path: root/sound/usb/card.c
2011-09-26ALSA: usb-audio: Check for possible chip NULL pointer before clearing ↵Thomas Pfaff
probing flag Before clearing the probing flag in the error exit path, check that the chip pointer is not NULL. Signed-off-by: Thomas Pfaff <tpfaff@gmx.net> Cc: <stable@kernel.org> [2.6.39+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-23ALSA: usb-audio - clear chip->probing on error exitThomas Pfaff
The Terratec Aureon 5.1 USB sound card support is broken since kernel 2.6.39. 2.6.39 introduced power management support for USB sound cards that added a probing flag in struct snd_usb_audio. During the probe of the card it gives following error message : usb 7-2: new full speed USB device number 2 using uhci_hcd cannot find UAC_HEADER snd-usb-audio: probe of 7-2:1.3 failed with error -5 input: USB Audio as /devices/pci0000:00/0000:00:1d.1/usb7/7-2/7-2:1.3/input/input6 generic-usb 0003:0CCD:0028.0001: input: USB HID v1.00 Device [USB Audio] on usb-0000:00:1d.1-2/input3 I can not comment about that "cannot find UAC_HEADER" error, but until 2.6.38 the card worked anyway. With 2.6.39 chip->probing remains 1 on error exit, and any later ioctl stops in snd_usb_autoresume with -ENODEV. Signed-off-by: Thomas Pfaff <tpfaff@gmx.net> Cc: <stable@kernel.org> [2.6.39+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-08ALSA: usb-audio: replace "void *" with more specific pointersPavel Roskin
Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: export snd_usb_feature_unit_ctlDaniel Mack
In order to allow quirks functions to hook up to the standard feature unit op tables, this patch exports a pointer to the struct that is used internally. That way, all the code handling the control can be kept private, and external code can reference the symbol to re-use it. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: move assignment of chip->ctrl_intfDaniel Mack
This is needed for upcoming changes to the quirks mechanism. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-21ALSA: usb - Remove trailing spaces from USB card name stringsTakashi Iwai
Some USB devices give trailing spaces in strings returned from usb_string(). This confuses the automatic card-id creation, resulting always in "default". This patch fixes the behavior by removing trailing spaces. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: usbaudio: implement USB autosuspendOliver Neukum
Devices are autosuspended if no pcm nor midi channel is open Mixer devices may be opened. This way they are active when in use to play or record sound, but can be suspended while users have a mixer application running. [Small clean-ups using static inline by tiwai] Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: usbaudio: fix suspend/resumeOliver Neukum
- ESHUTDOWN must be correctly handled - the optional interrupt endpoint's URB must be stopped and restarted Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: usb-audio: fix oops due to cleanup race when disconnectingTakashi Iwai
When a USB audio device is disconnected, snd_usb_audio_disconnect() kills all audio URBs. At the same time, the application, after being notified of the disconnection, might close the device, in which case ALSA calls the .hw_free callback, which should free the URBs too. Commit de1b8b93a0ba "[ALSA] Fix hang-up at disconnection of usb-audio" prevented snd_usb_hw_free() from freeing the URBs to avoid a hang that resulted from this race, but this introduced another race because the URB callbacks could now be executed after snd_usb_hw_free() has returned, and try to access already freed data. Fix the first race by introducing a mutex to serialize the disconnect callback and all PCM callbacks that manage URBs (hw_free and hw_params). Reported-and-tested-by: Pierre-Louis Bossart <pierre-louis.bossart@intel.com> Cc: <stable@kernel.org> [CL: also serialize hw_params callback] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-09Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-08ALSA: usb - Release capture substream URBs properlyTakashi Iwai
Due to the wrong "return" in the loop, a capture substream won't be released at disconnection properly if the device is capture only and has no playback substream. This caused Oops occasionally at the device reconnection. Reported-by: Kim Minhyoung <minhyoung.kim@lge.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-03Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-03ALSA: usb-audio: fix detection of vendor-specific device protocol settingsClemens Ladisch
The Audio Class v2 support code in 2.6.35 added checks for the bInterfaceProtocol field. However, there are devices (usually those detected by vendor-specific quirks) that do not have one of the predefined values in this field, which made the driver reject them. To fix this regression, restore the old behaviour, i.e., assume that a device with an unknown bInterfaceProtocol field (other than UAC_VERSION_2) has more or less UAC-v1-compatible descriptors. [compile warning fixes by tiwai] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-02ALSA: usb-audio: Assume first control interface is for audioDaniel Mack
For devices with more than one control interface, let's assume the first one contains the audio controls. Unfortunately, there is no field in any of the descriptors to tell us whether a control interface is for audio or MIDI controls, so a better check is not easy to implement. On a composite device with audio and MIDI functions, for example, the code currently overwrites chip->ctrl_intf, causing operations on the control interface to fail if they are issued after the device probe. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-14ALSA: usb: USB3 SuperSpeed sound supportPaul Zimmerman
This is V2 of the patch, after feedback from Clemens and Daniel. This patch adds SuperSpeed support to the USB drivers under sound/. It adds tests for USB_SPEED_SUPER to the appropriate places that check for the USB speed. This patch has been tested with our SS USB3 device emulating a set of Yamaha speakers and a Logitech microphone, but with the descriptors modified to add USB3 support. It has also been tested with the real speakers and microphone, to make sure that USB2 devices still work. Signed-off-by: Paul Zimmerman <paulz@synopsys.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-23ALSA: usb-audio: unify UAC macros and struct namesDaniel Mack
Get rid of the last occurances of _v1 suffixes, and move the version number right after the "uac" string. Now things are consitent again. Sorry for the forth and back, but it just looks much nicer this way. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: parse clock topology of UAC2 devicesDaniel Mack
Audio devices which comply to the UAC2 standard can export complex clock topologies in its descriptors and set up links between them. The entities that are defined are - clock sources, which define the end-leafs. - clock selectors, which act as switch to select one out of many possible clocks sources. - clock multipliers, which have an input clock source, and act as clock source again. They can be used to derive one clock from another. All sample rate changes, clock validity queries and the like must go to clock source elements, while clock selectors and multipliers can be used as terminal clock source. The following patch adds a parser for these elements and functions to iterate over the tree and find the leaf nodes (clock sources). The samplerate set functions were moved to the new clock.c file. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-22ALSA: usb: fix usb build error when PM is not enabledRandy Dunlap
Fix build errors when CONFIG_PM is not enabled: sound/usb/card.c:629: error: 'usb_audio_suspend' undeclared here (not in a function) sound/usb/card.c:630: error: 'usb_audio_resume' undeclared here (not in a function) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-12ALSA: usbmixer: rename usbmixer.[ch] -> mixer.[ch]Daniel Mack
For clearer namespace, also rename usbmixer_maps.c -> mixer_maps.c Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-12linux/usb/audio.h: split headerDaniel Mack
- Split the audio.h file in two to clearly denote the differences between the standards. - Add many more defines to audio-v2.h. Most of them are not currently used. - Replaced a magic value with a proper define Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: refactor codeDaniel Mack
Clean up the usb audio driver by factoring out a lot of functions to separate files. Code for procfs, quirks, urbs, format parsers etc all got a new home now. Moved almost all special quirk handling to quirks.c and introduced new generic functions to handle them, so the exceptions do not pollute the whole driver. Renamed usbaudio.c to card.c because this is what it actually does now. Renamed usbmidi.c to midi.c for namespace clarity. Removed more things from usbaudio.h. The non-standard drivers were adopted accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
