path: root/sound/sound_core.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-19Driver-Core: extend devnode callbacks to provide permissionsKay Sievers
This allows subsytems to provide devtmpfs with non-default permissions for the device node. Instead of the default mode of 0600, null, zero, random, urandom, full, tty, ptmx now have a mode of 0666, which allows non-privileged processes to access standard device nodes in case no other userspace process applies the expected permissions. This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-10sound: make OSS device number claiming optional and schedule its removalTejun Heo
If any OSS support is enabled, regardless of built-in or module, sound_core claims full OSS major number (that is, the old 0-255 region) to trap open attempts and request sound modules using custom module aliases. This feature is redundant as chrdev already has such mechanism. This preemptive claiming prevents alternative OSS implementation. The custom module aliases are scheduled to be removed and the previous patch made soundcore emit the standard chrdev aliases too to help transition. This patch schedule the feature for removal in a year and makes it optional so that developers and distros can try new things in the meantime without rebuilding the kernel. The pre-claiming can be turned off by using SOUND_OSS_CORE_PRECLAIM and/or kernel parameter soundcore.preclaim_oss. As this allows sound minors to be individually grabbed by other users, this patch updates sound_insert_unit() such that if registering individual device region fails, it tries the next available slot. For details on removal plan, please read the entry added by this patch in feature-removal-schedule.txt . Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-10sound: request char-major-* module aliases for missing OSS devicesTejun Heo
Till now missing OSS devices emitted sound-slot/service-* module alises instead of the standard char-major-* if a missing device number is opened if soundcore is loaded. The custom module aliases don't have any inherent benefit than backward compatibility. sound-slot/service-* module aliases is scheduled to be removed and to help the transition this patch makes soundcore emit the standard module alises along with the custom ones. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-03sound: do not set DEVNAME for OSS devicesKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-15Driver Core: sound: add nodename for sound driversKay Sievers
This adds support to the sound core to report the proper device name to userspace for their devices. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-15ALSA: Fix declaration of sound_classMark Brown
Include sound/core.h in sound_core.c so that sound_class is declared before it is defined, avoiding it looking like it should be static. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-21sound/sound_core: Fix sparse warningsHannes Eder
Fix the following sparse warnings: sound/sound_core.c:460:2: warning: returning void-valued expression sound/sound_core.c:477:2: warning: returning void-valued expression sound/sound_core.c:510:5: warning: symbol 'soundcore_open' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-27Merge branches 'topic/fix/asoc', 'topic/fix/hda', 'topic/fix/misc' and ↵Takashi Iwai
'topic/pci-ioremap-bar' into for-linus
2008-10-27sound: use a common working email addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-16device create: sound: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Cc: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-09ALSA: fix section mismatch in the sound_coreKrzysztof Helt
The __exit cleanup_oss_soundcore() is called from the __init init_soundcore(). This causes section mismatch and breaks kernel's linking on sparc64. Remove the __exit attribute from the cleanup_oss_soundcore(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-29sound: make OSS sound core optionalTejun Heo
sound/sound_core.c implements soundcore.ko and contains two parts - sound_class which is shared by both ALSA and OSS and device redirection support for OSS. It's always compiled when any sound support is enabled although it's necessary only when OSS (the actual one or emulation) is enabled. This is slightly wasteful and as device redirection always registers character device region for major 14, it prevents alternative implementation. This patch introduces a new config SOUND_OSS_CORE which is selected iff OSS support is actually necessary and build the OSS core part conditionally. If OSS is disabled, soundcore merely contains sound_class but leaving it that way seems to be the simplest approach as otherwise sound_class should be in ALSA core file if OSS is disabled but should be in soundcore if OSS is enabled. Also, there's also the user confusion factor. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-21device create: sound: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Cc: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-20sound: cdev lock_kernel() pushdownJonathan Corbet
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2007-02-12[PATCH] mark struct file_operations const 9Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-01Driver core: convert sound core to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. It also makes the struct sound_card to show up as a "real" device where all the different sound class devices are placed as childs and different card attribute files can hang off of. /sys/class/sound is still a flat directory, but the symlink targets of all devices belonging to the same card, point the the /sys/devices tree below the new card device object. Thanks to Kay for the updates to this patch. Signed-off-by: Kay Sievers <kay.sievers@novell.com> Acked-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-04[PATCH] The scheduled removal of some OSS driversAdrian Bunk
This patch contains the scheduled removal of OSS drivers that: - have ALSA drivers for the same hardware without known regressions and - whose Kconfig options have been removed in 2.6.17. [michal.k.k.piotrowski@gmail.com: build fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] build sound/sound_firmware.c only for OSSAdrian Bunk
All sound/sound_firmware.c contains is mod_firmware_load() that is a legacy API only used by some OSS drivers. This patch builds it into an own sound_firmware module that is only built depending on CONFIG_SOUND_PRIME making the kernel slightly smaller for ALSA users. [alan@lxorguk.ukuu.org.uk: comment fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove devfs support from the sound subsystemGreg Kroah-Hartman
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-30[PATCH] Assign device pointer to OSS devicesTakashi Iwai
Add register_sound_special_device() function to allow assignment of device pointer to a specific OSS device for HAL. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-06-20[PATCH] class: convert sound/* to use the new class api instead of class_simplegregkh@suse.de
