path: root/sound/usb/format.c
2010-09-03ALSA: usb-audio: fix detection of vendor-specific device protocol settingsClemens Ladisch
The Audio Class v2 support code in 2.6.35 added checks for the bInterfaceProtocol field. However, there are devices (usually those detected by vendor-specific quirks) that do not have one of the predefined values in this field, which made the driver reject them. To fix this regression, restore the old behaviour, i.e., assume that a device with an unknown bInterfaceProtocol field (other than UAC_VERSION_2) has more or less UAC-v1-compatible descriptors. [compile warning fixes by tiwai] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-15ALSA: sound/usb/format: silence uninitialized variable warningsDan Carpenter
Gcc complains that ret might be used uninitialized: sound/usb/format.c: In function ‘snd_usb_parse_audio_format’: sound/usb/format.c:354: warning: ‘ret’ may be used uninitialized in this function sound/usb/format.c:354: note: ‘ret’ was declared here sound/usb/format.c:414: warning: ‘ret’ may be used uninitialized in this function sound/usb/format.c:414: note: ‘ret’ was declared here I suppose it could be uninitialized if there is ever a UAC_VERSION_3 released. Anyway this patch is worthwhile if only to silence the gcc warning. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-23ALSA: usb-audio: simplify control interface accessDaniel Mack
As the control interface is now carried in struct snd_usb_audio, we can simplify the API a little and also drop the private ctrlif field from struct usb_mixer_interface. Also remove a left-over function prototype in pcm.h. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-11ALSA: usb-audio: parse UAC2 sample rate ranges correctlyDaniel Mack
A device may report its supported sample rates in ranges rather than in discrete triplets. The code used to only parse the MIN field instead of properly paying attention to the MAX and RES values. Also, handle RES values of 1 correctly and announce a continous sample rate range in this case. Signed-off-by: Daniel Mack <daniel@caiaq.de> Reported-by: Alex Lee <alexlee188@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-11ALSA: usb-audio: fix control messages for USB_RECIP_INTERFACEDaniel Mack
Control messages directed to an interface must have the interface number set in the lower 8 bits of wIndex. This wasn't done correctly for some clock and mixer messages. Signed-off-by: Daniel Mack <daniel@caiaq.de> Reported-by: Alex Lee <alexlee188@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-11ALSA: usb-audio: add check for faulty clock in parse_audio_format_rates_v2()Daniel Mack
2010-05-31ALSA: usb-audio: parse clock topology of UAC2 devicesDaniel Mack
Audio devices which comply to the UAC2 standard can export complex clock topologies in its descriptors and set up links between them. The entities that are defined are - clock sources, which define the end-leafs. - clock selectors, which act as switch to select one out of many possible clocks sources. - clock multipliers, which have an input clock source, and act as clock source again. They can be used to derive one clock from another. All sample rate changes, clock validity queries and the like must go to clock source elements, while clock selectors and multipliers can be used as terminal clock source. The following patch adds a parser for these elements and functions to iterate over the tree and find the leaf nodes (clock sources). The samplerate set functions were moved to the new clock.c file. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-27ALSA: usb-audio: fix return valuesDaniel Mack
-1 is not a good return value as it means -EPERM, "not permitted". Choose -ENOTSUPP instead, which is what the code really wants to tell its callers. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-27ALSA: usb-audio: parse more format descriptors with structsDaniel Mack
2010-03-29ALSA: usb - use of kmalloc/kfree requires the include of slab.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-12ALSA: usb-mixer: use defines from audio.hDaniel Mack
No need for the private enum. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-12linux/usb/audio.h: split headerDaniel Mack
- Split the audio.h file in two to clearly denote the differences between the standards. - Add many more defines to audio-v2.h. Most of them are not currently used. - Replaced a magic value with a proper define Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: support multiple formats with audio class v2 devicesClemens Ladisch
Change the parser to correctly handle v2 descriptors with multiple format bits set. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: use a format bitmask per alternate settingClemens Ladisch
In preparation for USB audio 2.0 support, change the audioformat structure so that it uses a bitmask to specify possible formats. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: refactor codeDaniel Mack
Clean up the usb audio driver by factoring out a lot of functions to separate files. Code for procfs, quirks, urbs, format parsers etc all got a new home now. Moved almost all special quirk handling to quirks.c and introduced new generic functions to handle them, so the exceptions do not pollute the whole driver. Renamed usbaudio.c to card.c because this is what it actually does now. Renamed usbmidi.c to midi.c for namespace clarity. Removed more things from usbaudio.h. The non-standard drivers were adopted accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
