alsa control is added to facilitate querying ac3 decode capability of
connected device. ac3 decode capability of the connected device is
updated in the ELD buffer. That information is updated in the
ALSA control structure.
Bug 909141
Bug 904553
Bug 920831
Change-Id: I81af196fc5dd85c5c87691393cf2f079611f9b47
Signed-off-by: Sayak Ghosh Choudhury <sayakc@nvidia.com>
Reviewed-on: http://git-master/r/83067
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
The vendor supplied driver has to be fixed to work on older kernels.
Bug 931371
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/78278
(cherry picked from commit ffce206b2d67bb9618a97d08e88c6ae25ba79baa)
Change-Id: Ifd8712758307cd4f31526cc050c62a89187a7c8d
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/82733
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com>
Add files for ALC5639 codec as provided by vendor.
Bug 931371
Reviewed-on: http://git-master/r/78277
(cherry picked from commit b45ab605accb68fd303deec5ed962f213047f9bf)
Change-Id: I6c19e13c3dfec394cef812a5be1bc2ee5d58751b
Reviewed-on: http://git-master/r/82732
Changes made to add support of ALC5639 codec for kai.
Bug 931371
Reviewed-on: http://git-master/r/77953
(cherry picked from commit 481fabd90e34b9a8246d494b0caefa212238c1c2)
Change-Id: I1bcc882cb4b8f7bd257b737295061ea1e9e7e41c
Reviewed-on: http://git-master/r/82731
Add support for ALC5639 codec present in the KAI A01 board.
Bug 931371
Reviewed-on: http://git-master/r/77952
(cherry picked from commit 1747f1003be6413e0e173dee39b25afcbe522528)
Change-Id: I5180d4ed669c4100ca29e6ed508406e69a88fe88
Reviewed-on: http://git-master/r/82730
commit b4ead019afc201f71c39cd0dfcaafed4a97b3dd2 upstream.
The recent change of the power-widget handling for IDT codecs caused
the silent output from the docking-station line-out jack. This was
partially fixed by the commit f2cbba7602383cd9cdd21f0a5d0b8bd1aad47b33
"ALSA: hda - Fix the lost power-setup of seconary pins after PM resume".
But the line-out on the docking-station is still silent when booted
with the jack plugged even by this fix.
The remainig bug is that the power-widget is set off in stac92xx_init()
because the pins in cfg->line_out_pins[] aren't checked there properly
but only hp_pins[] are checked in is_nid_hp_pin().
This patch fixes the problem by checking both HP and line-out pins
and leaving the power-map correctly.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42637
Change-Id: Ic0147c9a2f9067c6ec2277dbaebd714fdbd9daaa
Reviewed-on: http://git-master/r/79647
The very same problem is seen on Haier W18 laptop with ALC861 as seen
on ASUS A6Rp, which was fixed by the commit 3b25eb69.
Now we just need to add a new SSID entry pointing to the same fixup.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42656
Change-Id: I3aa7e2b665fd04d3ffccee77d91798dd082a84e1
Reviewed-on: http://git-master/r/79662
The refactoring of Realtek codec driver in 3.2 kernel caused a
regression for ASUS A6Rp laptop; it doesn't give any output.
The reason was that this machine has a secret master mute (or EAPD)
control via NID 0x0f VREF. Setting VREF50 on this node makes the
sound working again.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42588
Change-Id: I62fd76bc3d3bc6321da52341531d32dbd1292edd
Reviewed-on: http://git-master/r/79661
Bug: 919350
Reviewed-on: http://git-master/r/77989
Change-Id: I9a8d9a1a4d029f1b312405200fcb485de0fc5767
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/78704
add support for bt voice call and also make bt as master
and i2s as slave for bt-soc playback and record because for
bt voice call modem is slave and bt is master
Bug: 919350
Reviewed-on: http://git-master/r/77990
Change-Id: I5bbb6cc4b08c5ab1d700ce4d21bbdf9be606e551
Reviewed-on: http://git-master/r/78703
Dma user must call the function tegra_dma_get_transfer_count()
for knowing transferred count without stopping dma.
Change-Id: I5e0060fd8163b285496442268548a90bdd0e294c
Reviewed-on: http://git-master/r/77800
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Support I2S slave mode. Disable pll_p_out1 and
pll_a to reduce power when in slave mode.
Slave mode disabled by default.
Reviewed-on: http://git-master/r/76046
Change-Id: I873a11d54f1e037d99c86ff4cec06ee83064902a
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/77765
Bug: 924817
Reviewed-on: http://git-master/r/77238
Change-Id: Ife3bb3439b4b00d042684500d7ffb6bc00100ba6
Reviewed-on: http://git-master/r/77756
Clock function for non-integral of sample
rate clocks does not work correctly and
generates incorrect sample rate.
Reviewed-on: http://git-master/r/75792
Change-Id: I39977c9e2b647d4eabc8d9209c2d05665f708ab0
Reviewed-on: http://git-master/r/77752
In Voice Call when ringtone stream is opened the codec is busy and the
call mode needs to be set before closing the ringtone stream hence we
put the logic in codec driver to enable dai mode change even when codec
is busy
Bug: 919350
Reviewed-on: http://git-master/r/76954
Change-Id: Iaf7176b3a7f72709140e29c2c6071ab4101ec418
Reviewed-on: http://git-master/r/77732
Bug: 919350
Reviewed-on: http://git-master/r/76953
Change-Id: I95611af5e6c12e03cc22fc30c8147e3ef6852615
Reviewed-on: http://git-master/r/77731
Bug: 919350
Reviewed-on: http://git-master/r/76952
Change-Id: Iffc597141a3a5ea528089ce06bf57a4b012eefe8
Reviewed-on: http://git-master/r/77730
This reverts commit 78d27b4b610fbe7d77e3cf43a3b82e15cf879d37.
Bug 916409
Reviewed-on: http://git-master/r/76446
Change-Id: I4288dc4d90b393dd8dbefd7e997b9bfceb49d564
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/77305
Reviewed-on: http://git-master/r/75964
Change-Id: Iddc1a4ab042aaab00d7959f957b66fc879c76ccc
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/77302
Linux 3.1.10
Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118
Instead of using tight bitclk use 2x of minimum bitclk requirement
in codec master mode. This change is needed to have clean audio
in codec master mode on Tegra30 based cardhu platform.
Bug 915107
Change-Id: Ia59e1a906415ad8fd1ed324ab4dabef61746b62f
Reviewed-on: http://git-master/r/75706
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/76467
Bug 923312
Change-Id: I7c68f261989d2ca1ef7b273b7d41a519bc91c868
Reviewed-on: http://git-master/r/75700
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/76466
bug 921335
Change-Id: Ie5810536f1693a93c365a8cd9a51e4e9906d8c1a
Signed-off-by: Haley Teng <hteng@nvidia.com>
Reviewed-on: http://git-master/r/74904
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/75546
commit f2cbba7602383cd9cdd21f0a5d0b8bd1aad47b33 upstream.
When multiple headphone or other detectable output pins are present,
the power-map has to be updated after resume appropriately, but the
current driver doesn't check all pins but only the first pin (since
it's enough to check it for the mute-behavior). This resulted in the
silent output from the secondary outputs after PM resume.
This patch fixes the problem by checking all pins at (re-)init time.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740347
commit 4808d12d1dddb046ec86425e5f6766f02e950292 upstream.
Currently the driver checks only the out_mix_path[] for the primary
output route for judging whether to create the loopback-mixing control
or not. But, there are cases where aamix-routing is available only on
headphone or speaker paths but not on the primary output path. So, the
driver ignores such cases inappropriately.
This patch fixes the check of the loopback-mixing control by testing
all mix-routing paths.
commit 3a90274de3548ebb2aabfbf488cea8e275a73dc6 upstream.
When an invalid NID is given, get_wcaps() returns zero as the error,
but get_wcaps_type() takes it as the normal value and returns a bogus
AC_WID_AUD_OUT value. This confuses the parser.
With this patch, get_wcaps_type() returns -1 when value 0 is given,
i.e. an invalid NID is passed to get_wcaps().
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740118
commit de4da59e480cdf1075b33dbaf8078fc87bc52241 upstream.
These laptops can work well with the auto-parser and their BIOS setups,
and in addition, the auto-parser fixes the problem with S3/S4 where
the unsol event handling is killed after resume due to fallback to the
single-cmd mode.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740115
commit e7848163aa2a649d9065f230fadff80dc3519775 upstream.
Cards with identical PCI ids but no AC97 config in EEPROM do not have
the ac97 field initialized. We must check for this case to avoid kernel oops.
Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com>
commit 78e2a928e377d5124932d4399c6c581908b027a0 upstream.
There was a bug in the automute logic causing speakers not to
mute when headphones were plugged in.
Tested-by: Hsin-Yi Chen <hychen@canonical.com>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 40d03e63e91af8ddccdfd5a536cc2a6e51433e1d upstream.
The control name "HP/Speakers" is non-standard, and since there is
only one DAC on this chip there is no need for a virtual master
anyway.
commit d0f3a2eb9062560bebca8b923424f3ca02a331ba upstream.
They are not needed here.
Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de>
commit 37d5993c5cc9bc83762ae1b5bd287438022e8afe upstream.
Record the clock after the divider as that is what all SYSCLK users see.
Without this the other clock configuration in the device comes out at
half rate.
Change-Id: Ifd4d1165bc59b4cb35a3d30e43ebba442c67a68c
Reviewed-on: http://git-master/r/74167
commit 1c89fe3b51a2f8068f2f9faa9c48584151416583 upstream.
For the Asus 1101HA, reporting position by reading the DMA position
buffer map seems unstable and often wrong. The reporter says that
position_fix=LPIB works much better (although not 100%, but this is
probably due to other issues).
The controller chip is an Intel Poulsbo 8086:811b (rev 07) controller,
and complete alsa-info is available here:
https://launchpadlibrarian.net/86691768/alsa-info.txt.1TNwyE5Ea7
BugLink: http://bugs.launchpad.net/bugs/825709
Tested-by: Stefano Lodi
Change-Id: Ib024489660295b8842215eb8a3cd25feec25e00d
Reviewed-on: http://git-master/r/74605
Add the support for handling the wm8903 sound card registration
failure error.
Bug 910788
Change-Id: Ib25f9ca4dd7f5ebd417700421625eb2f3bdc7b5e
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/73694
(cherry picked from commit 505788de21a98bbc651a536a56f6594fa589252e)
Reviewed-on: http://git-master/r/73963
Implementation of suspend/resume functionality
is not proper for ALC5640 codec , so remove it
temporarily.
Bug 910788
Change-Id: I243c327602a45a3084befd17a1e722e4d844e502
Reviewed-on: http://git-master/r/73478
(cherry picked from commit 3e24bcc4df716bd1e1f3772300aaa9988319f91a)
Reviewed-on: http://git-master/r/73962
Changes made to add support of ALC5640 codec
for cardhu.
Bug 910788
Change-Id: I134b95a20d1a377eeb534e263fb74c0871e2fd0f
Reviewed-on: http://git-master/r/71459
(cherry picked from commit 844ef13a8281fe307b1adddcdc440b7e191d8926)
Reviewed-on: http://git-master/r/73956
set default bias level to standby
Change-Id: I89f375c88efae48fff43fe57e15659b40602dfac
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Reviewed-on: http://git-master/r/73174
Reviewed-by: Nikesh Oswal <noswal@nvidia.com>
(cherry picked from commit d00767b6573367a6827f35c2339e46f68f75cbaf)
Reviewed-on: http://git-master/r/73952
half rate.
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
during suspend if bias is set to off then disable the pll_a and
related clock only once this would prevent the kernel warnings
Bug: 920911
Change-Id: Id85cba4548894572dfd17e51c8a55707bfba7105
Reviewed-on: http://git-master/r/72739
We must keep the regulator ON always else spurious interrupts
are generated.
This reverts commit 0bdf658f5cd064e41cbbb12a6d1eff5fc0bd09f9.
Bug: 916893
Bug: 918912
Change-Id: I8effc272b71cf103da6f142b949091db9d953742
Reviewed-on: http://git-master/r/72364
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Bug: 912897
Change-Id: I3bdc879d7eecea78eace7452fd9b157f68aeea48
Reviewed-on: http://git-master/r/72355
stop the enabling/disabling of i2s capture from i2s dai in
voice call recording usecase because this would be handled
by the voice call management functions and also add parameters
for voice call record usecase in i2s structures.
Bug: 912897
Change-Id: I9df117300121218fe7f258fd8c79092ab3e1f8e1
Reviewed-on: http://git-master/r/72352
for cardhu and support wm8903 codec also without
need for code recompilation.
Bug 910788
Change-Id: Iace74293a44c38eaae516552f03d8bfa6bfe936f
Reviewed-on: http://git-master/r/71455
enclose the init fuction for i2s reg cache with CONFIG_PM
Change-Id: I4828059e397c151a5ad853b6a45a553c480ac197
Signed-off-by: Ken Chang <kenc@nvidia.com>
Reviewed-on: http://git-master/r/71581
codec->hw_write is broken now, convert codec->hw_write to snd_soc_write.
The hardware has 2 banks of registers sharing a section in I2C register space.
The 1st bank is the primary one and is cached.
The 2nd bank is for loading coefficients only and they do not need cache.
These coefficients registers are therefore direct writes.
Thus we set cache_bypass flag to deal with this before calling snd_soc_write.
Acked-by: Liam Girdwood <lrg@ti.com>
(cherry picked from commit 0d8d293898ff0ea395840cdf2ac85fbd53c8d3ea)
Change-Id: I162206b7c542d85c0349cb5c2af8048e8cee6700
Reviewed-on: http://git-master/r/69969
Move the biquad channel names to a separate array and iterate over it in
max98095_get_bq_channel rather than duplicating the hardcoded channel
names. Add an error message if an invalid channel is passed and check
the error in the callers.
Also added a BUILD_BUG_ON to ensure that the bq_mode_name and controls
arrays are the same size.
Signed-off-by: Ryan Mallon <rmallon@gmail.com>
(cherry picked from commit c855a1a7ff49a43e1e35571d504e89b4c670693d)
Change-Id: Id8e6b672007292416ad60a5d988b987f841927b9
Reviewed-on: http://git-master/r/69968
Visual inspection shows that max98095_put_eq_enum() and
max98095_put_bq_enum() each have a possible NULL deref of 'pdata'.
This change moves the NULL check above the use.
Signed-off-by: Taylor Hutt <thutt@chromium.org>
Acked-by: Peter Hsiang <Peter.Hsiang@maxim-ic.com>
(cherry picked from commit 539494253547d078089cc15490e83f6e5f2e7213)
Change-Id: I587b8d2ea14cdf8ce33a4319b6c2ba3a4df067aa
Reviewed-on: http://git-master/r/69963
during voice call, prevent suspend of codec and audio
modules, whereas for other mode they are allowed to suspend.
Bug: 917672
Change-Id: I1e8ff06fa21084a0187d35258177f22ae112f1ce
Reviewed-on: http://git-master/r/71174
