path: root/sound
2008-07-24CONFIG_SOUND_WM97XX: remove stale makefile lineAdrian Bunk
The driver is gone for a long time. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24remove the OSS trident driverAdrian Bunk
SOUND_TRIDENT was the last PCI OSS driver, and since there's already an ALSA driver for the same hardware we can remove it. [muli@il.ibm.com: update CREDITS] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-23Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (85 commits) [ARM] pxa: add base support for PXA930 Handheld Platform (aka SAAR) [ARM] pxa: add base support for PXA930 Evaluation Board (aka TavorEVB) [ARM] pxa: add base support for PXA930 (aka Tavor-P) [ARM] Update mach-types [ARM] pxa: make littleton to use the new smc91x platform data [ARM] pxa: make zylonite to use the new smc91x platform data [ARM] pxa: make mainstone to use the new smc91x platform data [ARM] pxa: make lubbock to use new smc91x platform data [NET] smc91x: prepare SMC_USE_PXA_DMA to be specified in platform data [NET] smc91x: prepare for SMC_IO_SHIFT to be a platform configurable variable [NET] smc91x: add SMC91X_NOWAIT flag to platform data [NET] smc91x: favor the use of SMC91X_USE_* instead of SMC_CAN_USE_* [NET] smc91x: remove "irq_flags" from "struct smc91x_platdata" [ARM] 5146/1: pxa2xx: convert all boards to call pxa2xx_transceiver_mode helper Support for LCD on e740 e750 e400 and e800 e-series PDAs E-series UDC support PXA UDC - allow use of inverted GPIO for pullup Add e350 support Fix broken e-series build E-series GPIO / IRQ definitions. ...
2008-07-21device create: sound: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Cc: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-14Merge branch 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6Linus Torvalds
* 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6: (64 commits) firmware: convert sb16_csp driver to use firmware loader exclusively dsp56k: use request_firmware edgeport-ti: use request_firmware() edgeport: use request_firmware() vicam: use request_firmware() dabusb: use request_firmware() cpia2: use request_firmware() ip2: use request_firmware() firmware: convert Ambassador ATM driver to request_firmware() whiteheat: use request_firmware() ti_usb_3410_5052: use request_firmware() emi62: use request_firmware() emi26: use request_firmware() keyspan_pda: use request_firmware() keyspan: use request_firmware() ttusb-budget: use request_firmware() kaweth: use request_firmware() smctr: use request_firmware() firmware: convert ymfpci driver to use firmware loader exclusively firmware: convert maestro3 driver to use firmware loader exclusively ... Fix up trivial conflicts with BKL removal in drivers/char/dsp56k.c and drivers/char/ip2/ip2main.c manually.
2008-07-14Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (241 commits) [ARM] 5171/1: ep93xx: fix compilation of modules using clocks [ARM] 5133/2: at91sam9g20 defconfig file [ARM] 5130/4: Support for the at91sam9g20 [ARM] 5160/1: IOP3XX: gpio/gpiolib support [ARM] at91: Fix NAND FLASH timings for at91sam9x evaluation kits. [ARM] 5084/1: zylonite: Register AC97 device [ARM] 5085/2: PXA: Move AC97 over to the new central device declaration model [ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC drivers [ARM] 5147/1: pxaficp_ir: drop pxa_gpio_mode calls, as pin setting [ARM] 5145/1: PXA2xx: provide api to control IrDA pins state [ARM] 5144/1: pxaficp_ir: cleanup includes [ARM] pxa: remove pxa_set_cken() [ARM] pxa: allow clk aliases [ARM] Feroceon: don't disable BPU on boot [ARM] Orion: LED support for HP mv2120 [ARM] Orion: add RD88F5181L-FXO support [ARM] Orion: add RD88F5181L-GE support [ARM] Orion: add Netgear WNR854T support [ARM] s3c2410_defconfig: update for current build [ARM] Acer n30: Minor style and indentation fixes. ...
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-14[ARM] Merge most of the PXA work for initial mergeRussell King
This includes PXA work up to the SPI changes for the initial merge, since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI tree being merged. Conflicts: arch/arm/configs/em_x270_defconfig arch/arm/configs/xm_x270_defconfig
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-14firmware: convert sb16_csp driver to use firmware loader exclusivelyJaswinder Singh
Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-14Merge branch 'x86/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (821 commits) x86: make 64bit hpet_set_mapping to use ioremap too, v2 x86: get x86_phys_bits early x86: max_low_pfn_mapped fix #4 x86: change _node_to_cpumask_ptr to return const ptr x86: I/O APIC: remove an IRQ2-mask hack x86: fix numaq_tsc_disable calling x86, e820: remove end_user_pfn x86: max_low_pfn_mapped fix, #3 x86: max_low_pfn_mapped fix, #2 x86: max_low_pfn_mapped fix, #1 x86_64: fix delayed signals x86: remove conflicting nx6325 and nx6125 quirks x86: Recover timer_ack lost in the merge of the NMI watchdog x86: I/O APIC: Never configure IRQ2 x86: L-APIC: Always fully configure IRQ0 x86: L-APIC: Set IRQ0 as edge-triggered x86: merge dwarf2 headers x86: use AS_CFI instead of UNWIND_INFO x86: use ignore macro instead of hash comment x86: use matching CFI_ENDPROC ...
2008-07-14ALSA: correct kcalloc usageMilton Miller
kcalloc is supposed to be called with the count as its first argument and the element size as the second. Both arguments are size_t so does not affect correctness. This callsite is during module_init and therefore not performance critical. Another patch will optimize the case when the count is variable but the size is fixed. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: ALSA driver for SGI O2 audio boardThomas Bogendoerfer
This patch adds a new ALSA driver for the audio device found inside most of the SGI O2 workstation. The hardware uses a SGI custom chip, which feeds a AD codec chip. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: asoc: kbuild - only show menus for the current ASoC CPU platform.Liam Girdwood
We don't want to see ASoC platform menus for other non selected architectures in our config. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: ALSA driver for SGI HAL2 audio deviceThomas Bogendoerfer
This patch adds a new ALSA driver for the audio device found inside many older SGI workstation (Indy, Indigo2). The hardware uses a SGI custom chip, which feeds two codec chips, an IEC chip and a synth chip. Currently only one of the codecs is supported. This driver already has the same functionality as the HAL2 OSS driver and will replace it. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: hda - Fix FSC V5505 modelTakashi Iwai
model=laptop-hpmicsense matches better to FSC V5505 laptop. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: hda - Fix missing init for unsol events on micsense modelTakashi Iwai
Fixed the missing initialization for unsolicited events on Cx5045 micsense model. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: hda - Fix internal mic vref pin setupTakashi Iwai
Set the vref80 to the internal mic pin 0x12 for Cx5045. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: hda: 92hd71bxx PC BeepMatthew Ranostay
Added volume controls for the analog PC Beep on 92hd71bxx codecs. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-13Merge branch 'pxa' into develRussell King
2008-07-12Merge branch 'pxa-tosa' into pxaRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/tosa.c arch/arm/mach-pxa/spitz.c
2008-07-10x86, VisWS: turn into generic arch, update include file changeIngo Molnar
2008-07-10Merge branches 'at91', 'dyntick', 'ep93xx', 'iop', 'ixp', 'misc', 'orion', ↵Russell King
'omap-reviewed', 'rpc', 'rtc' and 's3c' into devel
2008-07-10firmware: convert ymfpci driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10firmware: convert maestro3 driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10firmware: convert korg1212 driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10Fix a const pointer usage warning in the Digigram miXart soundcard driverDavid Howells
Fix a const pointer usage warning in the Digigram miXart soundcard driver. A const pointer is being passed to copy_from_user() to load the firmware into. This is okay in this case because the function has allocated the firmware struct itself, but the const qualifier is part of the firmware struct - so the patch casts the const away. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10Fix a const pointer usage warning in the Digigram pcxhr soundcard driverDavid Howells
Fix a const pointer usage warning in the Digigram pcxhr compatible soundcard driver. A const pointer is being passed to copy_from_user() to load the firmware into. This is okay in this case because the function has allocated the firmware struct itself, but the const qualifier is part of the firmware struct - so the patch casts the const away. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10Fix a const pointer usage warning in the Digigram VX soundcard driverDavid Howells
Fix a const pointer usage warning in the Digigram VX soundcard driver. A const pointer is being passed to copy_from_user() to load the firmware into. This is okay in this case because the function has allocated the firmware struct itself, but the const qualifier will be part of the firmware struct - so the patch casts the const away. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10ymfpci: treat firmware data as constDavid Woodhouse
Standardise both in-kernel and loaded firmware to be stored as little-endian instead of host-endian. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10maestro3: treat firmware data as constDavid Woodhouse
The maestro3 driver is byte-swapping its firmware to be host-endian in advance, when it doesn't seem to be necessary -- we could just use le16_to_cpu() as we load it. Doing that means that we need to switch the in-tree firmware to be little-endian too. Take the least intrusive way of doing this, which is to switch the existing snd_m3_convert_from_le() function to convert _to_ little-endian instead, and use it on the in-tree firmware instead of the loaded firmware. It's a bit suboptimal but doesn't matter much right now because we're about to remove the special cases for the in-tree version anyway. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10vx: treat firmware data as constDavid Woodhouse
2008-07-10pcxhr: treat firmware data as constDavid Woodhouse
2008-07-10riptide: treat firmware data as constDavid Woodhouse
2008-07-10vx222: treat firmware data as constDavid Woodhouse
2008-07-10ALSA: HDA - HP dc7600 with pci sub IDs 0x103c/0x3011 belongs to hp-3013 modelJaroslav Kysela
As reported and tested by an RedHat customer, HP dc7600 with pci sub IDs 0x103c/0x3011 works with the hp-3013 model and not with the hp only model. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10[ARM] 5130/4: Support for the at91sam9g20sedji gaouaou
Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC. AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. We created a new board for this device but based the chip support directly on 9260 files with little updates. Here is the chip page on Atmel wabsite: http://atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Justin Waters <justin.waters@timesys.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-10ALSA: usb-audio: add some Yamaha USB MIDI quirksClemens Ladisch
Add quirk entries for four Yamaha USB MIDI devices. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2008-07-10ALSA: usb-audio: fix Yamaha KX quirkClemens Ladisch
We have to restrict the quirk to interface 0 because the second interface is not MIDI but HID. Additionally, this product ID is used by all four KX models, so it is better to read the product name from the device. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2008-07-10ALSA: ASoC: Au12x0/Au1550 PSC Audio supportManuel Lauss
Audio for Au12x0/Au1550 PSCs in AC97 and I2S mode, for ASoC v1 framework. - DBDMA, AC97 and I2S drivers - sample AC97 machine code (Db1200) Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: Add Yamaha KX49 (USB MIDI controller) to usbquirks.hRichard Chan
This patch is for the Yamaha USB MIDI controller KX49. http://www.yamahasynth.com/products/kx/index.html It has a 3-port MIDI interface and an HID interface (it has a tiny keyboard subset). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: ASoC: pxa2xx-ac97: fix warning due to missing argument in fuction ↵Dmitry Baryshkov
declaration Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: tosa: fix compilation with new DAPM APIDmitry Baryshkov
2008-07-10ALSA: wavefront - add constTakashi Iwai
Fix const to non-const pointer cast warning in wavefront_synth.c. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: remove CONFIG_KMOD from soundJohannes Berg
A bunch of things in alsa depend on CONFIG_KMOD, use CONFIG_MODULES instead where the dependency is needed at all. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: Fix a const to non-const assignment in the Digigram VXpocket sound driverDavid Howells
Fix a const to non-const pointer assignment warning in the Digigram VXpocket sound driver. This may be due to patch 0aa4937648b91e9e6d3879b2cbeaa5f0c9863ac0. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: Fix a const pointer usage warning in the Digigram VX soundcard driverDavid Howells
Fix a const pointer usage warning in the Digigram VX soundcard driver. A const pointer is being passed to copy_from_user() to load the firmware into. This is okay in this case because the function has allocated the firmware struct itself, but the const qualifier is part of the firmware struct - so the patch casts the const away. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: asoc: at32 - DAI struct merge and enable_pin() change.Liam Girdwood
This adds support for the recent DAI struct merge and new DAPM pin API. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
