commit ff18620c2157671a8ee21ebb8e6a3520ea209b1f upstream.
... due to a copy & paste error.
Spotted by coverity CID 710923.
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 268ff14525edba31da29a12a9dd693cdd6a7872e upstream.
Spotted by coverity CID 115170.
commit d63733aed90b432e5cc489ddfa28e342f91b4652 upstream.
If the user passes an invalid value it leads to an info leak when we
print the error message or it could oops. This is called with user
supplied data from snd_ctl_elem_write().
commit d967967e8d1116fb38bad25e58714b5dddd03cca upstream.
This is called from snd_ctl_elem_write() with user supplied data so we
need to add some bounds checking.
commit f8d7b13e14357ed19d2ca2799539600418dc3939 upstream.
The ->put() function are called from snd_ctl_elem_write() with user
supplied data. The limit checks here could underflow leading to a
crash.
commit 9f6f0afbb9fdabf6dcac642dfec457f28981e3f8 upstream.
The MC13783 Chip Errata, Rev. 4 says, that depending on SPI clock
and main audio clock speed, the Audio Codec or Stereo DAC do sometimes
not start when programmed to do so. This is due to an internal clock
timing issue related to the loading of the SPI bits into the audio block.
On an i.MX27 based system, this issue lead to switched audio channels under
certain circumstances: RTC + Touch + Audio are used and loaded at startup.
The mentioned workaround of writing registers 40 and 41 two times is implemented
here.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
commit 85fa532b6ef920b32598df86b194571a7059a77c upstream.
Bit 9 of PLL2,3 and 4 is reserved as '0'. The 24bit fractional part
should be split across each register in 8bit chunks.
Signed-off-by: Mike Dyer <mike.dyer@md-soft.co.uk>
commit c90c0d7a96e634a73ef1580f1d20993606545647 upstream.
The Tegra30 I2S driver was writing the AHUB interface parameters to the
playback path register rather than the capture path register. This
caused the capture parameters not to be configured at all, so if
capturing using non-HW-default parameters (e.g. 16-bit stereo rather
than 8-bit mono) the audio would be corrupted.
With this fixed, audio capture from an analog microphone works correctly
on the Cardhu board.
commit e2c98a8bba958045bde861fe1d66be54315c7790 upstream.
Beep Volume Min/Max was backwards.
Change to SOC_SONGLE_SX_TLV for correct volume representation
Signed-off-by: Brian Austin <brian.austin@cirrus.com>
commit fe581391147cb3d738d961d0f1233d91a9e1113c upstream.
list_first_entry() will always return a valid pointer, even if the list is
empty. So the check whether path is NULL will always be false. So we end up
calling dapm_create_or_share_mixmux_kcontrol() with a path struct that points
right in the middle of the widget struct and by trying to modify the path the
widgets memory will become corrupted. Fix this by using list_emtpy() to check if
the widget doesn't have any paths.
commit 2e7ee15ced914e109a1a5b6dfcd463d846a13bd5 upstream.
Also fix return values for headphone switch updates.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
commit 647ab784c507763bfda79155f125b6edd1244806 upstream.
The errors were caused by copy/paste mistake in below commit
since v3.10:
3489d50 ASoC: tegra: Use common DAI DMA data struct
It also corrects slave_id initialization in tegra20_ac97 driver.
Signed-off-by: Richard Zhao <rizhao@nvidia.com>
Acked-by: Lucas Stach <dev@lynxeye.de>
commit cb6f66a2d278e57a6c9d8fb59bd9ebd8ab3965c2 upstream.
The registers of max98088 are 8 bits, not 16 bits. This bug causes the
contents of registers to be overwritten with bad values when the codec
is suspended and then resumed.
Signed-off-by: Chih-Chung Chang <chihchung@chromium.org>
Signed-off-by: Dylan Reid <dgreid@chromium.org>
commit 016fcab8ff46fca29375d484226ec91932aa4a07 upstream.
According to the sgtl5000 reference manual, the default value of CHIP_SSS_CTRL
is 0x10.
Reported-by: Oskar Schirmer <oskar@scara.com>
commit 5c78dfe87ea04b501ee000a7f03b9432ac9d008c upstream.
SGTL5000_PLL_FRAC_DIV_MASK is used to mask bits 0-10 (11 bits in total) of
register CHIP_PLL_CTRL, so fix the mask to accomodate all this bit range.
commit 571185717f8d7f2a088a7ac38d94a9ad5fd9da5c upstream.
snd_pcm_stop() must be called in the PCM substream lock context.
Acked-by: Mark Brown <broonie@linaro.org>
commit 61be2b9a18ec70f3cbe3deef7a5f77869c71b5ae upstream.
When calling snd_soc_dapm_sync(), it eventually tries to lock the same mutex
already locked in snd_soc_dapm_put_volsw_aic3x() and a deadlock occurs. By
moving the mutex unlock to just before snd_soc_dapm_sync(), this deadlock is
prevented. This problem was introduced in Linux 3.5
Signed-off-by: Andreas Irestål <Andreas.Irestal@axis.com>
Even though they are virtual widgets DAI widgets still get counted for the
DAPM context power management so we can't just use the active state to
check if they should be powered as they may not be part of a complete path.
Instead split them into input and output widgets and do the same power
checks as we perform on AIFs.
Reported-by: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
When declaring playback and capture capabilities check for both CODEC
side and CPU side support rather than only checking for CODEC side
support. While it is unusual some CPUs do have unidirectional DAIs.
Reported-by: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr>
Acked-by: Brian Austin <brian.austin@cirrus.com>
The default register value for MASTERA_VOL is 0x00, the same as
MASTERB_VOL.
Cc: stable@vger.kernel.org
The array 'drc_cfg' of size 3 may use index value -22 (EINVAL)
The array 'retune_mobile_cfg' of size 3 may use index value -22 (EINVAL)
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
During recent refactoring the code to report removal when MICDET reports
an absent microphone was removed, causing problems for systems which rely
solely on the MICDET for this functionality. Restore it.
The mask should define the bits to change in the register, not the
bits to preserve.
This fixes the inadvertent changes of the "Headphone Analog Gain"
value during mute/unmute.
controls.
McASP serial audio engine needs different rotation values on TX and RX
channels. Commit dde109fb462 ("ASoC: McASP: Fix data rotation for
playback. Enables 24bit audio playback") changed the calculation to fix
the playback format, but broke the capture stream by doing it for both
TXFMT and RXFMT.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Cc: stable@vger.kernel.org [3.9 only]
Add callback to initialise the speaker in the core following the recent
changes to handling of integration with the thermal interrupts.
request_threaded_irq() rejects calls which both do not specify a handler
(indicating that the primary IRQ handler should be used) and do not set
IRQF_ONESHOT because the combination is unsafe with level-triggered
interrupts. It is safe in this case, though, since max98090 IRQs are
edge-triggered and the interrupts aren't ACK'ed until the codec's IRQ
status register is read. Because of this, an IRQF_ONESHOT interrupt
doesn't really make a difference, but request one anyway in order to make
request_threaded_irq() happy.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull devm usage cleanup from Wolfram Sang:
"Lately, I have been experimenting how to improve the devm interface to
make writing device drivers easier and less error prone while also
getting rid of its subtle issues. I think it has more potential but
still needs work and definately conistency, especiall in its usage.
The first thing I come up with is a low hanging fruit regarding
devm_ioremap_resouce(). This function already checks if the passed
resource is valid and gives an error message if not. So, we can
remove similar checks from the drivers and get rid of a bit of code
and a number of inconsistent error strings.
This series only removes the unneeded check iff devm_ioremap_resource
follows platform_get_resource directly. The previous version tried to
shuffle code if needed, too, what lead to an embarrasing bug. It
turned out to me that shuffling code for all cases found will make the
automated script too complex, so I am unsure if an automated cleanup
is the proper tool for this case. Removing the easy stuff seems
worthwhile to me, though.
Despite various architectures and platform dependencies, I managed to
compile test 45 out of 57 modified files locally using heuristics and
defconfigs."
Pulled because: 296 deletions, 0 additions.
* 'devm_no_resource_check' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (33 commits)
sound/soc/kirkwood: don't check resource with devm_ioremap_resource
sound/soc/fsl: don't check resource with devm_ioremap_resource
arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource
arch/arm/plat-samsung: don't check resource with devm_ioremap_resource
arch/arm/mach-tegra: don't check resource with devm_ioremap_resource
drivers/watchdog: don't check resource with devm_ioremap_resource
drivers/w1/masters: don't check resource with devm_ioremap_resource
drivers/video/omap2/dss: don't check resource with devm_ioremap_resource
drivers/video/omap2: don't check resource with devm_ioremap_resource
drivers/usb/phy: don't check resource with devm_ioremap_resource
drivers/usb/host: don't check resource with devm_ioremap_resource
drivers/usb/gadget: don't check resource with devm_ioremap_resource
drivers/usb/chipidea: don't check resource with devm_ioremap_resource
drivers/thermal: don't check resource with devm_ioremap_resource
drivers/staging/nvec: don't check resource with devm_ioremap_resource
drivers/staging/dwc2: don't check resource with devm_ioremap_resource
drivers/spi: don't check resource with devm_ioremap_resource
drivers/rtc: don't check resource with devm_ioremap_resource
drivers/pwm: don't check resource with devm_ioremap_resource
drivers/pinctrl: don't check resource with devm_ioremap_resource
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
