path: root/sound/synth/emux
2006-03-22[ALSA] semaphore -> mutex (driver part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] seq: set client name in snd_seq_create_kernel_client()Clemens Ladisch
All users of snd_seq_create_kernel_client() have to set the client name anyway, so we can just pass the name as parameter. This relieves us from having to muck around with a struct snd_seq_client_info in these cases. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] seq: remove struct snd_seq_client_callbackClemens Ladisch
The fields of struct snd_seq_client_callback either aren't used or are always set to the same value, so we can get rid of it altogether. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Fix possible races in timer callbacksTakashi Iwai
Fix possible races in timer callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: Emu-X synthTakashi Iwai
Modules: Common EMU synth,SoundFont,Synth Remove xxx_t typedefs from the Emu-X synth support. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] emux - Avoid cast of function pointersTakashi Iwai
Modules: Common EMU synth Pass the proper functions instead of cast of function pointers, which can be dangerous with compiler optimizations. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Fix emu10k1 synth problems.Tim
Modules: EMU10K1/EMU10K2 driver,Common EMU synth This patch fixes problems with voices cutting off or not sounding at all. Signed-off-by: Tim <tedon@rogers.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - othersTakashi Iwai
Documentation,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,OPL3 OPL4,Digigram VX core,I2C cs8427,I2C lib core,I2C tea6330t,L3 drivers AK4114 receiver,AK4117 receiver,PDAudioCF driver,PPC PMAC driver SPARC AMD7930 driver,SPARC cs4231 driver,Synth,Common EMU synth USB generic driver,USB USX2Y Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] Fix missing spin_unlockTakashi Iwai
au88x0 driver,Common EMU synth Fixed missing spin_unlock. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-06-23[PATCH] create a kstrdup library functionPaulo Marques
This patch creates a new kstrdup library function and changes the "local" implementations in several places to use this function. Most of the changes come from the sound and net subsystems. The sound part had already been acknowledged by Takashi Iwai and the net part by David S. Miller. I left UML alone for now because I would need more time to read the code carefully before making changes there. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[ALSA] Remove redundant NULL checks before kfreeJesper Juhl
Timer Midlevel,ALSA sequencer,ALSA<-OSS sequencer,Digigram VX core I2C tea6330t,GUS Library,VIA82xx driver,VIA82xx-modem driver CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,YMFPCI driver Digigram VX Pocket driver,Common EMU synth,USB generic driver,USB USX2Y Checking a pointer for NULL before calling kfree() on it is redundant, kfree() deals with NULL pointers just fine. This patch removes such checks from sound/ This patch also makes another, but closely related, change. It avoids casting pointers about to be kfree()'ed. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
