path: root/sound
2012-12-20Merge tag 'sound-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This update contains overall only driver-specific fixes. Slightly large LOC are seen in usb-audio driver for a couple of new device quirks and cs42l71 ASoC driver for enhanced features. The others are a few small (regression) fixes HD-audio, and yet other small / trival ASoC fixes." * tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: usb-audio: Support for Digidesign Mbox 2 USB sound card: ALSA: HDA: Fix sound resume hang ALSA: hda - bug fix for invalid connection list of Haswell HDMI codec pins ALSA: hda - Fix the wrong pincaps set in ALC861VD dallas/hp fixup ALSA: hda - Set codec->single_adc_amp flag for Realtek codecs ASoC: atmel-ssc: change disable to disable in dts node ASoC: Prevent pop_wait overwrite ALSA: usb-audio: ignore-quirk for HP Wireless Audio ALSA: hda - Always turn on pins for HDMI/DP ALSA: hda - Fix pin configuration of HP Pavilion dv7 ASoC: core: Fix splitting of log messages ASoC: cs42l73: Change VSPIN/VSPOUT to VSPINOUT ASoC: cs42l73: Add DAPM events for power down. ASoC: cs42l73: Add DMIC's as DAPM inputs. ASoC: sigmadsp: Fix endianness conversion issue ASoC: tpa6130a2: Use devm_* APIs
2012-12-19ALSA: usb-audio: Support for Digidesign Mbox 2 USB sound card:Damien Zammit
This patch is the result of a lot of trial and error, since there are no specs available for the device. Full duplex support is provided, i.e. playback and recording in stereo. The format is hardcoded at 48000Hz @ 24 bit, which is the maximum that the device supports. Also, MIDI in and MIDI out both work. Users will notice that the S/PDIF light also flashes when playback or recording is active. I believe this means that S/PDIF input/output is simultaneously activated with the analogue i/o during use. But this particular functionality remains untested. Note that this particular version of the patch is so far untested on the physical hardware because I have not compiled a full kernel with the changes. However, extensive testing has been done by many users of the hardware who believe other versions of my patch have worked since circa 2009. [Modified to make a function static by tiwai] Signed-off-by: Damien Zammit <damien@zamaudio.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-18ALSA: HDA: Fix sound resume hangDaniel J Blueman
Resuming a switcheroo'd HDA controller hangs since the completion is one-shot (thus works the first time). Fix by using completions that explictly need rearming, so remain fired before. Signed-off-by: Daniel J Blueman <daniel@quora.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-18ALSA: hda - bug fix for invalid connection list of Haswell HDMI codec pinsMengdong Lin
Haswell HDMI codec pins may report invalid connection list entries, which will cause failure to play audio via HDMI or Display Port. So this patch adds fixup for Haswell to workaround this hardware issue: enable DP1.2 mode and override the pins' connection list entries with proper value. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Xingchao Wang <xingchao.wang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-17sound: remove reference to feature-removal-schedule.txtTao Ma
In commit 9c0ece069b32 ("Get rid of Documentation/feature-removal.txt"), Linus removed feature-removal-schedule.txt from Documentation, but there is still some reference to this file. So remove them. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17ALSA: hda - Fix the wrong pincaps set in ALC861VD dallas/hp fixupTakashi Iwai
The workaround to force VREF50 for dallas/hp model with ALC861VD was introduced in commit 8fdcb6fe4204bdb4c6991652717ab5063751414e, but it contained wrong pincap override bits. This patch fixes to exclude VREF80 pincap bit correctly. Cc: <stable@vger.kernel.org> [v3.2+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-17ALSA: hda - Set codec->single_adc_amp flag for Realtek codecsTakashi Iwai
It turned out that Realtek codecs (ALC260, etc) with input amps in audio-input widgets don't handle the multiple individual input amps. Thus we need to set codec->single_adc_amp flag for them in general. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-17Merge tag 'asoc-3.8p1' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: More updates for v3.8 Nothing terribly exciting here, just small localised changes. As well as fixes there are a couple of Cirrus changes and one devm_ change which were in prior to the merge window but got missed from the original pull to Takashi.
2012-12-15Merge remote-tracking branch 'asoc/topic/tpa6130a2' into asoc-nextMark Brown
2012-12-15Merge remote-tracking branch 'asoc/topic/log' into asoc-nextMark Brown
2012-12-15Merge remote-tracking branch 'asoc/topic/cs42l73' into asoc-nextMark Brown
2012-12-15Merge remote-tracking branch 'asoc/topic/core' into asoc-nextMark Brown
2012-12-15Merge remote-tracking branch 'asoc/fix/sigmadsp' into asoc-nextMark Brown
2012-12-15ASoC: Prevent pop_wait overwriteMisael Lopez Cruz
pop_wait is used to determine if a deferred playback close needs to be cancelled when the a PCM is open or if after the power-down delay expires it needs to run. pop_wait is associated with the CODEC DAI, so the CODEC DAI must be unique. This holds true for most CODECs, except for the dummy CODEC and its DAI. In DAI links with non-unique dummy CODECs (e.g. front-ends), pop_wait can be overwritten by another DAI link using also a dummy CODEC. Failure to cancel a deferred close can cause mute due to the DAPM STOP event sent in the deferred work. One scenario where pop_wait is overwritten and causing mute is below (where hw:0,0 and hw:0,1 are two front-ends with default pmdown_time = 5 secs): aplay /dev/urandom -D hw:0,0 -c 2 -r 48000 -f S16_LE -d 1 sleep 1 aplay /dev/urandom -D hw:0,1 -c 2 -r 48000 -f S16_LE -d 3 & aplay /dev/urandom -D hw:0,0 -c 2 -r 48000 -f S16_LE Since CODECs may not be unique, pop_wait is moved to the PCM runtime structure. Creating separate dummy CODECs for each DAI link can also solve the problem, but at this point it's only pop_wait variable in the CODEC DAI that has negative effects by not being unique. Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-15ALSA: usb-audio: ignore-quirk for HP Wireless AudioEldad Zack
As Joe Cooper <swelljoe@gmail.com> reported, "On most HP Envy laptops the snd-usb-audio module causes the system to become unresponsive and Gnome Shell 3 to crash.". See also: http://mailman.alsa-project.org/pipermail/alsa-devel/2012-December/057729.html Add a quirk to ignore this device (for now) to solve the instability issue and allow other USB audio devices to be used. Reported-by: Joe Cooper <swelljoe@gmail.com> Tested-by: Isaac Smith <hunternet93@gmail.com> Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-14ALSA: hda - Always turn on pins for HDMI/DPTakashi Iwai
We've seen the broken HDMI *video* output on some machines with GM965, and the debugging session pointed that the culprit is the disabled audio output pins. Toggling these pins dynamically on demand caused flickering of HDMI TV. This patch changes the behavior to keep the pin ON constantly. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51421 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-13Merge tag 'sound-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This update contains a fairly wide range of changes all over in sound subdirectory, mainly because of UAPI header moves by David and __dev* annotation removals by Bill. Other highlights are: - Introduced the support for wallclock timestamps in ALSA PCM core - Add the poll loop implementation for HD-audio jack detection - Yet more VGA-switcheroo fixes for HD-audio - New VIA HD-audio codec support - More fixes on resource management in USB audio and MIDI drivers - More quirks for USB-audio ASUS Xonar U3, Reloop Play, Focusrite, Roland VG-99, etc - Add support for FastTrack C400 usb-audio - Clean ups in many drivers regarding firmware loading - Add PSC724 Ultiimate Edge support to ice1712 - A few hdspm driver updates - New Stanton SCS.1d/1m FireWire driver - Standardisation of the logging in ASoC codes - DT and dmaengine support for ASoC Atmel - Support for Wolfson ADSP cores - New drivers for Freescale/iVeia P1022 and Maxim MAX98090 - Lots of other ASoC driver fixes and developments" Fix up trivial conflicts. And go out on a limb and assume the dts file 'status' field of one of the conflicting things was supposed to be "disabled", not "disable" like in pretty much all other cases. * tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (341 commits) ALSA: hda - Move runtime PM check to runtime_idle callback ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522 ALSA: hda - Avoid doubly suspend after vga switcheroo ALSA: usb-audio: Enable S/PDIF on the ASUS Xonar U3 ALSA: hda - Check validity of CORB/RIRB WP reads ALSA: hda - use usleep_range in link reset and change timeout check ALSA: HDA: VIA: Add support for codec VT1808. ALSA: HDA: VIA Add support for codec VT1705CF. ASoC: codecs: remove __dev* attributes ASoC: utils: remove __dev* attributes ASoC: ux500: remove __dev* attributes ASoC: txx9: remove __dev* attributes ASoC: tegra: remove __dev* attributes ASoC: spear: remove __dev* attributes ASoC: sh: remove __dev* attributes ASoC: s6000: remove __dev* attributes ASoC: OMAP: remove __dev* attributes ASoC: nuc900: remove __dev* attributes ASoC: mxs: remove __dev* attributes ASoC: kirkwood: remove __dev* attributes ...
2012-12-13Merge tag 'boards2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC board updates, take 2 from Olof Johansson: "This branch contains board updates for shmobile that had dependencies on earlier branches past the first driver branch, and thus are merged separately. Most of these are to enable audio and USB on shmobile. They contain a dependent ASoC branch that has been coordinated with Mark Brown." * tag 'boards2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: shmobile: mackerel: Add FLCTL IRQ resource ARM: shmobile: use FSI driver's audio clock on ap4evb ARM: shmobile: use FSI driver's audio clock on mackerel ARM: shmobile: use FSI driver's audio clock on armadillo800eva ARM: shmobile: mackerel: enable DMAEngine on USB Host ARM: shmobile: marzen: add USB OHCI driver support ARM: shmobile: marzen: add USB EHCI driver support ARM: shmobile: marzen: add USB phy support ASoC: fsi: add master clock control functions ASoC: fsi: care fsi_hw_start/stop() return value ASoC: fsi: fsi_set_master_clk() was called from fsi_hw_xxx() only ASoC: fsi: use devm_request_irq() ASoC: fsi: fixup channels_min/max
2012-12-13Merge tag 'pm-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC power management and clock changes from Olof Johansson: "This branch contains a largeish set of updates of power management and clock setup. The bulk of it is for OMAP/AM33xx platforms, but also a few around hotplug/suspend/resume on Exynos. It includes a split-up of some of the OMAP clock data into separate files which adds to the diffstat, but gross delta is fairly reasonable." * tag 'pm-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits) ARM: OMAP: Move plat-omap/dma-omap.h to include/linux/omap-dma.h ASoC: OMAP: mcbsp fixes for enabling ARM multiplatform support watchdog: OMAP: fixup for ARM multiplatform support ARM: EXYNOS: Add flush_cache_all in suspend finisher ARM: EXYNOS: Remove scu_enable from cpuidle ARM: EXYNOS: Fix soft reboot hang after suspend/resume ARM: EXYNOS: Add support for rtc wakeup ARM: EXYNOS: fix the hotplug for Cortex-A15 ARM: OMAP2+: omap_device: Correct resource handling for DT boot ARM: OMAP2+: hwmod: Add possibility to count hwmod resources based on type ARM: OMAP2+: hwmod: Add support for per hwmod/module context lost count ARM: OMAP2+: PRM: initialize some PRM functions early ARM: OMAP2+: voltage: fixup oscillator handling when CONFIG_PM=n ARM: OMAP4: USB: power down MUSB PHY during boot ARM: OMAP2+: clock: Cleanup !CONFIG_COMMON_CLK parts ARM: OMAP2xxx: clock: drop obsolete clock data ARM: OMAP2: clock: Cleanup !CONFIG_COMMON_CLK parts ARM: OMAP3+: DPLL: drop !CONFIG_COMMON_CLK sections ARM: AM33xx: clock: drop obsolete clock data ARM: OMAP3xxx: clk: drop obsolete clock data ...
2012-12-13Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform conversion patches from Olof Johansson: "Here are more patches in the progression towards multiplatform, sparse irq conversions in particular. Tegra has a handful of cleanups and general groundwork, but is not quite there yet on full enablement. Platforms that are enabled through this branch are VT8500 and Zynq. Note that i.MX was converted in one of the earlier cleanup branches as well (before we started a separate topic for multiplatform). And both new platforms for this merge window, sunxi and bcm, were merged with multiplatform support enabled." Fix up conflicts mostly as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: zynq: Remove all unused mach headers ARM: zynq: add support for ARCH_MULTIPLATFORM ARM: zynq: make use of debug_ll_io_init() ARM: zynq: remove TTC early mapping ARM: tegra: move debug-macro.S to include/debug ARM: tegra: don't include iomap.h from debug-macro.S ARM: tegra: decouple uncompress.h and debug-macro.S ARM: tegra: simplify DEBUG_LL UART selection options ARM: tegra: select SPARSE_IRQ ARM: tegra: enhance timer.c to get IO address from device tree ARM: tegra: enhance timer.c to get IRQ info from device tree ARM: timer: fix checkpatch warnings ARM: tegra: add TWD to device tree ARM: tegra: define DT bindings for and instantiate RTC ARM: tegra: define DT bindings for and instantiate timer clocksource/mtu-nomadik: use apb_pclk clk: ux500: Register mtu apb_pclocks ARM: plat-nomadik: convert platforms to SPARSE_IRQ mfd/db8500-prcmu: use the irq_domain_add_simple() mfd/ab8500-core: use irq_domain_add_simple() ...
2012-12-13ALSA: hda - Fix pin configuration of HP Pavilion dv7Takashi Iwai
Fix the quirk entry for HP Pavilion dv7 in order to make the bass speaker working. Reported-and-tested-by: Tomas Pospisek <tpo2@sourcepole.ch> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-12ALSA: hda - Move runtime PM check to runtime_idle callbackTakashi Iwai
The runtime_idle callback is the right place to check the suspend capability, but currently we do it wrongly in the runtime_suspend callback. This leads to a kernel error message like: pci_pm_runtime_suspend(): azx_runtime_suspend+0x0/0x50 [snd_hda_intel] returns -11 and the runtime PM core would even repeat the attempts. Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Cc: <stable@vger.kernel.org> [v3.7] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-12ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522Takashi Iwai
Acer Aspire One 522 has the infamous digital mic unit that needs the phase inversion fixup for stereo. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=715737 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-12ALSA: hda - Avoid doubly suspend after vga switcherooTakashi Iwai
The HD-audio driver artificially calls the suspend and the resume code path in the VGA switcheroo state changes. When a machine goes to suspend, it tries to suspend the device again, and it stalls at snd_power_wait(). This patch adds checks whether the devices were already in (forced) suspend in PM callbacks for avoiding the doubly suspend. Reported-by: Daniel J Blueman <daniel@quora.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-12ALSA: usb-audio: Enable S/PDIF on the ASUS Xonar U3Denis Washington
The only required change is to extend the existing Xonar U1 mixer quirks to the U3, which seems to be controlled the same way. Signed-off-by: Denis Washington <denisw@online.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-12ALSA: hda - Check validity of CORB/RIRB WP readsTakashi Iwai
When the HD-audio controller is disabled (e.g. via vga switcheroo) but the driver is still accessing it, it spews floods of "spurious response" kernel messages. It's because CORB/RIRB WP reads 0xff, and the driver tries to fill up until this number. This patch changes the CORB/RIRB WP reads to word instead of byte, and add the check of the read value. If it's 0xffff, the controller is supposed to be disabled, so the further action will be skipped. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-12ALSA: hda - use usleep_range in link reset and change timeout checkMengdong Lin
Reducing the time on HDA link reset can help to reduce the driver loading time. So we replace msleep with usleep_range to get more accurate time control and change the value to a smaller one. And a 100ms timeout is set for both entering and exiting the link reset. Signed-off-by: Xingchao Wang <xingchao.wang@intel.com> Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-10ALSA: HDA: VIA: Add support for codec VT1808.Lydia Wang
Add support for new codec VT1808, which is similiar with VT1705CF. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-10ALSA: HDA: VIA Add support for codec VT1705CF.Lydia Wang
Add support for new codec VT1705CF. When power on/off Audio output converter of VT1705CF, the stream tag will be cleared. But driver caches the value. So when power on Audio output converter, the update_conv_power_state() will restore the saved stream tag of it. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-10Merge tag 'asoc-3.8' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: Updates for v3.8 Some incremental updates, nothing too exciting. The biggest block here is the __dev annotation removal stuff from Bill, everything else is the usual driver-specific stuff - a combination of fixes and development. There will be at least more more set of fixes to come but I wanted to get these out ready for the merge window to make sure Bill's stuff makes it in.
2012-12-10ASoC: core: Fix splitting of log messagesMark Brown
Don't wrap log messages over multiple lines, it makes them hard to grep for. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-10ASoC: cs42l73: Change VSPIN/VSPOUT to VSPINOUTPaul Handrigan
Since VSP only has one power bit, only provide one DAPM widget. Signed-off-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-10ASoC: cs42l73: Add DAPM events for power down.Paul Handrigan
Add power down delays between setting PDN and MCLKDIS for spk amp, spklo amp, and ear amp. Signed-off-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-10ASoC: cs42l73: Add DMIC's as DAPM inputs.Paul Handrigan
2012-12-10ASoC: sigmadsp: Fix endianness conversion issueLars-Peter Clausen
The 'addr' field of the sigma_action struct is stored as big endian in the firmware file. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-12-10ASoC: codecs: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-10ASoC: utils: remove __dev* attributesBill Pemberton
2012-12-10ASoC: ux500: remove __dev* attributesBill Pemberton
2012-12-10ASoC: txx9: remove __dev* attributesBill Pemberton
2012-12-10ASoC: tegra: remove __dev* attributesBill Pemberton
2012-12-10ASoC: spear: remove __dev* attributesBill Pemberton
2012-12-10ASoC: sh: remove __dev* attributesBill Pemberton
2012-12-10ASoC: s6000: remove __dev* attributesBill Pemberton
2012-12-10ASoC: OMAP: remove __dev* attributesBill Pemberton
2012-12-10ASoC: nuc900: remove __dev* attributesBill Pemberton
2012-12-10ASoC: mxs: remove __dev* attributesBill Pemberton
2012-12-10ASoC: kirkwood: remove __dev* attributesBill Pemberton
2012-12-10ASoC: mid-x86: remove __dev* attributesBill Pemberton
2012-12-10ASoC: jz4740: remove __dev* attributesBill Pemberton
