path: root/sound
2011-06-24Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-06-24ALSA: Remove unneeded version.h includes from sound/Jesper Juhl
In the sound/ directory there are two files (flagged by 'make versioncheck'); sound/pci/asihpi/asihpi.c and sound/soc/codecs/wm8991.c that include linux/version.h although they don't need it. This patch removes the unneeded includes. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-23ASoC: pxa-ssp: Correct check for stream presenceDaniel Mack
Don't rely on the codec's channels_min information to decide wheter or not allocate a substream's DMA buffer. Rather check if the substream itself was allocated previously. Signed-off-by: Daniel Mack <zonque@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-06-23ASoC: imx: add missing module informationsArnaud Patard (Rtp)
- add some modules aliases - add module license to avoid tainted kernel when loading the imx-pcm-audio driver Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-23ASoC: imx: Remove unused Kconfig SND_MXC_SOC_SSI entryArnaud Patard (Rtp)
SND_MXC_SOC_SSI looks to be unused, so kill it. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-23ALSA: HDA: Pinfix quirk for HP Z200 WorkstationDavid Henningsson
BIOS lists the internal speaker as an internal line-out. Change to internal speaker + model=auto for better auto-mute capabilities. BugLink: http://bugs.launchpad.net/bugs/754964 Reported-by: Marc Legris <marc.legris@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-21ALSA: VIA HDA: Create a master amplifier control for VT1718S.Lydia Wang
Create a master volume and mute control of playback for VT1718S. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-21ALSA: VIA HDA: Mute/unmute mixer conncted to Headphone for VT1718S.Lydia Wang
When switch HP independent mode, mute/unmute connctions of mixer which is connected to headphone for VT1718S. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-21ALSA: VIA HDA: Modify initial verbs list for VT1718S.Lydia Wang
Remove some invalid initial verbs and correct some wrong initial verbs for VT1718S codec. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-21ALSA: hda - Remove ALC268 model override for CPR2000Tony Vroon
The "diverse" Quanta ID 0x0763 is overridden to ALC268_ACER. This keeps headphone automute and microphone input from operating on at least one laptop from Opti Systems. Without the override, the BIOS parser does a fine job setting the card up and everything works. Tested-By: Peter Schneider <e.at.chi.kaen@googlemail.com> Signed-off-by: Tony Vroon <tony@linx.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-20ALSA: HDA: Remove quirk for an HP deviceDavid Henningsson
The reporter, who is running kernel 2.6.38, reports that he needs to set model=auto for the headphone output to work correctly. BugLink: http://bugs.launchpad.net/bugs/761022 Cc: stable@kernel.org (v2.6.38+) Reported-by: Jo Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-17ALSA: hda - Fix no NID error with VIA codecsTakashi Iwai
The via driver spews warnigs like hda-codec: no NID for mapping control Independent HP:0:0 with some codecs because snd_hda_add_nid() is called with nid=0. This patch fixes it by skipping the call when no corresponding widget is found. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-17ALSA: isight: adjust for new queueing APIClemens Ladisch
Since commit 13882a82ee16 (optimize iso queueing by setting wake only after the last packet), drivers are required to call fw_iso_context_queue_flush() after queueing a batch of packets. The missing call would have an effect only if the controller queue underruns, but then the DMA would stop completely. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-16ALSA: 6fire - Fix signedness bugTorsten Schenk
Fixed remaining issues of the signedness bug discovered by Dan Carpenter. A check was remaining that tests if unsigned rt->rate is >= 0. Changed that so that rt->rate now consistently uses ARRAY_SIZE(rates) as invalid rate value and not -1. Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-15ALSA: lola - Fix section mismatchTakashi Iwai
Add missing __devinit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-14ALSA: hda - Fix missing static inline to beep dummy functionTakashi Iwai
The commit 2308f4add3de9f6c9c9f02e49461e94d84bb200a missed static inline thus it resulted in multiple-definitions error at linking. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-14ALSA: 6fire: Fix double-free bug in usb6fire_fw_ezusb_upload()Jesper Juhl
We have a double-free bug in sound/usb/6fire/firmware.c::usb6fire_fw_ezusb_upload(). We already call release_firmware(fw) on line 258, so when we then do it again after usb6fire_fw_ezusb_write() returns <0, we have a double-free. Easily fixed by just removing the last call to release_firmware(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-13ASoC: Remove unused and about to be broken SND_SOC_CUSTOM I/O busMark Brown
This will be removed in -next so let's drop it from mainline as soon as we can in order to minimise surprises. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-13ALSA: hda - Fix beep_device compilation warningsJoe Perches
Using static inline functions can reduce compilation messages and macro misuse. sound/pci/hda/patch_conexant.c: In function ‘patch_cxt5045’: sound/pci/hda/patch_conexant.c:1232:3: warning: statement with no effect Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-13ALSA: hda - Fix wrong auto-mute type for Acer Aspire-oneTakashi Iwai
The auto-mute setup for Acer Aspire-one with ALC268 was set wrongly during the clean-up of auto-mute function. Fixed now. Tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-12ALSA: emu10k1: Add details for E-mu 0404 PCIe versionFlorian Zeitz
This patch adds the necessary details to support the PCIe version of E-MU's 0404 card. From comparing the PCBs it seems the PCIe version just added a PCIe chipset and left all other components pretty much in place. For anyone intrigued to take a look at the PCB there are pictures I took at <http://babelmonkeys.de/~florob/E-MU%200404/>. Signed-off-by: Florian Zeitz <florob@babelmonkeys.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-12ALSA: hdspm - Add firmware revision ID for RME MADI PCI versionAdrian Knoth
The PCI version of the RME HDSP MADI card uses 0xcf as revision ID. Just add this to the list of supported cards. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-12ALSA: hdspm - Fix jumping external wordclock frequency in AutoSync modeAdrian Knoth
When using Word Clock on RME MADI cards, AutoSync mode was alternating betweeen MADI and WC due to a typo: AutoSync is indicated in the second status register (status2), not the first one (status). While the proc output was always correct, the reported WC frequency to ALSA was unstable as mentioned in http://mailman.alsa-project.org/pipermail/alsa-devel/2008-March/006723.html Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-12ALSA: hdspm - Fix locking in snd_hdspm_midi_input_readAdrian Knoth
For the MIDI part, we need to acquire (and release) the hmidi->lock, access to the global hdspm structure is serialized through hmidi->hdspm->lock instead. Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-06-10ALSA: hda: Fix inaudible internal speakers on CyberpowerPC Gamer Xplorer ↵Daniel T Chen
N57001 laptop BugLink: https://launchpad.net/bugs/761171 The original reporter needs the model=auto quirk for his internal speakers to be audible in the latest daily snapshot, so add an entry in the quirk table for his PCI SSID. A trivially different version of this patch using the model=asus quirk should be applied to the 2.6.38 and 2.6.39 stable kernels. We don't use the asus quirk in 3.0-rc2, because 3.0-rc2's autoparser is much improved. Reported-and-tested-by: tomdeering7 Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: Use %pV for snd_printk()Takashi Iwai
Clean up snd_printk() helper using the %pV prefix for recursive printks. This also automagically fixes an Oops with RO/NX-enabled modules. Tested-by: Maarten Lankhorst <m.b.lankhorst@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: hda - Fix initialization of hp pins with master_mute in RealtekTakashi Iwai
Some Reatlek model quirks use master_mute bool switch for controlling the master-mute of outputs. For these cases, the initialization of HP pins/amps were forgotten during the transition to the common automute helper function in 3.0 development time, and resulted in the muted HP output as default. This patch fixes the issue by adjusting the HP output explicitly with master_mute switch. Tested-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: hda - Fix invalid unsol tag for some alc262 model quirksTakashi Iwai
The tag number was forgotten to be fixed after cleaning up the model quirks for ALC262 fujitsu and lenovo-3000 models. Tested-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ASoC: SAMSUNG: Fix the incorrect referencing of I2SCON registerSangbeom Kim
If DMA active status should be checked, I2SCON register should be referenced. In this patch, Fix the incorrect referencing of I2SCON register. Reported-by : Lakkyung Jung <lakkyung.jung@samsung.com> Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-06-09ASoC: snd_soc_new_{mixer,mux,pga} make sure to use right DAPM contextLars-Peter Clausen
Currently it is possible that snd_soc_new_{mixer,mux,pga} is called with a DAPM context not matching the widgets context. This can lead to a wrong prefix_len calculation, which will result in undefined behaviour. To avoid this always use the DAPM context from the widget itself. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-06-09ASoC: fsl: fix initialization of DMA buffersTimur Tabi
The DMA (PCM) driver used by some Freescale PowerPC supports separate DAIs for playback and capture, so DMA buffers should be allocated only for the initialized streams. Instead of checking for the number of active channels, which apparently is not reliable, check to see if the actual stream object exists. Also provide a better name for the DMA interrupt. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-09ASoC: WM8804 does not support sample rates below 32kHzMark Brown
Reported-by: Kieran O'Leary <Kieran.O'Leary@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Cc: stable@kernel.org
2011-06-08ASoC: Fix WM8962 headphone volume update for use of advanced cachesMark Brown
2011-06-07ASoC: Blackfin: bf5xx-ad1836: Fix codec device nameLars-Peter Clausen
Fix the codec_name field of the dai_link to match the actual device name of the codec. Otherwise the card won't be instantiated. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-06-07ALSA: hda: Fix quirk for Dell Inspiron 910Daniel T Chen
BugLink: https://launchpad.net/bugs/792712 The original reporter states that sound from the internal speakers is inaudible until using the model=auto quirk. This symptom is due to an existing quirk mask for 0x102802b* that uses the model=dell quirk. To limit the possible regressions, leave the existing quirk mask but add a higher priority specific mask for the reporter's PCI SSID. Reported-and-tested-by: rodni hipp Cc: <stable@kernel.org> [2.6.38+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-06ASoC: AD1836: Fix setting the PCM formatLars-Peter Clausen
2011-06-06ASoC: Check for NULL register bank in snd_soc_get_cache_val()Mark Brown
2011-06-06ASoC: Add missing break in WM8915 FLL source selectionMark Brown
2011-06-06ASoC: Only update SYSCLK_ENA when pausing WM8915 SYSCLKMark Brown
2011-06-06Merge branch 'for-3.0' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into for-3.0
2011-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: usb - turn off de-emphasis in s/pdif for cm6206 ALSA: asihpi: Use angle brackets for system includes ALSA: fm801: add error handling if auto-detect fails ALSA: hda - Check pin support EAPD in ad198x_power_eapd_write ALSA: hda - Fix HP and Front pins of ad1988/ad1989 in ad198x_power_eapd() ALSA: 6fire: Don't leak firmware in error path ASoC: Fix wm_hubs input PGA ZC bits ASoC: Fix dapm_is_shared_kcontrol so everything isn't shared
2011-06-06Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-06-04Revert "ASoC: Update cx20442 for TTY API change"Linus Torvalds
This reverts commit ed0bd2333cffc3d856db9beb829543c1dfc00982. Since we reverted the TTY API change, we should revert the ASoC update to it too. Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-03ALSA: usb - turn off de-emphasis in s/pdif for cm6206Eric Lammerts
CM6206: Turn off de-emphasis channel status bit in S/PDIF output. Signed-off-by: Eric Lammerts <eric@lammerts.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-03ALSA: asihpi: Use angle brackets for system includesJoe Perches
Use the normal include style. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-03ASoC: atmel_ssc: Don't try to free ssc if request failedJoachim Eastwood
We should only call ssc_free() when ssc_request() succeeds or bad things will happen. Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-03ALSA: fm801: add error handling if auto-detect failsDan Carpenter
In the original code if auto detect failed and tea575x_tuner == 4 then we copy bogus information to chip->tea.card. I've changed the autodetect code to cleanup and return -ENODEV on error instead. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-03ALSA: hda - Check pin support EAPD in ad198x_power_eapd_writeRaymond Yau
Check whether the pin supports EAPD in ad198x_power_eapd_write. Signed-off-by: Raymond Yau <superquad.vortex2@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-03ALSA: hda - Fix HP and Front pins of ad1988/ad1989 in ad198x_power_eapd()Takashi Iwai
In ad198x_power_eapd(), wrong pin NIDs are used for controlling EAPD for HP and Front outputs of AD1988/AD1989. These are actually same with the ones for AD1984 & co, port-A is 0x11 and port-D 0x12. Reported-by: Raymond Yau <superquad.vortex2@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
