path: root/sound
2008-04-24[ALSA] at73c213: remove redundant private_free routineAtsushi Nemoto
snd_pcm_lib_preallocate_free_for_all() is called from snd_pcm_free() just after calling the private_free routine. So there should be no need to call it in driver's private_free routine. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] aw2 - Rename aw2-tsl.h to aw2-tsl.cTakashi Iwai
aw2-tsl.h should be rather a C file to be included since it's referred only in aw2-saa6146.c and includes a table data. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-intel - Fix microphone capture with ALC880 F1734 modelMichael Gruber
The default capture source should be the mic which is 0x01 on this model. In addition to that the change to VREF50 allows for higher capture volume. Signed-off-by: Michael Gruber <lists.mg@googlemail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda: Reorganized DAC outputsMatthew Ranostay
Changed so that internal speakers point to the Front mixer instead of Surround. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] at73c213: monaural supportAtsushi Nemoto
Add support for monaural playback to at73c213 driver. The sound will be apear on L-channel. Tested on AT91SAM9260-EK. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] at73c213: fix error checking for clk APIAtsushi Nemoto
The clk_round_rate() and clk_set_rate() will return int, so not store thier return value to unsigned long variable. This bug hides real error on these API. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] HDA Codecs: add support for Toshiba Equium L30Tobin Davis
This patch adds support for the Toshiba Equium L30 laptop and renames the mixer controls to match Laptop usages. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24sound: Use BUG_ONJulia Lawall
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no side-effects to allow a definition of BUG_ON that drops the code completely. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ disable unlikely @ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (unlikely(E)) { BUG(); } + BUG_ON(E); ) @@ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (E) { BUG(); } + BUG_ON(E); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-04-24[ALSA] hda-codec - Add internal mic item for ALC268 acer modelTakashi Iwai
Added the internal mic as a capture source item for ALC268 acer model. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Fix dmics on ALC268 in auto configurationTakashi Iwai
Fixed the handling of dmics on ALC268 in the auto-configuration mode. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda_intel: Add the DIDs of nvidia MCP79 HD audio controller to ↵Peer Chen
hda_intel.c Add the Device IDs of nvidia MCP79 HD audio controller to hda_intel.c Signed-off-by: Peer Chen <peerchen@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - model for cx20549 to support laptop HP530Jiang zhe
Currently the model laptop-hpsense use the 0x12 as ExtMic, and use 0x14 as Internal IntMic. But the hp530 only have one ExtMic, the Pin widget is 0x14. In this patch, I changed the mixer item for them. I still reserved the IntMic item, it will be helpful if other machine may use this model. ALSA bug#3821. Signed-off-by: Jiang zhe <zhe.jiang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - model for alc883 to support FUJITSU Pi2515Jiang zhe
There is no suitable model for Pi2515. This model is to support it. ALSA bug#3800. Signed-off-by: Jiang zhe <zhe.jiang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp: improve "enable" option handlingStas Sergeev
Simplify init code. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] ALC288 - Add NEC S970 to the quirk tablePascal Terjan
NEC S970 has no sound in the internal speakers when autodetection is used. With targa-dig model, there is sound in the speakers and it gets correctly muted when pluging headphones. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] pcsp - clean upsStas Sergeev
- make pcsp_start_timer_tasklet static - remove redundant includes. <asm/i8253.h> is not available on all platforms. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - model for alc883 to support M720RJiang zhe
There is no suitable model for M720R (ALSA bug#3781). This patch is to support HP jack-sensing and mixer. Signed-off-by: Jiang zhe <zhe.jiang@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] aw2 - Remove endian dependencyTakashi Iwai
Removed unnecessary dependency on the little-endianess. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: replace remaining __FUNCTION__ occurencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda_intel needs dma-mapping.hAndrew Morton
sparc32: sound/pci/hda/hda_intel.c: In function 'azx_create': sound/pci/hda/hda_intel.c:1838: error: 'DMA_64BIT_MASK' undeclared (first use in this function) sound/pci/hda/hda_intel.c:1838: error: (Each undeclared identifier is reported only once sound/pci/hda/hda_intel.c:1838: error: for each function it appears in.) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] soc - Add Invert Switch for ROUT2Graeme Gregory
GTA02 device has a speaker between LOUT2 & ROUT2 and in this mode ROUT2 needs to be inverted. This patch adds a mixer control for this. Signed-off-by: Graeme Gregory <graeme@openmoko.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Add PC-speaker sound driverStas Sergeev
Added PC-speaker sound driver (snd-pcsp). Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Fix the array over-range access with stac92hd71bxx codecTakashi Iwai
Add the check of the array range for dac_nids to prevent the over-range access. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda: add verbs for 92hd73xxx laptopsMatthew Ranostay
Added core_init[] for several 92hd73xxx laptops. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda: disable power management on fixed portsMatthew Ranostay
Power management can't be enabled on fixed ports, since the presence will always return false and prevent output. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: hda: missing includes of hda_patch.hHarvey Harrison
Move the array declaration to hda_codec.c where it is used and add includes where the individual presets are declared. Fixes the following sparse warnings: sound/pci/hda/patch_realtek.c:13744:25: warning: symbol 'snd_hda_preset_realtek' was not declared. Should it be static? sound/pci/hda/patch_cmedia.c:729:25: warning: symbol 'snd_hda_preset_cmedia' was not declared. Should it be static? sound/pci/hda/patch_analog.c:3656:25: warning: symbol 'snd_hda_preset_analog' was not declared. Should it be static? sound/pci/hda/patch_sigmatel.c:3995:25: warning: symbol 'snd_hda_preset_sigmatel' was not declared. Should it be static? sound/pci/hda/patch_si3054.c:286:25: warning: symbol 'snd_hda_preset_si3054' was not declared. Should it be static? sound/pci/hda/patch_atihdmi.c:156:25: warning: symbol 'snd_hda_preset_atihdmi' was not declared. Should it be static? sound/pci/hda/patch_conexant.c:1721:25: warning: symbol 'snd_hda_preset_conexant' was not declared. Should it be static? sound/pci/hda/patch_via.c:1962:25: warning: symbol 'snd_hda_preset_via' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] hda-codec - Use int instead of long in patch_sigmatel.cTakashi Iwai
The HD-audio parameters are at most 32bit int. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: patch_sigmatel.c fix shadowed variable warningHarvey Harrison
Temp variable in the loop shadows the second argument (which is otherwise unused in this function). Change this to defcfg as it is used to hold the default config. sound/pci/hda/patch_sigmatel.c:2759:18: warning: symbol 'cfg' shadows an earlier one sound/pci/hda/patch_sigmatel.c:2734:26: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: hdspm.c fix returning void expression warningsHarvey Harrison
Just drop the returns. sound/pci/rme9652/hdspm.c:1031:3: warning: returning void-valued expression sound/pci/rme9652/hdspm.c:1033:3: warning: returning void-valued expression Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: riptide.c fix shadowed variable warningsHarvey Harrison
In both cases we are passing around the substream number, use sub_num for this. sound/pci/riptide/riptide.c:1633:6: warning: symbol 'index' shadows an earlier one sound/pci/riptide/riptide.c:121:12: originally declared here sound/pci/riptide/riptide.c:1673:6: warning: symbol 'index' shadows an earlier one sound/pci/riptide/riptide.c:121:12: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: pcxhr_core.c fix shadowed variable warningHarvey Harrison
Inner loop redeclares err with u32 rather than int, stupid fix here is to change the inner err to err2. sound/pci/pcxhr/pcxhr_core.c:1008:8: warning: symbol 'err' shadows an earlier one sound/pci/pcxhr/pcxhr_core.c:983:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: virtuoso.c fix shadowed variable warningHarvey Harrison
Use priv_idx as an identifier. sound/pci/oxygen/virtuoso.c:277:15: warning: symbol 'index' shadows an earlier one sound/pci/oxygen/virtuoso.c:56:12: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ice1712.c fix shadowed variable warningsHarvey Harrison
In all four case, adding a private value to the iooff index, call it priv_idx. sound/pci/ice1712/ice1712.c:1300:6: warning: symbol 'index' shadows an earlier one sound/pci/ice1712/ice1712.c:85:12: originally declared here sound/pci/ice1712/ice1712.c:1312:6: warning: symbol 'index' shadows an earlier one sound/pci/ice1712/ice1712.c:85:12: originally declared here sound/pci/ice1712/ice1712.c:1338:6: warning: symbol 'index' shadows an earlier one sound/pci/ice1712/ice1712.c:85:12: originally declared here sound/pci/ice1712/ice1712.c:1350:6: warning: symbol 'index' shadows an earlier one sound/pci/ice1712/ice1712.c:85:12: originally declared here [tiwai - fixed coding issues as well] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: emu10k1x.c fix shadowed variable warningsHarvey Harrison
enable in these contexts refers specifically to intr enable, as per the two functions it is found in. Use intr_enable instead. sound/pci/emu10k1/emu10k1x.c:330:15: warning: symbol 'enable' shadows an earlier one sound/pci/emu10k1/emu10k1x.c:53:12: originally declared here sound/pci/emu10k1/emu10k1x.c:341:15: warning: symbol 'enable' shadows an earlier one sound/pci/emu10k1/emu10k1x.c:53:12: originally declared here instead of shadowing, use cap_voice as we test for the capture voice in this statement. sound/pci/emu10k1/emu10k1x.c:798:25: warning: symbol 'pvoice' shadows an earlier one sound/pci/emu10k1/emu10k1x.c:787:24: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: emuproc.c fix signedness warningHarvey Harrison
Reading regs from the fpga into an int instead of a u32, trivial fix. sound/pci/emu10k1/emuproc.c:422:34: warning: incorrect type in argument 3 (different signedness) sound/pci/emu10k1/emuproc.c:422:34: expected unsigned int [usertype] *value sound/pci/emu10k1/emuproc.c:422:34: got int *<noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: au88x0_pcm.c fix integer as NULL pointer warningHarvey Harrison
sound/pci/au88x0/au88x0_pcm.c:508:15: warning: Using plain integer as NULL pointer Also some small codingstyle fixes. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] snd-dummy - better realtime app supportAhmet İnan
when the time interval for a period is smaller than kernel HZ, then snd-aloop and snd-dummy cannot call snd_pcm_period_elapsed as fast enough annymore. this happens for example with games. but the app still needs to see, that the buffer actually did go further, which is provided by these patches. Signed-off-by: Ahmet İnan <ainan <at> mathematik.uni-freiburg.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ca0106_mixer.c fix shadowed variable warningsHarvey Harrison
Change the variable err to _err within the ADD_CTLS macro to avoid shadowing the local variable. sound/pci/ca0106/ca0106_mixer.c:710:2: warning: symbol 'err' shadows an earlier one sound/pci/ca0106/ca0106_mixer.c:663:6: originally declared here sound/pci/ca0106/ca0106_mixer.c:712:3: warning: symbol 'err' shadows an earlier one sound/pci/ca0106/ca0106_mixer.c:663:6: originally declared here sound/pci/ca0106/ca0106_mixer.c:721:3: warning: symbol 'err' shadows an earlier one sound/pci/ca0106/ca0106_mixer.c:663:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ca0106_main.c fix shadowed variable warningsHarvey Harrison
change to intr_enable as per the two functions it is defined in. sound/pci/ca0106/ca0106_main.c:438:15: warning: symbol 'enable' shadows an earlier one sound/pci/ca0106/ca0106_main.c:159:12: originally declared here sound/pci/ca0106/ca0106_main.c:449:15: warning: symbol 'enable' shadows an earlier one sound/pci/ca0106/ca0106_main.c:159:12: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ali5451.c fix shadowed variable warningsHarvey Harrison
enable is used to test for whether or not spdif should be enabled, change to spdif_enable. sound/pci/ali5451/ali5451.c:1812:15: warning: symbol 'enable' shadows an earlier one sound/pci/ali5451/ali5451.c:63:12: originally declared here sound/pci/ali5451/ali5451.c:1840:27: warning: symbol 'enable' shadows an earlier one sound/pci/ali5451/ali5451.c:63:12: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ac97_pcm.c fix shadowed variable warningHarvey Harrison
err is always assigned before it is used, no need to declare another inside the if statement. sound/pci/ac97/ac97_pcm.c:577:7: warning: symbol 'err' shadows an earlier one sound/pci/ac97/ac97_pcm.c:572:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: rme96.c fix integer as NULL pointer warningHarvey Harrison
kernel style does assignment outside of if() block sound/pci/rme96.c:1562:71: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: rme32.c fix integer as NULL pointer warningHarvey Harrison
kernel style does assignment outside of if() statements. sound/pci/rme32.c:1353:71: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: maestro3.c fix shadowed variable warningsHarvey Harrison
change id to elem_id as it is used to initialize each mixer element sound/pci/maestro3.c:2071:25: warning: symbol 'id' shadows an earlier one sound/pci/maestro3.c:67:13: originally declared here index is used in each of these places to count over the dsp's memory, change to the name dsp_index sound/pci/maestro3.c:2572:9: warning: symbol 'index' shadows an earlier one sound/pci/maestro3.c:66:12: originally declared here sound/pci/maestro3.c:2604:9: warning: symbol 'index' shadows an earlier one sound/pci/maestro3.c:66:12: originally declared here [tiwai - fixed coding style issues as well] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: fm801.c fix shadowed variable warningHarvey Harrison
id was only used as a counter in a for loop, move the declaration to where it is used and change it to i. sound/pci/fm801.c:1288:6: warning: symbol 'id' shadows an earlier one sound/pci/fm801.c:51:13: originally declared here [tiwai - fixed a coding style issue as well] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: es1968.c fox shadowed variable warningHarvey Harrison
id is used when initializing the mixer elements, use elem_id here instead. sound/pci/es1968.c:1963:25: warning: symbol 'id' shadows an earlier one sound/pci/es1968.c:129:13: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ens1370.c fix shadowed variable warningHarvey Harrison
index is incremented only when AC97_EI_SPDIF and then assigned to the index field. Change the temporary name to is_spdif. sound/pci/ens1370.c:1638:10: warning: symbol 'index' shadows an earlier one sound/pci/ens1370.c:84:12: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: cmipci.c fix shadowed variable warningHarvey Harrison
A temporary variable for each mixer element is used in an initialization loop, use the name elem_id. sound/pci/cmipci.c:2747:26: warning: symbol 'id' shadows an earlier one sound/pci/cmipci.c:56:13: originally declared here [tiwai - fixed a coding style issue as well] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] soc - Report errors from snd_soc_dapm_set_endpoint()Mark Brown
2008-04-24[ALSA] hda-codec - Add docking-station mic input for Thinkpad X61Takashi Iwai
Added the docking-stationc mic input to the capture source list for Thinkpad X61. Signed-off-by: Takashi Iwai <tiwai@suse.de>
