path: root/sound/usb/endpoint.c
2010-09-03Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-03ALSA: usb-audio: fix detection of vendor-specific device protocol settingsClemens Ladisch
The Audio Class v2 support code in 2.6.35 added checks for the bInterfaceProtocol field. However, there are devices (usually those detected by vendor-specific quirks) that do not have one of the predefined values in this field, which made the driver reject them. To fix this regression, restore the old behaviour, i.e., assume that a device with an unknown bInterfaceProtocol field (other than UAC_VERSION_2) has more or less UAC-v1-compatible descriptors. [compile warning fixes by tiwai] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-02ALSA: usb-audio: fix Fast Track Ultra (8R) 44.1 sample ratesClemens Ladisch
The M-Audio Fast Track Ultra series devices did not play sound correctly at 44.1/88.2 kHz. Changing the output endpoint attribute to adaptive fixes this. Signed-off-by: Felix Homann <fexpop@web.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-23ALSA: usb-audio: simplify control interface accessDaniel Mack
As the control interface is now carried in struct snd_usb_audio, we can simplify the API a little and also drop the private ctrlif field from struct usb_mixer_interface. Also remove a left-over function prototype in pcm.h. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-23ALSA: usb-audio: unify UAC macros and struct namesDaniel Mack
Get rid of the last occurances of _v1 suffixes, and move the version number right after the "uac" string. Now things are consitent again. Sorry for the forth and back, but it just looks much nicer this way. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-21ALSA: usb/endpoint, fix dangling pointer useJiri Slaby
Stanse found that in snd_usb_parse_audio_endpoints, there is a dangling pointer dereference. When snd_usb_parse_audio_format fails, fp is freed, and continue invoked. On the next loop, there is "fp && fp->altsetting == 1 && fp->channels == 1" test, but fp is set from the last iteration (but is bogus) and thus ilegally dereferenced. Set fp to NULL before "continue". Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: parse clock topology of UAC2 devicesDaniel Mack
Audio devices which comply to the UAC2 standard can export complex clock topologies in its descriptors and set up links between them. The entities that are defined are - clock sources, which define the end-leafs. - clock selectors, which act as switch to select one out of many possible clocks sources. - clock multipliers, which have an input clock source, and act as clock source again. They can be used to derive one clock from another. All sample rate changes, clock validity queries and the like must go to clock source elements, while clock selectors and multipliers can be used as terminal clock source. The following patch adds a parser for these elements and functions to iterate over the tree and find the leaf nodes (clock sources). The samplerate set functions were moved to the new clock.c file. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-27ALSA: usb-audio: parse UAC2 endpoint descriptors correctlyDaniel Mack
UAC2 devices have their information about pitch control stored in a different field. Parse it, and emulate the bits for a v1 device. A new struct uac2_iso_endpoint_descriptor is added. Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-27ALSA: usb-audio: parse more format descriptors with structsDaniel Mack
2010-03-29ALSA: usb - use of kmalloc/kfree requires the include of slab.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-25ALSA: usbaudio: Add basic support for M-Audio Fast Track Ultra seriesFelix Homann
This adds basic support for M-Audio's Fast Track Ultra series of USB audio interfaces. It is a refactored version of the patch Clemens Ladisch posted some time ago. Neither playback nor capturing work properly at 44100 Hz (don't know why). The other sampling rates work properly. There's no support for the DSP mixer, yet. Signed-off-by: Felix Homann <fexpop@web.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-12linux/usb/audio.h: split headerDaniel Mack
- Split the audio.h file in two to clearly denote the differences between the standards. - Add many more defines to audio-v2.h. Most of them are not currently used. - Replaced a magic value with a proper define Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: add support for samplerate setting on v2 devicesDaniel Mack
Sample rate setting is done with a 4-byte long class request that addresses the interface. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: use a format bitmask per alternate settingClemens Ladisch
In preparation for USB audio 2.0 support, change the audioformat structure so that it uses a bitmask to specify possible formats. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: refactor codeDaniel Mack
Clean up the usb audio driver by factoring out a lot of functions to separate files. Code for procfs, quirks, urbs, format parsers etc all got a new home now. Moved almost all special quirk handling to quirks.c and introduced new generic functions to handle them, so the exceptions do not pollute the whole driver. Renamed usbaudio.c to card.c because this is what it actually does now. Renamed usbmidi.c to midi.c for namespace clarity. Removed more things from usbaudio.h. The non-standard drivers were adopted accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
