path: root/sound
2010-10-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: usb-audio: automatically detect feedback format ASoC: sound/wm9090: add missing __devexit marker ASoC: sound/max98088: add missing __devexit marker ASoC: sound/ad73311: add missing __devexit marker ASoC: fsl - fix build error in pcm030-audio-fabric.c sound/oss/sb_ess.c: delete double assignment ALSA: hda - Change BTL amp level on some HP notebooks
2010-10-27ALSA: usb-audio: automatically detect feedback formatClemens Ladisch
There are two USB Audio Class specifications (v1 and v2), but neither of them clearly defines the feedback format for high-speed UAC v1 devices. Add to this whatever the Creative and M-Audio firmware writers have been smoking, and it becomes impossible to predict the exact feedback format used by a particular device. Therefore, automatically detect the feedback format by looking at the magnitude of the first received feedback value. Also, this allows us to get rid of some special cases for E-Mu devices. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-27ASoC: sound/wm9090: add missing __devexit markerArnaud Lacombe
This fixes the following warning: sound/soc/codecs/wm9090.c:668:12: warning: 'wm9090_i2c_remove' defined but not used Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-27ASoC: sound/max98088: add missing __devexit markerArnaud Lacombe
This fixes the following warning: sound/soc/codecs/max98088.c:2054:12: warning: 'max98088_i2c_remove' defined but not used Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-27ASoC: sound/ad73311: add missing __devexit markerArnaud Lacombe
This fixes the following warning: sound/soc/codecs/ad73311.c:50:12: warning: 'ad73311_remove' defined but not used Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-26ASoC: fsl - fix build error in pcm030-audio-fabric.cLiam Girdwood
Fix build error:- sound/soc/fsl/pcm030-audio-fabric.c:27:33: fatal error: sound/soc-of-simple.h: No such file or directory Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-26sound/oss/sb_ess.c: delete double assignmentJulia Lawall
Delete successive assignments to the same location. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression i; @@ *i = ...; i = ...; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-25Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits) omap: complete removal of machine_desc.io_pg_offst and .phys_io omap: UART: fix wakeup registers for OMAP24xx UART2 omap: Fix spotty MMC voltages ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h serial: omap-serial: fix signess error OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish omap: dma: Fix buffering disable bit setting for omap24xx omap: serial: Fix the boot-up crash/reboot without CONFIG_PM OMAP3: PM: fix scratchpad memory accesses for off-mode omap4: pandaboard: enable the ehci port on pandaboard omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set omap4: pandaboard: remove unused hsmmc definition OMAP: McBSP: Remove null omap44xx ops comment OMAP: McBSP: Swap CLKS source definition OMAP: McBSP: Fix CLKR and FSR signal muxing OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks OMAP: control: move plat-omap/control.h to mach-omap2/control.h OMAP: split plat-omap/common.c OMAP: McBSP: implement functional clock switching via clock framework OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c ... Fixed up trivial conflicts in arch/arm/mach-omap2/ {board-zoom-peripherals.c,devices.c} as per Tony
2010-10-25ALSA: hda - Change BTL amp level on some HP notebooksVitaliy Kulikov
Some HP laptops have lower amplifier levels for speakers in comparison with headphone outputs. This patch changes the BTL amp level for these machines to balance both the speaker and headphone output levels. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (110 commits) sh: i2c-sh7760: Replase from ctrl_* to __raw_* sh: clkfwk: Shuffle around to match the intc split up. sh: clkfwk: modify for_each_frequency end condition sh: fix clk_get() error handling sh: clkfwk: Fix fault in frequency iterator. sh: clkfwk: Add a helper for rate rounding by divisor ranges. sh: clkfwk: Abstract rate rounding helper. sh: clkfwk: support clock remapping. sh: pci: Convert to upper/lower_32_bits() helpers. sh: mach-sdk7786: Add support for the FPGA SRAM. sh: Provide a generic SRAM pool for tiny memories. sh: pci: Support secondary FPGA-driven PCIe clocks on SDK7786. sh: pci: Support slot 4 routing on SDK7786. sh: Fix up PMB locking. sh: mach-sdk7786: Add support for fpga gpios. sh: use pr_fmt for clock framework, too. sh: remove name and id from struct clk sh: free-without-alloc fix for sh_mobile_lcdcfb sh: perf: Set up perf_max_events. sh: perf: Support SH-X3 hardware counters. ... Fix up trivial conflicts (perf_max_events got removed) in arch/sh/kernel/perf_event.c
2010-10-25Merge branch 'topic/hda' into for-linusTakashi Iwai
2010-10-25ALSA: hda - Disable sticky PCM stream assignment for AD codecsTakashi Iwai
The sticky PCM stream assignment introduced in 2.6.36 kernel seems causing problems on AD codecs. At some time later, the streaming no longer works by unknown reason. A simple workaround is to disable sticky-assignment for these codecs. Tested-by: Vasily Khoruzhick <anarsoul@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-24ALSA: usb - Creative USB X-Fi volume knob supportMandar Joshi
Adds an entry for Creative USB X-Fi to the rc_config array in mixer_quirks.c to allow use of volume knob on the device. The action of the volume knob is received by lirc when its using the alsa_usb driver. Signed-off-by: Mandar Joshi <emailmandar@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-23Merge branch 'for-2.6.37' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
2010-10-23ALSA: ca0106: Use card specific dac id for mute controls.Andy Owen
Signed-off-by: Andy Owen <andy-alsa@ultra-premium.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-23ALSA: ca0106: Allow different sound cards to use different SPI channel mappings.Andy Owen
2010-10-23ALSA: ca0106: Create a nice spot for mapping channels to dacs.Andy Owen
This is to allow a future patch to have card specific mappings between dacs, which is required since the Sound Blaster 5.1vx seems to have a different mapping to what was previously used. Signed-off-by: Andy Owen <andy-alsa@ultra-premium.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-23ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence.Andy Owen
2010-10-23ALSA: ca0106: Pull out dac powering routine into separate function.Andy Owen
This is ground work for a future commit where cards (such as the Sound Blaster 5.1vx) have different mappings between dacs and channels. Signed-off-by: Andy Owen <andy-alsa@ultra-premium.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-23ALSA: ca0106 - add Sound Blaster 5.1vx info.Andy Owen
2010-10-23ASoC: tlv320dac33: Use usleep_range for delaysPeter Ujfalusi
Switch to use the more precise usleep_range instead of msleep(). Replace the udelay with usleep_range to remove the busy loop waiting. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Borwn <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-22driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devicesKay Sievers
This patch removes the old CONFIG_SYSFS_DEPRECATED_V2 config option, but it keeps the logic around to handle block devices in the old manner as some people like to run new kernel versions on old (pre 2007/2008) distros. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22ALSA: usb-audio: add Novation Launchpad supportClemens Ladisch
Add a quirk entry for the Novation Launchpad USB MIDI controller. QUIRK_MIDI_FASTLANE gets renamed to *_RAW_BYTES because this quirk type is now shared by different devices. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Jakob Flierl <jakob.flierl@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-22ALSA: hda - Add workarounds for CT-IBG controllersTakashi Iwai
Creative IBG controllers require the playback stream-tags to be started from 1, instead of capture+1. Otherwise the stream stalls. Reported-by: Wai Yew CHAY <wychay@ctl.creative.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-22ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecsClemens Ladisch
The bit value set for TLV mute was wrong in commit de8c85f7840e5e29629de95f5af24297fb325e0b, which resulted in bogus dB ranges that screw up PulseAudio. Corrected with the right constant. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (22 commits) pcmcia: synclink_cs: fix information leak to userland pcmcia: don't call flush_scheduled_work() spuriously serial_cs: drop spurious flush_scheduled_work() call pcmcia/yenta: guide users in case of problems with O2-bridges pcmcia: fix unused function compile warning pcmcia: vrc4173_cardu: Fix error path for pci_release_regions and pci_disable_device pcmcia: add a few debug statements pcmcia: remove obsolete and wrong comments pcmcia: avoid messages on module (un)loading pcmcia: move driver name to struct pcmcia_driver pcmcia: remove the "Finally, report what we've done" message pcmcia: use autoconfiguration feature for ioports and iomem pcmcia: introduce autoconfiguration feature pcmcia: Documentation update pcmcia: convert pcmcia_request_configuration to pcmcia_enable_device pcmcia: move config_{base,index,regs} to struct pcmcia_device pcmcia: simplify IntType pcmcia: simplify Status, ExtStatus register access pcmcia: remove Pin, Copy configuration register access pcmcia: move Vpp setup to struct pcmcia_device ...
2010-10-21ASoC: tpa6130a2: Error handling for broken chipPeter Ujfalusi
Correct/Implement handling of broken chip. Fail the i2c_prope if the communication with the chip fails. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-21ASoC: max98088: Staticise m98088_eq_bandDimitris Papastamos
This function is not exported and it does not seem to be called from anywhere else therefore it should be static. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-21ASoC: soc-core: Fix codec->name memory leakDimitris Papastamos
Ensure that the codec->name is freed when unregistering the codec. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-21ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066Takashi Iwai
Multiple Acer laptops with the SSID 1025:04xx require the quirk mode=ideapad, so let's use mask to apply to all these. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-21ALSA: hda - Add some workarounds for Creative IBGTakashi Iwai
Creative HD-audio controller chips require some workarounds: - Additional delay before RIRB response - Set the initial RIRB counter to 0xc0 The latter seems to be done in general in Windows driver, so we may use this value later for all types if it's confirmed to work better. Reported-by: Wai Yew CHAY <wychay@ctl.creative.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-21ALSA: hda - Fix wrong SPDIF NID assignment for CA0110Takashi Iwai
The dig_out_nid field must take a digital-converter widget, but the current ca0110 parser passed the pin wrongly instead. Reported-by: Wai Yew CHAY <wychay@ctl.creative.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-21ALSA: hda - Fix codec rename rules for ALC662-compatible codecsKailang Yang
Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-21ALSA: hda - Add alc_init_jacks() call to other codecsKailang Yang
2010-10-20Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-10-20ALSA: snd-aloop - add pause supportJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-20ALSA: snd-aloop - fix locking issues (running flag updates)Jaroslav Kysela
On SMP machines, the cable->running update must be atomic, otherwise stream is not started correctly sometimes. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-19ASoC: WM8580: Remove useless assignmentJassi Brar
The variable is not used anyway. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-19ASoC: Fix I2C component device id number creationJarkko Nikula
Use bitwise AND instead of logical AND when masking. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-19ALSA: hda - Fix codec muted after rebooting from WindowsCharles
Windows may leave pin power-down registers set after reboot, and this resulted in muted output on Linux. Reset these registers at initialization properly. Signed-off-by: Charles Chin <Charles.Chin@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-18ASoC: Restore MAX98088 CODEC driverMark Brown
This reverts commit f6765502f8daae3d237a394889276c8987f3e299 and adds the missing include file. Signed-off-by: Peter Hsiang <Peter.Hsiang@maxim-ic.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-18ASoC: davinci-mcasp.c: Return error code in failureJulia Lawall
In this code, 0 is returned on failure, even though other failures return -ENOMEM or other similar values. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @a@ identifier alloc; identifier ret; constant C; expression x; @@ x = alloc(...); if (x == NULL) { <+... \(ret = -C; \| return -C; \) ...+> } @@ identifier f, a.alloc; expression ret; expression x,e1,e2,e3; @@ ret = 0 ... when != ret = e1 *x = alloc(...) ... when != ret = e2 if (x == NULL) { ... when != ret = e3 return ret; } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-18ALSA: snd-aloop: add cable#0 and cable#1 files to proc card treeJaroslav Kysela
Show some useful runtime information using procfs. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-18Revert "ASoC: Add max98088 CODEC driver"Mark Brown
This reverts commit e65d255a5a610ce9e185e0df855250706aca7c21 since it does not build.
