path: root/sound
2013-12-04ALSA: hda - Check leaf nodes to find aamix ampsTakashi Iwai
commit 2ded3e5b61d61d0bc90bebb8004db6184c7db6eb upstream. The current generic parser assumes blindly that the volume and mute amps are found in the aamix node itself. But on some codecs, typically Analog Devices ones, the aamix amps are separately implemented in each leaf node of the aamix node, and the current driver can't establish the correct amp controls. This is a regression compared with the previous static quirks. This patch extends the search for the amps to the leaf nodes for allowing the aamix controls again on such codecs. In this implementation, I didn't code to loop through the whole paths, since usually one depth should suffice, and we can't search too deeply, as it may result in the conflicting control assignments. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65641 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ALSA: hda - Initialize missing bass speaker pin for ASUS AIO ET2700Takashi Iwai
commit 1f0bbf03cb829162ec8e6d03c98aaaed88c6f534 upstream. Add a fixup entry for the missing bass speaker pin 0x16 on ASUS ET2700 AiO desktop. The channel map will be added in the next patch, so that this can be backported easily to stable kernels. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65961 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ALSA: hda - Create Headhpone Mic Jack Mode when really neededTakashi Iwai
commit ced4cefc75fdb8be95eaee325ad0f6b2fc0a484b upstream. When a headphone jack is configurable as input, the generic parser tries to make it retaskable as Headphone Mic. The switching can be done smoothly if Capture Source control exists (i.e. there is another input source). Or when user explicitly enables the creation of jack mode controls, "Headhpone Mic Jack Mode" will be created accordingly. However, if the headphone mic is the only input source, we have to create "Headphone Mic Jack Mode" control because there is no capture source selection. Otherwise, the generic parser assumes that the input is constantly enabled, thus the headphone is permanently set as input. This situation happens on the old MacBook Airs where no input is supported properly, for example. This patch fixes the problem: now "Headphone Mic Jack Mode" is created when such an input selection isn't possible. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65681 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ALSA: hda - Fix hp-mic mode without VREF bitsTakashi Iwai
commit 16c0cefe8951b2c4b824fd06011ac1b359b1ab3b upstream. When the hp mic pin has no VREF bits, the driver forgot to set PIN_IN bit. Spotted during debugging old MacBook Airs. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65681 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ALSA: hda/realtek - Add support of ALC231 codecKailang Yang
commit ba4c4d0a9021ab034554d532a98133d668b87599 upstream. It's compatible with ALC269. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ALSA: hda/realtek - Set pcbeep amp for ALC668Kailang Yang
commit 9ad54547cf6f4410eba83bb95dfd2a0966718d6d upstream. Set the missing pcbeep default amp for ALC668. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ASoC: wm5110: Add post SYSCLK register patch for rev D chipCharles Keepax
commit f69f86b1ba6493126a7f093a65a8952bcb183de2 upstream. Certain registers require patching after the SYSCLK has been brought up add support for this into the CODEC driver. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ASoC: arizona: Set FLL to free-run before disablingRichard Fitzgerald
commit 3e68ce1bc72e5d6615677ec5a8b0a9bcb6c7a490 upstream. The FLL must be placed into free-run mode before disabling to allow it to entirely shut down. Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ASoC: fsl: imx-pcm-fiq: omit fiq counter to avoid harm in unbalanced situationsOskar Schirmer
commit fc7dc61d9a87011aaf8a6eb3144ebf9552adf5d2 upstream. Unbalanced calls to snd_imx_pcm_trigger() may result in endless FIQ activity and thus provoke eternal sound. While on the first glance, the switch statement looks pretty symmetric, the SUSPEND/RESUME pair is not: the suspend case comes along snd_pcm_suspend_all(), which for fsl/imx-pcm-fiq is called only at snd_soc_suspend(), but the resume case originates straight from the SNDRV_PCM_IOCTL_RESUME. This way userland may provoke an unbalanced resume, which might cause the fiq_enable counter to increase and never return to zero again, so eventually imx_pcm_fiq is never disabled. Simply removing the fiq_enable will solve the problem, as long as one never goes play and capture game simultaneously, but beware trying both at once, the early TRIGGER_STOP will cut off the other activity prematurely. So now playing and capturing is scrutinized separately, instead of by counting. Signed-off-by: Oskar Schirmer <oskar@scara.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ASoC: blackfin: Fix missing breakTakashi Iwai
commit afed4dbe3a043dbd833a53b6b4951e155708afd2 upstream. Fixes: 4b2ffc205cb9 ('ASoC: Blackfin I2S: add 8-bit sample support') Reported-by: David Binderman Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ASoC: wm8962: Turn on regcache_cache_only before disabling regulatorNicolin Chen
commit 50bfcf2df2fadf77e143d6099150e6fa7ef4d78c upstream. It's safer to turn on regcache_cache_only before disabling regulator since the driver will turn off the regcache_cache_only after enabling regulator. If we remain cache_only false, some command like 'amixer cset' would get failure if being run before wm8962_resume(). Signed-off-by: Nicolin Chen <b42378@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ASoC: cs42l52: Correct MIC CTL maskBrian Austin
commit 3d800c6d75b8c92fa928a0bcaf95cd7ac5fd1ce5 upstream. The mask for CS42L52_MIC_CTL_TYPE_MASK was wrong keeping the mic config from being set correctly. Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ASoC: ak4642: prevent un-necessary changes to SG_SL1Phil Edworthy
commit 7b5bfb82882b9b1c8423ce0ed6852ca3762d967a upstream. If you record the sound during playback, the playback sound becomes silent. Modify so that the codec driver does not clear SG_SL1::DACL bit which is controlled under widget Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04ASoC: wm_adsp: Interpret ADSP memory region lengths as 32 bit wordsNariman Poushin
commit c01422a4a184a183b03fb3046af88d61828f6d56 upstream. Pad the ADSP word (3 bytes) to 4 bytes in the kernel and calculate lengths based on padded ADSP words instead of treating them as bytes Signed-off-by: Nariman Poushin <nariman@opensource.wolfsonmicro.com> Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Provide missing pin configs for VAIO with ALC260Takashi Iwai
commit d08c5ef2a039393eaf2ab2152db5f07790fa0f40 upstream. Some models (or maybe depending on BIOS version) of Sony VAIO with ALC260 give no proper pin configurations as default, resulting in the non-working speaker, etc. Just provide the whole pin configurations via a fixup. Reported-by: Matthew Markus <mmarkus@hearit.co> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Add headset quirk for Dell Inspiron 3135David Henningsson
commit b8362e70cbbb397db50939bc4c7c78dc3246c3eb upstream. BugLink: https://bugs.launchpad.net/bugs/1253636 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Fix the headphone jack detection on Sony VAIO TXTakashi Iwai
commit 0f5a5b8515472a0219768423226b58228001e3d5 upstream. BIOS sets MISC_NO_PRESENCE bit wrongly to the pin config on NID 0x0f. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Fix unbalanced runtime PM notification at resumeTakashi Iwai
commit 0fc28fc030a85aa3d6d14e9e9fca0c8237c9ffb5 upstream. When a codec is resumed, it keeps the power on while the resuming phase via hda_keep_power_on(), then turns down via snd_hda_power_down(). At that point, snd_hda_power_down() notifies the power down to the controller, and this may confuse the refcount if the codec was already powered up before the resume. In the end result, the controller goes to runtime suspend even before the codec is kicked off to the power save, and the communication stalls happens. The fix is to add the power-up notification together with hda_keep_power_on(), and clears the flag appropriately. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Don't clear the power state at snd_hda_codec_reset()Takashi Iwai
commit d183b4fc463489b6bbe05c99afa0257a6fe578eb upstream. snd_hda_codec_reset() is called either in resetting the whole setup at error paths or hwdep clear/reconfig sysfs triggers. But all of these don't assume that the power has to be off, rather they want to keep the power state unchanged (e.g. reconfig_codec() calls the power up/down by itself). Thus, unconditionally clearing the power state in snd_hda_codec_reset() leads to the inconsistency, confuses the further operation. This patch gets rid of the lines doing that bad thing. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Don't turn off EAPD for headphone on Lenovo N100Takashi Iwai
commit 7a3e6107f94344e65c35bfe62de6c096a7b48965 upstream. The only EAPD on AD1986A is on NID 0x1b where usually the speaker. But this doesn't control only the speaker amp but may influence on all outputs, e.g. Lenovo N100 laptop seems to have this issue. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Check keep_eapd_on before inv_eapdTakashi Iwai
commit 468ac413045af1e0e4d1272291bed6878f248a69 upstream. We don't change the EAPD bit in set_pin_eapd() if keep_eapd_on flag is set by the codec driver and enable is false. But, we also apply the flipping of enable value according to inv_eapd flag in the same function, and this confused the former check, handled as if it's turned ON. The inverted EAPD check must be applied after keep_eapd_on check, instead. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Fix Line Out automute on Realtek multifunction jacksDavid Henningsson
commit 5959a6bc1124211a359525d209005abc07b0197b upstream. In case there is both a multifunction headset jack and a Line Out jack, automuting was not working properly from the Line Out jack. This patch fixes that issue. BugLink: https://bugs.launchpad.net/bugs/1250377 Tested-by: Cyrus Lien <cyrus.lien@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Add pincfg fixup for ASUS W5ATakashi Iwai
commit 487a588d09db0d6508261867df208d8bdc718251 upstream. BIOS on ASUS W5A laptop with ALC880 codec doesn't provide any pin configurations, so we have to set up all pins manually. Reported-and-tested-by: nb <nb@dagami.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Add support for CX20952Takashi Iwai
commit 8f42d7698751a45cd9f7134a5da49bc5b6206179 upstream. It's a superset of the existing CX2075x codecs, so we can reuse the existing parser code. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Make sure mute LEDs stay on during runtime suspend (Realtek)David Henningsson
commit d5b6b65e75ce607c2734227524e11574317a1c1a upstream. Some HP machines with Realtek codecs have mute LEDs connected to VREF pins. However when these go into runtime suspend, the pin powers down and its pin control is disabled, thus disabling the LED too. This patch fixes that issue by making sure that the pin stays in D0 with correct pin control. BugLink: https://bugs.launchpad.net/bugs/1248465 Tested-by: Franz Hsieh <franz.hsieh@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Force buffer alignment for Haswell HDMI controllersTakashi Iwai
commit 33499a15c2f7addc81695778753c2338b960eff7 upstream. Haswell HDMI audio controllers seem to get stuck when unaligned buffer size is used. Let's enable the buffer alignment for the corresponding entries. Since AZX_DCAPS_INTEL_PCH contains AZX_DCAPS_BUFSIZE that disables the buffer alignment forcibly, define AZX_DCAPS_INTEL_HASWELL and put the necessary AZX_DCAPS bits there. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=60769 Reported-by: Alexander E. Patrakov <patrakov@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Enable SPDIF for Acer TravelMate 6293Takashi Iwai
commit 24eff328f65c8ef352c90b6adb7c2f39eb94205d upstream. BIOS on Acer TravelMate 6293 doesn't set up the SPDIF output pin correctly as default, so enable it via a fixup entry. Reported-and-tested-by: Hagen Heiduck <heiduck.suse@fmail.postpro.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Introduce the bitmask for excluding output volumeTakashi Iwai
commit a1114a8c681b0724d6ad905f53ff06aa756f5fb8 upstream. Add a bitmask to hda_gen_spec indicating NIDs to exclude from the possible volume controls. That is, when the bit is set, the NID corresponding to the bit won't be picked as an output volume control any longer. Basically this is just a band-aid for working around the issue found with CS4208 codec, where only the headphone pin has a volume AMP with different dB steps. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=60811 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Add support of ALC255 codecsKailang Yang
commit 1d04c9de5c76df113e4af7120feb53c628b5efcc upstream. It's just another variant of ALC269 & co. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: msnd: Avoid duplicated driver nameTakashi Iwai
commit 092f9cd16aac7d054af1755c945f37c1b33399e6 upstream. msnd_pinnacle.c is used for both snd-msnd-pinnacle and snd-msnd-classic drivers, and both should have different driver names. Using the same driver name results in the sysfs warning for duplicated entries like kobject: 'msnd-pinnacle.7' (cec33408): kobject_release, parent (null) (delayed) kobject: 'msnd-pinnacle' (cecd4980): kobject_release, parent cf3ad9b0 (delayed) ------------[ cut here ]------------ WARNING: CPU: 0 PID: 1 at fs/sysfs/dir.c:486 sysfs_warn_dup+0x7d/0xa0() sysfs: cannot create duplicate filename '/bus/isa/drivers/msnd-pinnacle' ...... Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Apply MacBook fixups for CS4208 correctlyTakashi Iwai
commit 885845d78551be7bf8570f6283df8b7a7797c4d1 upstream. The commit [8fe7b65ab465: ALSA: hda - Apply GPIO setup for MacBooks with CS4208] added a fixup entry matching with the vendor id 0x106b. This broke the fixups for previous MBA6,1 and 6,2, since the PCI SSID vendor id matches before evaluating the codec SSIDs. We had a similar issue on Mac with Sigmatel codecs, and solve this problem again similarly, by introducing a skeleton entry matching with the all MacBooks, then remap to the right one. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=64401 Fixes: 8fe7b65ab465 ('ALSA: hda - Apply GPIO setup for MacBooks with CS4208') Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: hda - Apply GPIO setup for MacBooks with CS4208Takashi Iwai
commit 8fe7b65ab4656e5db466a7d98b1fd48ff83b2c64 upstream. Apply the existing GPIO0 fixup as default for MacBooks with CS4208 codec. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=64401 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: pcsp: Fix the order of input device unregistrationTakashi Iwai
commit 6408eac2665955343cd0e4bcd7d6237ce39611ed upstream. The current code may access to the already freed object. The input device must be accessed and unregistered before freeing the top level sound object. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: compress: fix drain calls blocking other compress functions (v6)Vinod Koul
commit f44f2a5417b2968a8724b352cc0b2545a6bcb1f4 upstream. The drain and drain_notify callback were blocked by low level driver until the draining was complete. Due to this being invoked with big fat mutex held, others ops like reading timestamp, calling pause, drop were blocked. So to fix this we add a new snd_compr_drain_notify() API. This would be required to be invoked by low level driver when drain or partial drain has been completed by the DSP. Thus we make the drain and partial_drain callback as non blocking and driver returns immediately after notifying DSP. The waiting is done while releasing the lock so that other ops can go ahead. [ The commit 917f4b5cba78 was wrongly applied from the preliminary patch. This commit corrects to the final version. Sorry for inconvenience! -- tiwai ] Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: compress: fix drain calls blocking other compress functionsVinod Koul
commit 917f4b5cba78980a527098a910d94139d3e82c8d upstream. The drain and drain_notify callback were blocked by low level driver untill the draining was complete. Due to this being invoked with big fat mutex held, others ops like reading timestamp, calling pause, drop were blocked. So to fix this we add a new snd_compr_drain_notify() API. This would be required to be invoked by low level driver when drain or partial drain has been completed by the DSP. Thus we make the drain and partial_drain callback as non blocking and driver returns immediately after notifying DSP. The waiting is done while relasing the lock so that other ops can go ahead. Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29ALSA: 6fire: Fix probe of multiple cardsTakashi Iwai
commit 9b389a8a022110b4bc055a19b888283544d9eba6 upstream. The probe code of snd-usb-6fire driver overrides the devices[] pointer wrongly without checking whether it's already occupied or not. This would screw up the device disconnection later. Spotted by coverity CID 141423. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-20ALSA: hda - hdmi: Fix reported channel map on common default layoutsAnssi Hannula
commit 56cac413dd6d43af8355f5d1f90a199b540f73fc upstream. hdmi_setup_fake_chmap() is supposed to set the reported channel map when the channel map is not specified by the user. However, the function indexes channel_allocations[] with a wrong value and extracts the wrong nibble from hdmi_channel_mapping[], causing wrong channel maps to be shown. Fix those issues. Tested on Intel HDMI to correctly generate various channel maps, for example 3,4,14,15,7,8,5,6 (instead of incorrect 3,4,8,7,5,6,14,0) for standard 7.1 channel audio. (Note that the side and rear channels are reported as RL/RR and RLC/RRC, respectively, as per the CEA-861 standard, instead of the more traditional SL/SR and RL/RR.) Note that this only fixes the layouts that only contain traditional 7.1 speakers (2.0, 2.1, 4.0, 5.1, 7.1, etc.). E.g. the rear center of 6.1 is still being shown wrongly due to an issue with from_cea_slot() which will be fixed in a later patch. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-31ALSA: fix oops in snd_pcm_info() caused by ASoC DPCMRussell King
Unable to handle kernel NULL pointer dereference at virtual address 00000008 pgd = d5300000 [00000008] *pgd=0d265831, *pte=00000000, *ppte=00000000 Internal error: Oops: 17 [#1] PREEMPT ARM CPU: 0 PID: 2295 Comm: vlc Not tainted 3.11.0+ #755 task: dee74800 ti: e213c000 task.ti: e213c000 PC is at snd_pcm_info+0xc8/0xd8 LR is at 0x30232065 pc : [<c031b52c>] lr : [<30232065>] psr: a0070013 sp : e213dea8 ip : d81cb0d0 fp : c05f7678 r10: c05f7770 r9 : fffffdfd r8 : 00000000 r7 : d8a968a8 r6 : d8a96800 r5 : d8a96200 r4 : d81cb000 r3 : 00000000 r2 : d81cb000 r1 : 00000001 r0 : d8a96200 Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user Control: 10c5387d Table: 15300019 DAC: 00000015 Process vlc (pid: 2295, stack limit = 0xe213c248) [<c031b52c>] (snd_pcm_info) from [<c031b570>] (snd_pcm_info_user+0x34/0x9c) [<c031b570>] (snd_pcm_info_user) from [<c03164a4>] (snd_pcm_control_ioctl+0x274/0x280) [<c03164a4>] (snd_pcm_control_ioctl) from [<c0311458>] (snd_ctl_ioctl+0xc0/0x55c) [<c0311458>] (snd_ctl_ioctl) from [<c00eca84>] (do_vfs_ioctl+0x80/0x31c) [<c00eca84>] (do_vfs_ioctl) from [<c00ecd5c>] (SyS_ioctl+0x3c/0x60) [<c00ecd5c>] (SyS_ioctl) from [<c000e500>] (ret_fast_syscall+0x0/0x48) Code: e1a00005 e59530dc e3a01001 e1a02004 (e5933008) ---[ end trace cb3d9bdb8dfefb3c ]--- This is provoked when the ASoC front end is open along with its backend, (which causes the backend to have a runtime assigned to it) and then the SNDRV_CTL_IOCTL_PCM_INFO is requested for the (visible) backend device. Resolve this by ensuring that ASoC internal backend devices are not visible to userspace, just as the commentry for snd_pcm_new_internal() says it should be. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mark Brown <broonie@linaro.org> Cc: <stable@vger.kernel.org> [v3.4+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-30Merge tag 'asoc-fix-v3.12-rc7' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.12 A few of the Coverity fixes from Takashi, one of which (the wm_hubs one) is particularly noticable.
2013-10-30Merge remote-tracking branch 'asoc/fix/wm8994' into asoc-linusMark Brown
2013-10-30ASoC: wm_hubs: Add missing break in hp_supply_event()Takashi Iwai
Spotted by coverity CID 115170. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-10-30ALSA: hda - Add a fixup for ASUS N76VZTakashi Iwai
ASUS N76VZ needs the same fixup as N56VZ for supporting the boost speaker. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=846529 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-28ASoC: dapm: Return -ENOMEM in snd_soc_dapm_new_dai_widgets()Takashi Iwai
... instead of NULL dereferences. Spotted by coverity CID 402004. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-28ASoC: dapm: Fix source list debugfs outputsTakashi Iwai
... due to a copy & paste error. Spotted by coverity CID 710923. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-10-26ALSA: hda - Fix silent headphone on Thinkpads with AD1984A codecTakashi Iwai
AD1984A codec has a couple of pins with EAPD controls, and the generic codec driver tries to turn each of them on/off depending on the pin active state. However, Thinkpads seem to use EAPD of the speaker pin as a master EAPD for controlling the mute of all outputs, including the headphone. This results in the dead headphone output via the headphone plugging because it mutes the speaker and turns off EAPD. The fix is to simply add spec->gen.keep_on_eapd flag. [This is a regression fix on 3.12 where we moved the AD codec parser to the generic parser. 3.11 and earlier didn't show this problem because still static quirks have been used.] Reported-and-tested-by: Vito Caputo <vcaputo@gnugeneration.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-25ALSA: hda - Add missing initial vmaster hook at build_controls callbackTakashi Iwai
The generic parser has a support of vmaster hook, but this is initialized only in the init callback with the check of the presence of the corresponding kctl. However, since kctl is NULL at the very first init callback that is called before build_controls callback, the vmaster hook sync is skipped there. Eventually this leads to the uninitialized state depending on the hook implementation. This patch adds a simple workaround, just calling the sync function explicitly at build_controls callback. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-24ALSA: hda - Fix unbalanced runtime PM refcount after S3/S4Takashi Iwai
When a machine goes to S3/S4 after power-save is enabled, the runtime PM refcount might be incorrectly decreased because the power-down triggered soon after resume assumes that the controller was already powered up, and issues the pm_notify down. This patch fixes the incorrect pm_notify call simply by checking the current value properly. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-19Merge tag 'asoc-v3.12-rc5' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.12 A number of small, fairly unexciting, fixes for drivers - nothing stand out.
2013-10-18Merge remote-tracking branch 'asoc/fix/tlv320aic3x' into asoc-linusMark Brown
2013-10-18Merge remote-tracking branch 'asoc/fix/rcar' into asoc-linusMark Brown
