path: root/sound/usb/caiaq/caiaq-device.c
2009-04-14ALSA: snd-usb-caiaq: rename files to remove redundant information in file pathesDaniel Mack
Cleanup only, no functional change. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-14ALSA: snd-usb-caiaq: clean up header includesDaniel Mack
2009-03-24Merge branch 'topic/usb-caiaq' into for-linusTakashi Iwai
2009-03-24Merge branch 'topic/snd_card_new-err' into for-linusTakashi Iwai
2009-03-18ALSA: snd-usb-caiaq: bump version numberDaniel Mack
2009-03-18ALSA: snd-usb-caiaq: drop bogus iso packetsDaniel Mack
Drop inbound packets that are smaller than expected. This has been observed at the very beginning of the streaming transaction. And when the hardware is in panic mode (which can only very rarely happen in case of massive EMI chaos), mute the input channels. Signed-off-by: Daniel Mack <daniel@caiaq.de> Tested-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: snd-usb-caiaq: Increase version number to 1.3.12Mark Hills
Indicates fixes affecting control messages and switching of input mode on Audio 8 DJ and Audio 4 DJ. Signed-off-by: Mark Hills <mark@pogo.org.uk> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: snd-usb-caiaq: Set default input mode of A4DJMark Hills
Do not start the device with input mode undefined. Mimic the behaviour of the Audio 8 DJ and start in phono input mode. Signed-off-by: Mark Hills <mark@pogo.org.uk> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-16ALSA: snd-usb-caiaq: support for two more audio devicesDaniel Mack
- Added support for two new audio devices from Native Instuments, 'Audio4DJ' and 'GuitarRig mobile' - Add missing statement about 'Session IO' in Kconfig help text - Version number bumped to 1.3.11 Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Return proper error code at probe in sound/usb/*Takashi Iwai
Some drivers in soudn/usb/* don't handle the error code properly from snd_card_create(). This patch fixes these places. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-09ALSA: caiaq - Version 1.3.10Takashi Iwai
Increase the version number in module info to indicate the fixes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-02ALSA: Use usb_set/get_intfdataJulia Lawall
Use the USB functions usb_get_intfdata and usb_set_intfdata instead of dev_get_drvdata and dev_set_drvdata, respectively. The semantic patch that makes this change for the usb_get_intfdata case is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @header@ @@ #include <linux/usb.h> @same depends on header@ position p; @@ usb_get_intfdata@p(...) { ... } @depends on header@ position _p!=same.p; identifier _f; struct usb_interface*intf; @@ _f@_p(...) { <+... - dev_get_drvdata(&intf->dev) + usb_get_intfdata(intf) ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-27ALSA: snd-usb-caiaq: clean up the control adding codeDaniel Mack
snd-usb-caiaq: clean up the control adding code by moving dulpicate code to a function. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-19[ALSA] snd_usb_caiaq: add support for 'Session I/O' interfaceDaniel Mack
This patch adds suport for Native Instruments new 'Guitar Rig Session I/O' audio hardware. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-21caiaq endianness fixAl Viro
2008-04-24[ALSA] snd_usb_caiaq: make high sample rates work with A8DJDaniel Mack
This patch for snd_usb_caiaq makes sample rates higher dann 48KHz work with devices which have more than 2 stereo input/output pairs. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] snd_usb_caiaq: correct input channel orderDaniel Mack
This patch corrects the input channel order of hardware supported by snd_usb_caiaq. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] snd_usb_caiaq: fix potential lockups lockingDaniel Mack
This patch fixes potential lockups in snd_usb_caiaq by refining the locking mechanims and by using usb_kill_urb() in favor to usb_unlink_urb(). Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-22[ALSA] caiaq - fix section mismatch warningSam Ravnborg
Fix following warning: WARNING: vmlinux.o(.text+0x11ec01a): Section mismatch in reference from the function setup_card() to the function .devinit.text:snd_usb_caiaq_control_init() setup_card() are only used by init_card(). init_card() are only used by snd_probe() snd_probe() are used for the .probe parameter in usb_driver.probe Annotate them all __devinit to fix the warning. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[ALSA] usb/caiaq: decrease period_bytes_minDaniel Mack
This patch decreases the snd_pcm_hardware->period_bytes_min field in the caiaq/usb audio driver. The hardware can actually handle as few as 128 bytes, depending on the system. So it makes no sense to keep applications from actually using such values. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] usb-caiaq - add support for Kore controller 2Daniel Mack
Added support for Native Instrument's Kore controller 2. This device has no audio but MIDI, input devices and ALSA controllers only. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] caiaq - add control API and more input featuresDaniel Mack
- added support for all input controllers on Native Instrument's 'Kore controller'. - added ALSA controls to switch LEDs on 'RigKontrol 2', 'RigKontrol3', 'Audio Kontrol 1' and 'Kore controller'. - added ALSA controls to switch input mode, software lock and ground lift features on 'Audio 8 DJ'. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] caiaq - support for Native Instrument's RigKontrol3Daniel Mack
This patch adds support for Native Instrument's upcoming RigKontrol3 sound interface. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add Native Instrument usb audio device supportDaniel Mack
Add snd-usb-caiaq driver to support caiaq usb-audio devices from Native Instrument: * Native Instruments RigKontrol2 * Native Instruments Kore Controller * Native Instruments Audio Kontrol 1 * Native Instruments Audio 8 DJ Signed-off-by: Daniel Mack <daniel@caiaq.org> Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
