path: root/sound
2010-08-28Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-28Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-28ALSA: pcm: add more format namesDan Carpenter
There were some new formats added in commit 15c0cee6c809 "ALSA: pcm: Define G723 3-bit and 5-bit formats". That commit increased SNDRV_PCM_FORMAT_LAST as well. My concern is that there are a couple places which do: for (i = 0; i < SNDRV_PCM_FORMAT_LAST; i++) { if (dummy->pcm_hw.formats & (1ULL << i)) snd_iprintf(buffer, " %s", snd_pcm_format_name(i)); } I haven't tested these but it looks like if "i" were equal to SNDRV_PCM_FORMAT_G723_24 or higher then we might read past the end of the array. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-28sound: oss: fix uninitialized spinlockAkinobu Mita
The spinlock lock in sound_timer.c is used without initialization. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-28ALSA: asihpi - Return hw error directly from oustream_write.Eliot Blennerhassett
If hw error is ignored, status is updated with invalid info. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-27ASoC: soc-core: fix debugfs_pop_time file permissionsAxel Lin
I think this is a typo, debugfs_pop_time should not be executable. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimloogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-26ALSA: hda - Add Sony VAIO quirk for ALC269David Henningsson
The attached patch enables playback on a Sony VAIO machine. BugLink: http://launchpad.net/bugs/618271 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-23Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-23ASoC: i.MX ssi: use SSI_STCCR in synchronous modeSascha Hauer
In synchronous mode the SSI_SRCCR values are ignored. Instead SSI_STCCR must be used for both receiving and transmitting. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-23Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-23ALSA: hda - Add support for Lenovo S10-3tJerone Young
This patch adds quirk for the Lenovo S10-3t so the headphone & microphone jacks will now work. Signed-off-by: Jerone Young <jerone.young@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-20ALSA: hda - Fix stream and channel-ids codec-bus wideTakashi Iwai
The new sticky PCM parameter introduced the delayed clean-ups of stream- and channel-id tags. In the current implementation, this check (adding dirty flag) and actual clean-ups are done only for the codec chip. However, with HD-audio architecture, multiple codecs can be on a single bus, and the controller assign stream- and channel-ids in the bus-wide. In this patch, the stream-id and channel-id are checked over all codecs connected to the corresponding bus. Together with it, the mutex is moved to struct hda_bus, as this becomes also bus-wide. Reported-and-tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-20ALSA: hda - Fix conflict of sticky PCM parameter in HDMI codecsTakashi Iwai
Intel and Nvidia HDMI codec drivers have own implementations of sticky PCM parameters. Now HD-audio core part already has it, thus both setups conflict. The fix is simply remove the part in patch_intelhdmi.c and patch_nvhdmi.c and simply call snd_hda_codec_setup_stream() as usual. Reported-and-tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: intel8x0: Mute External Amplifier by default for ThinkPad X31Daniel T Chen
BugLink: https://bugs.launchpad.net/bugs/619439 This ThinkPad model needs External Amplifier muted for audible playback, so set the inv_eapd quirk for it. Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk> Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: hda - Fix build error with CONFIG_PROC_FS=nTakashi Iwai
hdmi_eld_update_pcm_info() must be always compiled in. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-19ALSA: hda - Add support for IDT 92HD89XX codecsCharles Chin
Just added new codec ids. These are almost compatible with existing ones. Signed-off-by: Charles Chin <Charles.Chin@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-18Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-18Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-18ALSA: emu10k1 - delay the PCM interrupts (add pcm_irq_delay parameter)Jaroslav Kysela
With some hardware combinations, the PCM interrupts are acknowledged before the period boundary from the emu10k1 chip. The midlevel PCM code gets confused and the playback stream is interrupted. It seems that the interrupt processing shift by 2 samples is enough to fix this issue. This default value does not harm other, non-affected hardware. More information: Kernel bugzilla bug#16300 [A copmile warning fixed by tiwai] Signed-off-by: Jaroslav Kysela <perex@perex.cz> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-17ALSA: hda - Fix ALC680 base model captureKailang Yang
- Fix capture mixer elements for ALC680 base model - Support auto change ADC for recording from MIC - Cancel capture source assigned in auto mode. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-16ASoC: Remove DSP mode support for WM8776Mark Brown
This is not supported by current hardware revisions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Cc: stable@kernel.org
2010-08-16ALSA: hda - Add quirk for Dell Vostro 1220Takashi Iwai
model=dell-vostro is needed for Dell Vostro 1220 with Coexnat 5067. Reference: Novell bnc#631066 https://bugzilla.novell.com/show_bug.cgi?id=631066 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-16ALSA: riptide - Fix detection / load of firmware filesTakashi Iwai
The detection and loading of firmeware on riptide driver has been broken due to rewrite of some codes, checking the presense wrongly. This patch fixes the logic again. Reference: kernel bug 16596 https://bugzilla.kernel.org/show_bug.cgi?id=16596 Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: sound/usb/format: silence uninitialized variable warnings MAINTAINERS: Add Ian Lartey as comaintaner for Wolfson devices MAINTAINERS: Make Wolfson entry also cover CODEC drivers ASoC: Only tweak WM8994 chip configuration on devices up to rev D ASoC: Optimise DSP performance for WM8994 ALSA: hda - Fix dynamic ADC change working again ALSA: hda - Restrict PCM parameters per ELD information over HDMI sound: oss: sh_dac_audio.c removed duplicated #include
2010-08-15Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-15Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-15ALSA: sound/usb/format: silence uninitialized variable warningsDan Carpenter
Gcc complains that ret might be used uninitialized: sound/usb/format.c: In function ‘snd_usb_parse_audio_format’: sound/usb/format.c:354: warning: ‘ret’ may be used uninitialized in this function sound/usb/format.c:354: note: ‘ret’ was declared here sound/usb/format.c:414: warning: ‘ret’ may be used uninitialized in this function sound/usb/format.c:414: note: ‘ret’ was declared here I suppose it could be uninitialized if there is ever a UAC_VERSION_3 released. Anyway this patch is worthwhile if only to silence the gcc warning. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-13ASoC: Only tweak WM8994 chip configuration on devices up to rev DMark Brown
Any subsequent revisions will have these configuration changes applied by default. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-13ASoC: Optimise DSP performance for WM8994Mark Brown
Change the chip defaults to optimise performance of some of the DSP functionality. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-13ALSA: hda - Fix dynamic ADC change working againTakashi Iwai
The commit eb541337b7a43822fce7d0c9d967ee149b2d9a96 ALSA: hda - Make converter setups sticky changes the semantics of snd_hda_codec_cleanup_stream() not to clean up the stream at that moment but delay the action. This broke the codes expecting that the clean-up is done immediately, such as dynamic ADC changes in some codec drivers. This patch fixes the issue by introducing a lower helper, __snd_hda_codec_cleanup_stream(), to allow the immediate clean up. The original snd_hda_codec_cleanup_stream() is kept as is now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-13ALSA: hda - Restrict PCM parameters per ELD information over HDMITakashi Iwai
When a device is plugged over HDMI, it passes some information in ELD including the supported PCM parameters like formats, rates, channels. This patch adds the check to PCM open callback of HDMI streams so that only valid parameters the device supports are used. When no device is plugged, the parameters the codec supports are used; it's mostly all parameters the hardware can work. This is for apps that are started before device plugging and do probing (e.g. a sound daemon), so that at least, probing would work even before the device plugging. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: add AD1980 obsolete information ASoC: register cache should be 1 byte aligned for 1 byte long register ALSA: hda - Adding support for new IDT 92HD87XX codecs ASoC: Fix inverted mute controls for WM8580 ALSA: HDA: Use model=auto for LG R510 ALSA: hda - Update model entries in HD-Audio-Models.txt ALSA: hda: document VIA models ALSA: hda - patch_nvhdmi.c: Add missing codec IDs, unify names ALSA: hda - add support for Conexant CX20584 ALSA: hda - New snd-hda-intel model/pin config for hp dv7-4000 ALSA: hda - Fix missing stream for second ADC on Realtek ALC260 HDA codec ALSA: hda - Make converter setups sticky ALSA: hda - Add support for Acer ZGA ALC271 (1025:047c) sound/oss: Adjust confusing if indentation sound: oss: au1550_ac97.c removed duplicated #include ASoC: Fix for changed Eureka Kconfig symbol names
2010-08-12Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mmc_spi: Fix unterminated of_match_table of/sparc: fix build regression from of_device changes of/device: Replace struct of_device with struct platform_device
2010-08-12sound: oss: sh_dac_audio.c removed duplicated #includeAndrea Gelmini
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-11Merge branch 'topic/asoc' into for-linusTakashi Iwai
2010-08-11Merge branch 'topic/misc' into for-linusTakashi Iwai
2010-08-10ASoC: add AD1980 obsolete informationSonic Zhang
This codec has been obsoleted by ADI, so add appropriate warnings to the source tree to dissuade people from using in new designs based on driver support. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-10ASoC: register cache should be 1 byte aligned for 1 byte long registerCliff Cai
Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-08-10ALSA: hda - Adding support for new IDT 92HD87XX codecsCharles Chin
Added the entries for 92HD87B1/3 and 92HD87B2/4 codecs. These are compatible with existing 83xxx codecs. Signed-off-by: Charles Chin <Charles.Chin@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-10ASoC: Fix inverted mute controls for WM8580Mark Brown
2010-08-10ALSA: HDA: Use model=auto for LG R510David Henningsson
Two users report model=auto is needed to make the internal mic work properly. BugLink: https://bugs.launchpad.net/bugs/495134 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-10ALSA: hda - patch_nvhdmi.c: Add missing codec IDs, unify namesStephen Warren
* Add missing codec IDs. * Modify some existing codec names for discrete GPUs to match newly added IDs. Note: existing names were a mixture of marketing and engineering GPU names. Equally, there's no reason that codec IDs have to be specific to a particular GPU or board, so identify codecs in a less marketing-oriented fashion. * Reformat codec ID table so it's easier to read, for me at least. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-09ALSA: hda - add support for Conexant CX20584Takashi Iwai
The Conexant CX20584 with 141f:5068 seems compatible with other cxt5066 code. Just add the missing id. Tested-by: Cristopher Camacho Leandro <ccamacho@linuxmail.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-09ALSA: hda - New snd-hda-intel model/pin config for hp dv7-4000Steven Eastland
This provides a new model and pin config for the snd-hda-intel 92HD83XXX codec for hp laptop model dv7-4000, enabling the subwoofer. Signed-off-by: Steven Eastland <seastland at gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-09ALSA: hda - Fix missing stream for second ADC on Realtek ALC260 HDA codecJonathan Woithe
I discovered tonight that ALSA no longer sets up a stream for the second ADC provided by the Realtek ALC260 HDA codec. At some point alc_build_pcms() started using stream_analog_alt_capture when constructing the second ADC stream, but patch_alc260() was never updated accordingly. I have no idea when this regression occurred. The trivial patch to patch_alc260() given below fixes the problem as far as I can tell. The patch is against 2.6.35. Signed-off-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-09Merge remote branch 'gcl/next' into nextBenjamin Herrenschmidt
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-08-06sound/soc: mpc5200_psc_ac97: Use gpio pins for cold resetEric Millbrandt
Call the gpio reset platform function instead of using the flawed ac97 functionality of the MPC5200(b) From MPC5200B User's Manual: "Some AC97 devices goes to a test mode, if the Sync line is high during the Res line is low (reset phase). To avoid this behavior the Sync line must be also forced to zero during the reset phase. To do that, the pin muxing should switch to GPIO mode and the GPIO control register should be used to control the output lines." Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq pcmcia: do not request windows if you don't need to pcmcia: insert PCMCIA device resources into resource tree pcmcia: export resource information to sysfs pcmcia: use struct resource for PCMCIA devices, part 2 pcmcia: remove memreq_t pcmcia: move local definitions out of include/pcmcia/cs.h pcmcia: do not use io_req_t when calling pcmcia_request_io() pcmcia: do not use io_req_t after call to pcmcia_request_io() pcmcia: use struct resource for PCMCIA devices pcmcia: clean up cs.h pcmcia: use pcmica_{read,write}_config_byte pcmcia: remove cs_types.h pcmcia: remove unused flag, simplify headers pcmcia: remove obsolete CS_EVENT_ definitions pcmcia: split up central event handler pcmcia: simplify event callback pcmcia: remove obsolete ioctl Conflicts in: - drivers/staging/comedi/drivers/* - drivers/staging/wlags49_h2/wl_cs.c due to dev_info_t and whitespace changes
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
