- Fix capture mixer elements for ALC680 base model
- Support auto change ADC for recording from MIC
- Cancel capture source assigned in auto mode.
Signed-off-by: Kailang Yang <kailang@realtek.com>
This is not supported by current hardware revisions.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: stable@kernel.org
model=dell-vostro is needed for Dell Vostro 1220 with Coexnat 5067.
Reference: Novell bnc#631066
https://bugzilla.novell.com/show_bug.cgi?id=631066
Cc: <stable@kernel.org>
The detection and loading of firmeware on riptide driver has been broken
due to rewrite of some codes, checking the presense wrongly.
This patch fixes the logic again.
Reference: kernel bug 16596
https://bugzilla.kernel.org/show_bug.cgi?id=16596
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: sound/usb/format: silence uninitialized variable warnings
MAINTAINERS: Add Ian Lartey as comaintaner for Wolfson devices
MAINTAINERS: Make Wolfson entry also cover CODEC drivers
ASoC: Only tweak WM8994 chip configuration on devices up to rev D
ASoC: Optimise DSP performance for WM8994
ALSA: hda - Fix dynamic ADC change working again
ALSA: hda - Restrict PCM parameters per ELD information over HDMI
sound: oss: sh_dac_audio.c removed duplicated #include
Gcc complains that ret might be used uninitialized:
sound/usb/format.c: In function ‘snd_usb_parse_audio_format’:
sound/usb/format.c:354: warning: ‘ret’ may be used uninitialized in this function
sound/usb/format.c:354: note: ‘ret’ was declared here
sound/usb/format.c:414: warning: ‘ret’ may be used uninitialized in this function
sound/usb/format.c:414: note: ‘ret’ was declared here
I suppose it could be uninitialized if there is ever a UAC_VERSION_3
released. Anyway this patch is worthwhile if only to silence the gcc
warning.
Acked-by: Daniel Mack <daniel@caiaq.de>
Any subsequent revisions will have these configuration changes applied
by default.
Change the chip defaults to optimise performance of some of the DSP
functionality.
The commit eb541337b7a43822fce7d0c9d967ee149b2d9a96
ALSA: hda - Make converter setups sticky
changes the semantics of snd_hda_codec_cleanup_stream() not to clean up
the stream at that moment but delay the action. This broke the codes
expecting that the clean-up is done immediately, such as dynamic ADC
changes in some codec drivers.
This patch fixes the issue by introducing a lower helper,
__snd_hda_codec_cleanup_stream(), to allow the immediate clean up.
The original snd_hda_codec_cleanup_stream() is kept as is now.
When a device is plugged over HDMI, it passes some information in ELD
including the supported PCM parameters like formats, rates, channels.
This patch adds the check to PCM open callback of HDMI streams so that
only valid parameters the device supports are used.
When no device is plugged, the parameters the codec supports are used;
it's mostly all parameters the hardware can work. This is for apps
that are started before device plugging and do probing (e.g. a sound
daemon), so that at least, probing would work even before the device
plugging.
ASoC: add AD1980 obsolete information
ASoC: register cache should be 1 byte aligned for 1 byte long register
ALSA: hda - Adding support for new IDT 92HD87XX codecs
ASoC: Fix inverted mute controls for WM8580
ALSA: HDA: Use model=auto for LG R510
ALSA: hda - Update model entries in HD-Audio-Models.txt
ALSA: hda: document VIA models
ALSA: hda - patch_nvhdmi.c: Add missing codec IDs, unify names
ALSA: hda - add support for Conexant CX20584
ALSA: hda - New snd-hda-intel model/pin config for hp dv7-4000
ALSA: hda - Fix missing stream for second ADC on Realtek ALC260 HDA codec
ALSA: hda - Add support for Acer ZGA ALC271 (1025:047c)
sound/oss: Adjust confusing if indentation
sound: oss: au1550_ac97.c removed duplicated #include
ASoC: Fix for changed Eureka Kconfig symbol names
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
This codec has been obsoleted by ADI, so add appropriate warnings to the
source tree to dissuade people from using in new designs based on driver
support.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Cliff Cai <cliff.cai@analog.com>
Added the entries for 92HD87B1/3 and 92HD87B2/4 codecs.
These are compatible with existing 83xxx codecs.
Signed-off-by: Charles Chin <Charles.Chin@idt.com>
Two users report model=auto is needed to make the internal mic work properly.
BugLink: https://bugs.launchpad.net/bugs/495134
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
* Add missing codec IDs.
* Modify some existing codec names for discrete GPUs to match newly
added IDs. Note: existing names were a mixture of marketing and
engineering GPU names. Equally, there's no reason that codec IDs
have to be specific to a particular GPU or board, so identify
codecs in a less marketing-oriented fashion.
* Reformat codec ID table so it's easier to read, for me at least.
The Conexant CX20584 with 141f:5068 seems compatible with other
cxt5066 code. Just add the missing id.
Tested-by: Cristopher Camacho Leandro <ccamacho@linuxmail.org>
This provides a new model and pin config for the snd-hda-intel
92HD83XXX codec for hp laptop model dv7-4000, enabling the subwoofer.
Signed-off-by: Steven Eastland <seastland at gmail.com>
I discovered tonight that ALSA no longer sets up a stream for the second ADC
provided by the Realtek ALC260 HDA codec. At some point alc_build_pcms()
started using stream_analog_alt_capture when constructing the second ADC
stream, but patch_alc260() was never updated accordingly. I have no idea
when this regression occurred. The trivial patch to patch_alc260() given
below fixes the problem as far as I can tell. The patch is against 2.6.35.
Signed-off-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits)
ALSA: hda - Add pin-fix for HP dc5750
ALSA: als4000: Fix potentially invalid DMA mode setup
ALSA: als4000: enable burst mode
ALSA: hda - Fix initial capsrc selection in patch_alc269()
ASoC: TWL4030: Capture route runtime DAPM ordering fix
ALSA: hda - Add PC-beep whitelist for an Intel board
ALSA: hda - More relax for pending period handling
ALSA: hda - Define AC_FMT_* constants
ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs
ALSA: hda - Add support for HDMI HBR passthrough
ALSA: hda - Set Stream Type in Stream Format according to AES0
ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed
ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF
ASoC: wm9081: fix resource reclaim in wm9081_register error path
ASoC: wm8978: fix a memory leak if a wm8978_register fail
ASoC: wm8974: fix a memory leak if another WM8974 is registered
ASoC: wm8961: fix resource reclaim in wm8961_register error path
ASoC: wm8955: fix resource reclaim in wm8955_register error path
ASoC: wm8940: fix a memory leak if wm8940_register return error
ASoC: wm8904: fix resource reclaim in wm8904_register error path
Call the gpio reset platform function instead of using the flawed
ac97 functionality of the MPC5200(b)
From MPC5200B User's Manual:
"Some AC97 devices goes to a test mode, if the Sync line is high
during the Res line is low (reset phase). To avoid this behavior the
Sync line must be also forced to zero during the reset phase. To do
that, the pin muxing should switch to GPIO mode and the GPIO control
register should be used to control the output lines."
Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq
pcmcia: do not request windows if you don't need to
pcmcia: insert PCMCIA device resources into resource tree
pcmcia: export resource information to sysfs
pcmcia: use struct resource for PCMCIA devices, part 2
pcmcia: remove memreq_t
pcmcia: move local definitions out of include/pcmcia/cs.h
pcmcia: do not use io_req_t when calling pcmcia_request_io()
pcmcia: do not use io_req_t after call to pcmcia_request_io()
pcmcia: clean up cs.h
pcmcia: use pcmica_{read,write}_config_byte
pcmcia: remove cs_types.h
pcmcia: remove unused flag, simplify headers
pcmcia: remove obsolete CS_EVENT_ definitions
pcmcia: split up central event handler
pcmcia: simplify event callback
pcmcia: remove obsolete ioctl
Conflicts in:
- drivers/staging/comedi/drivers/*
- drivers/staging/wlags49_h2/wl_cs.c
due to dev_info_t and whitespace changes
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
So far, we reset the converter setups like the stream-tag, the
channel-id and format-id in prepare callbacks, and clear them in
cleanup callbacks. This often causes a silence of the digital
receiver for a couple of seconds.
This patch tries to delay the converter setup changes as much as
possible. The converter setups are cached and aren't reset as long
as the same values are used. At suspend/resume, they are cleared
to be recovered properly, too.
Indent the branch of an if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p1)
cocci.print_secs("after",p2)
// </smpl>
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (63 commits)
of/platform: Register of_platform_drivers with an "of:" prefix
of/address: Clean up function declarations
of/spi: call of_register_spi_devices() from spi core code
of: Provide default of_node_to_nid() implementation.
of/device: Make of_device_make_bus_id() usable by other code.
of/irq: Fix endian issues in parsing interrupt specifiers
of: Fix phandle endian issues
of/flattree: fix of_flat_dt_is_compatible() to match the full compatible string
of: remove of_default_bus_ids
of: make of_find_device_by_node generic
microblaze: remove references to of_device and to_of_device
sparc: remove references to of_device and to_of_device
powerpc: remove references to of_device and to_of_device
of/device: Replace of_device with platform_device in includes and core code
of/device: Protect against binding of_platform_drivers to non-OF devices
of: remove asm/of_device.h
of: remove asm/of_platform.h
of/platform: remove all of_bus_type and of_platform_bus_type references
of: Merge of_platform_bus_type with platform_bus_type
drivercore/of: Add OF style matching to platform bus
Fix up trivial conflicts in arch/microblaze/kernel/Makefile due to just
some obj-y removals by the devicetree branch, while the microblaze
updates added a new file.
Signed-off-by: Eric Bénard <eric@eukrea.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
The NID 0x11 on HP dc5750 with ALC260 should be a speaker although BIOS
gives it as a line-out. This patch adds a quirk to fix the pin config
so that the real line-out is used properly.
Reference: bnc#624118
https://bugzilla.novell.com/show_bug.cgi?id=624118
My previous patch assumed that the DMA mode (represented by 3 lowest bits of
ALS4K_GCR99_DMA_EMULATION_CTRL register) is set to the default value 0. If
that's not the case, it might result in invalid mode to be set.
This patch fixes this potential problem.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / Runtime: Add runtime PM statistics (v3)
PM / Runtime: Make runtime_status attribute not debug-only (v. 2)
PM: Do not use dynamically allocated objects in pm_wakeup_event()
PM / Suspend: Fix ordering of calls in suspend error paths
PM / Hibernate: Fix snapshot error code path
PM / Hibernate: Fix hibernation_platform_enter()
pm_qos: Get rid of the allocation in pm_qos_add_request()
pm_qos: Reimplement using plists
plist: Add plist_last
PM: Make it possible to avoid races between wakeup and system sleep
PNPACPI: Add support for remote wakeup
PM: describe kernel policy regarding wakeup defaults (v. 2)
PM / Hibernate: Fix typos in comments in kernel/power/swap.c
Enable burst mode to prevent dropouts during high PCI bus usage.
The card is useless in X without this because of dropouts when anything moves
on the screen (at least with PCI VGA card). Enabling this is also recommended
by the datasheet (page 48).
In patch_alc269(), we initialize the primary capsrc so that the device
works from the beginning. It issues CONNECT_SEL verb no matter which
widget is although some widget (e.g. 0x23) has no connection selection
but a mixer, which requires unmuting instead.
This patch fixes the initialization of capsrc by re-using the code as
a helper function.
Fix the ordering problem in DAPM domain, when the user
changes between digital and analog sources during active
capture (or loopback) scenario.
Before this patch, when the user changed from analog source
to digital there were a short time, when the codec enabled
analog mic bias (2.2 volts) instead of the correct digital
mic bias (1.8 volts) to the digital microphones.
This behaviour caused by the former implementation of
selecting the correct type of bias. This was done at the
POST_REG event of the DAPM_MUX_E("TXx Capture Route")
widget.
By moving the bias type selection as DAPM_SUPPLY and
connecting it to the corresponding digimic widget the
problematic situation can be avoided.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
An Intel board needs a white-list entry to enable PC-beep.
Otherwise the driver misdetects (due to bogus BIOS info) and ignores
the PC-beep on 2.6.35.
Reported-and-tested-by: Leandro Lucarella <luca@llucax.com.ar>
Since the pending periods are often bogus and take long time until
actually processed, it often results in a high CPU usage of the hd-audio
workq. Overall it's better to have low CPU consumption by avoiding a
too tight loop rather than the wake-up timing accuracy.
