path: root/sound
2010-12-03ALSA: hda: Use model=lg quirk for LG P1 Express to enable playback and captureDaniel T Chen
BugLink: https://launchpad.net/bugs/595482 The original reporter states that audible playback from the internal speaker is inaudible despite the hardware being properly detected. To work around this symptom, he uses the model=lg quirk to properly enable both playback, capture, and jack sense. Another user corroborates this workaround on separate hardware. Add this PCI SSID to the quirk table to enable it for further LG P1 Expresses. Reported-and-tested-by: Philip Peitsch <philip.peitsch@gmail.com> Tested-by: nikhov Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-02Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-12-02Merge branch 'for-2.6.37' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into fix/asoc
2010-12-02Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-12-02ASoC: omap: N810: Don't select CONFIG_OMAP_MUX but make it as dependencyJarkko Nikula
Not all omap boards use kernel based pin multiplexing so CONFIG_SND_OMAP_SOC_N810 should not select it by default as it can make harm to other boards in multi-board kernels. Therefore put CONFIG_OMAP_MUX as a dependency to N810 ASoC machine driver. Thanks to Tony Lindgren <tony@atomide.com> for noticing. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-02ALSA: hda: Use "alienware" model quirk for another SSIDDaniel T Chen
BugLink: https://launchpad.net/bugs/683695 The original reporter states that headphone jacks do not appear to work. Upon inspecting his codec dump, and upon further testing, it is confirmed that the "alienware" model quirk is correct. Reported-and-tested-by: Cody Thierauf Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-01ASoC: WM8731: Fix incorrect mask for bypass path disableDimitris Papastamos
According to the datasheet the bypass path enable/disable is bit 3 therefore we need 0x8 and not 0x4. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-01arm/pxa2xx: reorgazine SSP and SPI header filesSebastian Andrzej Siewior
The PXA-SPI driver relies on some files / defines which are arm specific and are within the ARM tree. The CE4100 SoC which is x86 has also the SPI core. This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to include/linux where the CE4100 can access them. This move got verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-11-30s6105-ipcam: fix compilationDaniel Glöckner
When the s6105-ipcam ASoC driver had been converted to the multi-component API, a single reference to a former structure element remained, blocking successful compilation. Signed-off-by: Daniel Glöckner <daniel-gl@gmx.net> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30s6000-pcm: fix compilationDaniel Glöckner
s6000_soc_platform has lost its forward declaration and there no longer is a name element in it, so use a string constant when calling request_irq. Signed-off-by: Daniel Glöckner <daniel-gl@gmx.net> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30s6000-i2s: fix compilationDaniel Glöckner
A semicolon was missing. Signed-off-by: Daniel Glöckner <daniel-gl@gmx.net> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30ASoC: Fix missing spin_unlock_irqrestoreAxel Lin
In nuc900_dma_hw_params(), if snd_pcm_lib_malloc_pages failed it returns without calling spin_unlock_irqrestore(). Since snd_pcm_lib_malloc_pages() does not touch struct nuc900_audio, we don't need to hold the lock while calling snd_pcm_lib_malloc_pages(). Fix it by moving spin_lock_irqsave() down to after snd_pcm_lib_malloc_pages(). In nuc900_dma_prepare(), spin_unlock_irqrestore() is missing in the error path. Fix it by removing the return in default case. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-30ALSA: Fix SNDCTL_DSP_RESET ioctl for OSS emulationTakashi Iwai
In OSS emulation, SNDCTL_DSP_RESET ioctl needs the reset of the internal buffer state in addition to drop of the running streams. Otherwise the succeeding access becomes inconsistent. Tested-by: Amit Nagal <helloin.amit@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-29ASoC: Add missing dev_set_drvdata in p1022_ds_probeAxel Lin
Otherwise, calling dev_get_drvdata in p1022_ds_remove returns NULL. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Add missing dev_set_drvdata in mpc8610_hpcd_probeAxel Lin
Otherwise, calling dev_get_drvdata in mpc8610_hpcd_remove returns NULL. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Remove unneeded !! operations while checking return value of ↵Axel Lin
nuc900_checkready I think this unneededd !! operations just reduce the readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Fix compile error for nuc900-pcm.cAxel Lin
This patch fixes below error: CC sound/soc/nuc900/nuc900-pcm.o sound/soc/nuc900/nuc900-pcm.c: In function 'nuc900_dma_open': sound/soc/nuc900/nuc900-pcm.c:267: error: 'nuc900_ac97_data' undeclared (first use in this function) sound/soc/nuc900/nuc900-pcm.c:267: error: (Each undeclared identifier is reported only once sound/soc/nuc900/nuc900-pcm.c:267: error: for each function it appears in.) sound/soc/nuc900/nuc900-pcm.c: At top level: sound/soc/nuc900/nuc900-pcm.c:337: error: expected ',' or ';' before 'static' sound/soc/nuc900/nuc900-pcm.c:354: error: 'nuc900_soc_platform_probe' undeclared here (not in a function) make[3]: *** [sound/soc/nuc900/nuc900-pcm.o] Error 1 make[2]: *** [sound/soc/nuc900] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Fix prototype for nuc900_ac97_probe and nuc900_ac97_removeAxel Lin
This patch fixes below compile warning: CC sound/soc/nuc900/nuc900-ac97.o sound/soc/nuc900/nuc900-ac97.c:300: warning: initialization from incompatible pointer type sound/soc/nuc900/nuc900-ac97.c:301: warning: initialization from incompatible pointer type Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ASoC: Fix compile error for nuc900-ac97.cAxel Lin
Fix below compile error by add a missing ';'. CC sound/soc/nuc900/nuc900-ac97.o sound/soc/nuc900/nuc900-ac97.c:300: warning: initialization from incompatible pointer type sound/soc/nuc900/nuc900-ac97.c:301: warning: initialization from incompatible pointer type sound/soc/nuc900/nuc900-ac97.c:318: error: expected ',' or ';' before 'static' sound/soc/nuc900/nuc900-ac97.c:405: error: 'nuc900_ac97_drvprobe' undeclared here (not in a function) make[3]: *** [sound/soc/nuc900/nuc900-ac97.o] Error 1 make[2]: *** [sound/soc/nuc900] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-29ALSA: hda: Use BIOS auto-parsing instead of existing model quirk for MEDION MD2Daniel T Chen
BugLink: https://launchpad.net/bugs/682199 A 2.6.35 (Ubuntu Maverick) user, burningphantom1, reported a regression in audio: playback was inaudible through both speakers and headphones. In commit 272a527c04 of sound-2.6.git, a new model was added with this machine's PCI SSID. Fortunately, it is now sufficient to use the auto model for BIOS auto-parsing instead of the existing quirk. Playback, capture, and jack sense were verified working for both 2.6.35 and the alsa-driver snapshot from 2010-11-27 when model=auto is used. Reported-and-tested-by: burningphantom1 Cc: <stable@kernel.org> [2.6.35+] Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (30 commits) ALSA: hda - Use ALC_INIT_DEFAULT for really default initialization ASoC: Fix resource reclaim for osk5912 ASoC: tlv320aic3x - fix variable may be used uninitialized warning ASoC: davinci-vcif - fix a memory leak ASoC: phycore-ac97: fix resource leak ASoC: imx-ssi: fix resource leak ASoC: simone: fix resource leak in simone_init error path ASoC: sam9g20_wm8731: fix resource leak in at91sam9g20ek_init error path ASoC: snd-soc-afeb9260: remove unneeded platform_device_del in error path ASoC: pcm030-audio-fabric: fix resource leak in pcm030_fabric_init error path ASoC: efika-audio-fabric: fix resource leak in efika_fabric_init error path ASoC: Call snd_soc_unregister_dais instead of snd_soc_unregister_dai in sh4_soc_dai_remove ASoC: fix SND_PXA2XX_LIB Kconfig warning ALSA: hda - Fix ALC660-VD/ALC861-VD capture/playback mixers ALSA: HDA: Add an extra DAC for Realtek ALC887-VD ASoC: nuc900-ac97: fix a memory leak ASoC: Return proper error for omap3pandora_soc_init ASoC: wm8961 - clear WM8961_MCLKDIV bit for freq <= 16500000 ASoC: wm8961 - clear WM8961_DACSLOPE bit for normal mode ALSA: hda - Fix Acer 7730G support ...
2010-11-26Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-11-26ALSA: hda - Use ALC_INIT_DEFAULT for really default initializationTakashi Iwai
When SKU assid gives no valid bits for 0x38, the driver didn't take any action, so far. This resulted in the missing initialization for external amps, etc, thus the silent output in the end. Especially users hit this problem on ALC888 newly since 2.6.35, where the driver doesn't force to use ALC_INIT_DEFAULT any more. This patch sets the default initialization scheme to use ALC_INIT_DEFAULT when no valid bits are set for SKU assid. Reference: https://bugzilla.redhat.com/show_bug.cgi?id=657388 Reported-and-tested-by: Kyle McMartin <kyle@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-25ASoC: Fix resource reclaim for osk5912Axel Lin
In current implementation, there are resources leak in the error path. This patch properly reclaims the allocated resources in the error path. Also adds a missing clk_put in osk_soc_exit. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: tlv320aic3x - fix variable may be used uninitialized warningAxel Lin
If aic3x_read failed , val is used uninitialized. Fix it by initializing val to 0. This patch fixes below compile warning: sound/soc/codecs/tlv320aic3x.c: In function 'aic3x_get_gpio': sound/soc/codecs/tlv320aic3x.c:1183: warning: 'val' may be used uninitialized in this function sound/soc/codecs/tlv320aic3x.c: In function 'aic3x_headset_detected': sound/soc/codecs/tlv320aic3x.c:1211: warning: 'val' may be used uninitialized in this function sound/soc/codecs/tlv320aic3x.c: In function 'aic3x_button_pressed': sound/soc/codecs/tlv320aic3x.c:1219: warning: 'val' may be used uninitialized in this function Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: davinci-vcif - fix a memory leakAxel Lin
2010-11-25ASoC: phycore-ac97: fix resource leakAxel Lin
Fix imx_phycore_init() error path and imx_phycore_exit() to properly free allocated resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: imx-ssi: fix resource leakAxel Lin
Fix imx_ssi_probe() error path and imx_ssi_remove() to properly free allocated resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: simone: fix resource leak in simone_init error pathAxel Lin
Fix the error path to properly free allocated resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: sam9g20_wm8731: fix resource leak in at91sam9g20ek_init error pathAxel Lin
Fix the error path to properly free allocated resources. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: snd-soc-afeb9260: remove unneeded platform_device_del in error pathAxel Lin
2010-11-25ASoC: pcm030-audio-fabric: fix resource leak in pcm030_fabric_init error pathAxel Lin
Add missing platform_device_put() if platform_device_add() failed. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: efika-audio-fabric: fix resource leak in efika_fabric_init error pathAxel Lin
2010-11-25ASoC: Call snd_soc_unregister_dais instead of snd_soc_unregister_dai in ↵Axel Lin
sh4_soc_dai_remove We call snd_soc_register_dais() in sh4_soc_dai_probe(), thus we should call snd_soc_unregister_dais() in sh4_soc_dai_remove(). Otherwise, we got "too many arguments to function 'snd_soc_unregister_dai'" error message. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ASoC: fix SND_PXA2XX_LIB Kconfig warningDmitry Artamonow
Fix following warning observed when SND_PXA2XX_SOC is set and SND_ARM isn't: warning: (SND_PXA2XX_AC97 && SOUND && !M68K && SND && SND_ARM && ARCH_PXA || SND_PXA2XX_SOC && SOUND && !M68K && SND && SND_SOC && ARCH_PXA) selects SND_PXA2XX_LIB which has unmet direct dependencies (SOUND && !M68K && SND && SND_ARM) Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-25ALSA: hda - Fix ALC660-VD/ALC861-VD capture/playback mixersHerton Ronaldo Krzesinski
The mixer nids passed to alc_auto_create_input_ctls are wrong: 0x15 is a pin, and 0x09 is the ADC on both ALC660-VD/ALC861-VD. Thus with current code, input playback volume/switches and input source mixer controls are not created, and recording doesn't work. Select correct mixers, 0x0b (input playback mixer) and 0x22 (capture source mixer). Reference: https://qa.mandriva.com/show_bug.cgi?id=61159 Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-24ALSA: HDA: Add an extra DAC for Realtek ALC887-VDDavid Henningsson
The patch enables ALC887-VD to use the DAC at nid 0x26, which makes it possible to use this DAC for e g Headphone volume. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-24ASoC: nuc900-ac97: fix a memory leakAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-24Merge branch 'fix/asoc' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into for-2.6.37
2010-11-24ASoC: Return proper error for omap3pandora_soc_initAxel Lin
Return PTR_ERR(omap3pandora_dac_reg) instead of 0 if regulator_get failed. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-24ASoC: wm8961 - clear WM8961_MCLKDIV bit for freq <= 16500000Axel Lin
MCLKDIV bit of Register 04h Clocking1: 0 : Divide by 1 1 : Divide by 2 Thus in the case of freq <= 16500000, we should clear MCLKDIV bit. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-11-24ASoC: wm8961 - clear WM8961_DACSLOPE bit for normal modeAxel Lin
DACSLOPE bit of Register 06h ADC and DAC Control 2: 0: Normal mode 1: Sloping stop-band mode Thus in the case of normal mode, we should clear DACSLOPE bit. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-11-24ARM: mach-shmobile: ap4evb: FSI clock use proper process for ak4642Kuninori Morimoto
Current AP4 FSI didn't use set_rate for ak4642, and used dummy rate when init. And FSI driver was modified to always call set_rate. The user which are using FSI set_rate is only AP4 now. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24ARM: mach-shmobile: ap4evb: FSI clock use proper process for HDMIKuninori Morimoto
Current AP4 FSI set_rate function used bogus clock process which didn't care enable/disable and clk->usecound. To solve this issue, this patch also modify FSI driver to call set_rate with enough options. This patch modify it. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24ALSA: hda - Fix Acer 7730G supportDenis Kuplyakov
Fixes automatic EAPD configuration on Acer 7730G laptop. Signed-off-by: Denis Kuplyakov <dener.kup@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (41 commits) ALSA: hda - Identify more variants for ALC269 ALSA: hda - Fix wrong ALC269 variant check ALSA: hda - Enable jack sense for Thinkpad Edge 11 ALSA: Revert "ALSA: hda - Fix switching between dmic and mic using the same mux on IDT/STAC" ALSA: hda - Fixed ALC887-VD initial error ALSA: atmel - Fix the return value in error path ALSA: hda: Use hp-laptop quirk to enable headphones automute for Asus A52J ALSA: snd-atmel-abdac: test wrong variable ALSA: azt3328: period bug fix (for PA), add missing ACK on stop timer ALSA: hda: Add Samsung R720 SSID for subwoofer pin fixup ALSA: sound/pci/asihpi/hpioctl.c: Remove unnecessary casts of pci_get_drvdata ALSA: sound/core/pcm_lib.c: Remove unnecessary semicolons ALSA: sound/ppc: Use printf extension %pR for struct resource ALSA: ac97: Apply quirk for Dell Latitude D610 binding Master and Headphone controls ASoC: uda134x - set reg_cache_default to uda134x_reg ASoC: Add support for MAX98089 CODEC ASoC: davinci: fixes for multi-component ASoC: Fix register cache setup WM8994 for multi-component ASoC: Fix dapm_seq_compare() for multi-component ASoC: RX1950: Fix hw_params function ...
2010-11-23ASoC: wm8994 - fix memory leaksAxel Lin
2010-11-23ASoC: wm8904 - fix memory leaksAxel Lin
2010-11-23ASoC: max98088 - fix a memory leakAxel Lin
2010-11-23ASoC: Do not update the cache if write to hardware failedAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
