path: root/sound/usb/pcm.h
2010-06-23ALSA: usb-audio: simplify control interface accessDaniel Mack
As the control interface is now carried in struct snd_usb_audio, we can simplify the API a little and also drop the private ctrlif field from struct usb_mixer_interface. Also remove a left-over function prototype in pcm.h. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: add support for samplerate setting on v2 devicesDaniel Mack
Sample rate setting is done with a 4-byte long class request that addresses the interface. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: refactor codeDaniel Mack
Clean up the usb audio driver by factoring out a lot of functions to separate files. Code for procfs, quirks, urbs, format parsers etc all got a new home now. Moved almost all special quirk handling to quirks.c and introduced new generic functions to handle them, so the exceptions do not pollute the whole driver. Renamed usbaudio.c to card.c because this is what it actually does now. Renamed usbmidi.c to midi.c for namespace clarity. Removed more things from usbaudio.h. The non-standard drivers were adopted accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
