In case we have a pending completion, for example due to a problem with the input clock which got corrected after we timed out. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-22ASoC: Clear any outstanding WM8962 FLL lock completions before waitingMark Brown
Ensure that we don't spuriously trigger early. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-22ASoC: Ensure we only run Speyside WM8962 bias level callbacks onceMark Brown
We get called once per DAPM context but only need to run once. When DAPM was serialized this was a series of noops but now it can run in parallel we need to take proper care. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-22ASoC: Fix configuration of WM8996 input enablesMark Brown
There's no need for separate widgets for the enables (as the map already shows). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-22ASoC: WM8996 record paths need AIFCLKMark Brown
Make AIFCLK supply the record paths otherwise record will not work unless there is a simultaneous playback. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-19ASoC: omap: Fix build errors in ams-deltaJarkko Nikula
Fix "error: too few arguments to function 'ams_delta_set_bias_level'" build errors in ams-delta.c that were introduced after commit d4c6005 ("ASoC: Add context parameter to card DAPM callbacks") by adding dapm context to ams_delta_set_bias_level calls. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-17ASoC: Fix check for symmetric rate enforcementSascha Hauer
The ASoC core tries to not enforce symmetric rates when two streams open simultaneously. It does so by checking rtd->rate being zero. This works exactly once after booting because it is not set to zero again when the streams close. Fix this by setting rtd->rate when no active stream is left. [This leads to lots of warnings about not enforcing the symmetry in some situations as there's a race in the userspace API where we know we've got two applications but don't know what rates they want to set. -- broonie ] Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-15ASoC: ad193x: remove cache supportScott Jiang
asoc cache layer can't support this kind of spi registers well. remove cache support and read/write registers directly Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-15ASoC: Add spi hw read function for 16 addr 8 data mode for ad193x fixScott Jiang
[This will be used by the ad193x driver to fix the fact that the original author of the driver put a bodge for their particular chip into a the generic ASoC register I/O abstraction layer which looked like an obvious bug which ended up getting fixed in 3.0. Sadly there were no comments documenting what was going on. A minimally invasive correction to the driver is to remove the register cache support and go direct to the hardware all the time so we're adding a new feature -- broonie] Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-15ASoC: ad193x: fix system clockScott Jiang
system clock is 24.576MHz instead of 12.288MHz Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-15ASoC: ad193x: fix dac word len settingScott Jiang
dac word len value should left shift before setting Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Acked-by: Barry Song <21cnbao@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-08-15ASoC: ad193x: fix registers definitionScott Jiang
fix dac word len mask and adc tdm fmt shift value Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-08-15ASoC: sta32x: Fix a memory leak if snd_soc_register_codec failsAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-15ASoC: soc-jack: Fix checking return value of request_any_context_irqAxel Lin
request_any_context_irq() returns a negative value on failure. On success, it returns either IRQC_IS_HARDIRQ or IRQC_IS_NESTED. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.orG
2011-08-14ASoC: rx1950: Fix compilation error due to missing headerVasily Khoruzhick
Add linux/types.h to fix this compilation error: In file included from arch/arm/mach-s3c2410/include/mach/gpio-fns.h:27:0, from arch/arm/mach-s3c2410/include/mach/gpio.h:27, from /home/anarsoul/work/pda-linux/linux-next/arch/arm/include/asm/gpio.h:5, from include/linux/gpio.h:18, from sound/soc/samsung/rx1950_uda1380.c:20: arch/arm/plat-samsung/include/plat/gpio-cfg.h:29:34: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘s3c_gpio_pull_t’ arch/arm/plat-samsung/include/plat/gpio-cfg.h:30:34: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘s5p_gpio_drvstr_t’ arch/arm/plat-samsung/include/plat/gpio-cfg.h:57:2: error: expected specifier-qualifier-list before ‘s3c_gpio_pull_t’ arch/arm/plat-samsung/include/plat/gpio-cfg.h:148:47: error: expected declaration specifiers or ‘...’ before ‘s3c_gpio_pull_t’ arch/arm/plat-samsung/include/plat/gpio-cfg.h:156:24: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘s3c_gpio_getpull’ arch/arm/plat-samsung/include/plat/gpio-cfg.h:175:24: error: expected declaration specifiers or ‘...’ before ‘s3c_gpio_pull_t’ arch/arm/plat-samsung/include/plat/gpio-cfg.h: In function ‘s3c_gpio_cfgrange_nopull’: arch/arm/plat-samsung/include/plat/gpio-cfg.h:180:47: error: ‘s3c_gpio_pull_t’ undeclared (first use in this function) arch/arm/plat-samsung/include/plat/gpio-cfg.h:180:47: note: each undeclared identifier is reported only once for each function it appears in arch/arm/plat-samsung/include/plat/gpio-cfg.h:180:47: error: expected ‘)’ before numeric constant arch/arm/plat-samsung/include/plat/gpio-cfg.h:180:47: error: too many arguments to function ‘s3c_gpio_cfgall_range’ arch/arm/plat-samsung/include/plat/gpio-cfg.h:174:12: note: declared here arch/arm/plat-samsung/include/plat/gpio-cfg.h: At top level: arch/arm/plat-samsung/include/plat/gpio-cfg.h:199:26: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘s5p_gpio_get_drvstr’ arch/arm/plat-samsung/include/plat/gpio-cfg.h:210:50: error: expected declaration specifiers or ‘...’ before ‘s5p_gpio_drvstr_t’ Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-14ASoC: h1940: Fix compilation error due to missing headerVasily Khoruzhick
2011-08-14ASoC: Move WM8962 CLKREG_OVD earlierMark Brown
When the clocking registers are not overriden some of the registers are not writable. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Cc: stable@kernel.org
2011-08-12ASoC: Fix compile warning in wm8750.cTakashi Iwai
sound/soc/codecs/wm8750.c:784:2: warning: missing braces around initializer sound/soc/codecs/wm8750.c:784:2: warning: (near initialization for ‘wm8750_spi_ids[2].name’) It's because struct spi_device_id.name is a char array, not a pointer, while the driver initializes explicitly with 0. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-12ASoC: omap: Update e-mail address of Jarkko NikulaJarkko Nikula
My gmail account got disabled and I'm not going to reopen it. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-12ASoC: SAMSUNG: Add I2S0 internal dma driverSangbeom Kim
I2S in Exynos4 and S5PC110(S5PV210) has a internal dma. It can be used low power audio mode and 2nd channel transfer. This patch can support idma. [Reapplied after dependencies propagated through in 3.1-rc1. --broonie] Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-11ASoC: Terminate WM8750 SPI device ID tableMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au>
2011-08-11ASoC: Add missing break in WM8994 probeMark Brown
This error would have no effect on current silicon revisions, the fall through case has the same behaviour. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-10ASoC: Fix typo in wm8750 spi_idsMark Brown
2011-08-10ASoC: Fix warning in Speyside WM8962Mark Brown
2011-08-10ASoC: Fix SPI driver binding for WM8987Mark Brown
As we had no id_table only the driver name would be matched against meaning that WM8987 devices wouldn't be bound. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-10ASoC: Fix binding of WM8750 on JiveMark Brown
The I2C address is misformatted and would never match. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Cc: stable@kernel.org
2011-08-09ASoC: WM8903: Free IRQ on device removalStephen Warren
Without this, request_irq on subsequent device initialization fails, and the codec cannot be used. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-09ASoC: Tegra: wm8903 machine driver: Allow re-insertion of moduleStephen Warren
Two issues were preventing module snd-soc-tegra-wm8903.ko from being removed and re-inserted: a) The speaker-enable GPIO is hosted by the WM8903 chip. This GPIO must be freed before snd_soc_unregister_card() is called, because that triggers wm8903.c:wm8903_remove(), which calls gpiochip_remove(), which then fails if any of the GPIOs are in use. To solve this, free all GPIOs first, so the code doesn't care where they come from. b) We need to call snd_soc_jack_free_gpios() to match the call to snd_soc_jack_add_gpios() during initialization. Without this, the call to snd_soc_jack_add_gpios() fails during any subsequent modprobe and initialization, since the GPIO and IRQ are already registered. In turn, this causes the headphone state not to be monitored, so the headphone is assumed not to be plugged in, and the audio path to it is never enabled. Signed-off-by: Stephen Warren <swarren@nvidia.com> Cc: stable@kernel.org Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-09ASoC: Tegra: tegra_pcm_deallocate_dma_buffer: Don't OOPSStephen Warren
Not all PCM devices have all sub-streams. Specifically, the SPDIF driver only supports playback and hence has no capture substream. Check whether a substream exists before dereferencing it, when de-allocating DMA buffers in tegra_pcm_deallocate_dma_buffer. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-08-08Merge branch 'wm8996-rename' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into fix/asoc
2011-08-08ASoC: Acknowledge WM8996 interrupts before acting on themMark Brown
This closes the small race between a status being read in response to an interrupt and clearing the interrupt, meaning that if the status changes between those periods we might not get a reassertion of the interrupt. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-08ASoC: Rename WM8915 to WM8996Mark Brown
For marketing reasons the part will be called WM8996. In order to avoid user confusion rename the driver to reflect this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: asihpi - Clarify adapter index validity check ALSA: asihpi - Don't leak firmware if mem alloc fails ALSA: rtctimer.c needs module.h ASoC: Fix txx9aclc.c build ALSA: hdspm - Add firmware revision 0xcc for RME MADI ALSA: hdspm - Fix reported external sample rate on RME MADI and MADIface ALSA: hdspm - Provide MADI speed mode selector on RME MADI and MADIface ALSA: sound/core/pcm_compat.c: adjust array index
2011-08-03ASoC: sgtl5000: fix cache handlingWolfram Sang
Cache handling in this driver is broken. The chip has 16-bit registers, yet the register numbers also increase by 2 per register, i.e. there are only even-numbered registers. The cache in this driver, though, simply increments register numbers, so it does need some mapping as seen in sgtl5000_restore_regs(), note the '>> 1': snd_soc_write(codec, SGTL5000_CHIP_LINREG_CTRL, cache[SGTL5000_CHIP_LINREG_CTRL >> 1]); That, of course, won't work with snd_soc_update_bits(). (Thus, we won't even notice the missing register 0x1c in the default regs which shifted all follwing registers to wrong values.) Noticed on the MX28EVK where enabling the regulators simply locked up the chip. Refactor the routines and use a properly sized default_regs array which matches the register layout of the underlying chip, i.e. create a truly flat cache. This also saves some code which should make up for the bigger array a little. When soc-core will somewhen have another cache type which handles a step size, this conversion will also ease the transition. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Dong Aisheng <b29396@freescale.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-08-02Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-07-29ASoC: Disable wm_hubs periodic DC servo updateMark Brown
This does not function correctly in all circumstances so disable the periodic updates unconditionally for stable; a future patch will reenable where appropriate. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-07-29ASoC: Fix txx9aclc.c buildRalf Baechle
552d1ef6b5a98d7b95959d5b139071e3c90cebf1 [ASoC: core - Optimise and refactor pcm_new() to pass only rtd] breaks compilation of txx9aclc.c: CC [M] sound/soc/txx9/txx9aclc.o /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c: In function 'txx9aclc_pcm_new': /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c:318:3: error: 'card' undeclared (first use in this function) /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c:318:3: note: each undeclared identifier is reported only once for each function it appears in make[5]: *** [sound/soc/txx9/txx9aclc.o] Error 1 Fixed by providing a definition for card. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (22 commits) ALSA: hda - Cirrus Logic CS421x support ALSA: Make pcm.h self-contained ALSA: hda - Allow codec-specific set_power_state ops ALSA: hda - Add post_suspend patch ops ALSA: hda - Make CONFIG_SND_HDA_POWER_SAVE depending on CONFIG_PM ALSA: hda - Make sure mute led reflects master mute state ALSA: hda - Fix invalid mute led state on resume of IDT codecs ASoC: Revert "ASoC: SAMSUNG: Add I2S0 internal dma driver" ALSA: hda - Add support of the 4 internal speakers on certain HP laptops ALSA: Make snd_pcm_debug_name usable outside pcm_lib ALSA: hda - Fix DAC filling for multi-connection pins in Realtek parser ASoC: dapm - Add methods to retrieve snd_card and soc_card from dapm context. ASoC: SAMSUNG: Add I2S0 internal dma driver ASoC: SAMSUNG: Modify I2S driver to support idma ASoC: davinci: add missing break statement ASoC: davinci: fix codec start and stop functions ASoC: dapm - add DAPM macro for external enum widgets ASoC: Acknowledge WM8962 interrupts before acting on them ASoC: sgtl5000: guide user when regulator support is needed ASoC: sgtl5000: refactor registering internal ldo ...
2011-07-26Merge branch 'next/devel2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits) OMAP: Add debugfs node to show the summary of all clocks OMAP2+: hwmod: Follow the recommended PRCM module enable sequence OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming OMAP2+: PM: idle clkdms only if already in idle OMAP2+: clockdomain: add clkdm_in_hwsup() OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition() OMAP4: hwmod: Introduce the module control in hwmod control OMAP4: cm: Add two new APIs for modulemode control OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure OMAP4: hwmod data: Add PRM context register offset OMAP4: prm: Remove deprecated functions OMAP4: prm: Replace warm reset API with the offset based version OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros OMAP: hwmod: Wait the idle status to be disabled OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros OMAP2+: hwmod: Init clkdm field at boot time OMAP4: hwmod data: Add clock domain attribute OMAP4: clock data: Add missing divider selection for auxclks ...
2011-07-26Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
