path: root/sound/usb/Makefile
2010-05-31ALSA: usb-audio: parse clock topology of UAC2 devicesDaniel Mack
Audio devices which comply to the UAC2 standard can export complex clock topologies in its descriptors and set up links between them. The entities that are defined are - clock sources, which define the end-leafs. - clock selectors, which act as switch to select one out of many possible clocks sources. - clock multipliers, which have an input clock source, and act as clock source again. They can be used to derive one clock from another. All sample rate changes, clock validity queries and the like must go to clock source elements, while clock selectors and multipliers can be used as terminal clock source. The following patch adds a parser for these elements and functions to iterate over the tree and find the leaf nodes (clock sources). The samplerate set functions were moved to the new clock.c file. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-12ALSA: usbmixer: rename usbmixer.[ch] -> mixer.[ch]Daniel Mack
For clearer namespace, also rename usbmixer_maps.c -> mixer_maps.c Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-12ALSA: usb-mixer: factor out quirksDaniel Mack
Move all non-standard mixer controls and vendor-specific extensions to a separate file. Some structs need to be exported now. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: refactor codeDaniel Mack
Clean up the usb audio driver by factoring out a lot of functions to separate files. Code for procfs, quirks, urbs, format parsers etc all got a new home now. Moved almost all special quirk handling to quirks.c and introduced new generic functions to handle them, so the exceptions do not pollute the whole driver. Renamed usbaudio.c to card.c because this is what it actually does now. Renamed usbmidi.c to midi.c for namespace clarity. Removed more things from usbaudio.h. The non-standard drivers were adopted accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: header file cleanupsDaniel Mack
Rename snd-usb-lib to snd-usbmidi-lib as MIDI functions are the only thing it actually contains. Introduce a new header file to only declare these functions. Introduced usbmixer.h for all functions exported by usbmixer.c. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: move ua101 driverDaniel Mack
As part of the USB audio code cleanup, move the non-standard ua101 driver out of the way. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-14sound: add Edirol UA-101 supportClemens Ladisch
Add experimental support for the Edirol UA-101 audio/MIDI interface. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-01ALSA: Add USB US122L driverKarsten Wiese
Added a new US122L usb-audio driver. This driver works together with a dedicated alsa-lib plugin. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-05-11[ALSA] Add Native Instrument usb audio device supportDaniel Mack
Add snd-usb-caiaq driver to support caiaq usb-audio devices from Native Instrument: * Native Instruments RigKontrol2 * Native Instruments Kore Controller * Native Instruments Audio Kontrol 1 * Native Instruments Audio 8 DJ Signed-off-by: Daniel Mack <daniel@caiaq.org> Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
