path: root/sound/usb
2011-08-19ALSA: usb-audio - Fix missing mixer dB informationTakashi Iwai
The recent fix for testing dB range at the mixer creation time seems to cause regressions in some devices. In such devices, reading the dB info at probing time gives an error, thus both dBmin and dBmax are still zero, and TLV flag isn't set although the later read of dB info succeeds. This patch adds a workaround for such a case by assuming that the later read will succeed. In future, a similar test should be performed in a case where a wrong dB range is seen even in the later read. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: <stable@kernel.org>
2011-08-14ALSA: snd_usb_caiaq: track submitted output urbsDaniel Mack
The snd_usb_caiaq driver currently assumes that output urbs are serviced in time and doesn't track when and whether they are given back by the USB core. That usually works fine, but due to temporary limitations of the XHCI stack, we faced that urbs were submitted more than once with this approach. As it's no good practice to fire and forget urbs anyway, this patch introduces a proper bit mask to track which requests have been submitted and given back. That alone however doesn't make the driver work in case the host controller is broken and doesn't give back urbs at all, and the output stream will stop once all pre-allocated output urbs are consumed. But it does prevent crashes of the controller stack in such cases. See http://bugzilla.kernel.org/show_bug.cgi?id=40702 for more details. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Matej Laitl <matej@laitl.cz> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-10ALSA: snd-usb-caiaq: Correct offset fields of outbound iso_frame_descDaniel Mack
This fixes faulty outbount packets in case the inbound packets received from the hardware are fragmented and contain bogus input iso frames. The bug has been there for ages, but for some strange reasons, it was only triggered by newer machines in 64bit mode. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: William Light <wrl@illest.net> Reported-by: Pedro Ribeiro <pedrib@gmail.com> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-10ALSA: usb-audio - Add quirk for BOSS Micro BR-80Kazutomo Yoshii
Signed-off-by: Kazutomo Yoshii <kazutomo.yoshii@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-06ALSA: snd-usb-caiaq: Fix keymap for RigKontrol3Daniel Mack
Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Renato <naretobh@gmail.com> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-06ALSA: snd-usb: Fix uninitialized variable usageDaniel Mack
Purely cosmetic, but fixes the following build warning. CC [M] sound/usb/quirks.o sound/usb/quirks.c: In function ‘snd_usb_apply_boot_quirk’: sound/usb/quirks.c:429:6: warning: ‘err’ may be used uninitialized in this function [-Wuninitialized] Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-05ALSA: usb-audio - add quirk for Keith McMillen StringPortMiller Puckette
Signed-off-by: Miller Puckette <msp@ucsd.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-04ALSA: snd-usb: operate on given mixer interface onlyDaniel Mack
When creating the mixers for an USB audio device, the current code looks at the host interface stored in mixer->chip->ctrl_if. Change this and rather keep a local pointer to the interface that was given when snd_usb_create_mixer() was called. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Nicolai Krakowiak <nicolai.krakowiak@gmail.com> Reported-by: Lean-Yves LENHOF <jean-yves@lenhof.eu.org> Acked-by: Clemens Ladisch <clemens@ladisch.de> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-04ALSA: snd-usb: avoid dividing by zero on invalid inputNicolai Krakowiak
Signed-off-by: Nicolai Krakowiak <nicolai.krakowiak@gmail.com> Acked-by: Daniel Mack <zonque@gmail.com> Acked-by: Clemens Ladisch <clemens@ladisch.de> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-04ALSA: snd-usb: Accept UAC2 FORMAT_TYPE descriptors with bLength > 6Clemens Ladisch
The Focusrite Scarlett 18i6 USB has them that way, which is probably a bug. Anyway, the driver should simply ignore this fact. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Nicolai Krakowiak <nicolai.krakowiak@gmail.com> Cc: stable@kernel.org Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-21ALSA: usb-audio - Add quirk for Roland / BOSS BR-800David G Turner
Add support for Roland/BOSS BR-800 (0582:011e) to snd-usb-audio driver. This allows playback and recording, which has been tested and found to work. The third interface should be MIDI (MTC/SMPTE?) for DAW interface and is set as per ME-25, but this has not been tested. SDHC card access is already supported by usb-storage for Backup/Rhythm Editor/Wave Convertor mode which should not conflict with this. Signed-off-by: David G Turner <dgturner@iee.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-12ALSA: usb-audio - Add quirks for M-Audio Fast Track Pro and QuattroGuillaume Pellerin
This patch gives M-Audio Fast Track Pro and M-Audio Quattro quirks and endpoints to boot and setup those devices with special options (digital inputs and outputs, 24 bits mode, etc...). M-Audio Audiophile quirks are just adapted to match the new global M-Audio parameters. Special configurations can be then loaded through a modprobe conf file. For example, to set the 24 bits mode on the Fast Track Pro add /etc/modprobe.d/fast_track_pro.conf : options snd_usb_audio vid=0x763 pid=0x2012 device_setup=0x08 Here is a list of the possibilities in this example : http://files.parisson.com/debian/fast-track-pro.conf Signed-off-by: Guillaume Pellerin <yomguy@parisson.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-08ALSA: usb-audio: replace "void *" with more specific pointersPavel Roskin
Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-17Merge branch 'fix/hda' into topic/miscTakashi Iwai
2011-06-17ALSA: firewire-speakers, oxygen, ua101: allow > 10 s periodsClemens Ladisch
Since commit f2b3614cefb6 (Don't check DMA time-out too shortly), drivers need no longer restrict their PCM period length to be shorter than 10 seconds. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-16ALSA: 6fire - Fix signedness bugTorsten Schenk
Fixed remaining issues of the signedness bug discovered by Dan Carpenter. A check was remaining that tests if unsigned rt->rate is >= 0. Changed that so that rt->rate now consistently uses ARRAY_SIZE(rates) as invalid rate value and not -1. Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-14ALSA: 6fire: Fix double-free bug in usb6fire_fw_ezusb_upload()Jesper Juhl
We have a double-free bug in sound/usb/6fire/firmware.c::usb6fire_fw_ezusb_upload(). We already call release_firmware(fw) on line 258, so when we then do it again after usb6fire_fw_ezusb_write() returns <0, we have a double-free. Easily fixed by just removing the last call to release_firmware(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-03ALSA: usb - turn off de-emphasis in s/pdif for cm6206Eric Lammerts
CM6206: Turn off de-emphasis channel status bit in S/PDIF output. Signed-off-by: Eric Lammerts <eric@lammerts.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-02ALSA: 6fire: Don't leak firmware in error pathJesper Juhl
One of the error paths in sound/usb/6fire/firmware.c::usb6fire_fw_ezusb_upload() neglects to free the memory allocated for the firmware before returning, thus leaking the memory. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: more control quirks for M-Audio FastTrack devicesDaniel Mack
Make use of the freshly introduced methods to re-use standard mixer handling and add some controls that are hidden but implemented in a standard conform way on M-Audio's FastTrack devices. Signed-off-by: Daniel Mack <zonque@gmail.com> Original-code-by: Felix Homann <linuxaudio@showlabor.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: add new quirk type QUIRK_AUDIO_STANDARD_MIXERDaniel Mack
This quirk type will let the driver assume that there is a standard mixer on a given interface, or that a specific mixer quirks will handle the device. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: export snd_usb_feature_unit_ctlDaniel Mack
In order to allow quirks functions to hook up to the standard feature unit op tables, this patch exports a pointer to the struct that is used internally. That way, all the code handling the control can be kept private, and external code can reference the symbol to re-use it. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: rework add_control_to_empty()Daniel Mack
This patch renames add_control_to_empty() to snd_usb_mixer_add_control() and exports it, so the quirks functions can make use of it. Also, as "struct mixer_build" is private to mixer.c, rewrite the function to take an argument of type "struct usb_mixer_interface" instead. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: move assignment of chip->ctrl_intfDaniel Mack
This is needed for upcoming changes to the quirks mechanism. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-22Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-05-18ALSA: usb-audio - Add support for USB X-Fi S51 ProMathieu Bouffard
USB X-Fi S51 Pro volume and mute from the volume knob on the unit. Compiled and tested with 2.6.39-rc7-git12 Signed-off-by: Mathieu Bouffard <mbouffard@strangequarks.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-18ALSA: usb-audio: handle "Fast Track Ultra" with USB_DEVICE_VENDOR_SPEC()Daniel Mack
That way, the class compliant MIDI interface is also handled. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Grant Diffey <gdiffey@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-18ALSA: usb-audio: assume valid clockDaniel Mack
If the interface can't report a clock's validity, assume that it's valid. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Vicente Joel <vicentejoel@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-18ALSA: usb-audio: add quirks for Roland GR-55Daniel Mack
Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Jeffrey Scott Flesher <jeffrey.scott.flesher@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-18ALSA: usb-audio: Add quirk for KORG PANDORA PX5D MIDI interfaceDaniel Mack
Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Frédéric Jaume <frederic.jaume@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-18ALSA: usb-audio: remove invalid extra mixers for Komplete Audio 6Daniel Mack
This was a flaw in the reading of the spec tables - Native Instrument's "Komplete Audio 6" device has no such extra controls. This patch also fixes the device name in two comments. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-18ALSA: usb-audio: include format.h in format.cDaniel Mack
Just in case a prototype changes, we'll be warned. This also fixes a sparse warning. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-18ALSA: usb-audio: make hwc_debug a noop in case HW_CONST_DEBUG is not setDaniel Mack
Just defining it to nothing is dangerous as it can alter the code execution flow, for example when used in as only function in a conditional code block. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-28ALSA: usb-audio - Terratec Aureon 7.1 USB ID as C-Media cm6206 quirksWolfgang Breyha
This patch adds support for the Terratec Aureon 7.1 USB which uses a C-Media cm6206 and needs all the quirks already found in the past. Signed-off-by: Wolfgang Breyha <wbreyha@gmx.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-28ALSA: usb-audio - Don't expose broken dB rangesTakashi Iwai
Some crappy USB-audio devices give broken dB ranges, e.g. both min and max are 0dB. This confuses the volume control that prefers dB expression such as alsactl or PulseAudio. In such a case, it's much better not to expose the broken dB information. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-26ALSA: 6fire: use the kernel's built-in bit reverse tableDaniel Mack
Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-14ALSA: usb-audio: Add quirks for Audio Kontrol 6Daniel Mack
This new device by Native Instruments is also compliant to the USB standard v2.0, but hides this detail at when connected. It needs the same boot quirks than other models, and also has two non-class-compliant mixer controls. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Don't query connections for widgets have no connections ALSA: HDA: Fix single internal mic on ALC275 (Sony Vaio VPCSB1C5E) ALSA: hda - HDMI: Fix MCP7x audio infoframe checksums ALSA: usb-audio: define another USB ID for a buggy USB MIDI cable ALSA: HDA: Fix dock mic for Lenovo X220-tablet ASoC: format_register_str: Don't clip register values ASoC: PXA: Fix oops in __pxa2xx_pcm_prepare ASoC: zylonite: set .codec_dai_name in initializer
2011-04-06ALSA: usb-audio: define another USB ID for a buggy USB MIDI cableTarek Soliman
There are many USB MIDI cables out there that have buggy firmware that reports it can do more than 4 bytes in a packet when they can only properly handle 4 This patch adds the ID of yet another one of those cables Signed-off-by: Tarek Soliman <tarek@bashasoliman.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-04ALSA: 6fire - Add support of digital-thru mixerTorsten Schenk
Digital Thru mixer element added (device can act as converter optical<->coax) Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-04ALSA: 6fire - Improve firmware loaderTorsten Schenk
Firmware loader: magical device bytes check updated (accepts all device versions now and accepts possibly loaded firmware, if it is knowing to be working) Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-04ALSA: 6fire - Add support for S32_LE formatTorsten Schenk
Added support for sample format s32_le. Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-04ALSA: 6fire - Fix pcm rate assignmentTorsten Schenk
Completion of signedness bug for pcm_runtime.rate: variable will never get assigned a negative value now. Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-04-04ALSA: 6fire - Update kernel configurationTorsten Schenk
Kernel configuration updated: - experimental dependency removed - description updated Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-23ALSA: usb-audio - Support for Boss JS-8 Jam StationKeith A. Milner
Signed-off-by: Keith A. Milner <maillist@superlative.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-23ALSA: usb-audio: add Cakewalk UM-1G supportClemens Ladisch
Add a quirk for the Cakewalk UM-1G USB MIDI interface in "advanced driver" mode. (It already works in standard mode.) Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-21ALSA: usb - Remove trailing spaces from USB card name stringsTakashi Iwai
Some USB devices give trailing spaces in strings returned from usb_string(). This confuses the automatic card-id creation, resulting always in "default". This patch fixes the behavior by removing trailing spaces. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: usbaudio: implement USB autosuspendOliver Neukum
Devices are autosuspended if no pcm nor midi channel is open Mixer devices may be opened. This way they are active when in use to play or record sound, but can be suspended while users have a mixer application running. [Small clean-ups using static inline by tiwai] Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: usbaudio: fix suspend/resumeOliver Neukum
- ESHUTDOWN must be correctly handled - the optional interrupt endpoint's URB must be stopped and restarted Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
