commit 7f94de483f4e37e14d646ad6e85a3c82f66fb487 upstream.
Due to the different routing for AIF1 and AIF2 we weren't using a
single widget to represent the ADCDAT signal. For consistency add
one.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
commit 78b3fb46753872fc79bffecc8d50355a8622b39b upstream.
fix wrong value in wm8994_set_tristate func. when updating reg bits,
it should use "value", not "reg".
Signed-off-by: Qiao Zhou <zhouqiao@marvell.com>
commit 20a4e7fc7e213365ea3771d7bf1e10a6bab853be upstream.
The DC servo codes are actually signed numbers so need to be treated as
such.
commit 15d2e22b820bad62854d6ad99d8af8320adf4a91 upstream.
One spot was missed in this driver when converting from
snd_soc_dai.private_data to snd_soc_dai_get_drvdata.
commit e9c2048915048d605fd76539ddd96f00d593e1eb upstream.
We need to tweak how we query the active capture/playback state after
the recent overhauls of common code.
commit 7ebcf5d6021a696680ee77d9162a2edec2d671dd upstream.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
commit 4514e8997fbefd5befd6176ac9785e287b4daed4 upstream.
When we disable the WM8994 FLL code path sharing means that we end up
writing out a configuration. Currently this is the currently active
input and output frequency (which causes snd_soc_update_bits() to
suppress actual writes both immediately and in the common case where
we reenable the same configuration later) but we allow machine drivers
to pass through a source of zero. Since the register values written
are one less than the source constants this causes corruption of other
bitfields in the register.
Fix this by using the most recently configured FLL source when none is
provided.
commit a6c47a85b8e7e4a8c47394607c5e5c43224b0892 upstream.
According to the reporter, node 0x15 needs to be muted for subwoofer
to stop sounding. This pin is marked as unused by BIOS, so fix that.
BugLink: http://bugs.launchpad.net/bugs/715877
Reported-by: Hans Peter
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit b1d4f7f4bdcf9915c41ff8cfc4425c84dabb1fde upstream.
If a timer interrupt was delayed too much, hrtimer_forward_now() will
forward the timer expiry more than once. When this happens, the
additional number of elapsed ALSA timer ticks must be passed to
snd_timer_interrupt() to prevent the ALSA timer from falling behind.
This mostly fixes MIDI slowdown problems on highly-loaded systems with
badly behaved interrupt handlers.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reported-and-tested-by: Arthur Marsh <arthur.marsh@internode.on.net>
commit 70f7db11c45a313b23922cacf248c613c3b2144c upstream.
The Conexant codec driver adds the jack arrays in init callback which
may be called also in each PM resume. This results in the addition of
new jack element at each time.
The fix is to check whether the requested jack is already present in
the array.
Reference: Novell bug 668929
https://bugzilla.novell.com/show_bug.cgi?id=668929
commit d757534ed15387202e322854cd72dc58bbb975de upstream.
This typo caused the dmesg output of the supported bits of HDMI
to be cut off early.
commit fd76804f3f5484b35e6a51214c91e916ebba05aa upstream.
This patch fixes the non-compiling AC97C driver for AVR32 architecture by
include mach/hardware.h only for AT91 architecture. The AVR32 architecture does
not supply the hardware.h include file.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
commit d9ab344336f74c012f6643ed3d1ad8ca0136de3b upstream.
Fix playback/capture channels patch to change supported playback
channels of au8830 to 1,2,4 and capture channels to 1,2.
This prevent oops when oss emulation use SNDCTL_DSP_CHANNELS to
set 3 Channels
Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com>
commit cdce2db74e156fbd9a2dc3c7b246166f8b70955b upstream.
Fix missing NULL checks in usb_stream_hwdep_poll() and usb_stream_hwdep_ioctl().
Wake up poll waiters before returning from usb_stream_hwdep_ioctl().
Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de>
commit 921eebdc18c82268eab446592191b39e35d031d6 upstream.
The US-122L always reads 9 bytes per urb unless they are set to 0xFD.
commit e03fa055bc126e536c7f65862e08a9b143138ea9 upstream.
Sjoerd Simons reports that, without using position_fix=1, recording
experiences overruns. Work around that by applying the LPIB quirk
for his hardware.
Reported-and-tested-by: Sjoerd Simons <sjoerd@debian.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
commit d81a12bc29ae4038770e05dce4ab7f26fd5880fb upstream.
The load_mixer_volumes() function, which can be triggered by
unprivileged users via the SOUND_MIXER_SETLEVELS ioctl, is vulnerable to
a buffer overflow. Because the provided "name" argument isn't
guaranteed to be NULL terminated at the expected 32 bytes, it's possible
to overflow past the end of the last element in the mixer_vols array.
Further exploitation can result in an arbitrary kernel write (via
subsequent calls to load_mixer_volumes()) leading to privilege
escalation, or arbitrary kernel reads via get_mixer_levels(). In
addition, the strcmp() may leak bytes beyond the mixer_vols array.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
commit 6027277e77df2d2893d906c42f5c9f9abcb731e0 upstream.
Add a quirk entry for Thinkpad Edge 11 as well as other TP Edge models.
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
commit 3f343f8512c7882a3637d9aea4ec6b3801cbcdc5 upstream.
Deemphasis control's .get callback should update control's value instead
of returning it - return value of callback function is used for indicating
error or success of operation.
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
commit a0968628097380be52db8b4664da98fc425546a5 upstream.
Acc to WM8580 manual, the default value for R8 is 0x10, not 0x1c.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
commit ed8cc471d75365f8590c76f580def899d58028c0 upstream.
SPKOUTL_BOOST start from third bit, SPKOUTLR_BOOST start from 0 bit.
Signed-off-by: Uk Kim <w0806.kim@samsung.com>
commit 77c4d5cdb81d25a45fbdfb84dd3348121219a072 upstream.
BugLink: https://launchpad.net/bugs/595482
The original reporter states that audible playback from the internal
speaker is inaudible despite the hardware being properly detected. To
work around this symptom, he uses the model=lg quirk to properly enable
both playback, capture, and jack sense. Another user corroborates this
workaround on separate hardware. Add this PCI SSID to the quirk table
to enable it for further LG P1 Expresses.
Reported-and-tested-by: Philip Peitsch <philip.peitsch@gmail.com>
Tested-by: nikhov
internal mic
commit dd5a089edfa51a74692604b4b427953d8e16bc35 upstream.
BugLink: https://launchpad.net/bugs/685161
The reporter of the bug states that he must use position_fix=1 to enable
capture for the internal microphone, so set it for his machine's PCI
SSID. Verified using 2.6.35 and the 2010-12-04 alsa-driver build.
Reported-and-tested-by: Ralph Wabel <rwabel@gmx.net>
commit 3dc86429032910bdf762adeb2969112bb303924c upstream.
Commit bbbe33900d1f3c added functionality to restrict PCM parameters
based on ELD info (derived from EDID data) of the audio sink.
However, according to CEA-861-D no SAD is needed for basic audio
(32/44.1/48kHz stereo 16-bit audio), which is instead indicated with a
basic audio flag in the CEA EDID Extension.
The flag is not present in ELD. However, as all audio capable sinks are
required to support basic audio, we can assume it to be always
available.
Fix allowed audio formats with sinks that have SADs (Short Audio
Descriptors) which do not completely overlap with the basic audio
formats (there are no reports of affected devices so far) by always
assuming that basic audio is supported.
Reported-by: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
commit 4b0dbdb17f846a8887e5f7fbeea2deb0703236bd upstream.
However, it wrongly assumes that the bits 0-2 of the first byte of
CEA Short Audio Descriptors mean a supported number of channels. In
reality, they mean the maximum number of channels (as per CEA-861-D
7.5.2). This means that the channel count can only be used to restrict
max_channels, not min_channels.
Restricting min_channels causes us to deny opening the device in stereo
mode if the sink only has SADs that declare larger numbers of channels
(like Primare SP32 AV Processor does).
Fix that by not restricting min_channels based on ELD information.
Reported-by: Jean-Yves Avenard <jyavenard@gmail.com>
Tested-by: Jean-Yves Avenard <jyavenard@gmail.com>
commit 8a96b1e02029aa512199b1b6d281dcede9ed81f1 upstream.
BugLink: http://launchpad.net/497546
Confirmed that the ideapad model works better than the current
quirk for Dell Vostro 320.
commit 0defe09ca70daccdc83abd9c3c24cd89ae6a1141 upstream.
BugLink: https://launchpad.net/bugs/683695
The original reporter states that headphone jacks do not appear to
work. Upon inspecting his codec dump, and upon further testing, it is
confirmed that the "alienware" model quirk is correct.
Reported-and-tested-by: Cody Thierauf
commit 60686aa0086a14f8b15c83a09f3df1eebe3aab3c upstream.
In OSS emulation, SNDCTL_DSP_RESET ioctl needs the reset of the internal
buffer state in addition to drop of the running streams. Otherwise the
succeeding access becomes inconsistent.
Tested-by: Amit Nagal <helloin.amit@gmail.com>
commit cc1c452e509aefc28f7ad2deed75bc69d4f915f7 upstream.
The patch enables ALC887-VD to use the DAC at nid 0x26,
which makes it possible to use this DAC for e g Headphone
volume.
commit 7167594a3da7dcc33203b85d62e519594baee390 upstream.
The mixer nids passed to alc_auto_create_input_ctls are wrong: 0x15 is
a pin, and 0x09 is the ADC on both ALC660-VD/ALC861-VD. Thus with
current code, input playback volume/switches and input source mixer
controls are not created, and recording doesn't work. Select correct
mixers, 0x0b (input playback mixer) and 0x22 (capture source mixer).
Reference: https://qa.mandriva.com/show_bug.cgi?id=61159
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
commit 5a8cfb4e8ae317d283f84122ed20faa069c5e0c4 upstream.
When SKU assid gives no valid bits for 0x38, the driver didn't take
any action, so far. This resulted in the missing initialization for
external amps, etc, thus the silent output in the end.
Especially users hit this problem on ALC888 newly since 2.6.35,
where the driver doesn't force to use ALC_INIT_DEFAULT any more.
This patch sets the default initialization scheme to use
ALC_INIT_DEFAULT when no valid bits are set for SKU assid.
Reference:
https://bugzilla.redhat.com/show_bug.cgi?id=657388
Reported-and-tested-by: Kyle McMartin <kyle@redhat.com>
commit a0e90acc657990511c83bc69965bfd3c63386d45 upstream.
BugLink: https://launchpad.net/bugs/677830
The original reporter states that the subwoofer does not mute when
inserting headphones. We need an entry for his machine's SSID in the
subwoofer pin fixup list, so add it there (verified using hda_analyzer).
Reported-and-tested-by: i-NoD
commit 2df03514de41f3bbb5623f2e7f2bf594e49cb2ec upstream.
BugLink: https://bugs.launchpad.net/bugs/656625
Add clause for handling Acer Aspire 8943G's subwoofer as additional
speaker pin for automuting.
Reported-by: RussianNeuroMancer
commit d41185882b828896ccecac319c9f65f708baaf0d upstream.
Signed-off-by: Valentine Sinitsyn <valentine.sinitsyn@gmail.com>
commit 6cb3b707f95954ac18f19b4b3919af235738371a upstream.
By adding the subwoofer as a speaker pin, it is treated correctly when auto-muting.
BugLink: https://launchpad.net/bugs/611803
controls
commit 0613a59456980161d0cd468bae6c63d772743102 upstream.
BugLink: https://launchpad.net/bugs/669279
The original reporter states: "The Master mixer does not change the
volume from the headphone output (which is affected by the headphone
mixer). Instead it only seems to control the on-board speaker volume.
This confuses PulseAudio greatly as the Master channel is merged into
the volume mix."
Fix this symptom by applying the hp_only quirk for the reporter's SSID.
The fix is applicable to all stable kernels.
Reported-and-tested-by: Ben Gamari <bgamari@gmail.com>
commit 01e0f1378c47947b825eac05c98697ab1be1c86f upstream.
ALC887-VD is like ALC888-VD. It can not be initialized as ALC882.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit 2f7dceeda4708f470fd927adb3861bd8ebbe2310 upstream.
MCLKDIV bit of Register 04h Clocking1:
0 : Divide by 1
1 : Divide by 2
Thus in the case of freq <= 16500000, we should clear MCLKDIV bit.
commit 08b1a38465cab8c2224a5202c7a3b5e5f5630894 upstream.
DACSLOPE bit of Register 06h ADC and DAC Control 2:
0: Normal mode
1: Sloping stop-band mode
Thus in the case of normal mode, we should clear DACSLOPE bit.
commit 6d212d8e86fb4221bd91b9266b7567ee2b83bd01 upstream.
Not all bits can be read back from POWER1 so avoid corruption when using
a read/modify/write cycle by marking it non-volatile - the only thing we
read back from it is the chip revision which has diagnostic value only.
We can re-add later but that's a more invasive change than is suitable
for a bugfix.
commit ac70eb1305d5a81efd1e32327d7e79be15a63a5a upstream.
BugLink: https://launchpad.net/bugs/682199
A 2.6.35 (Ubuntu Maverick) user, burningphantom1, reported a regression
in audio: playback was inaudible through both speakers and headphones.
In commit 272a527c04 of sound-2.6.git, a new model was added with this
machine's PCI SSID. Fortunately, it is now sufficient to use the auto
model for BIOS auto-parsing instead of the existing quirk.
Playback, capture, and jack sense were verified working for both
2.6.35 and the alsa-driver snapshot from 2010-11-27 when model=auto is
used.
Reported-and-tested-by: burningphantom1
commit 673f7a8984c3a9e2cb1108ce221da1ebbd9e5d09 upstream.
BugLink: https://launchpad.net/bugs/677652
The original reporter states that, in 2.6.35, headphones do not appear
to work, nor does inserting them mute the A52J's onboard speakers. Upon
inspecting the codec dump, it appears that the newly committed hp-laptop
quirk will suffice to enable this basic functionality. Testing was done
with an alsa-driver build from 2010-11-21.
Reported-and-tested-by: Joan Creus
[Not upstream as .37 fixes this differently in a much more complete way
that is not able to be backported easily.]
(Ported on top of 2.6.36)
BugLink: http://launchpad.net/bugs/628961
BugLink: http://launchpad.net/bugs/605047
Signed-off-by: Diego Elio Pettenò <flameeyes@gmail.com>
Acked-by: Takashi Iwai <tiwai@suse.de>
commit 838c364ff05c143fd1810e8ad1469935d6c23a7a upstream.
Fix mutex release and cleanup some locking code.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 14d34f166c57e77e3d7f9bc8b43d349186d922c1 upstream.
Creative HD-audio controller chips require some workarounds:
- Additional delay before RIRB response
- Set the initial RIRB counter to 0xc0
The latter seems to be done in general in Windows driver, so we may
use this value later for all types if it's confirmed to work better.
Reported-by: Wai Yew CHAY <wychay@ctl.creative.com>
commit 24b55c69b66eb2a122842820ec14ab215fc8572f upstream.
The dig_out_nid field must take a digital-converter widget, but the current
ca0110 parser passed the pin wrongly instead.
commit 62b7e5e09bcb854ff05e6ee1aa161f8283dc36ee upstream.
Creative IBG controllers require the playback stream-tags to be started
from 1, instead of capture+1. Otherwise the stream stalls.
commit 0e7adbe263f89ea2ef15b5af5e80a812b2a85025 upstream.
The sticky PCM stream assignment introduced in 2.6.36 kernel seems
causing problems on AD codecs. At some time later, the streaming no
longer works by unknown reason. A simple workaround is to disable
sticky-assignment for these codecs.
Tested-by: Vasily Khoruzhick <anarsoul@gmail.com>
When a driver module is unloaded and the last still open file is a raw
MIDI device, the card and its devices will be actually freed in the
snd_card_file_remove() call when that file is closed. Afterwards, rmidi
and rmidi->card point into freed memory, so the module pointer is likely
to be garbage.
(This was introduced by commit 9a1b64caac82aa02cb74587ffc798e6f42c6170a.)
Reported-by: Krzysztof Foltman <wdev@foltman.com>
Cc: 2.6.30-2.6.35 <stable@kernel.org>
BugLink: https://bugs.launchpad.net/bugs/653420
Add another HP DV6 notebook (103c:363e) to use STAC_HP_DV5.
Signed-off-by: Luke Yelavich <luke.yelavich@canonical.com>
