path: root/sound
2010-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix conflict of Mic Boot controls ALSA: HDA: Enable subwoofer on Asus G73Jw ALSA: HDA: Fix auto-mute on Lenovo Edge 14 ASoC: Fix bias power down of non-DAPM codec ASoC: WM8580: Fix R8 initial value ASoC: fix deemphasis control in wm8904/55/60 codecs
2010-12-17Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-12-17Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-12-17ALSA: hda - Fix conflict of Mic Boot controlsTakashi Iwai
Due to the recent change for multiple mics assignment, we need to handle the index of each Mic Boost control respectively. Otherwise the driver gets the control element conflicts, and gives the unsable state. Reference: kernel bug 25002 https://bugzilla.kernel.org/show_bug.cgi?id=25002 Reported-and-tested-by: Adam Williamson <awilliam@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-15ALSA: HDA: Enable subwoofer on Asus G73JwDavid Henningsson
Set default association/sequence right on pin 0x17 in order for the automatic parser to recognize the subwoofer correctly. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-15ALSA: HDA: Fix auto-mute on Lenovo Edge 14David Henningsson
BugLink: http://launchpad.net/bugs/690530 The SKU value of this machine dictates that auto-mute should be disabled. Since the SKU value is similar to the PCI SSID, the most likely conclusion is that the SKU value should be ignored. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: HDA: Quirk for Dell Vostro 320 to make microphone work ALSA: hda - Reset sample sizes and max bitrates when reading ELD ALSA: hda - Always allow basic audio irrespective of ELD info ALSA: hda - Do not wrongly restrict min_channels based on ELD ASoC: Correct WM8962 interrupt mask register read ASoC: WM8580: Debug BCLK and sample size ASoC: Fix resource leak if soc_register_ac97_dai_link failed ASoC: Hold client_mutex while calling snd_soc_instantiate_cards() ASoC: Fix swap of left and right channels for WM8993/4 speaker boost gain ASoC: Fix off by one error in WM8994 EQ register bank size ALSA: hda: Use position_fix=1 for Acer Aspire 5538 to enable capture on internal mic ALSA: hda - Enable jack sense for Thinkpad Edge 13 ALSA: hda - Fix ThinkPad T410[s] docking station line-out ALSA: hda: Use model=lg quirk for LG P1 Express to enable playback and capture
2010-12-13ASoC: Fix bias power down of non-DAPM codecJarkko Nikula
Currently bias of non-DAPM codec will be powered down (standby/off) whenever there is a stream stop. This is wrong in simultaneous playback/capture since the bias is put down immediately after stopping the first stream. Fix this by using the codec->active count when figuring out the needed bias level after stream stop. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-09ASoC: WM8580: Fix R8 initial valueSeungwhan Youn
Acc to WM8580 manual, the default value for R8 is 0x10, not 0x1c. Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-12-09ASoC: fix deemphasis control in wm8904/55/60 codecsDmitry Artamonow
Deemphasis control's .get callback should update control's value instead of returning it - return value of callback function is used for indicating error or success of operation. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-12-09Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-12-09Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-12-09ALSA: HDA: Quirk for Dell Vostro 320 to make microphone workDavid Henningsson
BugLink: http://launchpad.net/497546 Confirmed that the ideapad model works better than the current quirk for Dell Vostro 320. Cc: stable@kernel.org (2.6.35+) Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-08ALSA: hda - Reset sample sizes and max bitrates when reading ELDAnssi Hannula
When a new HDMI/DP device is plugged in, hdmi_update_short_audio_desc() is called for every SAD (Short Audio Descriptor) in the ELD data. For LPCM coding type SAD defines the supported sample sizes. For several other coding types (such as AC-3), a maximum bitrate is defined. The maximum bitrate and sample size fields are not always cleared. Therefore, if a device is unplugged and a different one is plugged in, and the coding types of some SAD positions differ between the devices, the old max_bitrate or sample_bits values will persist if the new SADs do not define those values. The leftover max_bitrate and sample_bits do not cause any issues other than wrongly showing up in eld#X.Y procfs file and kernel log. Fix that by always clearing sample_bits and max_bitrate when reading SADs. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-07ALSA: hda - Always allow basic audio irrespective of ELD infoAnssi Hannula
Commit bbbe33900d1f3c added functionality to restrict PCM parameters based on ELD info (derived from EDID data) of the audio sink. However, according to CEA-861-D no SAD is needed for basic audio (32/44.1/48kHz stereo 16-bit audio), which is instead indicated with a basic audio flag in the CEA EDID Extension. The flag is not present in ELD. However, as all audio capable sinks are required to support basic audio, we can assume it to be always available. Fix allowed audio formats with sinks that have SADs (Short Audio Descriptors) which do not completely overlap with the basic audio formats (there are no reports of affected devices so far) by always assuming that basic audio is supported. Reported-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-07ALSA: hda - Do not wrongly restrict min_channels based on ELDAnssi Hannula
Commit bbbe33900d1f3c added functionality to restrict PCM parameters based on ELD info (derived from EDID data) of the audio sink. However, it wrongly assumes that the bits 0-2 of the first byte of CEA Short Audio Descriptors mean a supported number of channels. In reality, they mean the maximum number of channels (as per CEA-861-D 7.5.2). This means that the channel count can only be used to restrict max_channels, not min_channels. Restricting min_channels causes us to deny opening the device in stereo mode if the sink only has SADs that declare larger numbers of channels (like Primare SP32 AV Processor does). Fix that by not restricting min_channels based on ELD information. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Reported-by: Jean-Yves Avenard <jyavenard@gmail.com> Tested-by: Jean-Yves Avenard <jyavenard@gmail.com> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-07ASoC: Correct WM8962 interrupt mask register readMark Brown
Fix mismerge from the out of tree BSP where this support was developed. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-07ASoC: WM8580: Debug BCLK and sample sizeJassi Brar
In case of SNDRV_PCM_FORMAT_S32_LE, we need to set WM8580_AIF_LENGTH_32, rather than WM8580_AIF_LENGTH_24. Also, the BCLK has to be 64fs, for sample size of 20, 24 and 32 bits. Signed-off-by: Jassi Brar <jassi.brar@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-07ASoC: Fix resource leak if soc_register_ac97_dai_link failedAxel Lin
Properly free the resources in the case of soc_register_ac97_dai_link failure. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-06ASoC: Hold client_mutex while calling snd_soc_instantiate_cards()Axel Lin
As the comments of snd_soc_instantiate_cards() said, snd_soc_instantiate_cards() must be called with client_mutex. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-06ASoC: Fix swap of left and right channels for WM8993/4 speaker boost gainUk Kim
SPKOUTL_BOOST start from third bit, SPKOUTLR_BOOST start from 0 bit. Signed-off-by: Uk Kim <w0806.kim@samsung.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-12-06ALSA: hda: Use position_fix=1 for Acer Aspire 5538 to enable capture on ↵Daniel T Chen
internal mic BugLink: https://launchpad.net/bugs/685161 The reporter of the bug states that he must use position_fix=1 to enable capture for the internal microphone, so set it for his machine's PCI SSID. Verified using 2.6.35 and the 2010-12-04 alsa-driver build. Reported-and-tested-by: Ralph Wabel <rwabel@gmx.net> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-04ALSA: hda - Enable jack sense for Thinkpad Edge 13Manoj Iyer
Added a quirk to cxt5066_cfg_tbl to enable jack sense for ThinkPad Edge 13. Reference: http://launchpad.net/bugs/685015 Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: omap: N810: Don't select CONFIG_OMAP_MUX but make it as dependency ALSA: hda: Use "alienware" model quirk for another SSID ASoC: WM8731: Fix incorrect mask for bypass path disable s6105-ipcam: fix compilation s6000-pcm: fix compilation s6000-i2s: fix compilation ASoC: Fix missing spin_unlock_irqrestore ALSA: Fix SNDCTL_DSP_RESET ioctl for OSS emulation ASoC: Add missing dev_set_drvdata in p1022_ds_probe ASoC: Add missing dev_set_drvdata in mpc8610_hpcd_probe ASoC: Remove unneeded !! operations while checking return value of nuc900_checkready ASoC: Fix compile error for nuc900-pcm.c ASoC: Fix prototype for nuc900_ac97_probe and nuc900_ac97_remove ASoC: Fix compile error for nuc900-ac97.c ALSA: hda: Use BIOS auto-parsing instead of existing model quirk for MEDION MD2
2010-12-03ALSA: hda - Fix ThinkPad T410[s] docking station line-outJohn Baboval
On the docking station for the Lenovo T410 and T410s, the line-out doesn't work. The trouble seems to be that it generates a plug event, but then doesn't report that the jack is connected. So automute mutes the jack when you plug something into it. The following patch (next message) fixes it. Signed-off-by: John Baboval <john.baboval at virtualcomputer.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-03ALSA: hda: Use model=lg quirk for LG P1 Express to enable playback and captureDaniel T Chen
BugLink: https://launchpad.net/bugs/595482 The original reporter states that audible playback from the internal speaker is inaudible despite the hardware being properly detected. To work around this symptom, he uses the model=lg quirk to properly enable both playback, capture, and jack sense. Another user corroborates this workaround on separate hardware. Add this PCI SSID to the quirk table to enable it for further LG P1 Expresses. Reported-and-tested-by: Philip Peitsch <philip.peitsch@gmail.com> Tested-by: nikhov Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-02Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-12-02Merge branch 'for-2.6.37' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into fix/asoc
2010-12-02Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-12-02ASoC: omap: N810: Don't select CONFIG_OMAP_MUX but make it as dependencyJarkko Nikula
Not all omap boards use kernel based pin multiplexing so CONFIG_SND_OMAP_SOC_N810 should not select it by default as it can make harm to other boards in multi-board kernels. Therefore put CONFIG_OMAP_MUX as a dependency to N810 ASoC machine driver. Thanks to Tony Lindgren <tony@atomide.com> for noticing. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-02ALSA: hda: Use "alienware" model quirk for another SSIDDaniel T Chen
BugLink: https://launchpad.net/bugs/683695 The original reporter states that headphone jacks do not appear to work. Upon inspecting his codec dump, and upon further testing, it is confirmed that the "alienware" model quirk is correct. Reported-and-tested-by: Cody Thierauf Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-01ASoC: WM8731: Fix incorrect mask for bypass path disableDimitris Papastamos
According to the datasheet the bypass path enable/disable is bit 3 therefore we need 0x8 and not 0x4. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30s6105-ipcam: fix compilationDaniel Glöckner
When the s6105-ipcam ASoC driver had been converted to the multi-component API, a single reference to a former structure element remained, blocking successful compilation. Signed-off-by: Daniel Glöckner <daniel-gl@gmx.net> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30s6000-pcm: fix compilationDaniel Glöckner
s6000_soc_platform has lost its forward declaration and there no longer is a name element in it, so use a string constant when calling request_irq. Signed-off-by: Daniel Glöckner <daniel-gl@gmx.net> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30s6000-i2s: fix compilationDaniel Glöckner
A semicolon was missing. Signed-off-by: Daniel Glöckner <daniel-gl@gmx.net> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30ASoC: Fix missing spin_unlock_irqrestoreAxel Lin
In nuc900_dma_hw_params(), if snd_pcm_lib_malloc_pages failed it returns without calling spin_unlock_irqrestore(). Since snd_pcm_lib_malloc_pages() does not touch struct nuc900_audio, we don't need to hold the lock while calling snd_pcm_lib_malloc_pages(). Fix it by moving spin_lock_irqsave() down to after snd_pcm_lib_malloc_pages(). In nuc900_dma_prepare(), spin_unlock_irqrestore() is missing in the error path. Fix it by removing the return in default case. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30ALSA: Fix SNDCTL_DSP_RESET ioctl for OSS emulationTakashi Iwai
In OSS emulation, SNDCTL_DSP_RESET ioctl needs the reset of the internal buffer state in addition to drop of the running streams. Otherwise the succeeding access becomes inconsistent. Tested-by: Amit Nagal <helloin.amit@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-29ASoC: Add missing dev_set_drvdata in p1022_ds_probeAxel Lin
Otherwise, calling dev_get_drvdata in p1022_ds_remove returns NULL. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Add missing dev_set_drvdata in mpc8610_hpcd_probeAxel Lin
Otherwise, calling dev_get_drvdata in mpc8610_hpcd_remove returns NULL. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Remove unneeded !! operations while checking return value of ↵Axel Lin
nuc900_checkready I think this unneededd !! operations just reduce the readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Fix compile error for nuc900-pcm.cAxel Lin
This patch fixes below error: CC sound/soc/nuc900/nuc900-pcm.o sound/soc/nuc900/nuc900-pcm.c: In function 'nuc900_dma_open': sound/soc/nuc900/nuc900-pcm.c:267: error: 'nuc900_ac97_data' undeclared (first use in this function) sound/soc/nuc900/nuc900-pcm.c:267: error: (Each undeclared identifier is reported only once sound/soc/nuc900/nuc900-pcm.c:267: error: for each function it appears in.) sound/soc/nuc900/nuc900-pcm.c: At top level: sound/soc/nuc900/nuc900-pcm.c:337: error: expected ',' or ';' before 'static' sound/soc/nuc900/nuc900-pcm.c:354: error: 'nuc900_soc_platform_probe' undeclared here (not in a function) make[3]: *** [sound/soc/nuc900/nuc900-pcm.o] Error 1 make[2]: *** [sound/soc/nuc900] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Fix prototype for nuc900_ac97_probe and nuc900_ac97_removeAxel Lin
This patch fixes below compile warning: CC sound/soc/nuc900/nuc900-ac97.o sound/soc/nuc900/nuc900-ac97.c:300: warning: initialization from incompatible pointer type sound/soc/nuc900/nuc900-ac97.c:301: warning: initialization from incompatible pointer type Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Fix compile error for nuc900-ac97.cAxel Lin
Fix below compile error by add a missing ';'. CC sound/soc/nuc900/nuc900-ac97.o sound/soc/nuc900/nuc900-ac97.c:300: warning: initialization from incompatible pointer type sound/soc/nuc900/nuc900-ac97.c:301: warning: initialization from incompatible pointer type sound/soc/nuc900/nuc900-ac97.c:318: error: expected ',' or ';' before 'static' sound/soc/nuc900/nuc900-ac97.c:405: error: 'nuc900_ac97_drvprobe' undeclared here (not in a function) make[3]: *** [sound/soc/nuc900/nuc900-ac97.o] Error 1 make[2]: *** [sound/soc/nuc900] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ALSA: hda: Use BIOS auto-parsing instead of existing model quirk for MEDION MD2Daniel T Chen
BugLink: https://launchpad.net/bugs/682199 A 2.6.35 (Ubuntu Maverick) user, burningphantom1, reported a regression in audio: playback was inaudible through both speakers and headphones. In commit 272a527c04 of sound-2.6.git, a new model was added with this machine's PCI SSID. Fortunately, it is now sufficient to use the auto model for BIOS auto-parsing instead of the existing quirk. Playback, capture, and jack sense were verified working for both 2.6.35 and the alsa-driver snapshot from 2010-11-27 when model=auto is used. Reported-and-tested-by: burningphantom1 Cc: <stable@kernel.org> [2.6.35+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (30 commits) ALSA: hda - Use ALC_INIT_DEFAULT for really default initialization ASoC: Fix resource reclaim for osk5912 ASoC: tlv320aic3x - fix variable may be used uninitialized warning ASoC: davinci-vcif - fix a memory leak ASoC: phycore-ac97: fix resource leak ASoC: imx-ssi: fix resource leak ASoC: simone: fix resource leak in simone_init error path ASoC: sam9g20_wm8731: fix resource leak in at91sam9g20ek_init error path ASoC: snd-soc-afeb9260: remove unneeded platform_device_del in error path ASoC: pcm030-audio-fabric: fix resource leak in pcm030_fabric_init error path ASoC: efika-audio-fabric: fix resource leak in efika_fabric_init error path ASoC: Call snd_soc_unregister_dais instead of snd_soc_unregister_dai in sh4_soc_dai_remove ASoC: fix SND_PXA2XX_LIB Kconfig warning ALSA: hda - Fix ALC660-VD/ALC861-VD capture/playback mixers ALSA: HDA: Add an extra DAC for Realtek ALC887-VD ASoC: nuc900-ac97: fix a memory leak ASoC: Return proper error for omap3pandora_soc_init ASoC: wm8961 - clear WM8961_MCLKDIV bit for freq <= 16500000 ASoC: wm8961 - clear WM8961_DACSLOPE bit for normal mode ALSA: hda - Fix Acer 7730G support ...
2010-11-26Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-11-26ALSA: hda - Use ALC_INIT_DEFAULT for really default initializationTakashi Iwai
When SKU assid gives no valid bits for 0x38, the driver didn't take any action, so far. This resulted in the missing initialization for external amps, etc, thus the silent output in the end. Especially users hit this problem on ALC888 newly since 2.6.35, where the driver doesn't force to use ALC_INIT_DEFAULT any more. This patch sets the default initialization scheme to use ALC_INIT_DEFAULT when no valid bits are set for SKU assid. Reference: https://bugzilla.redhat.com/show_bug.cgi?id=657388 Reported-and-tested-by: Kyle McMartin <kyle@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-25ASoC: Fix resource reclaim for osk5912Axel Lin
In current implementation, there are resources leak in the error path. This patch properly reclaims the allocated resources in the error path. Also adds a missing clk_put in osk_soc_exit. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: tlv320aic3x - fix variable may be used uninitialized warningAxel Lin
If aic3x_read failed , val is used uninitialized. Fix it by initializing val to 0. This patch fixes below compile warning: sound/soc/codecs/tlv320aic3x.c: In function 'aic3x_get_gpio': sound/soc/codecs/tlv320aic3x.c:1183: warning: 'val' may be used uninitialized in this function sound/soc/codecs/tlv320aic3x.c: In function 'aic3x_headset_detected': sound/soc/codecs/tlv320aic3x.c:1211: warning: 'val' may be used uninitialized in this function sound/soc/codecs/tlv320aic3x.c: In function 'aic3x_button_pressed': sound/soc/codecs/tlv320aic3x.c:1219: warning: 'val' may be used uninitialized in this function Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: davinci-vcif - fix a memory leakAxel Lin
