path: root/sound
2009-02-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: Only register AC97 bus if it's not done already ALSA: hda - Add snd_hda_multi_out_dig_cleanup() ALSA: hda - Add missing terminator in slave dig-out array ALSA: hda - Change HP dv7 (103c:30f4) quirk from hp-m4 to hp-dv5 model ALSA: hda - Register (new) devices at reconfig ALSA: mtpav - Fix initial value for input hwport ALSA: hda - add id for Intel IbexPeak integrated HDMI codec ALSA: hda - compute checksum in HDMI audio infoframe ALSA: hda - enable HDMI audio pin out at module loading time ALSA: hda - allow multi-channel HDMI audio playback when ELD is not present ASoC: Update SDP3430 machine driver for snd_soc_card ALSA: hda - Add quirk for Asus z37e (1043:8284) sound: Remove OSSlib stuff from linux/soundcard.h ASoC: WM8990: Fix kcontrol's private value use in put callback ASoC: TLV320AIC3X: Fix kcontrol's private value use in put callback
2009-02-13Merge branch 'fix/asoc' into for-linusTakashi Iwai
2009-02-13Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-02-13ASoC: Only register AC97 bus if it's not done alreadyMark Brown
ASoC supports both explicit codec drivers for AC97 devices and a simple driver which uses the standard ALSA AC97 framework for codec support. When used with the generic AC97 codec support that will provide the ad hoc AC97 device for drivers like touchscreens to attach to so the core shouldn't do so. Reported-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-13ALSA: hda - Add snd_hda_multi_out_dig_cleanup()Takashi Iwai
Added the helper function snd_hda_multi_out_dig_cleanup() to clean up the digital outputs with multi setup. This call is needed in cases the codec supports multiple digital outputs as slaves. Otherwise the slave widgets aren't properly cleaned up. For a single digital output (e.g. in patch_conexant.c), this call isn't needed. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-13ALSA: hda - Add missing terminator in slave dig-out arrayTakashi Iwai
Added the missing terminator for ad1989b_slave_dig_outs[]. Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-13ALSA: hda - Change HP dv7 (103c:30f4) quirk from hp-m4 to hp-dv5 modelHerton Ronaldo Krzesinski
Change HP dv7 quirk: although reported to work with hp-m4 model (https://bugzilla.novell.com/show_bug.cgi?id=445321), the original report doesn't contain info about testing of internal microphone. Recently I received a report about internal mic not working (https://qa.mandriva.com/show_bug.cgi?id=44855#c193), this must be related with the forced line in on pin 0x0e done with hp-m4 model. Thus change the current quirk from STAC_HP_M4 to STAC_HP_DV5, later reported to be fixed on a provided kernel with this change (https://qa.mandriva.com/show_bug.cgi?id=44855#c196). Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-12ALSA: hda - Register (new) devices at reconfigTakashi Iwai
The devices that have been newly added during reconfig must be registered. Otherwise they won't be visible to user-space. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-12ALSA: mtpav - Fix initial value for input hwportTakashi Iwai
Fix the initial value for input hwport. The old value (-1) may cause Oops when an realtime MIDI byte is received before the input port is explicitly given. Instead, now it's set to the broadcasting as default. Tested-by: Holger Dehnhardt <dehnhardt@ahdehnhardt.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-11ALSA: hda - add id for Intel IbexPeak integrated HDMI codecWu Fengguang
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-11ALSA: hda - compute checksum in HDMI audio infoframeWu Fengguang
2009-02-11ALSA: hda - enable HDMI audio pin out at module loading timeWu Fengguang
We found that enabling/disabling HDMI audio pin out at stream start/stop time will kill the leading 500ms or so sound samples. Avoid this by enabling pin out once and for ever at module loading time. The leading ~500ms audio samples will still be lost when switching from X-channel playback to Y-channel playback where X != Y. However there's no much we can do about it: the audio infoframe has to change and it looks like either G45 or YAMAHA requires some time to switch the configuration. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-11ALSA: hda - allow multi-channel HDMI audio playback when ELD is not presentWu Fengguang
The YAMAHA AV-X1800 requires audio infoframe to include speaker-channel mapping to play >2 channel HDMI audio. In theory that mapping should be derived from its speaker configurations contained in its ELD. However we currently cannot get ELD in console before the KMS functionalities are ready. This is a more or less general issue at least in the near future. As a workaround, we propose to allow playback of mult-channel audio when ELD is not available. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-10ASoC: Update SDP3430 machine driver for snd_soc_cardLopez Cruz, Misael
This patch replaces "snd_soc_machine" structure by "snd_soc_card" in SP3430 driver. This change is needed in SDP3430 driver to reflect changes introduced by "ASoC: Rename snd_soc_card to snd_soc_machine" patch (875065491fba8eb13219f16c36e79a6fb4e15c68). Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Acked-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-10ALSA: hda - Add quirk for Asus z37e (1043:8284)Mackenzie Morgan
Added a quirk for Asus Z37E for fixing suspend/hibernation problem. Reference: https://bugs.edge.launchpad.net/ubuntu/+source/linux/+bug/25896 http://launchpadlibrarian.net/17053575/0001-Add-quirk-for-ASUS-Z37E-to-make-sound-audible-afte.patch https://bugtrack.alsa-project.org/alsa-bug/bug_view_page.php?bug_id=4282 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-10[ARM] AACI: timeout will reach -1Roel Kluin
With a postfix decrement the timeout will reach -1 rather than 0, so the warning will not be issued. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-06Merge branch 'fix/usb-audio' into for-linusTakashi Iwai
2009-02-06Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-02-06ALSA: hda - Add missing COEF initialization for ALC887Takashi Iwai
2009-02-06ALSA: hda - Add missing initialization for ALC272Takashi Iwai
ALC272 needs EAPD for speaker outputs as well as other similar ALC codecs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-06ASoC: WM8990: Fix kcontrol's private value use in put callbackJarkko Nikula
Function wm899x_outpga_put_volsw_vu misuses the kcontrol's private value by still accessing it as bitfields even SOC_SINGLE_VALUE constructs it as a pointer into struct soc_mixer_control after the commit 4eaa9819dc08d7bfd1065ce530e31b18a119dcaf. This is very similar fix than fix to TLV320AIC3X codec made by Eero Nurkkala <ext-eero.nurkkala@nokia.com>. This fix is compile tested only. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-06ASoC: TLV320AIC3X: Fix kcontrol's private value use in put callbackEero Nurkkala
Function snd_soc_dapm_put_volsw_aic3x misuses the kcontrol's private value by still accessing it as bitfields even SOC_SINGLE_VALUE constructs it as a pointer into struct soc_mixer_control after the commit 4eaa9819dc08d7bfd1065ce530e31b18a119dcaf. This was causing arbitrary register writes when touching the controls defined with SOC_DAPM_SINGLE_AIC3X. Signed-off-by: Eero Nurkkala <ext-eero.nurkkala@nokia.com> Acked-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-06sound: usb-audio: handle wMaxPacketSize for FIXED_ENDPOINT devicesClemens Ladisch
For audio devices that do not have proper audio descriptors (e.g., Edirol UA-20), we use hardcoded parameters from our quirks list. However, we must still read the maximum packet size from the standard endpoint descriptor; otherwise, we might use packets that are too big and therefore rejected by the USB core. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: hda - Fix misc workqueue issuesTakashi Iwai
Some fixes regarding snd-hda-intel workqueue: - Use create_singlethread_workqueue() instead of create_workqueue() as per-CPU work isn't required. - Allocate workq name string properly - Renamed the workq name to "hd-audio*" to be more obvious. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-04ALSA: hda - Add quirk for FSC Amilo Xi2550Takashi Iwai
Added model=fujisu-pi2515 for FSC Amilo Xi2550 with ALC883 codec. Refernece: Novell bnc#450979 https://bugzilla.novell.com/show_bug.cgi?id=450979 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-04Merge branch 'fix/asoc' into for-linusTakashi Iwai
2009-02-04Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-02-04ALSA: pcm_oss: AFMT_S24_LE is set twice in return valueRoel Kluin
AFMT_S24_LE is set twice in return value vi sound/core/oss/pcm_oss.c +640 #define AFMT_S24_LE 0x00008000 #define AFMT_S24_BE 0x00010000 Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-03ALSA: ASoC: email - update email addresses.Liam Girdwood
This just updates my email address on some drivers I'd forgotten in a previous patch. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-02OMAP: ASoC: Fix spinlock misuse in omap-pcm.cEero Nurkkala
omap_pcm_trigger is called also in interrupt context so CPU flags must be restored when returning. Signed-off-by: Eero Nurkkala <ext-eero.nurkkala@nokia.com> Acked-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-02ALSA: hda - No widget selection for volume knob widgets in proc outputTakashi Iwai
Volume-knob widgets have no widget selection although they have widget connections. Thus, the connection list in the proc output shouldn't contain the selection (*). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-31ALSA: hda - Add support of iMac 24 AluminiumMark Eggleston
Added the support for 24" Aluminium iMac (106b:3e00) Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-31ALSA: alsa: time reaches -1, tested 0Roel Kluin
With a postfix decrement time will reach -1 rather than 0, so the warning will not be issued. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-30ALSA: hda - Add quirk for another HP dv5 modelTakashi Iwai
Added model=hp-dv5 for another HP dv5 model with AMD chip (103c:3600) Reference: kernel bug#12440 http://bugzilla.kernel.org/show_bug.cgi?id=12440 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-29Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-01-29Merge branch 'fix/asoc' into for-linusTakashi Iwai
2009-01-29ASoC: OMAP: Initialize XCCR and RCCR registers in McBSP DAI driverMisael Lopez Cruz
This patch explicitly initializes McBSP Transmit Configuration Control Register (XCCR) and Receive Configuration Control Register (RCCR) to their reset values. Reset values are 26 ns of DX delay and Transmit DMA disabled for XCCR register; receive full cycle mode enabled and Receive DMA disabled for RCCR register. This patch requires a counterpart in OMAP McBSP driver before to apply it. The required changes in McBSP were sent and approved in linux-omap mailing list and patch is going upstream (commit 3127f8f8595a064b3f1a1837fea2177902589ac3 from linux-omap-2.6 tree). Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> [ jarkko.nikula@nokia.com: Commit id for counterpart patch corrected ] Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-29ASoC: Fix null string usage with WM8753 DAIsMark Brown
The WM8753 driver multiplexes the DAI structures it exposes to the outside world, leaving them uninitialised until the codec probes. Since the DAI name is used during the registration and setup process provide a dummy name. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-28ALSA: hda - add another MacBook Pro 4, 1 subsystem IDLuke Yelavich
Add another MacBook Pro 4,1 SSID (106b:3800). It seems that latter revisions, (at least mine), have different IDs to earlier revisions. Signed-off-by: Luke Yelavich <themuso@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-27ALSA: hda - Fix compile warning with CONFIG_SND_JACK=nTakashi Iwai
sound/pci/hda/patch_conexant.c:352: warning: 'conexant_add_jack' defined but not used Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-27ALSA: hda - Add quirk for HP DV6700 laptopJoerg Schirottke
Added the matching model=laptop for HP DV6700 laptop. Signed-off-by: Joerg Schirottke <master@kanotix.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-23ALSA: hda - Fix PCM reference NID for STAC/IDT analog outputsTakashi Iwai
The reference NID for the analog outputs of STAC/IDT codecs is set to a fixed number 0x02. But this isn't always correct and in many codecs it points to a non-existing NID. This patch fixes the initialization of the PCM reference NID taken from the actually probed DAC list. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-23Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-01-23Merge branch 'fix/asoc' into for-linusTakashi Iwai
2009-01-23ALSA: hda: Add STAC92HD83XXX_PWR_REF quirkMatthew Ranostay
Some revisions of the 92hd8xxx codec's not supporting port power downs in which the using of it causes capture and also randomly playback streams to not function at all. Thus by disabling it by default and adding a option to enable it manually will fix all issue on current and future revisions. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-23ALSA: hda: revert change to 92hd83xxx power mappingMatthew Ranostay
Port 0xe power mapping was incorrect set to 0x80 changed to the correct value 0x40. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-22ALSA: hda - Add model entry for HP dv4Takashi Iwai
Added model=hp-dv5 for HP dv4 (103c:30f7). Reference: kernel bug #12440 http://bugzilla.kernel.org/show_bug.cgi?id=12440 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-21ALSA: hda: 83xxx port 0xe DAC selectionMatthew Ranostay
On the 92hd8xxx codecs port 0xe needs the connection selected to be the last DAC in the list. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-20ASoC: fix registration of the SoC card in the Freescale MPC8610 driversTimur Tabi
The Freescale MPC8610 driver was defining two SOC card (snd_soc_card) structures, partially initializing each one, but registering only one of them with ASoC. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-19Merge branch 'topic/virtuoso' into for-linusTakashi Iwai
