path: root/sound/sparc/dbri.c
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-28dt/sound: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of users of of_platform_driver in drivers/sound. The of_platform_{,un}register_driver functions are going away, so the users need to be converted to using the platform_bus_type directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-07-24of/platform: remove all of_bus_type and of_platform_bus_type referencesGrant Likely
Both of_bus_type and of_platform_bus_type are just #define aliases for the platform bus. This patch removes all references to them and switches to the of_register_platform_driver()/of_unregister_platform_driver() API for registering. Subsequent patches will convert each user of of_register_platform_driver() into plain platform_drivers without the of_platform_driver shim. At which point the of_register_platform_driver()/of_unregister_platform_driver() functions can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-06-28sparc/of: Move of_device fields into struct pdev_archdataGrant Likely
This patch moves SPARC architecture specific data members out of struct of_device and into the pdev_archdata structure. The reason for this change is to unify the struct of_device definition amongst all the architectures. It also remvoes the .sysdata, .slot, .portid and .clock_freq properties because they aren't actually used by anything. A subsequent patch will replace struct of_device entirely with struct platform_device and the of_platform support code will share common routines with the platform bus (but the bus instances themselves can remain separate). This patch also adds 'struct resources *resource' and num_resources to match the fields defined in struct platform_device. After this change, 'struct platform_device' can be used as a drop-in replacement for 'struct of_platform'. This change is in preparation for merging the of_platform_bus_type with the platform_bus_type. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-28ALSA: Add missing SNDRV_PCM_INFO_BATCH flag to some driversTakashi Iwai
Added SNDRV_PCM_INFO_BATCH flag to PCM info field of some drivers that really don't give the precise pointer value. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-29dbri: check dma_alloc_coherent errorsFUJITA Tomonori
Needs to check for dma_alloc_coherent() allocation failure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: sound/core/memalloc.c
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29dbri: Convert to pure OF driver.David S. Miller
2008-08-29sparc: Convert all SBUS drivers to dma_*() interfaces.David S. Miller
And all the SBUS dma interfaces are deleted. A private implementation remains inside of the 32-bit sparc port which exists only for the sake of the implementation of dma_*(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Make SBUS DMA interfaces take struct device.David S. Miller
This is the first step in converting all the SBUS drivers over to generic dma_*(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13ALSA: Kill snd_assert() in other placesTakashi Iwai
Kill snd_assert() in other places, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-06ALSA: make sparc/dbri.c:snd_dbri_proc() staticAdrian Bunk
This patch makes the needlessly global snd_dbri_proc() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] dbri - Fix broken change for value range checksTakashi Iwai
The last patch for value range checks included a broken merge result. Now fixed properly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly (in the rest drivers). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] dbri - Use linux/of.h instead of asm/prom.hKrzysztof Helt
The linux/of.h header should be used instead of asm/prom.h. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] dbri: conversion to OpenFirmware frameworkKrzysztof Helt
This patch converts the dbri driver to use OF framework. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] dbri: more cleanupsKrzysztof Helt
This patch: - removes redundant constant suffices - removes redundant parentheses - removes redundant curly brackets - removes check if a spinlock is locked inside method which is only called with the spinlock locked - moves few functions to the __init section - removes line which appears twice after the previous patch - minor comments improvements Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] dbri: driver cleanupKrzysztof Helt
This patch fixes white spaces, spelling and formatting to conform closer to the coding standard of the kernel. It contains few fixes pointed out by the checkpatch.pl script. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-09[ALSA] sparc dbri comment fixKrzysztof Helt
This is a comment fix to avoid misleading about locking in the dbri_cmdsend. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-29[PATCH] sound/sparc/dbri: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24[PATCH] NULL noise removalAl Viro
2006-09-23[ALSA] sparc dbri: SMP fixesKrzysztof Helt
The dbri driver hangs when used in kernel compiled with SMP support due to inproper locking. The patch fixes it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: OSS layer fixKrzysztof Helt
This patch removes setting of incorrect stop_threshold value inside the driver. After the change, playback through the OSS layer works correctly. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] dbri sparc: fixes TS leakKrzysztof Helt
This patch fixes time slot leak in the dbri driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: recording is backKrzysztof Helt
This patch fixes sound recording after the driver convertion to ring buffered version. It also contains small clean ups to the driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: hardware constrains addedKrzysztof Helt
This patch adds ALSA hardware constrains so stereo is possible only with 16-bit format. It contains small cleanups to ring buffered code as well. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: ring buffered versionKrzysztof Helt
It is a complete rework of low level layer to work on ring buffers for comands and data descriptors. This removes annoying noise due to delay in data buffer switching. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: simplifed linking time slot functionKrzysztof Helt
A simplified routines to link and unlink time slots. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: fixed setting of burst size after resetKrzysztof Helt
A proper way to set DBRI's burst size. The size must be set after each chip reset. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: more driver cleanupKrzysztof Helt
A general clean up and redudant code removal. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of dri_desc structKrzysztof Helt
The structure is in big part redudant. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of redudant volatile keywordsKrzysztof Helt
It removes redudant volatile keywords. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of unused struct membersKrzysztof Helt
It removes unused or rarely used members of defined structures. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri removal of DBRI_NO_INTSKrzysztof Helt
This patch removes define DBR_NO_INTS and all code related to handling more than one dbri irq statuses block. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] dbri driver cleanupKrzysztof Helt
This is a small clean up of the dbri driver for sparc machines. It contains also a fix to DBRI interrupt queue initialization. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-03[PATCH] sparc: resource warning fixAndrew Morton
sound/sparc/amd7930.c: In function 'amd7930_attach_common': sound/sparc/amd7930.c:1040: warning: format '%08lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' sound/sparc/cs4231.c:2043: warning: format '%016lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' sound/sparc/dbri.c: In function 'dbri_attach': sound/sparc/dbri.c:2650: warning: format '%016lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30typo fixes: specfic -> specificAdrian Bunk
2006-06-27[PATCH] 64bit resource: fix up printks for resources in sound driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[ALSA] Remove zero-initialization of static variablesTakashi Iwai
Removed zero-initializations of static variables. A tiny optimization. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
