Change-Id: I0931f4ef7a5464dd32d8c703288a137fc77857ce
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/100090
Allow setting bias level to turn off clock extern1 on KAI when
codec is idle. Added a dummy widgets to make the target_bias_level
to BIAS_OFF as per required by the new ALSA kernel.
Bug 964287
Change-Id: I628744040866a9879eedc41ed4ee25af38ed86fb
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/99667
Tested-by: Hunk Lin <hulin@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Allow setting bias level to turn off clock extern1 when codec
is idle.
Bug 964287
Change-Id: I48056b86a9fdaea70202bee9326debaaddf69c0c
Reviewed-on: http://git-master/r/99665
Reviewed-by: Simone Willett <swillett@nvidia.com>
is idle.
Bug 964287
Reviewed on: http://git-master/r/#change,93950
Change-Id: Icc11e8bfb359b432f0bfd9ba214877259188de2b
Reviewed-on: http://git-master/r/99659
condition to check bit-format is always false
because TEGRA20_I2S_CTRL_BIT_FORMAT_I2S is zero.
Bug 947429
Change-Id: Ieb92f0732b092100dc1bf323ad60aff4439d5b3d
Signed-off-by: Jubeom Kim <jubeomk@nvidia.com>
Reviewed-on: http://git-master/r/99341
Modified existing pcm driver to take dma mode/ hw structure.
Exported the functions needed for other pcm mode driver.
Added new TDM mode hw param structure.
Added pass SINGLE/DOUBLE buffered dma mode params.
Bug 948478
Change-Id: I58309d52748f813b3303a8d6a052fbb6cc7ca87a
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/99146
Set maximum supported channels of HDA driver based on the LPCM channel
capability of the HDMI device. This is needed because user space
decides number of PCM channels to be sent to kernel based on this
information.
Bug 960940
Change-Id: I59ae3b7d47dcf26f697bfb0877ca24556f0ab1fa
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/94831
Reviewed-on: http://git-master/r/98783
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Add Support to detect the HP insertion or removal during
LP0 state.
Bug 969405
Change-Id: Ibedf1769338e16877240ea9cc82fa7469eb7ff9e
Reviewed-on: http://git-master/r/98745
Instead of always using 2 dma_req count pass max dma_req_count
through a macro. Ensure dma_req_count does not cross
period_count.
Bug 968814
Change-Id: Iddfbd77017992ccb8c90441213e191133dadb347
Reviewed-on: http://git-master/r/97915
Change prototype of tegra_asoc_utils_init to pass snd_soc_card handle.
It is needed to move common tegra machine driver codes to
tegra_asoc_utils interface.
Bug 968814
Change-Id: I98490ffdda51cf7d0b89adadb23c31892183bc0e
Reviewed-on: http://git-master/r/97914
Bug 953210
Change-Id: Id40b3fe90174a2a8c9a6faf3f35f61d9f7eeb642
Signed-off-by: Sayak Ghosh Choudhury <sayakc@nvidia.com>
Reviewed-on: http://git-master/r/98477
Added TDM mode support in I2S driver.
Added support functions in AHUB to pass audio/client bits.
Added support functions in AHUB to pass audio/client channels.
Fixed the stopping of I2S/TDM by clearing the fifo.
Bug 948478
Change-Id: I246942b3a07ffcfbcfafbc820208190bd3acc5d4
Reviewed-on: http://git-master/r/98456
bug 949219
Change-Id: I52969e8dd1a5ed4dc76ac360ec08b0afb18cd4a5
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/92833
The bias control must be done after the default register value
been restored.
Bug 964400
Change-Id: Iefbd96506573d5ea0e1b3123bb34c38e34e75068
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Reviewed-on: http://git-master/r/96658
1. Use rt5639/40 internal clk source during jack insert detection.
2. Add delay to 100ms.
Bug 955019
Reviewed-on: http://git-master/r/93510
Reviewed-by: Chandler Zhang <chazhang@nvidia.com>
(cherry picked from commit 4c07fc1b10ac8abbbf167952071e47aa6179a635)
Change-Id: I4021232674f5432392dc013ddc76c3bf08b44ed0
Reviewed-on: http://git-master/r/95874
Tested-by: Manoj Gangwal <mgangwal@nvidia.com>
use common platform data for machine driver
Change-Id: I90e0d2f47aed46da650305d98f6525287adfaf04
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-on: http://git-master/r/95101
replace platform specific data with common platform data
Change-Id: Ie34b9b9288bf76a004db0bcdf4fd59845e0c9d71
Reviewed-on: http://git-master/r/95083
check max98095_reset() return value, this function fails if codec
read/write fails.
Change-Id: I4dddd75e0870e4168288396a462133f7287ad72e
Reviewed-on: http://git-master/r/95078
Add support to customize modem parameters for voice call.
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: I947bf1955713c4ae19e5dd829091bd7e51bca08f
Reviewed-on: http://git-master/r/93091
Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
Enable/disable the ext mic depending on the jack notification
for insertion/removal comes.This is done to save the Audio power.
Bug 955019
(cherry picked from commit 7a22037fd4a274637a5bdb18a8c5452fe58aad32)
Change-Id: I1a8b47c4e9c424a914f546b48c86a6fb07d8e42a
Reviewed-on: http://git-master/r/93956
Drive ext mic gpio (active low) to 1 during init. It will
be toggled as needed by ext mic events.
Bug 949026
Signed-off-by: Daniel Solomon <daniels@nvidia.com>
(cherry picked from commit de806c193fde5cd8c5b0285efeeaef4adb7be611)
Change-Id: Idd72830d89ebe080739694d7f2c8f6ad80d5cdf5
Reviewed-on: http://git-master/r/93955
Allow bias off in order to turn off clock extern1 when codec
is not used.
Bug 957635
(cherry picked from commit adc6929ab3170acd6a0b2cee4f65fa20a1c1d30f)
Change-Id: I4f2e91b0cd9bb4516a5722d2df268f08e78f92e2
Reviewed-on: http://git-master/r/93949
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline commit
16052827d98fbc13c31ebad560af4bd53e2b4dd5
Change-Id: I929a49556539621a0546829e88b3caa498c94be2
Reviewed-on: http://git-master/r/94463
To terminate request from dma, use the tegra_dma_cancel() inplace of
tegra_dma_dequeue().
The api tegra_dma_dequeue() is getting to be obsolete.
Change-Id: Id2a888a726086fb1e4ade04ac047442554188bee
Reviewed-on: http://git-master/r/91754
fix i2s for BT Sco.
Bug 936626
Change-Id: Iaf1d1a230fcb37d45d9deaaf1dae780f5870e99f
Reviewed-on: http://git-master/r/92860
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
bug 949219
Change-Id: I8abd1e837a774d15aef25ec8c40b857b8cba0426
Reviewed-on: http://git-master/r/92858
Few boards which uses wm8903 has independent regulators
for spk and mic while others do not have it.
For the boards which do not have independent regulators
we should avoid getting their regulators otherwise we
would get the following error messages:
"tegra-snd-wm8903 tegra-snd-wm8903.0: No speaker regulator found"
"tegra-snd-wm8903 tegra-snd-wm8903.0: No digital mic regulator found"
Bug 956562
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Ide1ce141b5d45d56e834dc82a7cf5a7adc6c3e80
Reviewed-on: http://git-master/r/91548
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Return -ENODEV instead of -EAGAIN if hdmi_pcm_open() fails. There is
a chance of user space getting hung while trying to open pcm device
if -EAGAIN is returned.
Bug 949659
Change-Id: If4ff4078d8e0d882859ac97742e7d48d2e6c230c
Reviewed-on: http://git-master/r/91819
alsa control is added to facilitate querying dts decode capability of
connected device. dts decode capability of the connected device is
updated in the ELD buffer. That information is updated in the
ALSA control structure. In addition to that, the code is amended to
handle other pass through decoder mode support.
Bug 943017
Change-Id: If8da7dfb24be3b86592191f5586b70492282b438
Reviewed-on: http://git-master/r/91813
Removing legacy i2s/spdif driver from tree.
These files are added to support customer projects prior
to moving over to alsa driver for audio.
There is no intention of using them and hence removing it.
Change-Id: I864dbc50e2e76ac16f40542460f63c8c8a0eff71
Reviewed-on: http://git-master/r/91758
use common platform data instead of using codec specific platform
data for different codecs
Change-Id: I88ecb08f3945e0d9c5162ec2b2d3279a4da50099
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/91686
add voice call, bt voice call, voice call with system sound mix,
bt voice call with system sound mix, voice call recording,
bt voice call recording functionalities for ti aic326x on ap30
Change-Id: Ia94c1586c30d0636d8de738ff6cbb716f4f79d16
Reviewed-on: http://git-master/r/90123
check for revision id, it must be 0x40 as per the datasheet,
if its not 0x40 then dont allow the card to register by failing
in the codec probe. This functionality will be required when the
same board support multiple codecs. Also register the irq only
after validating the codec.
Change-Id: I8553b85d534428c7137ec2d03e2f814b898609a6
Reviewed-on: http://git-master/r/90061
If card fails to instantiate then unregister the card
Change-Id: Ibcc0d505a8df48c1f924a3d8688dc23e362d5e8d
Reviewed-on: http://git-master/r/90060
If switch registration is success and later card registration
fails then we must unregister the switch
Change-Id: I140b3fb0890f41fea653100bcff450f10294cd9d
Reviewed-on: http://git-master/r/90058
Change-Id: I1b41c408b65b79f12b20a5efb7c0d2e3245bad6a
Reviewed-on: http://git-master/r/90057
This change resolves the control name (Line Out Switch) conflict between
wm8903 codec driver and tegra machine driver.
Bug 956506
Change-Id: Iab049c7fb2fdde0d481d07d8e1bbdbeea1a831d9
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/91510
Suspend and resume code included for headphone detection. Earlier,
it was causing problem in HP detection when device enters into LP0
state and headphone is plugged in. (Bug 937153)
Change-Id: If625f0e7b857b40b0535f8bc8d1c262650886fa7
Reviewed-on: http://git-master/r/89975
Added machine driver for P1852 board.
The driver supports a plug/play architecture where the
details of the codec_driver/codec_dai will come from the top level
board config file.
Bug 948478
Change-Id: Id34a34b224e02b61475ca17253c1b13893a09e6c
Reviewed-on: http://git-master/r/89474
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Fixing the typos in the member of cardhu_controls.
Bug 946932
Change-Id: I26f2a5a60f40d55846a89aaa76dab00741e018d0
Reviewed-on: http://git-master/r/88824
Reviewed-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: I0b2b50c007d9e7b722b2c4bbc0282c51a8d18b00
Reviewed-on: http://git-master/r/88239
change M/S configuration for bt, with BT as Slave and Modem
as Master
Change-Id: Ifae5ca228f3bcf0f882f47e79448c10bcc33ec4d
Reviewed-on: http://git-master/r/89127
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Improve the resume time of the HD Audio driver by replacing selected
msleep() functions with mdelay(). msleep() return times are not
deterministic.
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/86896
(cherry picked from commit eccbe7983d1b010cc60b49bfb13d041b3a0957d3)
Change-Id: I261ba51e7f8414bca50076ae73473114a308645c
Reviewed-on: http://git-master/r/88090
Tested-by: Scott Peterson <speterson@nvidia.com>
update the TIAIC326x driver for voice call
Change-Id: I1443b462b5b7e049fe4cbf39215aea6eeb955500
Reviewed-on: http://git-master/r/88012
change M/S configurations as modem has been made master
on whistler
Change-Id: Iae0cf3f85c43116b13ceb1ff5dfa4a9b121a5d62
Reviewed-on: http://git-master/r/88014
i2s bitclk for dsp mode was kept 4 times the minimum requirement
for bcm4330 bt chip on whistler we require only 2 times the minimum
requirement because modem is also configured similarly and for bt call
both the bit clocks should match
Change-Id: I6a84b22c9fbd66b4e60832933b508fe8cf21f387
Reviewed-on: http://git-master/r/88013
Fix for pop noise 'cut' from internal speaker while booting
on kai board.
Bug 929049
Change-Id: I9c3fe7e05d869709f50036042e70abc91722885e
Reviewed-on: http://git-master/r/87685
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Set I2s FIFO attention level based on sample size and channel count.
Also set playback DMA destination bus width and capture DMA source bus
width based on sample size. These changes are needed to have proper
BT SCO playback and record which uses 16bit-mono format.
Bug 934101
Bug 874428
Bug 927978
Reviewed-on: http://git-master/r/84817
(cherry picked from commit 3ca2eb665af450d7e8f3bf6f2471e31203052641)
Change-Id: I95c10716eaa990adb8b6ae535ce6acfca122a609
Reviewed-on: http://git-master/r/87192
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Remove snd_hda_power_up()/snd_hda_power_down() sequence from HDA codec
resume since it add around 90ms delay. This code was not essential
for HDA driver to work properly after suspend-resume cycle.
Bug 932606
Reviewed-on: http://git-master/r/80040
(cherry picked from commit 2ed8667c2bdfd4c8cbe371530b066b537aa9ae62)
Change-Id: I0ffb120eb0a54f6c4e20aaf96c5ac2d0f5ab6949
Reviewed-on: http://git-master/r/87188
Fix headset switch name for kai.
Bug 945640
Change-Id: I61b0a7c58a97bd3f2b976d521a5298a48a27798c
Reviewed-on: http://git-master/r/87136
