commit 862a6244eb9f9f5123fe819454fcfcae0ee1f2f9 upstream.
If the device is unplugged while running, it is possible for a PCM
device to be closed after the disconnect callback has returned. This
means that kill_stream_urb() and disable_iso_interface() would try to
access already-invalid or freed USB data structures.
The function free_usb_related_resources() was intended to prevent this,
but forgot to clear the affected variables.
Reported-and-tested-by: Olivier Courtay <olivier@courtay.org>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Since commit f2b3614cefb6 (Don't check DMA time-out too shortly),
drivers need no longer restrict their PCM period length to be shorter
than 10 seconds.
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits)
USB: remove unused usb_buffer_alloc and usb_buffer_free macros
usb: musb: update gfp/slab.h includes
USB: ftdi_sio: fix legacy SIO-device header
USB: kl5usb105: reimplement using generic framework
USB: kl5usb105: minor clean ups
USB: kl5usb105: fix memory leak
USB: io_ti: use kfifo to implement write buffering
USB: io_ti: remove unsused private counter
USB: ti_usb: use kfifo to implement write buffering
USB: ir-usb: fix incorrect write-buffer length
USB: aircable: fix incorrect write-buffer length
USB: safe_serial: straighten out read processing
USB: safe_serial: reimplement read using generic framework
USB: safe_serial: reimplement write using generic framework
usb-storage: always print quirks
USB: usb-storage: trivial debug improvements
USB: oti6858: use port write fifo
USB: oti6858: use kfifo to implement write buffering
USB: cypress_m8: use kfifo to implement write buffering
USB: cypress_m8: remove unused drain define
Fix up conflicts (due to usb_buffer_alloc/free renaming) in
drivers/input/tablet/acecad.c
drivers/input/tablet/kbtab.c
drivers/input/tablet/wacom_sys.c
drivers/media/video/gspca/gspca.c
sound/usb/usbaudio.c
Clean up the usb audio driver by factoring out a lot of functions to
separate files. Code for procfs, quirks, urbs, format parsers etc all
got a new home now.
Moved almost all special quirk handling to quirks.c and introduced new
generic functions to handle them, so the exceptions do not pollute the
whole driver.
Renamed usbaudio.c to card.c because this is what it actually does now.
Renamed usbmidi.c to midi.c for namespace clarity.
Removed more things from usbaudio.h.
The non-standard drivers were adopted accordingly.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Clemens Ladisch <clemens@ladisch.de>
Rename snd-usb-lib to snd-usbmidi-lib as MIDI functions are the only
thing it actually contains. Introduce a new header file to only declare
these functions.
Introduced usbmixer.h for all functions exported by usbmixer.c.
As part of the USB audio code cleanup, move the non-standard ua101
driver out of the way.
