path: root/sound
2014-09-03Merge tag 'asoc-v3.17-rc3' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.17 A few more driver specific fixes on top of the currently pending fixes (which are already in your tree but not Linus').
2014-09-02Merge remote-tracking branches 'asoc/fix/axi', 'asoc/fix/cs4265', ↵Mark Brown
'asoc/fix/da732x', 'asoc/fix/omap', 'asoc/fix/rsnd', 'asoc/fix/rt5640', 'asoc/fix/rt5677', 'asoc/fix/simple' and 'asoc/fix/tegra' into asoc-linus
2014-09-02Merge remote-tracking branch 'asoc/fix/core' into asoc-linusMark Brown
2014-09-02ALSA: hda - Fix COEF setups for ALC1150 codecTakashi Iwai
ALC1150 codec seems to need the COEF- and PLL-setups just like its compatible ALC882 codec. Some machines (e.g. SunMicro X10SAT) show the problem like too low output volumes unless the COEF setup is applied. Reported-and-tested-by: Dana Goyette <danagoyette@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-09-01ASoC: simple-card: Fix bug of wrong decrement DT node's refcountXiubo Li
DAI links's cpu_of_node's and codec_of_node's refcounts shouldn't be decremented immediately at the end of the probe() fucntion. Because we will still use them before the audio card is removed. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-09-01ALSA: hda - Fix digital mic on Acer Aspire 3830TGTakashi Iwai
Acer Aspire 3830TG with CX20588 codec has a digital built-in mic that has the same problem like many others, the inverted signal in stereo. Apply the same fixup to this machine, too. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-29ASoC: omap-twl4030: Fix typo in 2nd dai link's platform_namePeter Ujfalusi
The platform_name should be omap-mcasp3 for the 2nd link which is used for voice connection. Reported-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie+linaro@kernel.org> Cc: stable@vger.kernel.org
2014-08-29ALSA: firewire-lib/dice: add arrangements of PCM pointer and interrupts for ↵Takashi Sakamoto
Dice quirk In IEC 61883-6, one data block transfers one event. In ALSA, the event equals one PCM frame, hence one data block transfers one PCM frame. But Dice has a quirk at higher sampling rate (176.4/192.0 kHz) that one data block transfers two PCM frames. Commit 10550bea44a8 ("ALSA: dice/firewire-lib: Keep dualwire mode but obsolete CIP_HI_DUALWIRE") moved some codes related to this quirk into Dice driver. But the commit forgot to add arrangements for PCM period interrupts and DMA pointer updates. As a result, Dice driver cannot work correctly at higher sampling rate. This commit adds 'double_pcm_frames' parameter to amdtp structure for this quirk. When this parameter is set, PCM period interrupts and DMA pointer updates occur at double speed than in IEC 61883-6. Reported-by: Daniel Robbins <drobbins@funtoo.org> Fixes: 10550bea44a8 ("ALSA: dice/firewire-lib: Keep dualwire mode but obsolete CIP_HI_DUALWIRE") Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Cc: <stable@vger.kernel.org> # 3.16 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-29ALSA: dice: fix wrong channel mappping at higher sampling rateTakashi Sakamoto
The channel mapping is initialized by amdtp_stream_set_parameters(), however Dice driver set it before calling this function. Furthermore, the setting is wrong because the index is the value of array, and vice versa. This commit moves codes for channel mapping after the function and set it correctly. Reported-by: Daniel Robbins <drobbins@funtoo.org> Fixes: 10550bea44a8 ("ALSA: dice/firewire-lib: Keep dualwire mode but obsolete CIP_HI_DUALWIRE") Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Cc: <stable@vger.kernel.org> # 3.16 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-28ASoC: cs4265: Fix setting of functional mode and clock dividerPaul Handrigan
Reported-by: Zoltán Szenczi <zoltan@raspberrypi.org> Signed-off-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-08-28ASoC: cs4265: Fix clock rates in clock map tablePaul Handrigan
2014-08-28Merge tag 'sound-3.17-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here contains not many exciting changes but just a few minor ones: An off-by-one proc write fix, a couple of trivial incldue guard fixes, Acer laptop pinconfig fix, and a fix for DSD formats that are still rarely used" * tag 'sound-3.17-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Set up initial pins for Acer Aspire V5 ALSA: pcm: Fix the silence data for DSD formats ALSA: ctxfi: ct20k1reg: Fix typo in include guard ALSA: hda: ca0132_regs.h: Fix typo in include guard ALSA: core: fix buffer overflow in snd_info_get_line()
2014-08-27ASoC: rt5677: correct mismatch widget nameBard Liao
We name MICBIAS1 in dapm widget, but micbias1 in route table. Signed-off-by: Bard Liao <bardliao@realtek.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-27ASoC: rt5640: Do not allow regmap to use bulk read-write operationsJarkko Nikula
Debugging showed Realtek RT5642 doesn't support autoincrementing writes so driver should set the use_single_rw flag for regmap. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-08-27ALSA: hda - Set up initial pins for Acer Aspire V5Takashi Iwai
Acer Aspire V5 doesn't set up the pins correctly at the cold boot while the pins are corrected after the warm reboot. This patch gives the proper pin configs statically in the driver as a workaround. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81561 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-22ASoC: tegra: Fix typo in include guardRasmus Villemoes
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-22ASoC: da732x: Fix typo in include guardRasmus Villemoes
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-22ALSA: pcm: Fix the silence data for DSD formatsTakashi Iwai
Right now we set 0 as the silence data for DSD_U8 and DSD_U16 formats, but this is actually wrong. 0 is rather the most negative value. Alternatively, we may take the repeating 0x69 pattern like ffmpeg deploys. Reference: https://ffmpeg.org/pipermail/ffmpeg-cvslog/2014-April/076427.html Suggested-by: Alexander E. Patrakov <patrakov@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-22ALSA: ctxfi: ct20k1reg: Fix typo in include guardRasmus Villemoes
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-22ALSA: hda: ca0132_regs.h: Fix typo in include guardRasmus Villemoes
2014-08-22ALSA: core: fix buffer overflow in snd_info_get_line()Clemens Ladisch
snd_info_get_line() documents that its last parameter must be one less than the buffer size, but this API design guarantees that (literally) every caller gets it wrong. Just change this parameter to have its obvious meaning. Reported-by: Tommi Rantala <tt.rantala@gmail.com> Cc: <stable@vger.kernel.org> # v2.2.26+ Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-21Merge tag 'sound-3.17-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A bunch of ASoC fixes with a few HD-audio fixes in this pull request. All fairly small, boring and device-specific fixes, in addition to MAINTAINERS update for better reviewing" * tag 'sound-3.17-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/hdmi - apply Valleyview fix-ups to Cherryview display codec ALSA: hda/hdmi - set depop_delay for haswell plus ALSA: hda - restore the gpio led after resume ALSA: hda/realtek - Avoid setting wrong COEF on ALC269 & co ASoC: pxa-ssp: drop SNDRV_PCM_FMTBIT_S24_LE ASoC: fsl-esai: Revert .xlate_tdm_slot_mask() support ASoC: mcasp: Fix implicit BLCK divider setting ASoC: arizona: Fix TDM slot length handling in arizona_hw_params ASoC: pcm512x: Correct Digital Playback control names ASoC: dapm: Fix uninitialized variable in snd_soc_dapm_get_enum_double() ASoC: Intel: Restore Baytrail ADSP streams only when ADSP was in reset ASoC: Intel: Wait Baytrail ADSP boot at resume_early stage ASoC: Intel: Merge Baytrail ADSP suspend_noirq into suspend_late MAINTAINERS: Add i.MX maintainers and paths to Freescale ASoC entry ASoC: Intel: Update Baytrail ADSP firmware name
2014-08-19ALSA: hda/hdmi - apply Valleyview fix-ups to Cherryview display codecLibin Yang
Valleyview and Cherryview have the same behavior on display audio. So this patch defines is_valleyview_plus() to include codecs for both Valleyview and its successor Cherryview, and apply Valleyview fix-ups to Cherryview. Signed-off-by: Libin Yang <libin.yang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-19ALSA: hda/hdmi - set depop_delay for haswell plusLibin Yang
Both Haswell and Broadwell need set depop_delay to 0. So apply this setting to haswell plus. Signed-off-by: Libin Yang <libin.yang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-19ALSA: hda - restore the gpio led after resumeHui Wang
On some HP laptops, the mute led is controlled by codec gpio. When some machine resume from s3/s4, the codec gpio data will be cleared to 0 by BIOS: Before suspend: IO[3]: enable=1, dir=1, wake=0, sticky=0, data=1, unsol=0 After resume: IO[3]: enable=1, dir=1, wake=0, sticky=0, data=0, unsol=0 To skip the AFG node to enter D3 can't fix this problem. A workaround is to restore the gpio data when the system resume back from s3/s4. It is safe even on the machines without this problem. BugLink: https://bugs.launchpad.net/bugs/1358116 Tested-by: Franz Hsieh <franz.hsieh@canonical.com> Cc: stable@vger.kernel.org Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-17ASoC: rcar: Use && instead of & for boolean expressionsLars-Peter Clausen
Sparse spits out the following warning: sound/soc/sh/rcar/gen.c:250:21: warning: dubious: x & !y It does this because sometimes mixing boolean and bit-wise logic has not the intended result. In this case we are fine, but replacing the bit-wise '&' with the boolean '&&' silences the sparse warning. The generated code for both cases is the same. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-17ASoC: Use dev_set_name() instead of init_nameLars-Peter Clausen
init_name is basically a hack and should only be used for statically allocated device structs. For dynamically allocated devices dev_set_name() should be used. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-16ALSA: hda/realtek - Avoid setting wrong COEF on ALC269 & coTakashi Iwai
ALC269 & co have many vendor-specific setups with COEF verbs. However, some verbs seem specific to some codec versions and they result in the codec stalling. Typically, such a case can be avoided by checking the return value from reading a COEF. If the return value is -1, it implies that the COEF is invalid, thus it shouldn't be written. This patch adds the invalid COEF checks in appropriate places accessing ALC269 and its variants. The patch actually fixes the resume problem on Acer AO725 laptop. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=52181 Tested-by: Francesco Muzio <muziofg@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-16Merge tag 'asoc-v3.17-rc1' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.17 Nothing too exciting here, a bunch of driver fixes that came along since the initial pull request but none that really stand our and a warning fix in the core.
2014-08-15Merge tag 'sound-fix-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here is the additional fix patches that have been queued up since the previous pull request. A few HD-audio fixes, a USB-audio quirk addition, and a couple of trivial cleanup for the legacy OSS codes" * tag 'sound-fix-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Set TLV_DB_SCALE_MUTE bit for cx5051 vmaster ALSA: hda/ca0132 - Don't try loading firmware at resume when already failed ALSA: hda - Fix pop noises on reboot for Dell XPS 13 9333 ALSA: hda - Set internal mic as default input source on Dell XPS 13 9333 ALSA: usb-audio: fix BOSS ME-25 MIDI regression ALSA: hda - Fix parsing of CMI8888 codec ALSA: hda - Fix probing and stuttering on CMI8888 HD-audio controller ALSA: hda/realtek - Fixed ALC286/ALC288 recording delay for Headset Mic sound: oss: Remove typedefs wanc_info and wavnc_port_info sound: oss: uart401: Remove typedef uart401_devc
2014-08-15Merge remote-tracking branches 'asoc/fix/arizona', 'asoc/fix/fsl', ↵Mark Brown
'asoc/fix/fsl-esai', 'asoc/fix/intel', 'asoc/fix/mcasp' and 'asoc/fix/pxa' into asoc-linus
2014-08-15Merge remote-tracking branch 'asoc/fix/pcm512x' into asoc-linusMark Brown
2014-08-14Merge tag 'pci-v3.17-changes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull DEFINE_PCI_DEVICE_TABLE removal from Bjorn Helgaas: "Part two of the PCI changes for v3.17: - Remove DEFINE_PCI_DEVICE_TABLE macro use (Benoit Taine) It's a mechanical change that removes uses of the DEFINE_PCI_DEVICE_TABLE macro. I waited until later in the merge window to reduce conflicts, but it's possible you'll still see a few" * tag 'pci-v3.17-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Remove DEFINE_PCI_DEVICE_TABLE macro use
2014-08-14Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree updates from Grant Likely: "The branch contains the following device tree changes the v3.17 merge window: Group changes to the device tree. In preparation for adding device tree overlay support, OF_DYNAMIC is reworked so that a set of device tree changes can be prepared and applied to the tree all at once. OF_RECONFIG notifiers see the most significant change here so that users always get a consistent view of the tree. Notifiers generation is moved from before a change to after it, and notifiers for a group of changes are emitted after the entire block of changes have been applied Automatic console selection from DT. Console drivers can now use of_console_check() to see if the device node is specified as a console device. If so then it gets added as a preferred console. UART devices get this support automatically when uart_add_one_port() is called. DT unit tests no longer depend on pre-loaded data in the device tree. Data is loaded dynamically at the start of unit tests, and then unloaded again when the tests have completed. Also contains a few bugfixes for reserved regions and early memory setup" * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux: (21 commits) of: Fixing OF Selftest build error drivers: of: add automated assignment of reserved regions to client devices of: Use proper types for checking memory overflow of: typo fix in __of_prop_dup() Adding selftest testdata dynamically into live tree of: Add todo tasklist for Devicetree of: Transactional DT support. of: Reorder device tree changes and notifiers of: Move dynamic node fixups out of powerpc and into common code of: Make sure attached nodes don't carry along extra children of: Make devicetree sysfs update functions consistent. of: Create unlocked versions of node and property add/remove functions OF: Utility helper functions for dynamic nodes of: Move CONFIG_OF_DYNAMIC code into a separate file of: rename of_aliases_mutex to just of_mutex of/platform: Fix of_platform_device_destroy iteration of devices of: Migrate of_find_node_by_name() users to for_each_node_by_name() tty: Update hypervisor tty drivers to use core stdout parsing code. arm/versatile: Add the uart as the stdout device. of: Enable console on serial ports specified by /chosen/stdout-path ...
2014-08-14ALSA: hda - Set TLV_DB_SCALE_MUTE bit for cx5051 vmasterTakashi Iwai
Conexnat HD-audio driver has a workaround for cx5051 (aka CX20561) chip to add fake mute controls to each amp (commit 3868137e). This implies the minimum-as-mute TLV bit in TLV for each corresponding control. Meanwhile we build the virtual master from these, but the TLV bit is missing, even though the slaves have it. This patch simply adds the missing TLV_DB_SCALE_MUTE bit for vmaster, as already done in patch_sigmatel.c. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-13ASoC: pxa-ssp: drop SNDRV_PCM_FMTBIT_S24_LEDaniel Mack
This mode is unsupported, as the DMA controller can't do zero-padding of samples. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Johannes Stezenbach <js@sig21.net> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-08-13ASoC: fsl-esai: Revert .xlate_tdm_slot_mask() supportShengjiu Wang
This reverts commit a603c8ee526f5ea9ad9b40710308766299ad8a69. fsl_asoc_xlate_tdm_slot_mask() is different with snd_soc_xlate_tdm_slot_mask(). fsl_asoc_xlate_tdm_slot_mask() will set the enabled bit to 0, disabled bit to 1. snd_soc_xlate_tdm_slot_mask() will set the enabled bit to 1, disabled bit to 0. For esai when the bit value is 1, the slot is enabled, when the bit value is 0, the slot is disabled. If using fsl_asoc_xlate_tdm_slot_mask(), the esai will work abnormally. So revert this patch, make the esai use default function. Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com> Acked-by: Nicolin Chen <nicoleotsuka@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-12ASoC: mcasp: Fix implicit BLCK divider settingJyri Sarha
The implicit BLCK divider setting was broken by "ASoC: mcasp: don't override bclk divider if it was provided by the machine"-patch. After the BCLK divider is implicitly set for the first time the mcasp->bclk_div gets a non zero value and the implicit setting is "turned off". Signed-off-by: Jyri Sarha <jsarha@ti.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-12ASoC: arizona: Fix TDM slot length handling in arizona_hw_paramsNikesh Oswal
TDM slot length was set same as word length, regardless of the value received in set_tdm_slot. This patch sets the TDM slot length correctly as received in set_tdm_slot DAI callback Signed-off-by: Nikesh Oswal <Nikesh.Oswal@wolfsonmicro.com> Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-08-12ASoC: pcm512x: Correct Digital Playback control namesMark Brown
The source type should come before the direction specifier according to ControlNames.txt. Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-11ASoC: dapm: Fix uninitialized variable in snd_soc_dapm_get_enum_double()Geert Uytterhoeven
If soc_dapm_read() fails, reg_val will be uninitialized, and bogus values will be written later: sound/soc/soc-dapm.c: In function 'snd_soc_dapm_get_enum_double': sound/soc/soc-dapm.c:2862:15: warning: 'reg_val' may be used uninitialized in this function [-Wmaybe-uninitialized] unsigned int reg_val, val; ^ Return early on error to fix this. Introduced by commit ce0fc93ae56e2ba50ff8c220d69e4e860e889320 ("ASoC: Add DAPM support at the component level"). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de>
2014-08-11Merge branch 'devicetree/next-console' into devicetree/nextGrant Likely
2014-08-11ASoC: Intel: Restore Baytrail ADSP streams only when ADSP was in resetJarkko Nikula
There is no need to restore and restart PCM streams in case ADSP didn't reach reset and power off state during system suspend/resume cycle. In that case stream is still active but paused and firmware doesn't allow allocating a new stream before paused stream is freed. ADSP remains active in case suspend sequence didn't go to suspend_late stage. This can happen when either suspend sequence is aborted by a wakeup or by letting only devices suspend by "echo devices >/sys/power/pm_test". Currently stream restoring fails in these suspend cases. Fix this by adding a flag that indicates is complete stream reinitialization needed or is it enough to resume paused stream. Flag is set when we know that ADSP reached suspend_late. Initial fix to this issue came from Fang Yang. I modified it a little and forward ported it to top of two other suspend/resume patches from me. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Tested-by: Borun Fu <borun.fu@intel.com> Cc: yang fang <yang.a.fang@intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-11ASoC: Intel: Wait Baytrail ADSP boot at resume_early stageJarkko Nikula
Remove sst_byt_pcm_dev_resume() and move waiting of firmware boot into sst_byt_pcm_dev_resume_early(). Now suspend_late and resume_early phases are in sync with each other so that we know that ADSP was put into reset and was unpowered after suspend_late and is ready to resume IO after resume_early during resume stage in sst_byt_pcm_trigger(). Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Tested-by: Borun Fu <borun.fu@intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-11ASoC: Intel: Merge Baytrail ADSP suspend_noirq into suspend_lateJarkko Nikula
Merge DSP reset and cleanup sequence in sst_byt_pcm_dev_suspend_noirq() into sst_byt_pcm_dev_suspend_late(). First their order was wrong by first unloading firmware modules in suspend_late and then taking DSP into reset in suspend_noirq. Second ACPI has put device into OFF state already during suspend_late so trying to reset the DSP is a no-op at suspend_noirq stage. Fix these by moving DSP reset and cleanup into sst_byt_pcm_dev_suspend_late() before firmware unloading. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Tested-by: Borun Fu <borun.fu@intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-10ALSA: hda/ca0132 - Don't try loading firmware at resume when already failedTakashi Iwai
CA0132 driver tries to reload the firmware at resume. Usually this works since the firmware loader core caches the firmware contents by itself. However, if the driver failed to load the firmwares (e.g. missing files), reloading the firmware at resume goes through the actual file loading code path, and triggers a kernel WARNING like: WARNING: CPU: 10 PID:11371 at drivers/base/firmware_class.c:1105 _request_firmware+0x9ab/0x9d0() For avoiding this situation, this patch makes CA0132 skipping the f/w loading at resume when it failed at probe time. Reported-and-tested-by: Janek Kozicki <cosurgi@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-10ALSA: hda - Fix pop noises on reboot for Dell XPS 13 9333Gabriele Mazzotta
If nid 0x15 (Headphone Playback Switch) is in D3 and headphones are plugged in when the laptop reboots, a pop noise is generated. Prevent this by keeping nid 0x15 in D0 when headphones are plugged in. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=76611 Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-10ALSA: hda - Set internal mic as default input source on Dell XPS 13 9333Gabriele Mazzotta
If the laptop is powered on with a jack plugged in, independently on what is plugged, the jack is treated as a microphone jack. Initialize the capture source so that by default jacks are treated as headphones jacks. This will also prevent pop noises on boot in case headphones are plugged in since setting/unsetting mic-in as input source causes a pop noise. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=76611 Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-10ALSA: usb-audio: fix BOSS ME-25 MIDI regressionClemens Ladisch
The BOSS ME-25 turns out not to have any useful descriptors in its MIDI interface, so its needs a quirk entry after all. Reported-and-tested-by: Kees van Veen <kees.vanveen@gmail.com> Fixes: 8e5ced83dd1c ("ALSA: usb-audio: remove superfluous Roland quirks") Cc: <stable@vger.kernel.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
