The DSP is an optional silicon feature of i.MX8, i.MX8X SoCs.
This prevents the following message which is often followed by a
kernel oops.
| Failed power operation on resource 512 sc_err 3, power_on 1
Test the DSP disable fuse in the drivers init call and don't install
the driver if the SoC we are running on has no DSP.
Fuse code taken from vpu_encoder_b0.c.
Related-to: ELB-1380
toradex_4.14-2.0.x-imx-next
sound/soc/codecs/sgtl5000.c
This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
commit 8f157d4ff039e03e2ed4cb602eeed2fd4687a58f upstream.
Check for existance of jack before tracing.
NULL pointer dereference has been reported by KASAN while unloading
machine driver (snd_soc_cnl_rt274).
Signed-off-by: Pawel Harlozinski <pawel.harlozinski@linux.intel.com>
Link: https://lore.kernel.org/r/20191112130237.10141-1-pawel.harlozinski@linux.intel.com
Signed-off-by: Mark Brown <broonie@kernel.org>
Cc: stable@vger.kernel.org
[ Upstream commit ca58f55108fee41d87c9123f85ad4863e5de7f45 ]
This is an alternative fix attemp for the issue reported in the commit
caa8422d01e9 ("ALSA: hda: Flush interrupts on disabling") that was
reverted later due to regressions. Instead of tweaking the hardware
disablement order and the enforced irq flushing, do calling
cancel_work_sync() of the unsol work early enough, and explicitly
ignore the unsol events during the shutdown by checking the
bus->shutdown flag.
Fixes: caa8422d01e9 ("ALSA: hda: Flush interrupts on disabling")
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Link: https://lore.kernel.org/r/s5h1ruxt9cz.wl-tiwai@suse.de
commit 7aea8a9d71d54f449f49e20324df06341cc18395 upstream.
Renesas sound device has many IPs and many situations.
If platform/board uses MIXer, situation will be more complex.
To avoid duplicate DVC kctrl registration when MIXer was used,
it had original flags.
But it was issue when sound card was re-binded, because
no one can't cleanup this flags then.
To solve this issue, commit 9c698e8481a15237a ("ASoC: rsnd: tidyup
registering method for rsnd_kctrl_new()") checks registered
card->controls, because if card was re-binded, these were cleanuped
automatically. This patch could solve re-binding issue.
But, it start to avoid MIX kctrl.
To solve these issues, we need below.
To avoid card re-binding issue: check registered card->controls
To avoid duplicate DVC registration: check registered rsnd_kctrl_cfg
To allow multiple MIX registration: check registered rsnd_kctrl_cfg
This patch do it.
Fixes: 9c698e8481a15237a ("ASoC: rsnd: tidyup registering method for rsnd_kctrl_new()")
Reported-by: Jiada Wang <jiada_wang@mentor.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Tested-By: Jiada Wang <jiada_wang@mentor.com>
Cc: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp>
commit e190de6941db14813032af87873f5550ad5764fe upstream.
Mic mute led does not work on HP ProBook 645 G4.
We can use CXT_FIXUP_MUTE_LED_GPIO fixup to support it.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Cc: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20191120082035.18937-1-kai.heng.feng@canonical.com
commit 4cc8d6505ab82db3357613d36e6c58a297f57f7c upstream.
syzkaller reported an invalid access in PCM OSS read, and this seems
to be an overflow of the internal buffer allocated for a plugin.
Since the rate plugin adjusts its transfer size dynamically, the
calculation for the chained plugin might be bigger than the given
buffer size in some extreme cases, which lead to such an buffer
overflow as caught by KASAN.
Fix it by limiting the max transfer size properly by checking against
the destination size in each plugin transfer callback.
Reported-by: syzbot+f153bde47a62e0b05f83@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20191204144824.17801-1-tiwai@suse.de
commit e1e8c1fdce8b00fce08784d9d738c60ebf598ebc upstream.
headphone have noise even the volume is very small.
Let it fill up pcbeep hidden register to default value.
The issue was gone.
Fixes: 4344aec84bd8 ("ALSA: hda/realtek - New codec support for ALC256")
Fixes: 736f20a70608 ("ALSA: hda/realtek - Add support for ALC236/ALC3204")
Signed-off-by: Kailang Yang <kailang@realtek.com>
Link: https://lore.kernel.org/r/9ae47f23a64d4e41a9c81e263cd8a250@realtek.com
[ Upstream commit cd7fdc45bc69a62b4e22c6e875f1f1aea566256d ]
Add suffix ULL to constant 256 in order to give the compiler complete
information about the proper arithmetic to use.
Notice that such constant is used in a context that expects an
expression of type u64 (64 bits, unsigned) and the following
expression is currently being evaluated using 32-bit arithmetic:
256 * fs * 2 * mclk_src_scaling[i].param
Signed-off-by: Young_X <YangX92@hotmail.com>
[ Upstream commit 9c698e8481a15237a5b1db5f8391dd66d59e42a4 ]
Current rsnd dvc.c is using flags to avoid duplicating register for
MIXer case. OTOH, commit e894efef9ac7 ("ASoC: core: add support to card
rebind") allows to rebind sound card without rebinding all drivers.
Because of above patch and dvc.c flags, it can't re-register kctrl if
only sound card was rebinded, because dvc is keeping old flags.
(Of course it will be no problem if rsnd driver also be rebinded,
but it is not purpose of above patch).
This patch checks current card registered kctrl when registering.
In MIXer case, it can avoid duplicate register if card already has same
kctrl. In rebind case, it can re-register kctrl because card registered
kctl had been removed when unbinding.
This patch is updated version of commit b918f1bc7f1ce ("ASoC: rsnd: DVC
kctrl sets once")
Reported-by: Nguyen Viet Dung <dung.nguyen.aj@renesas.com>
Tested-by: Nguyen Viet Dung <dung.nguyen.aj@renesas.com>
Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
[ Upstream commit f5cdc9d4003a2f66ea57b3edd3e04acc2b1a4439 ]
If the nullity check for `substream->runtime` is outside of the lock
region, it is possible to have a null runtime in the critical section
if snd_pcm_detach_substream is called right before the lock.
Signed-off-by: paulhsia <paulhsia@chromium.org>
Link: https://lore.kernel.org/r/20191112171715.128727-2-paulhsia@chromium.org
commit 8ba3c5215d69c09f5c39783ff3b78347769822ad upstream.
Because of regmap cache, interrupts may not be cleared
as expected.
Declare IFCR register as write only and make writings
to IFCR register unconditional.
Signed-off-by: Olivier Moysan <olivier.moysan@st.com>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
commit 0c4c68d6fa1bae74d450e50823c24fcc3cd0b171 upstream.
I2S supports 16 bits data in 32 channel length.
However the expected driver behavior, is to
set channel length to 16 bits when data format is 16 bits.
commit 1ac2bd16448997d9ec01922423486e1e85535eda upstream.
DMA configuration is not balanced on start/stop.
Move DMA configuration to trigger callback.
[ Upstream commit 4523817d51bc3b2ef38da768d004fda2c8bc41de ]
When our call to get the external clock fails, we forget to clean up
the enabled internal clock correctly. Enable the clock after we have
obtained all our resources.
Fixes: 84aac6c79bfd ("ASoC: kirkwood: fix loss of external clock at probe time")
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Link: https://lore.kernel.org/r/E1iNGyK-0004oF-6A@rmk-PC.armlinux.org.uk
[ Upstream commit d3645b055399538415586ebaacaedebc1e5899b0 ]
Parameter fragments and fragment_size are type of u32. U32_MAX is
the correct check.
Signed-off-by: Xiaojun Sang <xsang@codeaurora.org>
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Acked-by: Vinod Koul <vkoul@kernel.org>
Link: https://lore.kernel.org/r/20191021095432.5639-1-srinivas.kandagatla@linaro.org
[ Upstream commit 9110d1b0e229cebb1ffce0c04db2b22beffd513d ]
According to the PM8916 Hardware Register Description,
CDC_D_CDC_CONN_HPHR_DAC_CTL has only a single bit (RX_SEL)
to switch between RX1 (0) and RX2 (1). It is not possible to
disable it entirely to achieve the "ZERO" state.
However, at the moment the "RDAC2 MUX" mixer defines three possible
values ("ZERO", "RX2" and "RX1"). Setting the mixer to "ZERO"
actually configures it to RX1. Setting the mixer to "RX1" has
(seemingly) no effect.
Remove "ZERO" and replace it with "RX1" to fix this.
Fixes: 585e881e5b9e ("ASoC: codecs: Add msm8916-wcd analog codec")
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Link: https://lore.kernel.org/r/20191020153007.206070-1-stephan@gerhold.net
The simple-audio-card driver sets clk_id to a constant 0.
Assume that we want to derive the sysclk from the MCLK in that case rather
than error out with -EINVAL.
This allows using this codec with the simple-sound-card driver.
[ Upstream commit eb7ebfa3c1989aa8e59d5e68ab3cddd7df1bfb27 ]
Compiling with clang yields the following warning:
sound/i2c/cs8427.c:140:31: warning: implicit conversion from 'int'
to 'char' changes value from 160 to -96 [-Wconstant-conversion]
data[0] = CS8427_REG_AUTOINC | CS8427_REG_CORU_DATABUF;
Because CS8427_REG_AUTOINC is defined as 128, it is too big for a
char field.
So change data from char to unsigned char, that it can hold the value.
This patch does not change the generated code.
Signed-off-by: Philipp Klocke <philipp97kl@gmail.com>
[ Upstream commit a85227da2dcc291b762c8482a505bc7d0d2d4b07 ]
Similar to the following:
commit 4321723648b0 ("ASoC: tegra_alc5632: fix device_node refcounting")
commit 7c5dfd549617 ("ASoC: tegra: fix device_node refcounting")
Acked-by: Jon Hunter <jonathanh@nvidia.com>
callback
[ Upstream commit 51e68fb0929c29e47e9074ca3e99ffd6021a1c5a ]
In some error paths, reference count of firewire unit is not decreased.
This commit fixes the bug.
Fixes: 5b14ec25a79b('ALSA: firewire: release reference count of firewire unit in .remove callback of bus driver')
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
[ Upstream commit d153135e93a50cdb6f1b52e238909e9965b56056 ]
The Elo VuPoint 15MX has two headphone jacks of which neither work by
default. Disabling automute allows ALSA to work normally with the
speakers & left headphone jack.
Future pin configuration changes may be required in the future to get
the right headphone jack working in tandem.
Signed-off-by: Michael Pobega <mpobega@neverware.com>
[ Upstream commit 7064f376d4a10686f51c879401a569bb4babf9c6 ]
The interrupt handler has to be acquired after the other resource
initialization when allocated with IRQF_SHARED. Otherwise it's
triggered before the resource gets ready, and may lead to unpleasant
behavior.
[ Upstream commit 3b857472f34faa7d11001afa5e158833812c98d7 ]
Playback of 44.1Khz contents with HDMI plugged returns
"Invalid pipe config" because HDMI paths in the FW
topology are configured to operate at 48Khz.
This patch filters out sampling rates not supported
at hdac_hdmi_create_dais() to let user space SRC
to do the converting.
Signed-off-by: Yong Zhi <yong.zhi@intel.com>
Reviewed-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Reviewed-by: Takashi Iwai <tiwai@suse.de>
[ Upstream commit 9ab708aef61f5620113269a9d1bdb1543d1207d0 ]
In the case where lo_vag <= SGTL5000_LINE_OUT_GND_BASE, lo_vag
is set to zero and later vol_quot is computed by dividing by
lo_vag causing a division by zero error. Fix this by avoiding
a zero division and set vol_quot to zero in this specific case
so that the lowest setting for i is correctly set.
[ Upstream commit 0e289012b47a2de1f029a6b61c75998e2f159dd9 ]
Same SSI device may be used in different dai links,
by only having one dma struct in rsnd_ssi, after the first
instance's dma config be initilized, the following instances
can no longer configure dma, this causes issue, when their
dma data address are different from the first instance.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
Signed-off-by: Timo Wischer <twischer@de.adit-jv.com>
[Kuninori: tidyup for upstream]
Tested-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
[ Upstream commit e33ffbd9cd39da09831ce62c11025d830bf78d9e ]
If the CPU DAI does not initialise rate_max, say if using
using KNOT or CONTINUOUS, then the rate_max field will be
initialised to 0. A value of zero in the rate_max field of
the hardware runtime will cause the sound card to support no
sample rates at all. Obviously this is not desired, just a
different mechanism is being used to apply the constraints. As
such update the setting of rate_max in dpcm_init_runtime_hw
to be consistent with the non-DPCM cases and set rate_max to
UINT_MAX if nothing is defined on the CPU DAI.
Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com>
[ Upstream commit b8e131542b47b81236ecf6768c923128e1f5db6e ]
snd_seq_system_client_init() doesn't check the errors returned from
its port creations. Let's do it properly and handle the error paths.
[ Upstream commit 6f128fa41f310e1f39ebcea9621d2905549ecf52 ]
The "frames" variable is unsigned so the error handling doesn't work
properly.
commit 528699317dd6dc722dccc11b68800cf945109390 upstream.
While output urb's snd_complete_urb() is executing, calling
prepare_outbound_urb() may cause endpoint stopped before
prepare_outbound_urb() returns and result in next urb submitted
to stopped endpoint. usb-audio driver cannot re-use it afterwards as
the urb is still hold by usb stack.
This change checks EP_FLAG_RUNNING flag after prepare_outbound_urb() again
to let snd_complete_urb() know the endpoint already stopped and does not
submit next urb. Below kind of error will be fixed:
[ 213.153103] usb 1-2: timeout: still 1 active urbs on EP #1
[ 213.164121] usb 1-2: cannot submit urb 0, error -16: unknown error
Signed-off-by: Henry Lin <henryl@nvidia.com>
Link: https://lore.kernel.org/r/20191113021420.13377-1-henryl@nvidia.com
commit 167beb1756791e0806365a3f86a0da10d7a327ee upstream.
A check of the return value from get_cur_mix_raw() is missing at the
resolution test code in get_min_max_with_quirks(), which may leave the
variable untouched, leading to a random uninitialized value, as
detected by syzkaller fuzzer.
Add the missing return error check for fixing that.
Reported-and-tested-by: syzbot+abe1ab7afc62c6bb6377@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20191109181658.30368-1-tiwai@suse.de
commit 1b8b68b05d1868404316d32e20782b00442aba90 upstream
All error handling paths in this function 'goto err' except this one.
If one of the 2 previous memory allocations fails, we should go through
the existing error handling path. Otherwise there is an unbalanced
pm_runtime_enable()/pm_runtime_disable().
Fixes: dd55ff8346a9 ("ASoC: davinci-mcasp: Add set_tdm_slots() support")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
commit befff4fbc27e19b14b343eb4a65d8f75d38b6230 upstream
Don't use BUG_ON() for a non-critical sanity check on production
systems. This patch replaces with a softer WARN_ON() and an error
path.
commit 0c8b794c4a10aaf7ac0d4a49be2b2638e2038adb upstream
devm_kasprintf() can fail here and we must check its return value.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
commit 09fc38c1af4cb888255e9ecf267bf9757c12885d upstream
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Addresses-Coverity-ID: 1195220
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
commit dcb407b257af06fa58b0544ec01ec9e0d3927e02 upstream
Currently BCLK inverting is only handled when the DAI format is
DSP, but the BCLK may be inverted in any supported mode. Without
this using this CODEC in any other mode than DSP with the BCLK
inverted leads to bad sampling timing and very poor audio quality.
Signed-off-by: Andrew F. Davis <afd@ti.com>
commit 15c2b3cc09a31620914955cb2a89c277c18ee999 upstream.
The unsolicited event handler for the headphone jack on CA0132 codec
driver tries to reschedule the another delayed work with
cancel_delayed_work_sync(). It's no good idea, unfortunately,
especially after we changed the work queue to the standard global
one; this may lead to a stall because both works are using the same
global queue.
Fix it by dropping the _sync but does call cancel_delayed_work()
instead.
Fixes: 993884f6a26c ("ALSA: hda/ca0132 - Delay HP amp turnon.")
BugLink: https://bugzilla.suse.com/show_bug.cgi?id=1155836
Link: https://lore.kernel.org/r/20191105134316.19294-1-tiwai@suse.de
Saffire Pro i/o series
commit 706ad6746a66546daf96d4e4a95e46faf6cf689a upstream.
For Focusrite Saffire Pro i/o, the lowest 8 bits of register represents
configured source of sampling clock. The next lowest 8 bits represents
whether the configured source is actually detected or not just after
the register is changed for the source.
Current implementation evaluates whole the register to detect configured
source. This results in failure due to the next lowest 8 bits when the
source is connected in advance.
Fixes: 25784ec2d034 ("ALSA: bebob: Add support for Focusrite Saffire/SaffirePro series")
Cc: <stable@vger.kernel.org> # v3.16+
Link: https://lore.kernel.org/r/20191102150920.20367-1-o-takashi@sakamocchi.jp
commit e7af6307a8a54f0b873960b32b6a644f2d0fbd97 upstream.
The clean up commit 41672c0c24a6 ("ALSA: timer: Simplify error path in
snd_timer_open()") unified the error handling code paths with the
standard goto, but it introduced a subtle bug: the timer instance is
stored in snd_timer_open() incorrectly even if it returns an error.
This may eventually lead to UAF, as spotted by fuzzer.
The culprit is the snd_timer_open() code checks the
SNDRV_TIMER_IFLG_EXCLUSIVE flag with the common variable timeri.
This variable is supposed to be the newly created instance, but we
(ab-)used it for a temporary check before the actual creation of a
timer instance. After that point, there is another check for the max
number of instances, and it bails out if over the threshold. Before
the refactoring above, it worked fine because the code returned
directly from that point. After the refactoring, however, it jumps to
the unified error path that stores the timeri variable in return --
even if it returns an error. Unfortunately this stored value is kept
in the caller side (snd_timer_user_tselect()) in tu->timeri. This
causes inconsistency later, as if the timer was successfully
assigned.
In this patch, we fix it by not re-using timeri variable but a
temporary variable for testing the exclusive connection, so timeri
remains NULL at that point.
Fixes: 41672c0c24a6 ("ALSA: timer: Simplify error path in snd_timer_open()")
Reported-and-tested-by: Tristan Madani <tristmd@gmail.com>
Link: https://lore.kernel.org/r/20191106165547.23518-1-tiwai@suse.de
[ Upstream commit b1e620e7d32f5aad5353cc3cfc13ed99fea65d3a ]
If rockchip_pcm_platform_register() fails, e.g. upon deferring to wait
for an absent DMA channel, we return without disabling RPM, which makes
subsequent re-probe attempts scream with errors about the unbalanced
enable. Don't do that.
Fixes: ebb75c0bdba2 ("ASoC: rockchip: i2s: Adjust devm usage")
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Link: https://lore.kernel.org/r/bcb12a849a05437fb18372bc7536c649b94bdf07.1570029862.git.robin.murphy@arm.com
[ Upstream commit 3ae7359c0e39f42a96284d6798fc669acff38140 ]
User space always expects to be able to read ALSA controls, so ensure
no kcontrols are generated without an appropriate READ flag. In the case
of a read of such a control zeros will be returned.
Signed-off-by: Stuart Henderson <stuarth@opensource.cirrus.com>
Link: https://lore.kernel.org/r/20191002084240.21589-1-ckeepax@opensource.cirrus.com
[ Upstream commit 1a7f60b9df614bb36d14dc0c0bc898a31b2b506f ]
This reverts commit caa8422d01e983782548648e125fd617cadcec3f.
It turned out that this commit caused a regression at shutdown /
reboot, as the synchronize_irq() calls seems blocking the whole
shutdown. Also another part of the change about shuffling the call
order looks suspicious; the azx_stop_chip() call disables the CORB /
RIRB while the others may still need the CORB/RIRB update.
Since the original commit itself was a cargo-fix, let's revert the
whole patch.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=205333
BugLinK: https://bugs.freedesktop.org/show_bug.cgi?id=111174
Link: https://lore.kernel.org/r/20191028081056.22010-1-tiwai@suse.de
[ Upstream commit a39331867335d4a94b6165e306265c9e24aca073 ]
When a card is disconnected while in use, the system waits until all
opened files are closed then releases the card. This is done via
put_device() of the card device in each device release code.
The recently reported mutex deadlock bug happens in this code path;
snd_timer_close() for the timer device deals with the global
register_mutex and it calls put_device() there. When this timer
device is the last one, the card gets freed and it eventually calls
snd_timer_free(), which has again the protection with the global
register_mutex -- boom.
Basically put_device() call itself is race-free, so a relative simple
workaround is to move this put_device() call out of the mutex. For
achieving that, in this patch, snd_timer_close_locked() got a new
argument to store the card device pointer in return, and each caller
invokes put_device() with the returned object after the mutex unlock.
Reported-and-tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
[ Upstream commit 41672c0c24a62699d20aab53b98d843b16483053 ]
Just a minor refactoring to use the standard goto for error paths in
snd_timer_open() instead of open code. The first mutex_lock() is
moved to the beginning of the function to make the code clearer.
commit f0778871a13889b86a65d4ad34bef8340af9d082 upstream.
Support new codec ALC623.
Link: https://lore.kernel.org/r/ed97b6a8bd9445ecb48bc763d9aaba7a@realtek.com
commit 8a6c55d0f883e9a7e7c91841434f3b6bbf932bb2 upstream.
These 2 ThinkCentres installed a new realtek codec ID 0x623,
it has 2 front mics with the same location on pin 0x18 and 0x19.
Apply fixup ALC283_FIXUP_HEADSET_MIC to change 1 front mic
location to right, then pulseaudio can handle them.
One "Front Mic" and one "Mic" will be shown, and audio output works
fine.
Signed-off-by: Aaron Ma <aaron.ma@canonical.com>
Link: https://lore.kernel.org/r/20191024114439.31522-1-aaron.ma@canonical.com
commit f2bbdbcb075f3977a53da3bdcb7cd460bc8ae5f2 upstream.
A helper function of ALSA bebob driver returns negative value in a
function which has a prototype to return unsigned value.
This commit fixes it by changing the prototype.
Fixes: eb7b3a056cd8 ("ALSA: bebob: Add commands and connections/streams management")
Link: https://lore.kernel.org/r/20191026030620.12077-1-o-takashi@sakamocchi.jp
[ Upstream commit f6ef4e0e284251ff795c541db1129c84515ed044 ]
The init sequence for ALC294 headphone stuff is needed not only for
the boot up time but also for the resume from hibernation, where the
device is switched from the boot kernel without sound driver to the
suspended image. Since we record the PM event in the device
power_state field, we can now recognize the call pattern and apply the
sequence conditionally.
