path: root/sound
2010-09-03Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-09-03ALSA: usb-audio: fix detection of vendor-specific device protocol settingsClemens Ladisch
The Audio Class v2 support code in 2.6.35 added checks for the bInterfaceProtocol field. However, there are devices (usually those detected by vendor-specific quirks) that do not have one of the predefined values in this field, which made the driver reject them. To fix this regression, restore the old behaviour, i.e., assume that a device with an unknown bInterfaceProtocol field (other than UAC_VERSION_2) has more or less UAC-v1-compatible descriptors. [compile warning fixes by tiwai] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-03ALSA: usb-audio: add BOSS ME-25 supportClemens Ladisch
Add a quirk to make the BOSS ME-25 work. Many thanks to Kees van Veen. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-03ALSA: usb-audio: add Roland A-PRO supportClemens Ladisch
Add a quirk for the Roland/Cakewalk A-300PRO/A-500PRO/A-800PRO keyboards. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-03ALSA: usb-audio: add Edirol PCR-1 PCM supportClemens Ladisch
Add a quirk for the other logical device of the PCR-1 so that not only the MIDI interface but also the audio interface works. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-02ALSA: usb-audio: Assume first control interface is for audioDaniel Mack
For devices with more than one control interface, let's assume the first one contains the audio controls. Unfortunately, there is no field in any of the descriptors to tell us whether a control interface is for audio or MIDI controls, so a better check is not easy to implement. On a composite device with audio and MIDI functions, for example, the code currently overwrites chip->ctrl_intf, causing operations on the control interface to fail if they are issued after the device probe. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-02ALSA: usb-audio: fix Fast Track Ultra (8R) 44.1 sample ratesClemens Ladisch
The M-Audio Fast Track Ultra series devices did not play sound correctly at 44.1/88.2 kHz. Changing the output endpoint attribute to adaptive fixes this. Signed-off-by: Felix Homann <fexpop@web.de> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-28Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-28Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-28ALSA: pcm: add more format namesDan Carpenter
There were some new formats added in commit 15c0cee6c809 "ALSA: pcm: Define G723 3-bit and 5-bit formats". That commit increased SNDRV_PCM_FORMAT_LAST as well. My concern is that there are a couple places which do: for (i = 0; i < SNDRV_PCM_FORMAT_LAST; i++) { if (dummy->pcm_hw.formats & (1ULL << i)) snd_iprintf(buffer, " %s", snd_pcm_format_name(i)); } I haven't tested these but it looks like if "i" were equal to SNDRV_PCM_FORMAT_G723_24 or higher then we might read past the end of the array. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-28sound: oss: fix uninitialized spinlockAkinobu Mita
The spinlock lock in sound_timer.c is used without initialization. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-28ALSA: asihpi - Return hw error directly from oustream_write.Eliot Blennerhassett
If hw error is ignored, status is updated with invalid info. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-27ASoC: soc-core: fix debugfs_pop_time file permissionsAxel Lin
I think this is a typo, debugfs_pop_time should not be executable. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimloogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-26ALSA: hda - Add Sony VAIO quirk for ALC269David Henningsson
The attached patch enables playback on a Sony VAIO machine. BugLink: http://launchpad.net/bugs/618271 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-23Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-23ASoC: i.MX ssi: use SSI_STCCR in synchronous modeSascha Hauer
In synchronous mode the SSI_SRCCR values are ignored. Instead SSI_STCCR must be used for both receiving and transmitting. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-23Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-23ALSA: hda - Add support for Lenovo S10-3tJerone Young
This patch adds quirk for the Lenovo S10-3t so the headphone & microphone jacks will now work. Signed-off-by: Jerone Young <jerone.young@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-23ALSA: ice1712: Add support for Edirol DA-2496Garnet MacPhee
This device is similar to the M-Audio Delta 1010LT in that it uses the AK4524VF ADC/DAC, but it does not use the CS8427 for SPDIF. The SPDIF appears to be set up correctly, but I am not able to test it as I do not have any devices that use it. This patch makes the ADC/DAC's and the hardware mixer visible to apps such as alsamixer and envy24control. Signed-off-by: Garnet MacPhee <dhubsith@comcast.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-20ALSA: hda - Fix stream and channel-ids codec-bus wideTakashi Iwai
The new sticky PCM parameter introduced the delayed clean-ups of stream- and channel-id tags. In the current implementation, this check (adding dirty flag) and actual clean-ups are done only for the codec chip. However, with HD-audio architecture, multiple codecs can be on a single bus, and the controller assign stream- and channel-ids in the bus-wide. In this patch, the stream-id and channel-id are checked over all codecs connected to the corresponding bus. Together with it, the mutex is moved to struct hda_bus, as this becomes also bus-wide. Reported-and-tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-20ALSA: hda - Fix conflict of sticky PCM parameter in HDMI codecsTakashi Iwai
Intel and Nvidia HDMI codec drivers have own implementations of sticky PCM parameters. Now HD-audio core part already has it, thus both setups conflict. The fix is simply remove the part in patch_intelhdmi.c and patch_nvhdmi.c and simply call snd_hda_codec_setup_stream() as usual. Reported-and-tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: intel8x0: Mute External Amplifier by default for ThinkPad X31Daniel T Chen
BugLink: https://bugs.launchpad.net/bugs/619439 This ThinkPad model needs External Amplifier muted for audible playback, so set the inv_eapd quirk for it. Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: hda - Fix build error with CONFIG_PROC_FS=nTakashi Iwai
hdmi_eld_update_pcm_info() must be always compiled in. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: hda - Add support for IDT 92HD89XX codecsCharles Chin
Just added new codec ids. These are almost compatible with existing ones. Signed-off-by: Charles Chin <Charles.Chin@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-18Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-18Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-18ALSA: pcm midlevel code - add time check for double interrupt acknowledgeJaroslav Kysela
The current code in pcm_lib.c do all checks using only the position in the ring buffer. Unfortunately, where the interrupts gets delayed or merged into one, we need another timing source to check when the buffer size boundary overlaps to avoid the wrong updating of the ring buffer pointers. This code uses jiffies to check the right time window without any performance impact. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-18Merge branch 'fix/misc' into topic/miscTakashi Iwai
2010-08-18Merge branch 'topic/aloop' into topic/miscTakashi Iwai
2010-08-18Merge branch 'topic/isa' into topic/miscTakashi Iwai
2010-08-18ALSA: emu10k1 - delay the PCM interrupts (add pcm_irq_delay parameter)Jaroslav Kysela
With some hardware combinations, the PCM interrupts are acknowledged before the period boundary from the emu10k1 chip. The midlevel PCM code gets confused and the playback stream is interrupted. It seems that the interrupt processing shift by 2 samples is enough to fix this issue. This default value does not harm other, non-affected hardware. More information: Kernel bugzilla bug#16300 [A copmile warning fixed by tiwai] Signed-off-by: Jaroslav Kysela <perex@perex.cz> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-17ALSA: hda - Fix ALC680 base model captureKailang Yang
- Fix capture mixer elements for ALC680 base model - Support auto change ADC for recording from MIC - Cancel capture source assigned in auto mode. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-16ASoC: Remove DSP mode support for WM8776Mark Brown
This is not supported by current hardware revisions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Cc: stable@kernel.org
2010-08-16ALSA: hda - Add quirk for Dell Vostro 1220Takashi Iwai
model=dell-vostro is needed for Dell Vostro 1220 with Coexnat 5067. Reference: Novell bnc#631066 https://bugzilla.novell.com/show_bug.cgi?id=631066 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-16ALSA: riptide - Fix detection / load of firmware filesTakashi Iwai
The detection and loading of firmeware on riptide driver has been broken due to rewrite of some codes, checking the presense wrongly. This patch fixes the logic again. Reference: kernel bug 16596 https://bugzilla.kernel.org/show_bug.cgi?id=16596 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: sound/usb/format: silence uninitialized variable warnings MAINTAINERS: Add Ian Lartey as comaintaner for Wolfson devices MAINTAINERS: Make Wolfson entry also cover CODEC drivers ASoC: Only tweak WM8994 chip configuration on devices up to rev D ASoC: Optimise DSP performance for WM8994 ALSA: hda - Fix dynamic ADC change working again ALSA: hda - Restrict PCM parameters per ELD information over HDMI sound: oss: sh_dac_audio.c removed duplicated #include
2010-08-15Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-15Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-15ALSA: sound/usb/format: silence uninitialized variable warningsDan Carpenter
Gcc complains that ret might be used uninitialized: sound/usb/format.c: In function ‘snd_usb_parse_audio_format’: sound/usb/format.c:354: warning: ‘ret’ may be used uninitialized in this function sound/usb/format.c:354: note: ‘ret’ was declared here sound/usb/format.c:414: warning: ‘ret’ may be used uninitialized in this function sound/usb/format.c:414: note: ‘ret’ was declared here I suppose it could be uninitialized if there is ever a UAC_VERSION_3 released. Anyway this patch is worthwhile if only to silence the gcc warning. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-14ALSA: usb: USB3 SuperSpeed sound supportPaul Zimmerman
This is V2 of the patch, after feedback from Clemens and Daniel. This patch adds SuperSpeed support to the USB drivers under sound/. It adds tests for USB_SPEED_SUPER to the appropriate places that check for the USB speed. This patch has been tested with our SS USB3 device emulating a set of Yamaha speakers and a Logitech microphone, but with the descriptors modified to add USB3 support. It has also been tested with the real speakers and microphone, to make sure that USB2 devices still work. Signed-off-by: Paul Zimmerman <paulz@synopsys.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-13ASoC: Only tweak WM8994 chip configuration on devices up to rev DMark Brown
Any subsequent revisions will have these configuration changes applied by default. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-13ASoC: Optimise DSP performance for WM8994Mark Brown
Change the chip defaults to optimise performance of some of the DSP functionality. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-13ALSA: ISA: Remove snd-sgalaxyRené Herman
Its hardware is handled more fully by the new azt1605/azt2316 drivers. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-13ALSA: ISA: New Aztech Sound Galaxy driverRené Herman
This is a new driver for Aztech Sound Galaxy ISA soundcards based on the AZT1605 and AZT2316 chipsets. It's constructed as two seperate drivers for either chipset generated from the same source file, with (very) minimal ifdeffery. The drivers check the SB DSP version to decide if they are being loaded for the right chip. AZT1605 returns 2.1 by default and AZT2316 3.1. This isn't full-proof as the DSP version can actually be set through software but it's close enough -- as far as I've been able to see, the DSP version can not be stored in the EEPROM and the cards will therefore startup with the defaults. This distinction could (with the same success rate) also be used to decide which chip we're looking at at runtime meaning a single, merged driver is also an option but I feel it's actually nicer this way. A merged driver would have to postpone translating the passed in resource values to the card configuration until it knew which one it was looking at and would need to postpone erring out on mpu_irq=10 for azt1605 and mpu_irq=3 for azt2316. The drivers have been tested on various cards. For snd-azt1605: FCC-ID I38-MMSN811: Aztech Sound Galaxy Nova 16 Extra FCC-ID I38-MMSN822: Aztech Sound Galaxy Pro 16 II and for snd-azt2316: FCC-ID I38-MMSN824: Aztech Sound Galaxy Pro 16 AB FCC-ID I38-MMSN826: Trust Sound Expert DeLuxe Wave 32 (05201) FCC-ID I38-MMSN830: Trust Sound Expert DeLuxe 16+ (05202) FCC-ID I38-MMSN837: Packard Bell ISA Soundcard 030069 FCC-ID I38-MMSN846: Trust Sound Expert DeLuxe 16-3D (06300) FCC-ID I38-MMSN847: Trust Sound Expert DeLuxe Wave 32-3D (06301) FCC-ID I38-MMSN852: Aztech Sound Galaxy Waverider Pro 32-3D 826 and 846 were also marketed directly by Aztech and then known as: FCC-ID I38-MMSN826: Aztech Sound Galaxy Waverider 32+ FCC-ID I38-MMSN846: Aztech Sound Galaxy Nova 16 Extra II-3D Together, these cover the AZT1605 and AT2316A, AZT2316R and AZT2316-S chipsets. All cards work fully -- full-duplex PCM, MIDI and FM. Full duplex is a little flaky on some. I38-MSN811 tends to not work in full-duplex but sometimes does with the highest success rate being achieved when you first start the capture and then a playback instead of the other way around (it's a CS4231-KL codec). The cards with an AD1845XP codec (my I38-MMSN826 and one of my I38-MMSN830s) are also somewhat duplex-challenged. Sometimes full-duplex works, sometimes not and this varies from try to try. This seems likely to be a timing problem somewhere inside wss-lib. I38-MMSN826 has an additional "ICS2115 WaveFront" wavetable synth onboard that isn't supported yet. The wavetable synths on I38-MMSN847 and I38-MMSN852 are wired directly to the standard MPU-401 UART and the AUX1 input on the codec and work without problem. CD-ROM audio on the cards is routed to the codec "Line" input, Line-In to its Aux input, and FM/Wavetable to its AUX1 input. I did not rename the controls due to the capture source enumeration: I see that capture-source overrides are hardcoded in wss-lib and this is just too ugly to live. Versus the old snd-sgalaxy driver these drivers add support for the models without a configuration EEPROM (which are common), full-duplex, MPU-401 UART and OPL3. In the future they might grow support for that ICS2115 WaveFront synth on 826 and an hwdep interface to write to the EEPROM on the models that have one. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-13ALSA: hda - Fix dynamic ADC change working againTakashi Iwai
The commit eb541337b7a43822fce7d0c9d967ee149b2d9a96 ALSA: hda - Make converter setups sticky changes the semantics of snd_hda_codec_cleanup_stream() not to clean up the stream at that moment but delay the action. This broke the codes expecting that the clean-up is done immediately, such as dynamic ADC changes in some codec drivers. This patch fixes the issue by introducing a lower helper, __snd_hda_codec_cleanup_stream(), to allow the immediate clean up. The original snd_hda_codec_cleanup_stream() is kept as is now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-13ALSA: hda - Restrict PCM parameters per ELD information over HDMITakashi Iwai
When a device is plugged over HDMI, it passes some information in ELD including the supported PCM parameters like formats, rates, channels. This patch adds the check to PCM open callback of HDMI streams so that only valid parameters the device supports are used. When no device is plugged, the parameters the codec supports are used; it's mostly all parameters the hardware can work. This is for apps that are started before device plugging and do probing (e.g. a sound daemon), so that at least, probing would work even before the device plugging. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: add AD1980 obsolete information ASoC: register cache should be 1 byte aligned for 1 byte long register ALSA: hda - Adding support for new IDT 92HD87XX codecs ASoC: Fix inverted mute controls for WM8580 ALSA: HDA: Use model=auto for LG R510 ALSA: hda - Update model entries in HD-Audio-Models.txt ALSA: hda: document VIA models ALSA: hda - patch_nvhdmi.c: Add missing codec IDs, unify names ALSA: hda - add support for Conexant CX20584 ALSA: hda - New snd-hda-intel model/pin config for hp dv7-4000 ALSA: hda - Fix missing stream for second ADC on Realtek ALC260 HDA codec ALSA: hda - Make converter setups sticky ALSA: hda - Add support for Acer ZGA ALC271 (1025:047c) sound/oss: Adjust confusing if indentation sound: oss: au1550_ac97.c removed duplicated #include ASoC: Fix for changed Eureka Kconfig symbol names
2010-08-12Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mmc_spi: Fix unterminated of_match_table of/sparc: fix build regression from of_device changes of/device: Replace struct of_device with struct platform_device
2010-08-12sound: oss: sh_dac_audio.c removed duplicated #includeAndrea Gelmini
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-11Merge branch 'topic/asoc' into for-linusTakashi Iwai
